Date/Time: Mon, 25 Nov 2024 06:39:15 +0000
Handling Properties Window Drawing New vs Old
View Count: 240
[2024-03-18 04:33:20] |
nicktrader - Posts: 709 |
I have a lot of problems with the handling of the new window, because I don't understand the logic behind it at all. Why are there TC1 - TC4 under "Settings/ Configurations"? How do I proceed if I want to change and save a saved TC? How do I create a new TC? The handling of the old windows was much much easier in comparison. Is there a detailed description for the new window? |
[2024-03-18 15:58:04] |
There actually is no difference in functionality and how all of this works is documented here: Chart Drawing Tools: Using Multiple Drawing Tool Configurations The display of TC1 through TC4 on the main Settings page of the Chart Drawing Properties/Configuration windows is a convenience to be able to quickly select those. To access all the configuration options, you need to go to the Config page on the Chart Drawing Properties/Configuration window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-18 21:47:45] |
Sierra_Chart Engineering - Posts: 17172 |
You can control the number of Quick Configuration buttons as they are called, on each tab of the Chart Drawing Properties/Configuration windows. Refer to: Chart Drawing Tools: Shortcut Menu and Properties Window (Global Settings >> Tool Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
