Date/Time: Wed, 27 Nov 2024 07:43:36 +0000
Maximum scan limitaion
View Count: 986
[2014-08-11 15:26:23] |
User17064 - Posts: 70 |
Hi SC support, Currently I'm using IB as my data feed.When I try to scan the symbol, it told me I have exceed the limitation. So why I still have data limitation? I have used IB as data feed not SC historical data feed. Thanks |
[2014-08-12 00:46:47] |
Are you scanning Historical Daily charts? Because what will happen is the historical daily data requests are mapped to the Sierra Chart Historical Data service. There is a way around this depending upon the symbol. Are you scanning stock symbols? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 00:49:09
[2014-08-12 01:12:15] |
Hi SC support, Yes. Historical daily chart and stock symbols. But I think this symbol could be identify by IB. Like the symbol for Facebook, symbol as FB. This could be identified by both IB and SC historical data service. Is there any setting I'm doing wrong? |
[2014-08-12 09:49:38] |
You need to format the stock symbols like this: FB-STK-SMART To cause the historical Daily download requests to go to Interactive Brokers instead of the Sierra Chart Historical Data Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 17:02:58
[2014-08-12 15:00:02] |
May I know the possible solved date? So I could measure if it worth for the waiting. Current version is 1173 already above than 1170. Thanks! |
[2014-08-12 17:02:31] |
What do you mean by this?There is nothing to wait for. When using version 1173, or really any version now that we think about this some more, the historical Daily data requests will go to Interactive Brokers when using this symbol format: [stock symbol]-STK-SMART Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
