Date/Time: Mon, 25 Nov 2024 06:44:18 +0000
[User Discussion] - Quality of Delayed Data with Trial
View Count: 248
[2024-03-19 18:27:09] |
DP - Posts: 4 |
Hello, I am currently running the trial and having trouble with a 5tick range chart not displaying bars correctly using the delayed data for the ESM24-CME. Some bars are bigger than 5ticks. Some bars are 3 or more points in size instead of 5ticks. It usually happens when there are quick and sudden moves in the market. I have good internet connection with fiber to the house and cat 5 to my trading computer. Any suggestions for fixing this? Is the quality of Live & Real-time Danali data better and more accurate than delayed data with the trial? I was hoping to use Danali after I finish with the trial. thanks. |
[2024-03-19 23:52:21] |
Sawtooth - Posts: 4120 |
Since you are using a Range chart, the Intraday Data Storage Time Unit must be set to 1 Tick. Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit. Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) |
[2024-03-20 02:44:49] |
Sierra_Chart Engineering - Posts: 17172 |
For help with this, refer to: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
