Date/Time: Mon, 25 Nov 2024 06:33:18 +0000
search/filter not showing on trade activity report
View Count: 172
[2024-03-19 14:32:21] |
User153286 - Posts: 49 |
Not certain what has happened, but the start end date for Trade Activity is not displaying Seems to coincide with latest update to 49616 64 bit windows From the trade activity log display setts dialog I see View option. I click on it I see a Show Search Box but I am unable to click the check box. Suggestions? |
[2024-03-19 14:42:59] |
Sierra_Chart Engineering - Posts: 17172 |
Immediately update to the current version of Sierra Chart. Instructions: Software Download: Fast Update There is a stability issue, with the Trade Activity Log related to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
