Date/Time: Mon, 25 Nov 2024 05:20:07 +0000
Spread sheet help
View Count: 286
[2024-03-19 14:58:07] |
User411320 - Posts: 289 |
Hello, In my L column I've had a formula, now I'm changing that formula but the new formula will change back to the old formula after some time. Am I doing something wrong? |
[2024-03-19 15:55:57] |
Is that Spreadsheet Study setup to have a separate "Calculation Sheet" as defined by the Inputs for "Formula Source Sheet..."? If so, then refer to the following: Spreadsheet Study Inputs: Formulas Getting Erased For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-20 11:51:36] |
I'm honestly not sure, this sheet was a duplicate of another sheet but I'm removed everything except for a moving average
[2024-03-20 16:24:21] |
Is this a Spreadsheet Study, or just a plain Spreadsheet?
[2024-03-23 22:08:27] |
Spreadsheet study
[2024-03-24 17:34:47] |
Sawtooth - Posts: 4120 |
You must only edit the same Sheet# as the Formula Source Sheet Number setting.
[2024-03-31 16:27:34] |
Date Time Of Last Edit: 2024-03-31 16:27:45
