Date/Time: Mon, 25 Nov 2024 07:31:59 +0000
Custom study and chart graphics settings not working on second system after copying
View Count: 207
[2024-03-17 20:20:15]
User130696 - Posts: 88
I followed the following instructions, but the custom study was not working on the second system.
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Also the custom graphics settings for charts are not porting over to the second system as well.
Please let me know
thanks
Update: I was running ARM version of exe, after running SierraChart.exe and simply copying the entire root home dir, custom study works. I do not know if this because of copying entire tree or just running SierraChart.exe instead of SierraChart_ARM64.exe
Does not seem different by running SierraChart.exe since my Mac has ARM architecture.
Date Time Of Last Edit: 2024-03-17 21:10:35
[2024-03-18 15:33:01]
We can not answer these questions, as we do not have enough information.
If you are working fine now, then this is good.
