Date/Time: Fri, 28 Feb 2025 01:46:56 +0000
How to reattach a detached Chart Window without Title / Menu / Scrollbar
View Count: 543
[2024-03-19 07:31:39]
User291728 - Posts: 4
I have all my charts set up in the way that they do not show any title, menu or scroll bars to save space.. Anyhow this morning I thought I can quickly try something new but this seems to be far more difficult than anticipated.
I detached my profile window which was then a window without Title, Menu and Scrollbar. I tried to reattach it for 10mins now. Its simply impossible I cannot find a button to click, there is no way to put the Menu on the Detached window... Right clicking doesnt lead to anything and I also cannot find any solution here on the Support Board.
So the only way I was able to get my Window back where it was before was to shut down Sierra Chart click the not save option and restart it.
I am sure there is a another way :D Please enlighten me. How can I reattach a detached chart Window that has no Title and no Menu.
Have a great day
[2024-03-19 10:57:05]
User431178 - Posts: 603
1. You can add the attach/detach command to the chart context menu.
Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu)
2. You can attach/detach from the Windows and Chartbooks window.
Window, CB and CW Menus: Windows and Chartbooks (Window)
3. You can add a keyboard shortcut
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
[2024-03-19 11:05:33]
Mercrastius - Posts: 45
Another option is to use a detached (floating) control bar with Show Menu, Show Title Bar, and Show Scroll Bar buttons.
[2024-03-19 15:05:04]
John - SC Support - Posts: 38259
Worst case, you can always restore the menu by right clicking over the Region Data Line at the top of the detached chart below the title bar. A context menu item Show Menu will be listed. Select this to reenable the menu.
Refer to the section highlighted in green at the following link:
Chart Menu: Show Menu (Chart menu)
