Date/Time: Mon, 25 Nov 2024 06:36:57 +0000
web based access
View Count: 254
[2024-03-20 15:33:19] |
User504309 - Posts: 11 |
Hi, is there a waz to access mz SC account (adjust open positions ) through web? AMP + Teton |
[2024-03-20 16:18:53] |
Sierra_Chart Engineering - Posts: 17172 |
Yes refer to: Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
