Date/Time: Mon, 25 Nov 2024 07:59:40 +0000
Please roll back the trade activity log
View Count: 321
[2024-03-18 12:51:27]
GlennDB - Posts: 10
The previous trade activity log was so useful and easy to use 2015 the current version 2017 while cleaner is lacking. You could get what you wanted like a weekly view from a month ago.
[2024-03-18 14:16:08]
Sierra_Chart Engineering - Posts: 17172
The changes, were not complete in the version you are running. You need to install the current version which is 2617. Follow the instructions here:
The functionality is 100% the same. No changes at all. Just the interface for the controls is in a separate window which can be open all the time.
Date Time Of Last Edit: 2024-03-18 14:16:54
[2024-03-18 15:52:34]
GlennDB - Posts: 10
Sorry I meant 2615 and 2617. The issue is you can no longer check start and finish dates only start date and current date from what I see. If that is the case it is a giant step backwards. I did intall 2616 it was useless, I rolled back to 2615. This morning I installed 2617 still useless and rolled back to 2615.
Glenn
Date Time Of Last Edit: 2024-03-18 15:54:04
[2024-03-18 16:12:46]
Sawtooth - Posts: 4120
I frequently also use an end date that is not Today.
Please consider including this former option to the new Trade Activity Log Display Options window.
[2024-03-18 16:36:14]
User35525 - Posts: 181
I also downloaded the 2616 "current version" yesterday. If 2617 has the problem too I guess I can roll back. Waiting until after this trading session.
Date Time Of Last Edit: 2024-03-18 16:37:33
[2024-03-18 16:39:07]
We see the problem. For some reason the Ending/To Date-Time settings are not there.
Date Time Of Last Edit: 2024-03-18 16:39:30
[2024-03-18 16:56:46]
We are putting out a new release in about 20 minutes. We apologize for this. There was a programming error made.
This would also cause instability with the Trade Activity Log and cause an abnormal termination of Sierra Chart.
[2024-03-18 17:05:56]
User1967 - Posts: 34
I am having same issues with new filter settings display. How could we filter between two dates let' say from 3-14-2024 to 3-15-2024? It is only giving one option "Filter from Date"... I have upgraded to version 2017
[2024-03-18 17:07:43]
Version 2618 is now released to resolve these issues.
Date Time Of Last Edit: 2024-03-18 17:17:34
