Date/Time: Wed, 27 Nov 2024 07:48:57 +0000
charts
View Count: 994
[2014-08-11 19:47:29] |
User22263 - Posts: 1 |
I have just paid for the charts. can I sign up for another trial period so I can use sierra until my paid subscription is active so I can continue to use the charts thank you Date Time Of Last Edit: 2014-08-12 07:24:11
[2014-08-12 07:24:58] |
When you pay for Sierra Chart usage time, the usage time is immediately added to your Sierra Chart account. You only need to restart Sierra Chart after. But a study have any problem using Sierra Chart after restarting it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
