Date/Time: Mon, 25 Nov 2024 07:33:51 +0000
Trade Log not working after update
View Count: 325
[2024-03-18 14:21:48] |
User577660 - Posts: 9 |
Hello, I updated to the newest version of SC. Everything seemed fine. However today the Trade Log was not working...could not see the ribbon at the top to select dates,accounts etc. I tried restarting SC, but that did not solve the problem. So I reverted back to version 2576, and it worked. The trade log is working correctly on 2576.
[2024-03-18 14:27:51] |
Sierra_Chart Engineering - Posts: 17172 |
It sounds like you are referring to the Trade Activity Log. To access the settings you need to select DisplaySettings on the menu of the Trade Activity Log window. And then press either Apply All or Ok to apply them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-18 17:20:29
[2024-03-18 15:47:32] |
Thank you, it is working again now, but I do not see an option anywhere that says "DisplaySettings" on the menu.
[2024-03-18 17:19:51] |
You need to update to version 2618. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
