Date/Time: Mon, 25 Nov 2024 06:58:55 +0000
Multi Symbol scanner with different Alert Condition Setting
View Count: 246
[2024-03-21 11:02:34] |
User199448 - Posts: 1 |
I studied the documentation and understood how to scan several symbols associated with one chart with some Alert. But the problem is that all symbols are scanned with the same alert conditions settings. For example I have 30 symbols and want to scan each, please help me do the following options: Option 1 - different only alert condition setting: timeframe - 1 min /the same for all symbols/ study - momentum(Last, 5) /the same for all symbols/ alert condition - study > X /X is different for each Symbol/ Option 2 - different study and alert condition setting: timeframe - 1 min /the same for all symbols/ study - momentum(Last, Y) /Y is different for each Symbol/ alert condition - study > X /X is different for each Symbol/ I tried to solve this with Quote Spreadsheet but didn't find how to do it. Of course, I understand that I can open a chart for each symbol and set any alert conditions on each chart. Is it possible to solve this more elegantly by using scanning feature? Thanks in advance. |
[2024-03-21 16:06:29] |
The only way to do what you want is to create your own custom study where you could somehow control the Alert conditions based on the symbol and then alert as you want. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
