Date/Time: Wed, 27 Nov 2024 07:30:14 +0000
error with the Open File dialog.
View Count: 932
[2014-08-11 00:53:46]
User021827 - Posts: 174
This is the dialog to name spreadsheet under spreadsheet settings
There was an error with the Open File dialog. Error code: 2 | 2014-08-10 20:52:20
regards
[2014-08-11 00:54:48]
Restart your computer. This is caused by a system issue on your side.
[2014-08-11 01:53:10]
User120827 - Posts: 77
Ok thanks for the info
regards
[2014-08-11 04:39:05]
We have looked up this error code and this is what it means for that open File window:
CDERR_INITIALIZATION
In particular what the initialization error is, we do not know.
We have done 2 tests and cannot duplicate the problem and we are fairly certain it is a system specific issue. When we see problems with the Open File window, it usually is system specific and a restart of the operating system almost always resolves it.
[2014-08-11 12:25:06]
Yes I found the error in windows log. It was an error in my system . Restart did clear it.
Thanks for the info
regards
