Date/Time: Mon, 28 Sep 2026 22:59:28 +0000
Can not connect to CQG now
View Count: 1639
[2014-08-11 02:45:42]
User25540 - Posts: 22
Trade connection is fine and I can send an order. But market data connection was rejected.
CQG Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2014-08-11 10:41:50
Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2014-08-11 10:41:51
The network socket is connected. | 2014-08-11 10:41:51
CQG Trading FIX: Sending the Logon message. | 2014-08-11 10:41:51
CQG Trading: Connected to trading server. | 2014-08-11 10:41:52
CQG Trading: Connecting to market data server. | 2014-08-11 10:41:52
Connecting to websocket server. | 2014-08-11 10:41:52
CQG Trading FIX - FCM name: AMP | 2014-08-11 10:41:52
Resolved address api.cqg.com to IP 208.48.16.34 | 2014-08-11 10:41:52
Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2014-08-11 10:41:59
Socket has been shutdown and closed. | 2014-08-11 10:41:59
CQG Trading: Websocket closed. | 2014-08-11 10:41:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-11 10:41:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-11 10:41:59
CQG Trading FIX: Sending a Logout message. | 2014-08-11 10:41:59
CQG Trading: Disconnected. | 2014-08-11 10:41:59
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-11 10:41:59
[2014-08-11 03:23:10]
We have reported this problem to CQG. We are waiting for them to resolve it.
[2014-08-11 03:29:24]
It is good now.
[2014-08-11 04:13:46]
Yes, we can see that now.
[2014-09-16 01:01:13]
The same problem is going on.
[2014-09-16 01:18:33]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-09-16 01:33:21]
CQG Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2014-09-16 09:32:55
Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2014-09-16 09:32:55
The network socket is connected. | 2014-09-16 09:32:55
CQG Trading FIX: Sending the Logon message. | 2014-09-16 09:32:55
CQG Trading: Connected to trading server. | 2014-09-16 09:32:56
CQG Trading: Connecting to market data server. | 2014-09-16 09:32:56
Connecting to websocket server. | 2014-09-16 09:32:56
Resolved address api.geo.cqg.com to IP 118.201.11.216 | 2014-09-16 09:32:56
CQG Trading FIX - FCM name: AMP | 2014-09-16 09:32:56
Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2014-09-16 09:32:57
Socket has been shutdown and closed. | 2014-09-16 09:32:57
CQG Trading: Websocket closed. | 2014-09-16 09:32:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-16 09:32:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-16 09:32:57
CQG Trading FIX: Sending a Logout message. | 2014-09-16 09:32:57
CQG Trading: Disconnected. | 2014-09-16 09:32:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-16 09:32:57
CQG Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2014-09-16 09:32:57
CQG Trading FIX: Logged out and disconnected. | 2014-09-16 09:32:57
CQG Trading FIX: Disconnected. | 2014-09-16 09:32:57
File >> Disconnect selected. | 2014-09-16 09:33:00
CQG Trading: Disconnected. | 2014-09-16 09:33:00
[2014-09-16 03:19:24]
You are getting a socket error 10061 when connecting to the CQG market data server which means:
No connection could be made because the target machine actively refused it
This can either be an issue with the CQG market data server or a firewall is blocking the connection. If it is a firewall refer to help topic 1.2 here:
http://www.sierrachart.com/index.php?page=doc/helpdetails1.html#h1.2
