Date/Time: Mon, 25 Nov 2024 07:23:25 +0000
Chart Header
View Count: 214
[2024-03-18 12:23:04] |
DGee - Posts: 82 |
How do I remove the data on top of the chart? See pic circled. Some I will keep but I'm sure most of this can be removed. I cannot find the answer anywhere.
Screenshot 2024-03-18 051648.png / V - Attached On 2024-03-18 12:22:31 UTC - Size: 31.74 KB - 60 views |
[2024-03-18 16:16:13] |
Refer to the following: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
