Date/Time: Mon, 28 Sep 2026 14:37:08 +0000
Last step of Telegram alerts
View Count: 1828
[2024-03-20 04:59:59]
bitzbytz786 - Posts: 14
I have followed all the steps of configuring chat groups and attach to Telegram
I followed the detailed instructions at Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts
Thanks for providing detailed steps.
Even after attaching , I do not see any alerts on my telegram. My Sierra chart chat id is bitzbytz786
Should I add my telegram id or megrim group iD at any place in the Sierra chart settings or Chat settings.
Thanks,
Srinath
[2024-03-20 15:57:10]
John - SC Support - Posts: 48028
Did you follow Step 16 that states the following:
16. To do the Telegram integration select Commands >> Telegram Notifications from the Sierra Chart Chat window. And follow through the instructions in the pop-up message.
When you select "Yes" on the popup you should go to your Telegram App and see the Bot has started a conversation. You need to select the "Start" button to accept the conversation and then a new set of instructions will come up. Follow those instructions.
[2024-03-20 17:17:25]
Sierra_Chart Engineering - Posts: 24994
Once the conversation with this Sierra Chart Telegram Chat But is started, then you perform a Paste operation which will paste in the unique one time token into the chat (Begins with /attach) to initiate the link to your Sierra Chart chat interface/window for group chats that are set to Relay to Telegram.
Once you paste that, press the send button on Telegram to send that attach command.
[2024-07-15 13:03:36]
ISB3 - Posts: 15
Idk if you resolved your issue, but anyway mbe it will hep others people. Personnaly I add this problem too, and it was because in chat group settings, at "Telegram Options", the case "Relay Own Messages to Telegram" was set to False
[2025-06-26 12:24:56]
User160486 - Posts: 42
I am trying to attach to telegram but I do not get a unique one time token that begins with /attach. How do I get the token?
[2025-06-26 14:49:54]
We no longer support the use of Telegram for alert notifications. There were issues with this that we were not able to overcome. We are now supporting NTFY. Refer to the following:
Chat and Communications Platform: Integration with Mobile Ntfy Application
