Date/Time: Mon, 25 Nov 2024 06:52:09 +0000
install latest version and my personal file won't open or boot
View Count: 235
[2024-03-19 20:11:40] |
User254953 - Posts: 6 |
SC basic file boots but when I open my file, it starts booting and then sc closes by itself! best regard Dan |
[2024-03-19 20:12:54] |
Please start Sierra Chart in Safe Mode by following these instructions: Sierra Chart - Software Login Instructions: Using Safe Mode If you can then open your Chartbook in Safe Mode, then this implies that you are having a problem with a custom study, as Safe Mode does not allow for custom studies to run. You would need to figure out which one by removing them one-by-one, if you have more than one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
