Date/Time: Mon, 25 Nov 2024 06:51:34 +0000
Compatibility error with G7FX chartbook.
View Count: 306
[2024-03-20 21:11:11] |
Pandaa - Posts: 1 |
Hello, I received an error stating that Sierra Charts is not compatible with the customized G7FX chartbook file. The login error prompted me to contact support for assistance in converting the file to make it work. Regards, Antony. |
[2024-03-20 21:11:33] |
Refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
