Date/Time: Mon, 25 Nov 2024 06:45:56 +0000
4h chart dax future
View Count: 287
[2024-03-20 21:31:44] |
User731133 - Posts: 27 |
Hi can someone explain to me why the 4h chart skip dosen't generate all the candle but it stops at 17.00pm for then restart to generate at 01.00am?
[2024-03-20 21:36:07] |
EUREX trading is from 07:30 to 22:00 CET. From what you are stating, it sounds like your Time Zone and Session Times are not set properly. Refer to the following: Chart Session Times Time Zone Setting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
