Date/Time: Mon, 25 Nov 2024 06:54:01 +0000
The software works very slowly except for one version
View Count: 234
[2024-03-20 13:10:44] |
tankil - Posts: 2 |
Hello, I have a very powerful computer that I bought recently and when I use your software the flow of data and the response within the software are very slow (not related to the computer as I mentioned earlier it is very powerful) except for one version that worked great and it is 2604 everything else is the same problem, I would appreciate it if you could help me Solve the problem. Thanks
[2024-03-20 16:30:27] |
The only thing we can do is refer you to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
