Date/Time: Mon, 25 Nov 2024 06:52:09 +0000
Highlighting Ask Volume Bid Volume Difference Percent in NBCV
View Count: 325
[2024-03-19 20:39:02] |
User878643 - Posts: 9 |
Hey guys, I'm trying to highlight all bars with high positive or negative Ask Volume Bid Volume Difference Percent (SG11) on the Numbers Bars Calculated Values. I'm using the Color background based on alert condition, but none of the formulas work Example: =ID1.SG11 > 0.2 (20%) (Display percent values as decimal or percentage is set to Decimal). or ID1.SG11 < -0.2 (-20%) What am I doing wrong? |
[2024-03-20 15:19:54] |
You can not color the background of the "Numbers Bars Calculated Values" study. What you are trying to do will not work. You can color the background of the Main Price Graph at the bar that meets your condition, if that is what you want to do. Or, you can use the "Color Background Based on Value Percentage" Inputs for the Numbers Bars Calculated Values to get a particular background color at a certain level relative to the Maximum and Minimum. Also, when setting up Alerts for the Numbers Bars Calculated Values, refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
