Date/Time: Mon, 25 Nov 2024 05:16:15 +0000
[Feature Request] Only Load Specific Dates
View Count: 336
[2024-03-21 00:21:35] |
cesium - Posts: 85 |
Hello John Hello Engineering Team, Thank you for this great program and quick updates. Id like to request the ability to only load a specific list of dates in sierrachart. Similar to how the date exclusion works, but the opposite set. One reasoning being to make back testing specific dates with news events far in the past easier and to cut down on loading times with Volume Profiles. I realize there is already a long list of feature requests that come after critical updates, and also if this wont be possible that is fine as well. Thank you for your time |
[2024-03-27 01:05:24] |
Sierra_Chart Engineering - Posts: 17169 |
The only way this can be done is by excluding dates: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
