Date/Time: Wed, 27 Nov 2024 07:52:57 +0000
Reconnect after Trade Entry
View Count: 913
[2014-08-11 13:18:51] |
User96267 - Posts: 43 |
Dear SC-Community, I have a general question: Can I see an entered open position after my internet connection has failed and I reconnect to Sierra Chart? I'm using AMP/TTnet. If not, how can I close this position when I can't see it anymore? Best regards Maximilian |
[2014-08-11 16:25:50] |
Yes, you will see your current Trade Positions after reconnecting to the server. Is there a problem with this? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-11 17:07:06] |
Thank you very much! Was a general question before entering a trade. |
