Date/Time: Mon, 25 Nov 2024 06:24:55 +0000
Targets missing in bracket
View Count: 211
[2024-03-18 18:57:20] |
Ed Levy - Posts: 17 |
Hello, I took a short three MNQ and my bracket didn't display properly. The stops showed up where they should have but the targets were missing. When I tried to move one of the stops to scale out as price moved in my direction, it didn't work. I was able to flatten out successfully. However, when I try it on sim, it works fine. Can you please advise? Thank you.
[2024-03-18 18:58:48] |
You need to look at the Orders in your "Trade Activity" page of the "Trade Activity Log" and see what might have occurred to the Targets. It sounds like they were rejected for some reason. Also look in your "Trade >> Trade Services Log" to see if there is any information in there. You can post the contents of this log to this thread for us to take a look, if you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-20 05:05:15] |
Sierra_Chart Engineering - Posts: 17170 |
Complete details: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
