Date/Time: Wed, 27 Nov 2024 06:53:41 +0000
Is it possible for Region 2 to contain same symbol but different interval?
View Count: 1074
[2014-08-11 02:59:59] |
User27189 - Posts: 26 |
Actually two questions: 1.) Is it possible for Region 2 to contain a bar chart of same symbol but a different interval? 2.) Is it possible for Region 2 to contain a different "hybrid", "derivative" or "Sum Study" type symbol chart than Region 1 with also a different interval (e.g. Main Graph in Region 1 as a simple ES Range bar and Region 2 as a time interval bar of a "Sum Study" of the Tick-NYSE+Tick-NASDAQ)with its own study(-ies), like a MA or MACD? Thank you. Date Time Of Last Edit: 2014-08-11 03:17:23
[2014-08-11 09:22:50] |
1, 2. Yes. Refer to help topic 28 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html 2. Yes, refer to Based On in the Study Settings here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#SettingsandInputsTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
