Date/Time: Mon, 25 Nov 2024 06:35:26 +0000
Weekly Volume profile reference 1 period back plotting at bottom of chart, not correct.
View Count: 230
[2024-03-20 06:37:56]
jmftattoo - Posts: 94
title says the issue, on daily chart i have a daily profile set to reference 1 period back thuse showing prior days volume profile overlaid on current price. This works as intended. when I try to duplicate exact study and change to weekly profile it does not plot correctly(See image link). Instead of plotting over current price it plots a successive row of tiny weekly profiles at the bottom of the chart in a perfect row, NOT overlaid on current price. This is obviously wrong. Works fine on daily, I need the same functionality on the weekly. No other settings were changed other than the volume profiles time frame from day to week after duplicated.
https://www.sierrachart.com/image.php?Image=1710916373501.png
[2024-03-20 06:44:40]
and here is chart rolled over, updated, and moved to a smaller time frame. same issue, prior weekly profile plotting in a row at bottom of chart while prior daily profile plots fine. https://www.sierrachart.com/image.php?Image=171091703069.png
[2024-03-20 06:48:46]
Mods - Disregard, Found issue. Had to use "multiple profiles from start time to end time" since I use RTH pit session hours.
