Date/Time: Mon, 25 Nov 2024 06:54:19 +0000
AMP Futures
View Count: 255
[2024-03-19 11:35:55] |
User608696 - Posts: 5 |
Hello, Is it possible to link an account with AMP Futures to my Sierra Chart account and if so, could someone give me a bit of a pointer as to how to go about this please? Many thanks in advance for any help you can give me with this. Kind Regards MW |
[2024-03-19 15:09:41] |
Sierra Chart works with AMP. As to how to connect, it depends on what order routing service you are setup to use with AMP. If you are setup for the Teton Order Routing Service, then follow the instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions If you are setup with CQG for order routing, then follow the instructions at the following link: CQG Trading Platform Service: Setup Instructions -- In either case, you will need to use the data from our Denali Exchange Data Feed. This is the case because the Teton Order Routing Service is from us, so the data comes from us. And in the case of CQG, we do not have support for data from the CME Group and EUREX with them. To setup data for The CME Group, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* To setup data for EUREX, CFE, or U.S. Equities, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
