Date/Time: Mon, 25 Nov 2024 06:42:57 +0000
can not start my chart
View Count: 303
[2024-03-17 20:16:15]
User904434 - Posts: 54
pls can you check what is wrong with my account can not use sierra?
[2024-03-18 00:47:53]
Sierra_Chart Engineering - Posts: 17172
Your Sierra Chart account is fine.
Are you able to run Sierra Chart? Or what exactly is the problem?
If you are able to run Sierra Chart, then:
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
Date Time Of Last Edit: 2024-03-18 00:48:22
[2024-03-18 17:49:56]
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:30:48.644
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:30:48.644
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:30:48.644
SC DTC Delayed Exchange Data | Failed connections: 9257 | 2024-03-17 10:30:48.644
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:30:48.644
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:30:48.645
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:30:48.645
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:30:48.645
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:30:48.645
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:30:48.793
DTC Client socket (3) | Closed. | 2024-03-17 10:30:48.793
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:30:50.636
DTC Client socket (3) | Creating socket. | 2024-03-17 10:30:50.647
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:30:50.647
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:30:50.648
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:30:50.799
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:30:50.799
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:30:50.799
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:30:51.091
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:30:51.091
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Failed connections: 9258 | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:30:51.390
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:30:51.390
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:30:51.390
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:30:51.390
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:30:51.537
DTC Client socket (3) | Closed. | 2024-03-17 10:30:51.537
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:30:53.385
DTC Client socket (3) | Creating socket. | 2024-03-17 10:30:53.386
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:30:53.386
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:30:53.386
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:30:53.530
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:30:53.530
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:30:53.530
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:30:53.702
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:30:53.702
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:30:53.835
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:30:53.835
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:30:53.835
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:30:53.835
SC DTC Delayed Exchange Data | Failed connections: 9259 | 2024-03-17 10:30:53.835
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:30:53.835
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:30:53.836
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:30:53.836
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:30:53.836
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:30:53.836
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:30:53.987
DTC Client socket (3) | Closed. | 2024-03-17 10:30:53.987
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:30:55.838
DTC Client socket (3) | Creating socket. | 2024-03-17 10:30:55.839
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:30:55.839
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:30:55.839
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:30:55.984
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:30:55.984
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:30:55.984
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:30:56.212
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:30:56.212
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Failed connections: 9260 | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:30:56.385
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:30:56.385
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:30:56.385
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:30:56.385
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:30:56.528
DTC Client socket (3) | Closed. | 2024-03-17 10:30:56.528
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:30:58.373
DTC Client socket (3) | Creating socket. | 2024-03-17 10:30:58.374
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:30:58.374
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:30:58.374
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:30:58.540
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:30:58.540
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:30:58.540
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:30:58.783
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:30:58.783
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:30:59.005
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:30:59.005
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:30:59.005
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:30:59.006
SC DTC Delayed Exchange Data | Failed connections: 9261 | 2024-03-17 10:30:59.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:30:59.006
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:30:59.006
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:30:59.006
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:30:59.006
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:30:59.006
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:30:59.159
DTC Client socket (3) | Closed. | 2024-03-17 10:30:59.159
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:00.997
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:00.998
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:00.998
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:31:00.998
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:01.140
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:01.140
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:01.140
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:01.320
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:01.320
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:01.465
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:01.465
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:01.465
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:01.465
SC DTC Delayed Exchange Data | Failed connections: 9262 | 2024-03-17 10:31:01.465
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:01.465
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:01.466
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:01.466
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:01.466
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:01.466
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:01.608
DTC Client socket (3) | Closed. | 2024-03-17 10:31:01.608
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:03.478
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:03.484
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:03.484
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:31:03.484
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:03.619
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:03.619
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:03.619
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:03.779
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:03.779
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:03.915
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:03.915
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:03.915
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:03.915
SC DTC Delayed Exchange Data | Failed connections: 9263 | 2024-03-17 10:31:03.915
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:03.915
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:03.916
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:03.916
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:03.916
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:03.916
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:04.059
DTC Client socket (3) | Closed. | 2024-03-17 10:31:04.059
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:05.918
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:05.923
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:05.923
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:31:05.923
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:06.060
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:06.060
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:06.060
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:06.225
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:06.225
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:06.372
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:06.372
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:06.372
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:06.372
SC DTC Delayed Exchange Data | Failed connections: 9264 | 2024-03-17 10:31:06.372
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:06.372
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:06.373
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:06.373
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:06.373
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:06.373
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:06.507
DTC Client socket (3) | Closed. | 2024-03-17 10:31:06.507
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:31:08.397
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:08.399
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:08.400
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:31:08.400
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:08.545
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:08.545
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:08.545
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:08.721
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:08.722
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:08.852
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:08.852
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:08.852
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:08.852
SC DTC Delayed Exchange Data | Failed connections: 9265 | 2024-03-17 10:31:08.852
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:08.852
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:08.853
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:08.853
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:08.853
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:08.853
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:08.987
DTC Client socket (3) | Closed. | 2024-03-17 10:31:08.987
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:31:10.848
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:10.849
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:10.849
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:31:10.849
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:11.039
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:11.039
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:11.039
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:11.249
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:11.249
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:11.442
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:11.442
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:11.442
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:11.442
SC DTC Delayed Exchange Data | Failed connections: 9266 | 2024-03-17 10:31:11.442
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:11.442
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:11.443
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:11.443
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:11.443
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:11.444
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:11.627
DTC Client socket (3) | Closed. | 2024-03-17 10:31:11.627
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:31:13.438
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:13.478
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:13.478
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:31:13.478
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:13.609
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:13.609
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:13.609
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:13.749
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:13.749
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:13.889
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:13.889
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:13.889
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:13.889
SC DTC Delayed Exchange Data | Failed connections: 9267 | 2024-03-17 10:31:13.889
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:13.889
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:13.890
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:13.890
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:13.890
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:13.890
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:14.027
DTC Client socket (3) | Closed. | 2024-03-17 10:31:14.027
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:31:15.912
DTC Client socket (3) | Creating socket. | 2024-03-17 10:31:15.914
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:31:15.914
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:31:15.914
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:16.059
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:16.059
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:16.060
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:16.232
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:16.232
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Failed connections: 9268 | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:16.370
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:31:16.370
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:16.370
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:16.370
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:31:16.506
DTC Client socket (3) | Closed. | 2024-03-17 10:31:16.507
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:18.373
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:18.374
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:18.374
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:31:18.374
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:18.519
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:18.519
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:18.519
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:18.779
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:18.779
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:18.925
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:18.925
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:18.925
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:18.925
SC DTC Delayed Exchange Data | Failed connections: 9269 | 2024-03-17 10:31:18.925
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:18.925
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:18.926
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:18.926
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:18.926
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:18.926
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:19.068
DTC Client socket (2) | Closed. | 2024-03-17 10:31:19.068
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:31:20.925
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:20.928
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:20.928
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:31:20.928
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:21.081
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:21.081
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:21.081
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:21.234
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:21.234
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:21.374
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:21.374
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:21.374
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:21.374
SC DTC Delayed Exchange Data | Failed connections: 9270 | 2024-03-17 10:31:21.374
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:21.374
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:21.375
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:21.375
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:21.375
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:21.375
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:21.507
DTC Client socket (2) | Closed. | 2024-03-17 10:31:21.507
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:31:23.390
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:23.392
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:23.392
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:31:23.392
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:23.530
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:23.530
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:23.531
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:23.902
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:23.902
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:24.035
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:24.035
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:24.035
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:24.035
SC DTC Delayed Exchange Data | Failed connections: 9271 | 2024-03-17 10:31:24.035
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:24.035
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:24.036
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:24.036
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:24.036
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:24.037
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:24.176
DTC Client socket (2) | Closed. | 2024-03-17 10:31:24.176
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:31:26.037
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:26.038
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:26.038
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:31:26.038
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:26.178
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:26.178
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:26.179
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:26.389
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:26.389
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:26.564
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:26.564
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:26.564
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:26.564
SC DTC Delayed Exchange Data | Failed connections: 9272 | 2024-03-17 10:31:26.564
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:26.564
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:26.565
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:26.565
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:26.565
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:26.565
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:26.707
DTC Client socket (2) | Closed. | 2024-03-17 10:31:26.707
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:28.580
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:28.625
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:28.625
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:31:28.625
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:28.771
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:28.771
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:28.771
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:28.932
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:28.932
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:29.066
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:29.066
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:29.066
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:29.066
SC DTC Delayed Exchange Data | Failed connections: 9273 | 2024-03-17 10:31:29.066
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:29.067
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:29.067
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:29.067
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:29.068
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:29.068
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:29.206
DTC Client socket (2) | Closed. | 2024-03-17 10:31:29.207
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:31.064
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:31.105
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:31.105
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:31:31.105
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:31.239
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:31.239
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:31.239
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:31.402
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:31.402
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Failed connections: 9274 | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:31.540
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:31.540
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:31.540
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:31.540
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:31.682
DTC Client socket (2) | Closed. | 2024-03-17 10:31:31.683
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:33.534
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:33.534
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:33.534
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:31:33.534
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:33.678
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:33.678
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:33.678
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:33.838
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:33.838
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:33.970
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:33.970
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:33.970
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:33.970
SC DTC Delayed Exchange Data | Failed connections: 9275 | 2024-03-17 10:31:33.970
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:33.970
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:33.971
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:33.971
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:33.971
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:33.971
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:34.116
DTC Client socket (2) | Closed. | 2024-03-17 10:31:34.116
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:31:36.010
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:36.014
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:36.015
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:31:36.015
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:36.158
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:36.158
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:36.158
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:36.330
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:36.330
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Failed connections: 9276 | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:36.485
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:36.485
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:36.485
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:36.487
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:36.632
DTC Client socket (2) | Closed. | 2024-03-17 10:31:36.632
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:31:38.511
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:38.512
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:38.512
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:31:38.512
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:38.697
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:38.698
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:38.698
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:38.891
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:38.891
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Failed connections: 9277 | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:39.081
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:39.081
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:39.082
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:39.082
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:39.082
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:39.275
DTC Client socket (2) | Closed. | 2024-03-17 10:31:39.276
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:31:41.082
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:41.083
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:41.083
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:31:41.083
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:41.232
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:41.232
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:41.232
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:41.412
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:41.412
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Failed connections: 9278 | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:41.549
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:41.549
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:41.549
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:41.549
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:41.719
DTC Client socket (2) | Closed. | 2024-03-17 10:31:41.719
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:31:43.583
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:43.584
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:43.584
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:31:43.584
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:43.740
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:43.740
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:43.740
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:43.881
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:43.881
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Failed connections: 9279 | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:44.013
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:44.013
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:44.013
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:44.013
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:44.165
DTC Client socket (2) | Closed. | 2024-03-17 10:31:44.165
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:46.032
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:46.034
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:46.034
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:31:46.034
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:46.178
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:46.178
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:46.178
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:46.481
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:46.481
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:46.794
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:46.794
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:46.794
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:46.794
SC DTC Delayed Exchange Data | Failed connections: 9280 | 2024-03-17 10:31:46.794
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:46.794
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:46.795
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:46.795
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:46.795
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:46.795
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:46.936
DTC Client socket (2) | Closed. | 2024-03-17 10:31:46.936
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:31:48.797
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:48.798
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:48.798
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:31:48.798
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:48.939
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:48.939
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:48.940
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:49.111
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:49.111
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:49.257
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:49.257
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:49.257
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:49.257
SC DTC Delayed Exchange Data | Failed connections: 9281 | 2024-03-17 10:31:49.257
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:49.258
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:49.258
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:49.258
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:49.258
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:49.258
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:49.398
DTC Client socket (2) | Closed. | 2024-03-17 10:31:49.398
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:31:51.258
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:51.258
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:51.258
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:31:51.258
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:51.403
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:51.404
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:51.404
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:51.733
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:51.733
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:51.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:51.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:51.879
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:51.879
SC DTC Delayed Exchange Data | Failed connections: 9282 | 2024-03-17 10:31:51.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:51.879
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:51.885
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:51.885
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:51.885
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:51.885
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:52.070
DTC Client socket (2) | Closed. | 2024-03-17 10:31:52.070
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:31:53.884
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:53.885
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:53.885
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:31:53.885
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:54.031
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:54.031
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:54.031
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:54.237
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:54.237
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Failed connections: 9283 | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:54.397
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:54.397
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:54.397
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:54.397
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:54.575
DTC Client socket (2) | Closed. | 2024-03-17 10:31:54.575
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:56.403
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:56.403
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:56.403
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:31:56.403
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:56.537
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:56.537
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:56.537
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:56.699
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:56.699
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:56.828
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:56.828
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:56.828
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:31:56.828
SC DTC Delayed Exchange Data | Failed connections: 9284 | 2024-03-17 10:31:56.828
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:56.828
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:56.828
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:56.829
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:56.829
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:56.829
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:56.966
DTC Client socket (2) | Closed. | 2024-03-17 10:31:56.966
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:31:58.836
DTC Client socket (2) | Creating socket. | 2024-03-17 10:31:58.836
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:31:58.837
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:31:58.837
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:31:58.977
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:31:58.977
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:31:58.978
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:31:59.137
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:31:59.137
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Failed connections: 9285 | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:31:59.275
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:31:59.275
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:31:59.275
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:31:59.275
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:31:59.418
DTC Client socket (2) | Closed. | 2024-03-17 10:31:59.418
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:01.499
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:01.508
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:01.508
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:32:01.508
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:01.648
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:01.648
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:01.648
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:01.811
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:01.811
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:01.949
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:01.949
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:01.949
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:01.949
SC DTC Delayed Exchange Data | Failed connections: 9286 | 2024-03-17 10:32:01.949
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:01.949
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:01.950
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:01.950
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:01.950
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:01.950
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:02.086
DTC Client socket (2) | Closed. | 2024-03-17 10:32:02.086
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:32:03.965
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:03.967
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:03.967
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:32:03.967
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:04.108
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:04.108
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:04.108
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:04.277
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:04.277
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:04.421
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:04.421
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:04.421
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:04.421
SC DTC Delayed Exchange Data | Failed connections: 9287 | 2024-03-17 10:32:04.421
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:04.421
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:04.422
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:04.422
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:04.422
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:04.422
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:04.571
DTC Client socket (2) | Closed. | 2024-03-17 10:32:04.571
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:32:06.424
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:06.434
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:06.435
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:32:06.435
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:06.616
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:06.616
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:06.616
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:06.806
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:06.807
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Failed connections: 9288 | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:06.989
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:06.989
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:06.989
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:06.989
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:07.178
DTC Client socket (2) | Closed. | 2024-03-17 10:32:07.178
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:32:09.057
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:09.064
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:09.064
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:32:09.064
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:09.202
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:09.202
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:09.203
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:09.356
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:09.356
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:09.519
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:09.519
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:09.519
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:09.519
SC DTC Delayed Exchange Data | Failed connections: 9289 | 2024-03-17 10:32:09.519
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:09.519
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:09.520
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:09.520
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:09.520
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:09.520
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:09.667
DTC Client socket (2) | Closed. | 2024-03-17 10:32:09.667
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:32:11.533
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:11.535
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:11.535
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:32:11.535
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:11.682
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:11.682
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:11.682
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:11.851
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:11.851
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Failed connections: 9290 | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:11.993
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:11.993
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:11.993
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:11.993
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:12.134
DTC Client socket (2) | Closed. | 2024-03-17 10:32:12.134
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:13.990
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:14.033
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:14.033
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:32:14.033
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:14.176
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:14.176
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:14.176
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:14.777
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:14.777
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Failed connections: 9291 | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:15.168
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:15.168
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:15.168
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:15.168
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:15.304
DTC Client socket (2) | Closed. | 2024-03-17 10:32:15.304
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:32:17.175
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:17.176
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:17.176
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:32:17.176
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:17.316
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:17.316
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:17.316
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:17.476
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:17.476
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:17.617
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:17.617
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:17.617
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:17.617
SC DTC Delayed Exchange Data | Failed connections: 9292 | 2024-03-17 10:32:17.617
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:17.617
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:17.618
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:17.618
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:17.618
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:17.618
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:17.754
DTC Client socket (2) | Closed. | 2024-03-17 10:32:17.754
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:32:19.625
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:19.625
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:19.625
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:32:19.625
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:19.766
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:19.766
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:19.766
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:20.142
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:20.142
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Failed connections: 9293 | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:20.405
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:20.405
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:20.405
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:20.405
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:20.544
DTC Client socket (2) | Closed. | 2024-03-17 10:32:20.544
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:32:22.404
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:22.405
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:22.405
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:32:22.405
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:22.550
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:22.550
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:22.550
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:22.747
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:22.747
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:22.885
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:22.885
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:22.885
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:22.885
SC DTC Delayed Exchange Data | Failed connections: 9294 | 2024-03-17 10:32:22.885
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:22.885
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:22.885
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:22.886
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:22.886
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:22.887
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:23.023
DTC Client socket (2) | Closed. | 2024-03-17 10:32:23.023
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:24.905
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:24.905
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:24.905
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:32:24.905
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:25.047
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:25.047
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:25.047
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:25.218
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:25.218
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Failed connections: 9295 | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:25.365
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:25.365
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:25.365
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:25.365
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:25.504
DTC Client socket (2) | Closed. | 2024-03-17 10:32:25.504
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:27.372
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:27.374
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:27.374
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:32:27.374
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:27.522
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:27.522
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:27.522
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:27.688
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:27.688
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:27.829
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:27.829
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:27.829
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:27.829
SC DTC Delayed Exchange Data | Failed connections: 9296 | 2024-03-17 10:32:27.829
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:27.829
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:27.830
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:27.830
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:27.830
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:27.830
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:27.985
DTC Client socket (2) | Closed. | 2024-03-17 10:32:27.985
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:29.824
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:29.826
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:29.827
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:32:29.827
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:29.967
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:29.967
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:29.967
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:30.112
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:30.112
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:30.242
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:30.242
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:30.242
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:30.242
SC DTC Delayed Exchange Data | Failed connections: 9297 | 2024-03-17 10:32:30.242
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:30.243
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:30.243
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:30.244
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:30.244
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:30.244
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:30.383
DTC Client socket (2) | Closed. | 2024-03-17 10:32:30.383
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:32:32.252
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:32.254
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:32.254
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:32:32.254
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:32.397
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:32.397
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:32.397
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:32.566
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:32.566
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:32.695
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:32.695
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:32.695
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:32.695
SC DTC Delayed Exchange Data | Failed connections: 9298 | 2024-03-17 10:32:32.695
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:32.695
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:32.696
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:32.697
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:32.697
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:32.697
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:32.833
DTC Client socket (2) | Closed. | 2024-03-17 10:32:32.833
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:32:34.706
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:34.707
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:34.707
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:32:34.707
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:34.895
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:34.896
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:34.896
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:35.093
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:35.093
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:35.279
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:35.279
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:35.279
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:35.279
SC DTC Delayed Exchange Data | Failed connections: 9299 | 2024-03-17 10:32:35.279
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:35.279
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:35.280
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:35.280
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:35.280
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:35.280
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:35.473
DTC Client socket (2) | Closed. | 2024-03-17 10:32:35.473
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:32:37.300
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:37.301
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:37.302
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:32:37.302
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:37.449
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:37.449
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:37.450
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:37.630
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:37.630
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:37.768
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:37.769
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:37.769
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:37.769
SC DTC Delayed Exchange Data | Failed connections: 9300 | 2024-03-17 10:32:37.769
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:37.769
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:37.769
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:37.770
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:37.770
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:37.770
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:37.914
DTC Client socket (2) | Closed. | 2024-03-17 10:32:37.914
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:32:39.774
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:39.775
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:39.775
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:32:39.775
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:39.915
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:39.915
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:39.916
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:40.077
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:40.077
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:40.241
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:40.241
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:40.241
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:40.241
SC DTC Delayed Exchange Data | Failed connections: 9301 | 2024-03-17 10:32:40.241
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:40.241
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:40.242
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:40.242
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:40.242
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:40.253
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:40.393
DTC Client socket (2) | Closed. | 2024-03-17 10:32:40.393
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:42.262
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:42.263
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:42.263
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:32:42.263
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:42.397
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:42.397
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:42.397
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:42.597
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:42.597
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Failed connections: 9302 | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:42.765
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:42.765
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:42.765
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:42.765
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:42.905
DTC Client socket (2) | Closed. | 2024-03-17 10:32:42.905
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:32:44.797
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:44.798
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:44.798
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:32:44.798
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:44.945
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:44.945
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:44.945
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:45.142
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:45.143
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Failed connections: 9303 | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:45.283
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:45.283
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:45.283
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:45.283
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:45.417
DTC Client socket (2) | Closed. | 2024-03-17 10:32:45.417
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:32:47.288
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:47.300
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:47.303
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:32:47.303
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:47.437
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:47.437
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:47.437
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:47.649
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:47.649
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:47.780
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:47.780
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:47.780
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:47.780
SC DTC Delayed Exchange Data | Failed connections: 9304 | 2024-03-17 10:32:47.780
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:47.780
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:47.780
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:47.781
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:47.781
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:47.781
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:47.943
DTC Client socket (2) | Closed. | 2024-03-17 10:32:47.943
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:32:49.778
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:49.778
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:49.779
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:32:49.779
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:49.925
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:49.925
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:49.925
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:50.158
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:50.158
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:50.328
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:50.328
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:50.328
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:50.328
SC DTC Delayed Exchange Data | Failed connections: 9305 | 2024-03-17 10:32:50.328
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:50.328
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:50.329
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:50.329
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:50.329
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:50.329
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:50.472
DTC Client socket (2) | Closed. | 2024-03-17 10:32:50.472
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:52.345
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:52.346
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:52.346
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:32:52.346
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:52.488
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:52.488
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:52.488
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:52.646
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:52.646
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:52.774
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:52.774
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:52.774
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:52.774
SC DTC Delayed Exchange Data | Failed connections: 9306 | 2024-03-17 10:32:52.774
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:52.774
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:52.775
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:52.775
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:52.775
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:52.775
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:52.912
DTC Client socket (2) | Closed. | 2024-03-17 10:32:52.912
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:54.776
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:54.777
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:54.777
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:32:54.777
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:54.915
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:54.915
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:54.915
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:55.075
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:55.075
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:55.214
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:55.214
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:55.214
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:32:55.214
SC DTC Delayed Exchange Data | Failed connections: 9307 | 2024-03-17 10:32:55.214
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:55.214
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:55.215
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:55.215
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:55.215
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:55.215
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:55.352
DTC Client socket (2) | Closed. | 2024-03-17 10:32:55.352
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:32:57.231
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:57.232
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:57.232
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:32:57.232
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:57.377
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:57.377
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:57.377
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:57.525
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:57.525
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Failed connections: 9308 | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:32:57.656
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:32:57.656
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:32:57.656
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:32:57.657
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:32:57.657
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:32:57.793
DTC Client socket (2) | Closed. | 2024-03-17 10:32:57.793
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:32:59.656
DTC Client socket (2) | Creating socket. | 2024-03-17 10:32:59.657
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:32:59.657
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:32:59.657
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:32:59.805
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:32:59.805
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:32:59.805
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:32:59.986
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:32:59.986
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Failed connections: 9309 | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:00.124
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:00.124
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:00.124
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:00.124
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:00.262
DTC Client socket (2) | Closed. | 2024-03-17 10:33:00.262
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:33:02.127
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:02.128
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:02.128
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:33:02.128
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:02.324
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:02.324
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:02.324
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:02.537
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:02.537
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:02.722
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:02.722
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:02.722
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:02.722
SC DTC Delayed Exchange Data | Failed connections: 9310 | 2024-03-17 10:33:02.722
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:02.722
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:02.723
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:02.723
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:02.723
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:02.723
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:02.913
DTC Client socket (2) | Closed. | 2024-03-17 10:33:02.913
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:33:04.741
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:04.742
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:04.742
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:33:04.742
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:04.887
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:04.887
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:04.887
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:05.035
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:05.035
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Failed connections: 9311 | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:05.173
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:05.173
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:05.173
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:05.173
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:05.302
DTC Client socket (2) | Closed. | 2024-03-17 10:33:05.302
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:33:07.185
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:07.186
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:07.186
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:33:07.186
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:07.326
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:07.326
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:07.326
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:07.465
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:07.465
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:07.601
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:07.601
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:07.601
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:07.601
SC DTC Delayed Exchange Data | Failed connections: 9312 | 2024-03-17 10:33:07.601
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:07.601
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:07.602
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:07.602
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:07.602
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:07.602
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:07.742
DTC Client socket (2) | Closed. | 2024-03-17 10:33:07.742
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:09.602
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:09.606
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:09.606
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:33:09.606
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:09.745
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:09.745
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:09.745
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:09.970
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:09.970
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Failed connections: 9313 | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:10.148
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:10.148
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:10.148
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:10.149
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:10.149
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:10.302
DTC Client socket (2) | Closed. | 2024-03-17 10:33:10.302
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:33:12.135
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:12.137
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:12.138
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:33:12.138
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:12.273
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:12.273
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:12.273
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:12.415
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:12.415
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Failed connections: 9314 | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:12.557
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:12.557
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:12.557
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:12.557
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:12.692
DTC Client socket (2) | Closed. | 2024-03-17 10:33:12.692
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:33:14.567
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:14.568
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:14.568
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:33:14.568
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:14.716
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:14.716
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:14.716
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:15.281
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:15.281
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:15.556
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:15.556
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:15.557
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:15.557
SC DTC Delayed Exchange Data | Failed connections: 9315 | 2024-03-17 10:33:15.557
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:15.557
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:15.558
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:15.558
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:15.558
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:15.558
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:15.707
DTC Client socket (2) | Closed. | 2024-03-17 10:33:15.708
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:33:17.570
DTC Client socket (2) | Creating socket. | 2024-03-17 10:33:17.570
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:33:17.570
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:33:17.570
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:17.713
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:17.713
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:17.713
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:17.918
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:17.918
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:18.054
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:18.054
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:18.054
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:18.054
SC DTC Delayed Exchange Data | Failed connections: 9316 | 2024-03-17 10:33:18.054
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:18.054
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:33:18.054
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:18.055
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:18.055
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:18.055
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:33:18.231
DTC Client socket (2) | Closed. | 2024-03-17 10:33:18.231
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:20.043
DTC Client socket (1) | Creating socket. | 2024-03-17 10:33:20.044
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:33:20.044
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:33:20.044
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:20.183
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:20.183
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:20.183
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:20.344
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:20.344
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:20.482
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:20.482
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:20.482
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:20.482
SC DTC Delayed Exchange Data | Failed connections: 9317 | 2024-03-17 10:33:20.482
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:20.482
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:33:20.483
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:20.483
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:20.483
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:20.483
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:33:20.622
DTC Client socket (1) | Closed. | 2024-03-17 10:33:20.622
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:22.498
DTC Client socket (1) | Creating socket. | 2024-03-17 10:33:22.498
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:33:22.498
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:33:22.498
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:22.633
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:22.633
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:22.633
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:22.774
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:22.774
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:22.906
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:22.906
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:22.906
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:22.906
SC DTC Delayed Exchange Data | Failed connections: 9318 | 2024-03-17 10:33:22.906
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:22.906
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:33:22.907
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:22.907
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:22.907
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:22.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:33:23.041
DTC Client socket (1) | Closed. | 2024-03-17 10:33:23.041
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:24.914
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:24.914
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:24.914
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:33:24.914
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:25.063
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:25.063
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:25.063
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:25.224
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:25.224
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:25.359
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Failed connections: 9319 | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:25.360
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:25.360
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:25.360
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:25.360
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:25.505
DTC Client socket (3) | Closed. | 2024-03-17 10:33:25.505
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:33:27.356
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:27.357
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:27.357
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:33:27.357
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:27.497
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:27.497
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:27.497
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:27.672
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:27.672
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:27.811
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:27.811
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:27.811
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:27.811
SC DTC Delayed Exchange Data | Failed connections: 9320 | 2024-03-17 10:33:27.811
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:27.811
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:27.812
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:27.812
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:27.812
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:27.812
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:27.951
DTC Client socket (3) | Closed. | 2024-03-17 10:33:27.951
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:33:29.830
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:29.831
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:29.831
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:33:29.831
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:30.027
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:30.027
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:30.027
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:30.243
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:30.243
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Failed connections: 9321 | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:30.435
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:30.435
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:30.435
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:30.435
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:30.624
DTC Client socket (3) | Closed. | 2024-03-17 10:33:30.624
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:33:32.459
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:32.460
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:32.460
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:33:32.460
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:32.603
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:32.603
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:32.603
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:32.743
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:32.743
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Failed connections: 9322 | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:32.879
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:32.879
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:32.879
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:32.879
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:33.020
DTC Client socket (3) | Closed. | 2024-03-17 10:33:33.020
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:33:34.873
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:34.873
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:34.873
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:33:34.873
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:35.012
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:35.012
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:35.013
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:35.174
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:35.174
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:35.314
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:35.314
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:35.314
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:35.314
SC DTC Delayed Exchange Data | Failed connections: 9323 | 2024-03-17 10:33:35.314
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:35.314
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:35.315
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:35.315
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:35.315
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:35.315
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:35.450
DTC Client socket (3) | Closed. | 2024-03-17 10:33:35.450
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:37.319
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:37.320
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:37.320
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:33:37.320
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:37.462
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:37.462
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:37.462
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:37.804
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:37.804
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Failed connections: 9324 | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:38.006
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:38.006
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:38.006
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:38.006
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:38.150
DTC Client socket (3) | Closed. | 2024-03-17 10:33:38.150
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:33:40.005
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:40.006
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:40.006
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:33:40.006
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:40.143
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:40.143
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:40.143
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:40.303
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:40.303
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:40.438
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:40.438
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:40.438
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:40.438
SC DTC Delayed Exchange Data | Failed connections: 9325 | 2024-03-17 10:33:40.438
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:40.438
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:40.439
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:40.439
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:40.439
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:40.439
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:40.570
DTC Client socket (3) | Closed. | 2024-03-17 10:33:40.570
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:33:42.448
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:42.449
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:42.449
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:33:42.449
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:42.596
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:42.596
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:42.596
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:42.983
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:42.983
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Failed connections: 9326 | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:43.372
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:43.372
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:43.372
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:43.372
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:43.541
DTC Client socket (3) | Closed. | 2024-03-17 10:33:43.541
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:33:45.375
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:45.375
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:45.375
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:33:45.375
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:45.521
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:45.521
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:45.522
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:45.903
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:45.903
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:46.045
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:46.045
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:46.045
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:46.045
SC DTC Delayed Exchange Data | Failed connections: 9327 | 2024-03-17 10:33:46.045
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:46.045
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:46.045
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:46.046
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:46.046
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:46.046
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:46.190
DTC Client socket (3) | Closed. | 2024-03-17 10:33:46.190
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:48.057
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:48.057
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:48.057
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:33:48.057
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:48.192
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:48.192
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:48.192
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:48.355
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:48.355
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:48.489
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:48.489
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:48.489
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:48.489
SC DTC Delayed Exchange Data | Failed connections: 9328 | 2024-03-17 10:33:48.489
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:48.489
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:48.490
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:48.490
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:48.490
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:48.490
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:48.630
DTC Client socket (3) | Closed. | 2024-03-17 10:33:48.630
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:50.493
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:50.494
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:50.495
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:33:50.495
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:50.631
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:50.631
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:50.631
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:50.802
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:50.802
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:50.941
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:50.941
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:50.941
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:33:50.941
SC DTC Delayed Exchange Data | Failed connections: 9329 | 2024-03-17 10:33:50.941
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:50.941
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:50.942
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:50.942
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:50.942
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:50.942
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:51.080
DTC Client socket (3) | Closed. | 2024-03-17 10:33:51.080
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:33:52.944
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:52.944
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:52.944
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:33:52.944
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:53.081
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:53.081
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:53.081
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:53.222
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:53.222
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Failed connections: 9330 | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:53.349
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:53.349
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:53.349
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:53.349
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:53.489
DTC Client socket (3) | Closed. | 2024-03-17 10:33:53.489
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:33:55.347
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:55.347
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:55.348
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:33:55.348
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:55.492
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:55.492
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:55.492
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:55.655
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:55.655
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Failed connections: 9331 | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:55.796
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:55.796
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:55.796
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:55.796
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:55.940
DTC Client socket (3) | Closed. | 2024-03-17 10:33:55.940
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:33:57.799
DTC Client socket (3) | Creating socket. | 2024-03-17 10:33:57.800
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:33:57.800
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:33:57.800
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:33:57.991
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:33:57.991
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:33:57.991
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:33:58.203
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:33:58.203
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:33:58.393
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:33:58.393
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:33:58.393
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:33:58.393
SC DTC Delayed Exchange Data | Failed connections: 9332 | 2024-03-17 10:33:58.393
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:33:58.393
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:33:58.394
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:33:58.394
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:33:58.394
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:33:58.394
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:33:58.579
DTC Client socket (3) | Closed. | 2024-03-17 10:33:58.579
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:34:00.393
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:00.394
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:00.394
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:34:00.394
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:00.531
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:00.531
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:00.531
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:00.694
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:00.694
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:00.820
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:00.820
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:00.820
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:00.820
SC DTC Delayed Exchange Data | Failed connections: 9333 | 2024-03-17 10:34:00.820
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:00.820
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:00.821
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:00.821
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:00.821
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:00.821
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:00.959
DTC Client socket (3) | Closed. | 2024-03-17 10:34:00.959
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:34:02.823
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:02.824
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:02.824
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:34:02.824
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:02.962
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:02.962
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:02.962
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:03.121
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:03.121
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Failed connections: 9334 | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:03.264
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:03.264
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:03.264
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:03.264
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:03.409
DTC Client socket (3) | Closed. | 2024-03-17 10:34:03.410
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:05.264
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:05.265
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:05.265
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:34:05.265
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:05.401
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:05.401
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:05.401
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:05.781
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:05.781
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:05.915
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:05.915
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:05.915
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:05.915
SC DTC Delayed Exchange Data | Failed connections: 9335 | 2024-03-17 10:34:05.915
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:05.915
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:05.915
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:05.916
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:05.916
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:05.916
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:06.059
DTC Client socket (3) | Closed. | 2024-03-17 10:34:06.059
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:34:07.915
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:07.916
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:07.916
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:34:07.916
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:08.050
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:08.051
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:08.051
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:08.236
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:08.236
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:08.378
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:08.378
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:08.378
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:08.378
SC DTC Delayed Exchange Data | Failed connections: 9336 | 2024-03-17 10:34:08.378
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:08.378
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:08.379
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:08.379
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:08.379
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:08.379
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:08.509
DTC Client socket (3) | Closed. | 2024-03-17 10:34:08.510
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:34:10.373
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:10.374
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:10.374
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:34:10.374
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:10.511
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:10.511
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:10.511
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:10.741
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:10.741
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:10.945
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:10.945
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:10.945
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:10.945
SC DTC Delayed Exchange Data | Failed connections: 9337 | 2024-03-17 10:34:10.945
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:10.945
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:10.946
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:10.946
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:10.946
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:10.946
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:11.109
DTC Client socket (3) | Closed. | 2024-03-17 10:34:11.109
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:34:12.938
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:12.939
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:12.939
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:34:12.939
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:13.080
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:13.080
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:13.081
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:13.360
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:13.360
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Failed connections: 9338 | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:13.530
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:13.530
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:13.530
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:13.530
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:13.681
DTC Client socket (3) | Closed. | 2024-03-17 10:34:13.681
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:15.527
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:15.528
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:15.528
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:34:15.528
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:15.672
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:15.672
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:15.672
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:15.820
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:15.820
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Failed connections: 9339 | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:15.944
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:15.944
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:15.944
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:15.944
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:16.078
DTC Client socket (3) | Closed. | 2024-03-17 10:34:16.078
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:17.960
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:17.961
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:17.961
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:34:17.961
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:18.100
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:18.100
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:18.100
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:18.242
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:18.242
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:18.375
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:18.375
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:18.375
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:18.375
SC DTC Delayed Exchange Data | Failed connections: 9340 | 2024-03-17 10:34:18.375
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:18.375
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:18.375
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:18.376
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:18.376
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:18.376
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:18.520
DTC Client socket (3) | Closed. | 2024-03-17 10:34:18.520
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:20.375
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:20.375
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:20.375
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:34:20.376
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:20.514
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:20.514
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:20.514
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:20.651
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:20.651
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:20.793
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:20.793
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:20.793
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:20.793
SC DTC Delayed Exchange Data | Failed connections: 9341 | 2024-03-17 10:34:20.793
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:20.793
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:20.793
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:20.794
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:20.794
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:20.794
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:20.931
DTC Client socket (3) | Closed. | 2024-03-17 10:34:20.931
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:34:22.803
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:22.805
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:22.805
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:34:22.805
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:22.951
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:22.951
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:22.951
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:23.142
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:23.142
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:23.285
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:23.285
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:23.285
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:23.285
SC DTC Delayed Exchange Data | Failed connections: 9342 | 2024-03-17 10:34:23.285
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:23.285
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:23.286
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:23.286
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:23.286
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:23.286
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:23.418
DTC Client socket (3) | Closed. | 2024-03-17 10:34:23.418
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:34:25.295
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:25.296
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:25.296
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:34:25.296
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:25.484
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:25.484
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:25.484
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:25.694
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:25.694
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:25.878
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:25.878
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:25.878
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:25.878
SC DTC Delayed Exchange Data | Failed connections: 9343 | 2024-03-17 10:34:25.878
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:25.878
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:25.880
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:25.880
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:25.880
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:25.880
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:26.068
DTC Client socket (3) | Closed. | 2024-03-17 10:34:26.068
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:34:27.881
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:27.883
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:27.883
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:34:27.883
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:28.025
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:28.025
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:28.025
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:28.161
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:28.161
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:28.299
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:28.299
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:28.299
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:28.299
SC DTC Delayed Exchange Data | Failed connections: 9344 | 2024-03-17 10:34:28.299
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:28.299
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:28.300
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:28.300
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:28.300
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:28.300
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:28.443
DTC Client socket (3) | Closed. | 2024-03-17 10:34:28.444
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:34:30.291
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:30.293
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:30.293
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:34:30.294
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:30.448
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:30.448
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:30.449
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:30.610
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:30.610
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Failed connections: 9345 | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:30.749
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:30.749
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:30.749
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:30.749
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:30.888
DTC Client socket (3) | Closed. | 2024-03-17 10:34:30.888
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:32.756
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:32.757
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:32.757
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:34:32.757
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:32.903
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:32.903
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:32.903
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:33.160
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:33.160
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:33.294
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:33.294
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:33.294
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:33.294
SC DTC Delayed Exchange Data | Failed connections: 9346 | 2024-03-17 10:34:33.294
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:33.294
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:33.295
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:33.295
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:33.295
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:33.295
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:33.428
DTC Client socket (3) | Closed. | 2024-03-17 10:34:33.429
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:34:35.308
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:35.309
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:35.309
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:34:35.309
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:35.459
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:35.459
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:35.459
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:35.611
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:35.611
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:35.750
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:35.750
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:35.750
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:35.750
SC DTC Delayed Exchange Data | Failed connections: 9347 | 2024-03-17 10:34:35.750
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:35.750
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:35.751
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:35.751
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:35.751
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:35.751
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:35.888
DTC Client socket (3) | Closed. | 2024-03-17 10:34:35.888
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:34:37.745
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:37.749
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:37.749
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:34:37.749
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:37.892
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:37.892
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:37.892
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:38.150
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:38.150
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:38.288
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:38.288
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:38.288
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:38.288
SC DTC Delayed Exchange Data | Failed connections: 9348 | 2024-03-17 10:34:38.288
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:38.288
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:38.289
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:38.289
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:38.289
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:38.289
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:38.448
DTC Client socket (3) | Closed. | 2024-03-17 10:34:38.448
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:34:40.299
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:40.300
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:40.300
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:34:40.300
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:40.442
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:40.442
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:40.442
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:40.708
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:40.708
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:40.842
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:40.842
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:40.842
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:40.842
SC DTC Delayed Exchange Data | Failed connections: 9349 | 2024-03-17 10:34:40.842
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:40.842
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:40.843
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:40.843
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:40.843
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:40.843
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:41.058
DTC Client socket (3) | Closed. | 2024-03-17 10:34:41.058
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:42.851
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:42.853
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:42.853
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:34:42.853
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:42.990
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:42.990
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:42.990
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:43.141
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:43.141
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:43.267
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:43.267
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:43.267
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:43.267
SC DTC Delayed Exchange Data | Failed connections: 9350 | 2024-03-17 10:34:43.267
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:43.267
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:43.268
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:43.268
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:43.268
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:43.269
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:43.412
DTC Client socket (3) | Closed. | 2024-03-17 10:34:43.412
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:45.262
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:45.263
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:45.263
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:34:45.263
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:45.406
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:45.406
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:45.407
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:45.543
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:45.543
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:45.681
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:45.681
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:45.681
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:45.681
SC DTC Delayed Exchange Data | Failed connections: 9351 | 2024-03-17 10:34:45.681
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:45.681
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:45.682
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:45.682
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:45.682
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:45.682
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:45.818
DTC Client socket (3) | Closed. | 2024-03-17 10:34:45.818
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:34:47.685
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:47.685
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:47.686
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:34:47.686
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:47.823
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:47.823
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:47.823
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:48.097
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:48.097
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:48.278
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:48.278
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:48.278
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:48.278
SC DTC Delayed Exchange Data | Failed connections: 9352 | 2024-03-17 10:34:48.278
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:48.278
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:48.288
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:48.288
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:48.288
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:48.288
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:48.458
DTC Client socket (3) | Closed. | 2024-03-17 10:34:48.458
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:34:50.303
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:50.303
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:50.303
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:34:50.304
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:50.455
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:50.455
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:50.456
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:50.623
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:50.623
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Failed connections: 9353 | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:50.754
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:50.754
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:50.754
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:50.754
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:50.888
DTC Client socket (3) | Closed. | 2024-03-17 10:34:50.888
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:34:52.769
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:52.770
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:52.771
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:34:52.771
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:52.963
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:52.963
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:52.963
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:53.153
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:53.153
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:53.340
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:53.340
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:53.340
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:53.340
SC DTC Delayed Exchange Data | Failed connections: 9354 | 2024-03-17 10:34:53.340
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:53.340
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:53.341
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:53.341
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:53.341
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:53.341
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:53.527
DTC Client socket (3) | Closed. | 2024-03-17 10:34:53.527
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:34:55.351
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:55.356
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:55.356
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:34:55.356
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:55.499
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:55.499
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:55.499
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:55.643
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:55.644
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:55.782
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:55.782
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:55.782
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:34:55.782
SC DTC Delayed Exchange Data | Failed connections: 9355 | 2024-03-17 10:34:55.782
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:55.782
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:55.783
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:55.783
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:55.783
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:55.783
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:55.918
DTC Client socket (3) | Closed. | 2024-03-17 10:34:55.918
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:34:57.781
DTC Client socket (3) | Creating socket. | 2024-03-17 10:34:57.782
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:34:57.782
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:34:57.782
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:34:57.921
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:34:57.921
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:34:57.921
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:34:58.094
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:34:58.094
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:34:58.228
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:34:58.228
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:34:58.228
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:34:58.228
SC DTC Delayed Exchange Data | Failed connections: 9356 | 2024-03-17 10:34:58.229
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:34:58.229
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:34:58.230
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:34:58.231
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:34:58.231
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:34:58.231
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:34:58.366
DTC Client socket (3) | Closed. | 2024-03-17 10:34:58.367
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:00.244
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:00.245
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:00.245
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:35:00.245
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:00.391
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:00.391
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:00.391
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:00.622
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:00.622
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:00.763
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:00.763
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:00.763
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:00.763
SC DTC Delayed Exchange Data | Failed connections: 9357 | 2024-03-17 10:35:00.763
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:00.763
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:00.764
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:00.764
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:00.764
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:00.764
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:00.907
DTC Client socket (3) | Closed. | 2024-03-17 10:35:00.907
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:35:02.778
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:02.779
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:02.780
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:35:02.780
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:02.926
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:02.926
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:02.926
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:03.085
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:03.085
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:03.227
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:03.227
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:03.227
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:03.227
SC DTC Delayed Exchange Data | Failed connections: 9358 | 2024-03-17 10:35:03.227
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:03.227
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:03.228
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:03.228
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:03.228
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:03.228
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:03.366
DTC Client socket (3) | Closed. | 2024-03-17 10:35:03.366
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:35:05.219
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:05.221
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:05.221
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:35:05.221
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:05.361
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:05.361
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:05.361
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:05.725
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:05.725
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:05.963
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:05.963
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:05.963
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:05.963
SC DTC Delayed Exchange Data | Failed connections: 9359 | 2024-03-17 10:35:05.963
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:05.963
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:05.963
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:05.964
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:05.964
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:05.964
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:06.108
DTC Client socket (3) | Closed. | 2024-03-17 10:35:06.108
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:35:07.974
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:07.975
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:07.975
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:35:07.975
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:08.140
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:08.140
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:08.140
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:08.408
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:08.408
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:08.539
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:08.539
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:08.539
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:08.539
SC DTC Delayed Exchange Data | Failed connections: 9360 | 2024-03-17 10:35:08.539
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:08.539
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:08.540
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:08.540
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:08.540
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:08.540
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:08.681
DTC Client socket (3) | Closed. | 2024-03-17 10:35:08.681
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:10.537
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:10.538
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:10.538
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:35:10.538
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:10.680
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:10.680
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:10.680
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:10.840
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:10.840
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:10.990
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:10.990
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:10.990
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:10.990
SC DTC Delayed Exchange Data | Failed connections: 9361 | 2024-03-17 10:35:10.990
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:10.990
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:10.991
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:10.991
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:10.991
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:10.991
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:11.136
DTC Client socket (3) | Closed. | 2024-03-17 10:35:11.137
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:12.995
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:12.996
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:12.996
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:35:12.996
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:13.132
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:13.132
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:13.132
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:13.293
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:13.293
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:13.435
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:13.435
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:13.435
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:13.435
SC DTC Delayed Exchange Data | Failed connections: 9362 | 2024-03-17 10:35:13.435
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:13.435
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:13.436
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:13.436
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:13.436
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:13.436
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:13.567
DTC Client socket (3) | Closed. | 2024-03-17 10:35:13.567
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:15.453
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:15.454
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:15.455
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:35:15.455
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:15.603
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:15.603
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:15.603
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:15.752
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:15.752
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:15.891
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:15.891
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:15.891
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:15.891
SC DTC Delayed Exchange Data | Failed connections: 9363 | 2024-03-17 10:35:15.891
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:15.891
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:15.892
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:15.892
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:15.892
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:15.892
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:16.017
DTC Client socket (3) | Closed. | 2024-03-17 10:35:16.017
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:35:17.914
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:17.915
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:17.916
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:35:17.916
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:18.058
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:18.058
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:18.058
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:18.231
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:18.231
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:18.370
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:18.370
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:18.370
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:18.370
SC DTC Delayed Exchange Data | Failed connections: 9364 | 2024-03-17 10:35:18.370
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:18.371
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:18.372
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:18.373
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:18.373
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:18.373
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:18.517
DTC Client socket (3) | Closed. | 2024-03-17 10:35:18.517
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:35:20.399
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:20.401
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:20.401
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:35:20.401
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:20.588
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:20.588
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:20.588
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:20.785
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:20.785
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Failed connections: 9365 | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:20.973
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:20.973
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:20.973
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:20.973
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:21.166
DTC Client socket (3) | Closed. | 2024-03-17 10:35:21.166
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:35:22.969
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:22.971
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:22.972
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:35:22.972
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:23.110
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:23.110
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:23.110
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:23.269
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:23.269
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:23.404
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:23.404
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:23.404
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:23.404
SC DTC Delayed Exchange Data | Failed connections: 9366 | 2024-03-17 10:35:23.404
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:23.405
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:23.405
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:23.405
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:23.405
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:23.405
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:23.552
DTC Client socket (3) | Closed. | 2024-03-17 10:35:23.552
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:35:25.426
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:25.427
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:25.427
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:35:25.427
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:25.568
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:25.568
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:25.568
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:25.728
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:25.728
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Failed connections: 9367 | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:25.870
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:25.870
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:25.870
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:25.870
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:26.006
DTC Client socket (3) | Closed. | 2024-03-17 10:35:26.006
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:27.899
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:27.900
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:27.900
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:35:27.900
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:28.052
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:28.052
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:28.052
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:28.338
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:28.338
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:28.468
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:28.468
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:28.468
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:28.468
SC DTC Delayed Exchange Data | Failed connections: 9368 | 2024-03-17 10:35:28.468
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:28.468
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:28.468
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:28.469
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:28.469
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:28.469
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:28.606
DTC Client socket (3) | Closed. | 2024-03-17 10:35:28.606
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:35:30.480
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:30.481
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:30.481
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:35:30.481
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:30.627
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:30.627
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:30.628
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:30.800
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:30.800
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:30.935
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:30.935
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:30.935
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:30.936
SC DTC Delayed Exchange Data | Failed connections: 9369 | 2024-03-17 10:35:30.936
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:30.936
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:30.936
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:30.936
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:30.936
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:30.936
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:31.076
DTC Client socket (3) | Closed. | 2024-03-17 10:35:31.076
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:35:32.938
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:32.939
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:32.940
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:35:32.940
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:33.084
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:33.084
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:33.084
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:33.373
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:33.373
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:33.872
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:33.872
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:33.873
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:33.873
SC DTC Delayed Exchange Data | Failed connections: 9370 | 2024-03-17 10:35:33.873
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:33.873
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:33.873
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:33.873
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:33.873
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:33.874
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:34.056
DTC Client socket (3) | Closed. | 2024-03-17 10:35:34.056
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:35:35.877
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:35.878
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:35.878
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:35:35.878
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:36.017
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:36.017
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:36.017
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:36.312
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:36.312
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:36.605
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:36.605
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:36.605
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:36.605
SC DTC Delayed Exchange Data | Failed connections: 9371 | 2024-03-17 10:35:36.605
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:36.605
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:36.606
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:36.606
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:36.606
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:36.606
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:36.785
DTC Client socket (3) | Closed. | 2024-03-17 10:35:36.785
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:38.621
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:38.622
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:38.622
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:35:38.622
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:38.758
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:38.758
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:38.758
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:38.932
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:38.932
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:39.065
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:39.065
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:39.065
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:39.065
SC DTC Delayed Exchange Data | Failed connections: 9372 | 2024-03-17 10:35:39.065
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:39.065
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:39.066
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:39.066
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:39.066
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:39.066
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:39.205
DTC Client socket (3) | Closed. | 2024-03-17 10:35:39.205
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:41.070
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:41.071
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:41.071
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:35:41.071
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:41.219
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:41.219
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:41.219
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:41.378
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:41.378
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:41.514
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:41.514
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:41.514
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:41.514
SC DTC Delayed Exchange Data | Failed connections: 9373 | 2024-03-17 10:35:41.514
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:41.514
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:41.515
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:41.515
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:41.515
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:41.515
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:41.661
DTC Client socket (3) | Closed. | 2024-03-17 10:35:41.661
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:43.517
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:43.517
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:43.517
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:35:43.517
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:43.657
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:43.657
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:43.657
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:43.843
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:43.843
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Failed connections: 9374 | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:43.977
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:43.977
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:43.977
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:43.977
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:44.115
DTC Client socket (3) | Closed. | 2024-03-17 10:35:44.115
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:35:45.990
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:45.992
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:45.992
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:35:45.992
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:46.142
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:46.142
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:46.142
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:46.314
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:46.314
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Failed connections: 9375 | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:46.473
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:46.473
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:46.473
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:46.473
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:46.617
DTC Client socket (3) | Closed. | 2024-03-17 10:35:46.617
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:35:48.473
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:48.476
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:48.476
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:35:48.476
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:48.668
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:48.668
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:48.668
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:48.859
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:48.859
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Failed connections: 9376 | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:49.052
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:49.052
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:49.052
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:49.052
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:49.234
DTC Client socket (3) | Closed. | 2024-03-17 10:35:49.235
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:35:51.049
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:51.050
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:51.050
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:35:51.050
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:51.188
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:51.188
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:51.188
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:51.365
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:51.365
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:51.511
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:51.511
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:51.511
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:51.511
SC DTC Delayed Exchange Data | Failed connections: 9377 | 2024-03-17 10:35:51.511
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:51.511
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:51.512
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:51.512
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:51.512
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:51.512
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:51.638
DTC Client socket (3) | Closed. | 2024-03-17 10:35:51.638
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:35:53.514
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:53.516
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:53.516
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:35:53.518
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:53.657
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:53.657
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:53.657
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:53.820
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:53.820
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Failed connections: 9378 | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:53.943
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:53.943
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:53.943
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:53.944
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:54.084
DTC Client socket (3) | Closed. | 2024-03-17 10:35:54.084
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:35:55.943
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:55.946
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:55.946
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:35:55.946
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:56.086
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:56.086
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:56.086
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:56.351
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:56.351
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:56.510
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:56.510
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:56.510
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:35:56.510
SC DTC Delayed Exchange Data | Failed connections: 9379 | 2024-03-17 10:35:56.510
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:56.510
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:56.511
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:56.511
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:56.511
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:56.511
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:56.675
DTC Client socket (3) | Closed. | 2024-03-17 10:35:56.675
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:35:58.600
DTC Client socket (3) | Creating socket. | 2024-03-17 10:35:58.601
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:35:58.601
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:35:58.601
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:35:58.748
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:35:58.748
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:35:58.748
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:35:58.901
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:35:58.901
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Failed connections: 9380 | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:35:59.039
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:35:59.039
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:35:59.039
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:35:59.039
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:35:59.186
DTC Client socket (3) | Closed. | 2024-03-17 10:35:59.186
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:36:01.041
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:01.041
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:01.041
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:36:01.041
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:01.187
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:01.187
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:01.187
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:01.419
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:01.419
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:01.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:01.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:01.620
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:01.620
SC DTC Delayed Exchange Data | Failed connections: 9381 | 2024-03-17 10:36:01.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:01.620
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:01.623
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:01.623
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:01.623
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:01.623
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:01.780
DTC Client socket (3) | Closed. | 2024-03-17 10:36:01.780
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:36:03.636
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:03.636
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:03.636
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:36:03.636
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:03.777
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:03.777
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:03.777
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:04.115
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:04.115
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:04.265
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:04.265
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:04.265
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:04.265
SC DTC Delayed Exchange Data | Failed connections: 9382 | 2024-03-17 10:36:04.265
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:04.265
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:04.266
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:04.266
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:04.266
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:04.266
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:04.437
DTC Client socket (3) | Closed. | 2024-03-17 10:36:04.437
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:06.262
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:06.262
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:06.262
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:36:06.263
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:06.408
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:06.408
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:06.408
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:06.569
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:06.569
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:06.716
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:06.716
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:06.716
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:06.716
SC DTC Delayed Exchange Data | Failed connections: 9383 | 2024-03-17 10:36:06.716
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:06.716
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:06.719
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:06.719
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:06.719
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:06.719
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:06.854
DTC Client socket (3) | Closed. | 2024-03-17 10:36:06.854
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:08.724
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:08.726
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:08.727
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:36:08.727
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:08.866
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:08.866
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:08.866
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:09.008
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:09.008
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Failed connections: 9384 | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:09.147
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:09.147
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:09.147
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:09.148
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:09.285
DTC Client socket (3) | Closed. | 2024-03-17 10:36:09.285
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:11.161
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:11.163
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:11.163
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:36:11.163
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:11.306
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:11.306
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:11.306
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:11.489
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:11.489
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:11.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:11.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:11.620
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:11.620
SC DTC Delayed Exchange Data | Failed connections: 9385 | 2024-03-17 10:36:11.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:11.620
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:11.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:11.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:11.621
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:11.621
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:11.765
DTC Client socket (3) | Closed. | 2024-03-17 10:36:11.765
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:36:13.628
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:13.637
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:13.637
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:36:13.637
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:13.806
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:13.806
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:13.807
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:14.022
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:14.022
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Failed connections: 9386 | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:14.179
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:14.179
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:14.179
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:14.190
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:14.323
DTC Client socket (3) | Closed. | 2024-03-17 10:36:14.324
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:36:16.189
DTC Client socket (3) | Creating socket. | 2024-03-17 10:36:16.190
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:36:16.194
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:36:16.194
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:16.385
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:16.385
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:16.385
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:16.598
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:16.598
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Failed connections: 9387 | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:16.785
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:36:16.785
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:16.785
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:16.785
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:36:16.974
DTC Client socket (3) | Closed. | 2024-03-17 10:36:16.974
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:36:18.804
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:18.805
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:18.805
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:36:18.805
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:18.948
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:18.948
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:18.948
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:19.134
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:19.134
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:19.266
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:19.266
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:19.266
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:19.266
SC DTC Delayed Exchange Data | Failed connections: 9388 | 2024-03-17 10:36:19.266
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:19.266
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:19.268
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:19.268
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:19.268
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:19.268
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:19.403
DTC Client socket (1) | Closed. | 2024-03-17 10:36:19.403
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:36:21.280
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:21.281
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:21.281
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:36:21.281
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:21.425
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:21.425
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:21.426
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:21.589
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:21.589
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:21.734
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:21.734
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:21.734
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:21.734
SC DTC Delayed Exchange Data | Failed connections: 9389 | 2024-03-17 10:36:21.734
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:21.734
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:21.735
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:21.735
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:21.736
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:21.736
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:21.873
DTC Client socket (1) | Closed. | 2024-03-17 10:36:21.873
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:23.759
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:23.761
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:23.762
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:36:23.762
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:23.905
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:23.905
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:23.905
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:24.368
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:24.368
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:24.512
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:24.512
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:24.512
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:24.512
SC DTC Delayed Exchange Data | Failed connections: 9390 | 2024-03-17 10:36:24.512
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:24.512
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:24.513
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:24.513
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:24.513
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:24.513
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:24.673
DTC Client socket (1) | Closed. | 2024-03-17 10:36:24.673
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:36:26.533
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:26.534
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:26.534
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:36:26.534
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:26.677
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:26.677
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:26.677
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:26.848
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:26.849
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:26.985
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:26.985
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:26.985
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:26.985
SC DTC Delayed Exchange Data | Failed connections: 9391 | 2024-03-17 10:36:26.985
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:26.985
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:26.986
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:26.986
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:26.986
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:26.986
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:27.133
DTC Client socket (1) | Closed. | 2024-03-17 10:36:27.133
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:36:29.003
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:29.004
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:29.004
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:36:29.004
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:29.145
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:29.145
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:29.145
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:29.505
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:29.505
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:29.837
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Failed connections: 9392 | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:29.838
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:29.838
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:29.838
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:29.839
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:29.973
DTC Client socket (1) | Closed. | 2024-03-17 10:36:29.973
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:36:31.859
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:31.860
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:31.860
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:36:31.860
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:32.008
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:32.008
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:32.009
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:32.325
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:32.325
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Failed connections: 9393 | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:32.478
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:32.478
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:32.478
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:32.478
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:32.622
DTC Client socket (1) | Closed. | 2024-03-17 10:36:32.623
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:34.492
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:34.493
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:34.493
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:36:34.493
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:34.637
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:34.637
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:34.637
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:34.779
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:34.779
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:34.915
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:34.915
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:34.915
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:34.915
SC DTC Delayed Exchange Data | Failed connections: 9394 | 2024-03-17 10:36:34.915
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:34.915
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:34.916
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:34.916
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:34.916
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:34.916
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:35.054
DTC Client socket (1) | Closed. | 2024-03-17 10:36:35.054
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:36.917
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:36.918
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:36.919
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:36:36.919
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:37.056
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:37.056
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:37.057
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:37.214
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:37.214
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:37.352
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:37.352
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:37.352
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:37.352
SC DTC Delayed Exchange Data | Failed connections: 9395 | 2024-03-17 10:36:37.352
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:37.352
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:37.353
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:37.353
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:37.353
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:37.353
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:37.492
DTC Client socket (1) | Closed. | 2024-03-17 10:36:37.492
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:39.349
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:39.351
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:39.351
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:36:39.351
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:39.494
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:39.494
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:39.494
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:39.664
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:39.664
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:39.787
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:39.787
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:39.787
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:39.787
SC DTC Delayed Exchange Data | Failed connections: 9396 | 2024-03-17 10:36:39.787
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:39.787
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:39.788
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:39.788
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:39.788
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:39.788
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:39.922
DTC Client socket (1) | Closed. | 2024-03-17 10:36:39.922
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:36:41.797
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:41.799
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:41.799
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:36:41.799
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:41.948
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:41.948
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:41.949
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:42.113
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:42.113
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Failed connections: 9397 | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:42.258
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:42.258
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:42.258
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:42.258
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:42.402
DTC Client socket (1) | Closed. | 2024-03-17 10:36:42.402
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:36:44.266
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:44.266
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:44.266
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:36:44.266
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:44.454
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:44.454
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:44.454
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:44.674
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:44.674
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Failed connections: 9398 | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:44.867
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:44.867
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:44.867
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:44.867
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:45.062
DTC Client socket (1) | Closed. | 2024-03-17 10:36:45.062
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:36:46.884
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:46.885
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:46.885
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:36:46.885
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:47.027
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:47.027
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:47.028
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:47.168
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:47.168
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:47.316
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:47.316
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:47.316
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:47.316
SC DTC Delayed Exchange Data | Failed connections: 9399 | 2024-03-17 10:36:47.316
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:47.316
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:47.317
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:47.317
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:47.317
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:47.317
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:47.454
DTC Client socket (1) | Closed. | 2024-03-17 10:36:47.454
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:36:49.308
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:49.309
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:49.309
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:36:49.309
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:49.447
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:49.447
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:49.447
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:49.618
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:49.618
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:49.755
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:49.755
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:49.755
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:49.755
SC DTC Delayed Exchange Data | Failed connections: 9400 | 2024-03-17 10:36:49.755
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:49.755
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:49.756
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:49.756
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:49.756
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:49.756
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:49.892
DTC Client socket (1) | Closed. | 2024-03-17 10:36:49.892
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:36:51.758
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:51.759
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:51.759
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:36:51.759
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:51.897
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:51.897
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:51.897
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:52.178
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:52.178
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:52.317
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:52.317
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:52.317
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:52.317
SC DTC Delayed Exchange Data | Failed connections: 9401 | 2024-03-17 10:36:52.317
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:52.317
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:52.318
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:52.318
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:52.318
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:52.318
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:52.462
DTC Client socket (1) | Closed. | 2024-03-17 10:36:52.462
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:36:54.316
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:54.317
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:54.317
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:36:54.317
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:54.453
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:54.453
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:54.454
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:54.624
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:54.624
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:54.764
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:54.764
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:54.764
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:36:54.764
SC DTC Delayed Exchange Data | Failed connections: 9402 | 2024-03-17 10:36:54.764
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:54.764
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:54.765
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:54.765
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:54.765
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:54.765
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:54.901
DTC Client socket (1) | Closed. | 2024-03-17 10:36:54.902
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:36:56.797
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:56.798
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:56.798
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:36:56.798
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:56.947
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:56.947
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:56.947
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:57.147
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:57.147
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:57.297
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:57.297
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:57.297
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:57.297
SC DTC Delayed Exchange Data | Failed connections: 9403 | 2024-03-17 10:36:57.297
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:57.297
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:57.298
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:57.299
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:57.299
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:57.299
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:36:57.441
DTC Client socket (1) | Closed. | 2024-03-17 10:36:57.442
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:36:59.304
DTC Client socket (1) | Creating socket. | 2024-03-17 10:36:59.305
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:36:59.305
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:36:59.305
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:36:59.447
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:36:59.447
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:36:59.447
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:36:59.757
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:36:59.757
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:36:59.985
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:36:59.985
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:36:59.985
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:36:59.985
SC DTC Delayed Exchange Data | Failed connections: 9404 | 2024-03-17 10:36:59.985
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:36:59.985
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:36:59.986
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:36:59.986
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:36:59.986
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:36:59.986
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:00.134
DTC Client socket (1) | Closed. | 2024-03-17 10:37:00.134
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:02.002
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:02.003
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:02.003
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:37:02.004
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:02.157
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:02.157
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:02.157
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:02.321
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:02.321
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:02.457
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:02.457
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:02.457
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:02.457
SC DTC Delayed Exchange Data | Failed connections: 9405 | 2024-03-17 10:37:02.457
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:02.457
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:02.458
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:02.458
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:02.458
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:02.458
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:02.601
DTC Client socket (1) | Closed. | 2024-03-17 10:37:02.602
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:04.472
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:04.472
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:04.472
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:37:04.473
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:04.616
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:04.616
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:04.616
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:04.786
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:04.786
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Failed connections: 9406 | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:04.914
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:04.914
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:04.914
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:04.914
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:05.051
DTC Client socket (1) | Closed. | 2024-03-17 10:37:05.052
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:06.908
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:06.909
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:06.909
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:37:06.909
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:07.046
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:07.046
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:07.046
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:07.210
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:07.210
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Failed connections: 9407 | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:07.340
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:07.340
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:07.340
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:07.340
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:07.471
DTC Client socket (1) | Closed. | 2024-03-17 10:37:07.471
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:37:09.343
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:09.344
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:09.344
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:37:09.344
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:09.483
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:09.483
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:09.483
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:09.674
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:09.674
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:09.824
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:09.824
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:09.824
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:09.824
SC DTC Delayed Exchange Data | Failed connections: 9408 | 2024-03-17 10:37:09.824
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:09.824
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:09.825
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:09.825
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:09.825
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:09.825
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:09.961
DTC Client socket (1) | Closed. | 2024-03-17 10:37:09.962
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:37:11.838
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:11.838
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:11.838
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:37:11.839
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:12.033
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:12.033
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:12.033
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:12.245
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:12.245
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Failed connections: 9409 | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:12.431
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:12.431
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:12.431
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:12.431
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:12.621
DTC Client socket (1) | Closed. | 2024-03-17 10:37:12.621
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:37:14.478
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:14.479
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:14.479
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:37:14.479
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:14.625
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:14.625
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:14.625
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:14.796
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:14.796
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Failed connections: 9410 | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:14.937
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:14.937
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:14.937
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:14.937
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:15.083
DTC Client socket (1) | Closed. | 2024-03-17 10:37:15.084
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:37:16.956
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:16.956
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:16.956
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:37:16.956
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:17.104
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:17.104
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:17.104
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:17.282
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:17.282
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:17.419
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:17.419
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:17.419
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:17.419
SC DTC Delayed Exchange Data | Failed connections: 9411 | 2024-03-17 10:37:17.419
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:17.419
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:17.420
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:17.420
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:17.420
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:17.421
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:17.562
DTC Client socket (1) | Closed. | 2024-03-17 10:37:17.562
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:19.428
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:19.430
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:19.430
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:37:19.430
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:19.576
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:19.576
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:19.576
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:19.826
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:19.826
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:19.955
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:19.955
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:19.955
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:19.955
SC DTC Delayed Exchange Data | Failed connections: 9412 | 2024-03-17 10:37:19.955
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:19.955
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:19.955
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:19.956
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:19.956
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:19.956
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:20.120
DTC Client socket (1) | Closed. | 2024-03-17 10:37:20.121
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:37:21.979
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:21.980
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:21.981
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:37:21.981
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:22.125
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:22.125
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:22.125
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:22.287
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:22.287
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:22.431
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:22.431
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:22.431
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:22.431
SC DTC Delayed Exchange Data | Failed connections: 9413 | 2024-03-17 10:37:22.431
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:22.431
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:22.432
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:22.432
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:22.432
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:22.432
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:22.574
DTC Client socket (1) | Closed. | 2024-03-17 10:37:22.574
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:37:24.452
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:24.482
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:24.483
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:37:24.483
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:24.624
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:24.624
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:24.624
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:24.886
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:24.886
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:25.024
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:25.024
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:25.024
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:25.024
SC DTC Delayed Exchange Data | Failed connections: 9414 | 2024-03-17 10:37:25.024
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:25.024
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:25.025
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:25.025
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:25.025
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:25.025
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:25.170
DTC Client socket (1) | Closed. | 2024-03-17 10:37:25.171
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:37:27.027
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:27.027
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:27.028
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:37:27.028
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:27.172
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:27.172
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:27.172
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:27.396
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:27.396
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Failed connections: 9415 | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:27.595
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:27.595
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:27.595
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:27.595
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:27.740
DTC Client socket (1) | Closed. | 2024-03-17 10:37:27.740
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:29.597
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:29.598
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:29.598
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:37:29.598
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:29.746
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:29.746
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:29.746
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:29.884
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:29.884
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:30.016
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:30.016
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:30.016
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:30.016
SC DTC Delayed Exchange Data | Failed connections: 9416 | 2024-03-17 10:37:30.016
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:30.016
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:30.017
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:30.017
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:30.017
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:30.017
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:30.150
DTC Client socket (1) | Closed. | 2024-03-17 10:37:30.150
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:32.013
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:32.017
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:32.018
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:37:32.018
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:32.162
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:32.162
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:32.162
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:32.325
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:32.325
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:32.471
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:32.471
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:32.471
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:32.471
SC DTC Delayed Exchange Data | Failed connections: 9417 | 2024-03-17 10:37:32.471
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:32.471
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:32.472
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:32.472
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:32.472
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:32.472
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:32.610
DTC Client socket (1) | Closed. | 2024-03-17 10:37:32.610
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:34.478
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:34.478
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:34.478
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:37:34.479
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:34.622
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:34.622
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:34.622
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:34.765
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:34.765
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:34.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:34.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:34.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:34.897
SC DTC Delayed Exchange Data | Failed connections: 9418 | 2024-03-17 10:37:34.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:34.897
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:34.898
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:34.898
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:34.898
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:34.898
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:35.030
DTC Client socket (1) | Closed. | 2024-03-17 10:37:35.031
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:37:36.900
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:36.901
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:36.901
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:37:36.901
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:37.045
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:37.045
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:37.045
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:37.193
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:37.193
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:37.331
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:37.331
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:37.331
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:37.331
SC DTC Delayed Exchange Data | Failed connections: 9419 | 2024-03-17 10:37:37.331
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:37.331
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:37.332
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:37.332
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:37.332
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:37.332
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:37.470
DTC Client socket (1) | Closed. | 2024-03-17 10:37:37.470
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:37:39.346
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:39.361
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:39.361
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:37:39.361
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:39.559
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:39.559
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:39.559
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:39.772
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:39.772
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:39.973
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:39.973
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:39.973
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:39.973
SC DTC Delayed Exchange Data | Failed connections: 9420 | 2024-03-17 10:37:39.973
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:39.973
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:39.974
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:39.974
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:39.974
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:39.974
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:40.173
DTC Client socket (1) | Closed. | 2024-03-17 10:37:40.173
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:37:41.983
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:41.983
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:41.983
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:37:41.983
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:42.132
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:42.132
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:42.132
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:42.309
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:42.309
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Failed connections: 9421 | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:42.449
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:42.449
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:42.450
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:42.450
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:42.592
DTC Client socket (1) | Closed. | 2024-03-17 10:37:42.592
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:37:44.453
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:44.486
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:44.486
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:37:44.486
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:44.633
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:44.633
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:44.633
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:44.816
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:44.816
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:44.950
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:44.950
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:44.950
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:44.950
SC DTC Delayed Exchange Data | Failed connections: 9422 | 2024-03-17 10:37:44.950
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:44.950
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:44.951
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:44.951
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:44.951
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:44.951
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:45.090
DTC Client socket (1) | Closed. | 2024-03-17 10:37:45.090
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:46.960
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:46.961
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:46.961
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:37:46.961
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:47.104
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:47.104
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:47.104
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:47.393
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:47.393
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:47.551
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:47.551
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:47.551
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:47.551
SC DTC Delayed Exchange Data | Failed connections: 9423 | 2024-03-17 10:37:47.551
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:47.551
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:47.552
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:47.552
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:47.552
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:47.552
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:47.692
DTC Client socket (1) | Closed. | 2024-03-17 10:37:47.692
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:37:49.570
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:49.570
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:49.570
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:37:49.570
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:49.712
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:49.712
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:49.712
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:49.852
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:49.852
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:49.991
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:49.991
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:49.991
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:49.991
SC DTC Delayed Exchange Data | Failed connections: 9424 | 2024-03-17 10:37:49.991
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:49.991
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:49.994
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:49.994
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:49.994
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:49.994
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:50.143
DTC Client socket (1) | Closed. | 2024-03-17 10:37:50.143
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:37:52.003
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:52.005
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:52.005
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:37:52.005
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:52.131
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:52.131
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:52.131
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:52.444
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:52.444
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:52.745
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:52.745
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:52.745
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:52.745
SC DTC Delayed Exchange Data | Failed connections: 9425 | 2024-03-17 10:37:52.745
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:52.745
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:52.746
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:52.746
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:52.746
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:52.746
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:52.939
DTC Client socket (1) | Closed. | 2024-03-17 10:37:52.939
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:37:54.758
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:54.760
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:54.760
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:37:54.760
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:54.904
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:54.904
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:54.904
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:55.215
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:55.215
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:55.375
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:55.375
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:55.375
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:37:55.375
SC DTC Delayed Exchange Data | Failed connections: 9426 | 2024-03-17 10:37:55.375
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:55.375
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:55.376
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:55.376
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:55.376
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:55.376
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:55.523
DTC Client socket (1) | Closed. | 2024-03-17 10:37:55.523
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:57.378
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:57.379
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:57.379
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:37:57.379
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:57.522
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:57.522
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:57.522
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:37:57.683
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:37:57.683
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Failed connections: 9427 | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:37:57.823
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:37:57.823
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:37:57.823
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:37:57.823
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:37:57.959
DTC Client socket (1) | Closed. | 2024-03-17 10:37:57.959
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:37:59.845
DTC Client socket (1) | Creating socket. | 2024-03-17 10:37:59.846
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:37:59.846
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:37:59.846
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:37:59.988
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:37:59.988
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:37:59.988
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:00.142
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:00.142
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:00.264
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:00.264
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:00.264
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:00.264
SC DTC Delayed Exchange Data | Failed connections: 9428 | 2024-03-17 10:38:00.264
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:00.264
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:00.265
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:00.265
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:00.265
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:00.265
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:00.400
DTC Client socket (1) | Closed. | 2024-03-17 10:38:00.400
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:02.285
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:02.286
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:02.286
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:38:02.286
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:02.435
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:02.435
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:02.435
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:02.602
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:02.602
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:02.748
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:02.748
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:02.748
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:02.748
SC DTC Delayed Exchange Data | Failed connections: 9429 | 2024-03-17 10:38:02.748
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:02.748
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:02.749
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:02.749
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:02.749
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:02.749
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:02.891
DTC Client socket (1) | Closed. | 2024-03-17 10:38:02.891
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:38:04.755
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:04.763
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:04.763
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:38:04.763
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:05.031
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:05.031
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:05.031
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:05.191
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:05.191
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:05.320
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:05.320
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:05.320
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:05.320
SC DTC Delayed Exchange Data | Failed connections: 9430 | 2024-03-17 10:38:05.320
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:05.320
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:05.321
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:05.321
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:05.321
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:05.321
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:05.458
DTC Client socket (1) | Closed. | 2024-03-17 10:38:05.458
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:38:07.328
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:07.329
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:07.329
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:38:07.329
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:07.602
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:07.602
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:07.602
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:07.851
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:07.851
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:08.033
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:08.033
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:08.033
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:08.033
SC DTC Delayed Exchange Data | Failed connections: 9431 | 2024-03-17 10:38:08.033
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:08.033
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:08.036
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:08.036
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:08.036
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:08.036
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:08.229
DTC Client socket (1) | Closed. | 2024-03-17 10:38:08.229
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:38:10.062
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:10.067
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:10.067
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:38:10.067
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:10.212
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:10.212
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:10.213
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:10.371
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:10.371
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Failed connections: 9432 | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:10.512
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:10.512
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:10.512
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:10.512
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:10.650
DTC Client socket (1) | Closed. | 2024-03-17 10:38:10.650
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:38:12.531
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:12.532
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:12.532
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:38:12.533
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:12.671
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:12.671
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:12.671
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:12.810
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:12.810
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:12.941
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:12.941
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:12.941
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:12.941
SC DTC Delayed Exchange Data | Failed connections: 9433 | 2024-03-17 10:38:12.941
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:12.941
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:12.942
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:12.942
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:12.942
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:12.942
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:13.078
DTC Client socket (1) | Closed. | 2024-03-17 10:38:13.078
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:14.935
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:14.941
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:14.941
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:38:14.941
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:15.089
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:15.089
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:15.090
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:15.441
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:15.441
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Failed connections: 9434 | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:15.852
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:15.852
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:15.852
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:15.852
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:16.022
DTC Client socket (1) | Closed. | 2024-03-17 10:38:16.022
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:38:17.840
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:17.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:17.841
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:38:17.841
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:17.990
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:17.990
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:17.990
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:18.168
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:18.168
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:18.308
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:18.308
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:18.308
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:18.308
SC DTC Delayed Exchange Data | Failed connections: 9435 | 2024-03-17 10:38:18.308
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:18.308
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:18.309
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:18.309
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:18.309
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:18.309
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:18.448
DTC Client socket (1) | Closed. | 2024-03-17 10:38:18.448
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:38:20.319
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:20.320
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:20.320
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:38:20.320
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:20.461
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:20.461
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:20.461
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:20.691
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:20.691
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Failed connections: 9436 | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:20.930
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:20.930
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:20.930
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:20.931
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:20.931
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:21.078
DTC Client socket (1) | Closed. | 2024-03-17 10:38:21.079
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:38:22.937
DTC Client socket (1) | Creating socket. | 2024-03-17 10:38:22.938
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:38:22.938
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:38:22.938
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:23.136
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:23.136
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:23.136
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:23.454
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:23.454
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Failed connections: 9437 | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:23.602
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:38:23.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:23.602
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:23.602
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:38:23.739
DTC Client socket (1) | Closed. | 2024-03-17 10:38:23.739
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:25.597
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:25.628
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:25.628
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:38:25.628
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:25.796
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:25.796
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:25.796
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:26.014
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:26.014
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:26.160
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:26.160
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:26.160
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:26.160
SC DTC Delayed Exchange Data | Failed connections: 9438 | 2024-03-17 10:38:26.160
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:26.160
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:26.161
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:26.161
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:26.161
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:26.161
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:26.297
DTC Client socket (3) | Closed. | 2024-03-17 10:38:26.297
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:28.225
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:28.431
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:28.431
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:38:28.431
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:28.596
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:28.596
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:28.596
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:28.880
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:28.880
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:29.041
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:29.041
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:29.041
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:29.041
SC DTC Delayed Exchange Data | Failed connections: 9439 | 2024-03-17 10:38:29.041
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:29.041
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:29.041
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:29.042
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:29.042
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:29.042
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:29.175
DTC Client socket (3) | Closed. | 2024-03-17 10:38:29.175
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:31.031
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:31.038
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:31.039
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:38:31.039
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:31.175
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:31.175
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:31.175
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:31.310
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:31.310
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:31.443
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:31.443
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:31.443
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:31.443
SC DTC Delayed Exchange Data | Failed connections: 9440 | 2024-03-17 10:38:31.443
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:31.443
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:31.444
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:31.444
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:31.444
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:31.444
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:31.605
DTC Client socket (3) | Closed. | 2024-03-17 10:38:31.605
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:38:33.437
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:33.437
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:33.437
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:38:33.437
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:33.570
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:33.570
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:33.570
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:33.744
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:33.744
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Failed connections: 9441 | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:33.895
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:33.895
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:33.895
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:33.895
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:34.037
DTC Client socket (3) | Closed. | 2024-03-17 10:38:34.037
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:38:35.888
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:35.890
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:35.891
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:38:35.891
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:36.081
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:36.081
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:36.081
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:36.299
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:36.299
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:36.496
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:36.496
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:36.496
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:36.496
SC DTC Delayed Exchange Data | Failed connections: 9442 | 2024-03-17 10:38:36.496
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:36.496
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:36.497
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:36.497
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:36.497
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:36.497
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:36.690
DTC Client socket (3) | Closed. | 2024-03-17 10:38:36.690
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:38:38.521
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:38.528
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:38.528
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:38:38.529
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:38.660
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:38.660
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:38.660
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:38.821
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:38.821
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:38.958
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:38.958
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:38.958
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:38.958
SC DTC Delayed Exchange Data | Failed connections: 9443 | 2024-03-17 10:38:38.958
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:38.958
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:38.959
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:38.959
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:38.959
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:38.959
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:39.097
DTC Client socket (3) | Closed. | 2024-03-17 10:38:39.097
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:38:40.950
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:40.951
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:40.951
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:38:40.951
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:41.096
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:41.096
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:41.096
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:41.259
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:41.259
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:41.384
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:41.384
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:41.384
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:41.384
SC DTC Delayed Exchange Data | Failed connections: 9444 | 2024-03-17 10:38:41.384
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:41.384
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:41.385
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:41.385
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:41.385
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:41.385
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:41.529
DTC Client socket (3) | Closed. | 2024-03-17 10:38:41.529
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:43.409
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:43.410
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:43.410
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:38:43.410
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:43.552
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:43.552
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:43.552
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:44.120
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:44.120
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Failed connections: 9445 | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:44.294
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:44.294
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:44.295
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:44.295
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:44.295
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:44.439
DTC Client socket (3) | Closed. | 2024-03-17 10:38:44.439
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:38:46.295
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:46.298
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:46.298
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:38:46.298
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:46.438
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:46.438
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:46.439
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:46.583
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:46.583
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:46.730
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:46.730
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:46.730
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:46.730
SC DTC Delayed Exchange Data | Failed connections: 9446 | 2024-03-17 10:38:46.730
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:46.730
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:46.731
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:46.731
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:46.731
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:46.732
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:46.867
DTC Client socket (3) | Closed. | 2024-03-17 10:38:46.867
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:38:48.747
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:48.755
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:48.755
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:38:48.755
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:48.888
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:48.888
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:48.888
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:49.199
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:49.199
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Failed connections: 9447 | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:49.333
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:49.333
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:49.333
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:49.333
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:49.487
DTC Client socket (3) | Closed. | 2024-03-17 10:38:49.487
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:38:51.347
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:51.348
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:51.348
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:38:51.348
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:51.493
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:51.493
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:51.494
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:51.751
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:51.751
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:51.882
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:51.882
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:51.882
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:51.882
SC DTC Delayed Exchange Data | Failed connections: 9448 | 2024-03-17 10:38:51.882
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:51.882
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:51.883
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:51.883
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:51.883
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:51.883
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:52.046
DTC Client socket (3) | Closed. | 2024-03-17 10:38:52.046
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:53.885
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:53.886
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:53.886
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:38:53.886
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:54.029
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:54.029
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:54.029
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:54.194
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:54.194
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Failed connections: 9449 | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:54.329
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:54.329
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:54.329
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:54.329
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:54.467
DTC Client socket (3) | Closed. | 2024-03-17 10:38:54.467
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:56.347
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:56.348
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:56.348
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:38:56.348
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:56.492
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:56.492
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:56.492
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:56.643
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:56.643
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:56.792
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:56.792
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:56.792
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:38:56.792
SC DTC Delayed Exchange Data | Failed connections: 9450 | 2024-03-17 10:38:56.792
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:56.792
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:56.792
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:56.793
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:56.793
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:56.793
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:56.937
DTC Client socket (3) | Closed. | 2024-03-17 10:38:56.937
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:38:58.799
DTC Client socket (3) | Creating socket. | 2024-03-17 10:38:58.800
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:38:58.800
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:38:58.800
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:38:58.938
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:38:58.938
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:38:58.938
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:38:59.092
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:38:59.092
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Failed connections: 9451 | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:38:59.226
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:38:59.226
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:38:59.226
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:38:59.226
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:38:59.368
DTC Client socket (3) | Closed. | 2024-03-17 10:38:59.368
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:39:01.216
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:01.217
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:01.217
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:39:01.217
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:01.360
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:01.360
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:01.361
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:01.525
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:01.525
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:01.671
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:01.671
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:01.671
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:01.671
SC DTC Delayed Exchange Data | Failed connections: 9452 | 2024-03-17 10:39:01.671
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:01.671
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:01.673
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:01.673
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:01.673
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:01.673
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:01.817
DTC Client socket (3) | Closed. | 2024-03-17 10:39:01.817
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:39:03.668
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:03.669
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:03.669
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:39:03.669
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:03.892
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:03.892
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:03.892
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:04.112
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:04.112
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Failed connections: 9453 | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:04.309
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:04.309
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:04.309
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:04.309
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:04.497
DTC Client socket (3) | Closed. | 2024-03-17 10:39:04.497
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:39:06.325
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:06.326
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:06.326
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:39:06.326
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:06.470
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:06.470
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:06.470
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:06.612
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:06.612
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:06.749
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:06.749
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:06.749
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:06.749
SC DTC Delayed Exchange Data | Failed connections: 9454 | 2024-03-17 10:39:06.749
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:06.749
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:06.749
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:06.750
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:06.750
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:06.750
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:06.886
DTC Client socket (3) | Closed. | 2024-03-17 10:39:06.886
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:39:08.747
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:08.747
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:08.748
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:39:08.748
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:08.885
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:08.885
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:08.885
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:09.059
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:09.059
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:09.197
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:09.197
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:09.197
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:09.197
SC DTC Delayed Exchange Data | Failed connections: 9455 | 2024-03-17 10:39:09.197
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:09.197
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:09.198
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:09.198
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:09.198
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:09.198
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:09.326
DTC Client socket (3) | Closed. | 2024-03-17 10:39:09.326
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:11.213
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:11.215
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:11.215
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:39:11.215
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:11.358
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:11.358
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:11.358
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:11.676
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:11.676
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:11.817
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:11.817
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:11.817
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:11.817
SC DTC Delayed Exchange Data | Failed connections: 9456 | 2024-03-17 10:39:11.817
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:11.817
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:11.818
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:11.818
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:11.818
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:11.818
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:11.956
DTC Client socket (3) | Closed. | 2024-03-17 10:39:11.956
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:39:13.828
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:13.829
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:13.829
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:39:13.829
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:13.969
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:13.969
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:13.969
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:14.139
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:14.139
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:14.287
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:14.287
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:14.287
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:14.287
SC DTC Delayed Exchange Data | Failed connections: 9457 | 2024-03-17 10:39:14.287
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:14.287
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:14.288
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:14.288
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:14.288
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:14.289
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:14.426
DTC Client socket (3) | Closed. | 2024-03-17 10:39:14.426
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:39:16.305
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:16.307
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:16.308
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:39:16.308
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:16.448
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:16.448
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:16.449
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:17.052
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:17.052
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:17.248
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:17.248
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:17.248
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:17.248
SC DTC Delayed Exchange Data | Failed connections: 9458 | 2024-03-17 10:39:17.248
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:17.248
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:17.249
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:17.249
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:17.249
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:17.249
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:17.417
DTC Client socket (3) | Closed. | 2024-03-17 10:39:17.417
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:39:19.257
DTC Client socket (2) | Creating socket. | 2024-03-17 10:39:19.259
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:39:19.259
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:39:19.259
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:19.410
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:19.410
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:19.410
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:19.718
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:19.718
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:19.900
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:19.900
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:19.900
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:19.900
SC DTC Delayed Exchange Data | Failed connections: 9459 | 2024-03-17 10:39:19.900
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:19.900
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:39:19.900
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:19.901
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:19.901
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:19.901
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:39:20.051
DTC Client socket (2) | Closed. | 2024-03-17 10:39:20.051
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:21.907
DTC Client socket (2) | Creating socket. | 2024-03-17 10:39:21.908
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:39:21.908
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:39:21.908
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:22.049
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:22.049
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:22.049
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:22.211
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:22.211
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:22.338
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:22.338
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:22.338
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:22.338
SC DTC Delayed Exchange Data | Failed connections: 9460 | 2024-03-17 10:39:22.338
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:22.338
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:39:22.339
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:22.339
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:22.339
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:22.339
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:39:22.475
DTC Client socket (2) | Closed. | 2024-03-17 10:39:22.475
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:24.345
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:24.346
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:24.346
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:39:24.346
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:24.485
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:24.485
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:24.485
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:24.621
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:24.621
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Failed connections: 9461 | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:24.758
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:24.758
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:24.758
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:24.758
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:24.896
DTC Client socket (3) | Closed. | 2024-03-17 10:39:24.896
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:26.765
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:26.766
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:26.767
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:39:26.767
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:26.920
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:26.920
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:26.921
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:27.051
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:27.051
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Failed connections: 9462 | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:27.194
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:27.194
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:27.194
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:27.194
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:27.335
DTC Client socket (3) | Closed. | 2024-03-17 10:39:27.335
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:39:29.196
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:29.197
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:29.198
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:39:29.198
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:29.329
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:29.329
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:29.330
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:29.514
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:29.514
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:29.656
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:29.656
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:29.656
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:29.656
SC DTC Delayed Exchange Data | Failed connections: 9463 | 2024-03-17 10:39:29.656
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:29.656
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:29.657
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:29.657
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:29.657
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:29.657
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:29.795
DTC Client socket (3) | Closed. | 2024-03-17 10:39:29.795
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:39:31.666
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:31.667
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:31.667
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:39:31.667
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:31.860
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:31.860
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:31.860
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:32.071
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:32.071
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:32.262
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:32.262
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:32.262
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:32.262
SC DTC Delayed Exchange Data | Failed connections: 9464 | 2024-03-17 10:39:32.262
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:32.262
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:32.263
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:32.263
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:32.263
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:32.263
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:32.467
DTC Client socket (3) | Closed. | 2024-03-17 10:39:32.467
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:39:34.276
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:34.277
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:34.277
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:39:34.277
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:34.419
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:34.419
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:34.420
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:34.561
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:34.561
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:34.707
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:34.707
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:34.707
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:34.707
SC DTC Delayed Exchange Data | Failed connections: 9465 | 2024-03-17 10:39:34.707
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:34.707
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:34.708
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:34.708
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:34.708
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:34.708
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:34.848
DTC Client socket (3) | Closed. | 2024-03-17 10:39:34.848
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:39:36.723
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:36.723
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:36.723
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:39:36.724
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:36.867
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:36.867
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:36.867
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:37.027
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:37.027
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:37.173
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:37.173
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:37.173
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:37.173
SC DTC Delayed Exchange Data | Failed connections: 9466 | 2024-03-17 10:39:37.173
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:37.173
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:37.174
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:37.174
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:37.174
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:37.174
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:37.316
DTC Client socket (3) | Closed. | 2024-03-17 10:39:37.317
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:39.185
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:39.186
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:39.186
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:39:39.186
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:39.326
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:39.326
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:39.326
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:39.530
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:39.530
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:39.672
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:39.672
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:39.672
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:39.672
SC DTC Delayed Exchange Data | Failed connections: 9467 | 2024-03-17 10:39:39.672
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:39.672
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:39.674
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:39.674
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:39.674
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:39.674
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:39.829
DTC Client socket (3) | Closed. | 2024-03-17 10:39:39.829
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:39:41.696
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:41.697
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:41.697
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:39:41.697
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:41.836
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:41.836
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:41.836
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:42.001
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:42.001
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Failed connections: 9468 | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:42.151
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:42.151
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:42.151
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:42.152
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:42.284
DTC Client socket (3) | Closed. | 2024-03-17 10:39:42.284
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:39:44.166
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:44.167
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:44.167
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:39:44.168
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:44.309
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:44.309
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:44.309
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:44.787
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:44.787
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:44.992
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:44.992
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:44.992
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:44.992
SC DTC Delayed Exchange Data | Failed connections: 9469 | 2024-03-17 10:39:44.992
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:44.992
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:44.993
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:44.994
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:44.994
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:44.994
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:45.136
DTC Client socket (3) | Closed. | 2024-03-17 10:39:45.136
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:39:46.989
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:46.991
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:46.991
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:39:46.991
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:47.141
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:47.141
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:47.141
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:47.366
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:47.366
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:47.573
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:47.573
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:47.573
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:47.573
SC DTC Delayed Exchange Data | Failed connections: 9470 | 2024-03-17 10:39:47.573
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:47.573
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:47.575
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:47.575
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:47.575
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:47.575
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:47.715
DTC Client socket (3) | Closed. | 2024-03-17 10:39:47.715
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:49.590
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:49.591
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:49.591
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:39:49.591
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:49.738
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:49.738
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:49.738
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:49.896
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:49.896
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:50.038
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:50.038
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:50.038
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:50.038
SC DTC Delayed Exchange Data | Failed connections: 9471 | 2024-03-17 10:39:50.038
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:50.038
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:50.039
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:50.039
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:50.039
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:50.039
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:50.174
DTC Client socket (3) | Closed. | 2024-03-17 10:39:50.174
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:52.032
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:52.033
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:52.034
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:39:52.034
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:52.180
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:52.180
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:52.180
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:52.338
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:52.338
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:52.481
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:52.481
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:52.481
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:39:52.481
SC DTC Delayed Exchange Data | Failed connections: 9472 | 2024-03-17 10:39:52.481
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:52.481
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:52.482
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:52.482
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:52.482
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:52.483
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:52.625
DTC Client socket (3) | Closed. | 2024-03-17 10:39:52.625
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:39:54.487
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:54.489
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:54.489
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:39:54.489
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:54.629
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:54.629
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:54.629
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:54.789
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:54.789
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Failed connections: 9473 | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:54.927
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:54.927
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:54.927
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:54.927
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:55.064
DTC Client socket (3) | Closed. | 2024-03-17 10:39:55.064
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:39:56.924
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:56.925
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:56.925
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:39:56.925
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:57.078
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:57.078
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:57.078
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:57.230
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:57.230
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:57.388
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:57.388
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:57.388
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:57.388
SC DTC Delayed Exchange Data | Failed connections: 9474 | 2024-03-17 10:39:57.388
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:57.388
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:57.389
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:57.389
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:57.389
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:57.389
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:39:57.524
DTC Client socket (3) | Closed. | 2024-03-17 10:39:57.524
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:39:59.387
DTC Client socket (3) | Creating socket. | 2024-03-17 10:39:59.389
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:39:59.390
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:39:59.390
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:39:59.581
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:39:59.581
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:39:59.581
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:39:59.789
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:39:59.789
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:39:59.973
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:39:59.973
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:39:59.973
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:39:59.974
SC DTC Delayed Exchange Data | Failed connections: 9475 | 2024-03-17 10:39:59.974
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:39:59.974
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:39:59.974
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:39:59.974
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:39:59.974
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:39:59.974
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:00.165
DTC Client socket (3) | Closed. | 2024-03-17 10:40:00.165
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:40:01.988
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:01.989
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:01.989
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:40:01.989
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:02.128
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:02.128
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:02.128
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:02.321
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:02.321
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:02.461
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:02.461
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:02.461
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:02.461
SC DTC Delayed Exchange Data | Failed connections: 9476 | 2024-03-17 10:40:02.461
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:02.461
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:02.462
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:02.462
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:02.462
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:02.462
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:02.606
DTC Client socket (3) | Closed. | 2024-03-17 10:40:02.606
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:40:04.459
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:04.461
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:04.461
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:40:04.462
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:04.598
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:04.598
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:04.598
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:04.752
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:04.752
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:04.923
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:04.923
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:04.923
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:04.923
SC DTC Delayed Exchange Data | Failed connections: 9477 | 2024-03-17 10:40:04.923
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:04.923
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:04.924
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:04.924
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:04.924
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:04.924
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:05.053
DTC Client socket (3) | Closed. | 2024-03-17 10:40:05.054
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:06.923
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:06.924
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:06.924
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:40:06.924
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:07.063
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:07.063
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:07.063
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:07.339
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:07.339
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:07.513
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:07.513
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:07.513
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:07.513
SC DTC Delayed Exchange Data | Failed connections: 9478 | 2024-03-17 10:40:07.513
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:07.513
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:07.514
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:07.514
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:07.515
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:07.515
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:07.653
DTC Client socket (3) | Closed. | 2024-03-17 10:40:07.653
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:40:09.535
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:09.536
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:09.536
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:40:09.536
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:09.678
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:09.678
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:09.678
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:09.827
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:09.827
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:09.976
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:09.976
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:09.976
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:09.976
SC DTC Delayed Exchange Data | Failed connections: 9479 | 2024-03-17 10:40:09.976
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:09.976
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:09.977
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:09.977
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:09.977
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:09.977
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:10.116
DTC Client socket (3) | Closed. | 2024-03-17 10:40:10.116
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:40:11.971
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:11.972
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:11.972
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:40:11.972
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:12.115
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:12.115
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:12.115
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:12.469
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:12.469
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Failed connections: 9480 | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:12.629
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:12.629
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:12.629
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:12.629
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:12.823
DTC Client socket (3) | Closed. | 2024-03-17 10:40:12.823
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:40:14.630
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:14.631
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:14.631
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:40:14.631
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:14.774
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:14.774
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:14.774
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:15.065
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:15.065
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:15.204
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:15.204
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:15.204
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:15.204
SC DTC Delayed Exchange Data | Failed connections: 9481 | 2024-03-17 10:40:15.204
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:15.204
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:15.205
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:15.205
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:15.205
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:15.205
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:15.373
DTC Client socket (3) | Closed. | 2024-03-17 10:40:15.373
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:17.225
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:17.225
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:17.225
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:40:17.225
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:17.377
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:17.377
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:17.377
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:17.546
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:17.546
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:17.688
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:17.688
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:17.688
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:17.688
SC DTC Delayed Exchange Data | Failed connections: 9482 | 2024-03-17 10:40:17.688
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:17.688
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:17.689
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:17.689
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:17.689
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:17.689
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:17.833
DTC Client socket (3) | Closed. | 2024-03-17 10:40:17.833
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:19.697
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:19.699
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:19.699
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:40:19.699
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:19.835
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:19.835
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:19.835
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:19.999
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:19.999
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:20.136
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:20.136
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:20.136
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:20.136
SC DTC Delayed Exchange Data | Failed connections: 9483 | 2024-03-17 10:40:20.136
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:20.136
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:20.137
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:20.137
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:20.137
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:20.137
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:20.272
DTC Client socket (3) | Closed. | 2024-03-17 10:40:20.273
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:22.147
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:22.149
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:22.150
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:40:22.150
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:22.296
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:22.296
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:22.296
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:22.458
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:22.458
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:22.593
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:22.593
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:22.593
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:22.593
SC DTC Delayed Exchange Data | Failed connections: 9484 | 2024-03-17 10:40:22.593
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:22.593
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:22.594
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:22.594
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:22.594
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:22.594
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:22.732
DTC Client socket (3) | Closed. | 2024-03-17 10:40:22.732
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:40:24.612
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:24.614
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:24.614
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:40:24.614
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:24.758
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:24.758
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:24.758
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:24.918
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:24.918
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:25.054
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:25.054
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:25.054
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:25.054
SC DTC Delayed Exchange Data | Failed connections: 9485 | 2024-03-17 10:40:25.054
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:25.054
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:25.055
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:25.055
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:25.055
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:25.055
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:25.192
DTC Client socket (3) | Closed. | 2024-03-17 10:40:25.193
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:40:27.071
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:27.072
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:27.072
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:40:27.072
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:27.269
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:27.269
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:27.269
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:27.490
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:27.490
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:27.668
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:27.668
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:27.668
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:27.668
SC DTC Delayed Exchange Data | Failed connections: 9486 | 2024-03-17 10:40:27.668
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:27.668
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:27.669
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:27.669
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:27.669
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:27.669
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:27.862
DTC Client socket (3) | Closed. | 2024-03-17 10:40:27.862
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:40:29.668
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:29.670
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:29.670
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:40:29.670
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:29.804
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:29.804
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:29.804
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:29.967
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:29.967
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:30.106
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:30.106
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:30.106
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:30.106
SC DTC Delayed Exchange Data | Failed connections: 9487 | 2024-03-17 10:40:30.106
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:30.106
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:30.107
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:30.107
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:30.107
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:30.107
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:30.243
DTC Client socket (3) | Closed. | 2024-03-17 10:40:30.243
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:40:32.128
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:32.129
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:32.129
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:40:32.130
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:32.276
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:32.276
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:32.277
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:32.435
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:32.435
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:32.576
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:32.576
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:32.576
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:32.576
SC DTC Delayed Exchange Data | Failed connections: 9488 | 2024-03-17 10:40:32.576
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:32.576
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:32.578
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:32.578
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:32.578
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:32.579
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:32.727
DTC Client socket (3) | Closed. | 2024-03-17 10:40:32.727
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:34.598
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:34.600
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:34.601
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:40:34.601
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:34.745
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:34.745
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:34.745
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:34.974
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:34.974
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:35.113
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:35.113
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:35.113
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:35.113
SC DTC Delayed Exchange Data | Failed connections: 9489 | 2024-03-17 10:40:35.113
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:35.113
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:35.115
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:35.115
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:35.115
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:35.115
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:35.264
DTC Client socket (3) | Closed. | 2024-03-17 10:40:35.264
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:40:37.121
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:37.123
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:37.124
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:40:37.124
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:37.268
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:37.268
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:37.268
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:37.436
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:37.436
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Failed connections: 9490 | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:37.574
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:37.574
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:37.574
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:37.574
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:37.715
DTC Client socket (3) | Closed. | 2024-03-17 10:40:37.715
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:40:39.602
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:39.603
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:39.603
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:40:39.603
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:39.747
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:39.747
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:39.747
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:40.007
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:40.008
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:40.146
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:40.146
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:40.146
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:40.146
SC DTC Delayed Exchange Data | Failed connections: 9491 | 2024-03-17 10:40:40.146
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:40.146
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:40.148
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:40.148
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:40.148
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:40.148
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:40.292
DTC Client socket (3) | Closed. | 2024-03-17 10:40:40.292
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:40:42.141
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:42.143
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:42.143
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:40:42.143
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:42.286
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:42.286
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:42.286
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:42.585
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:42.585
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:42.722
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:42.722
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:42.722
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:42.722
SC DTC Delayed Exchange Data | Failed connections: 9492 | 2024-03-17 10:40:42.722
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:42.722
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:42.723
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:42.723
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:42.723
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:42.723
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:42.862
DTC Client socket (3) | Closed. | 2024-03-17 10:40:42.862
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:44.737
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:44.739
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:44.739
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:40:44.739
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:44.874
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:44.874
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:44.874
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:45.008
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:45.008
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:45.155
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:45.155
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:45.155
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:45.155
SC DTC Delayed Exchange Data | Failed connections: 9493 | 2024-03-17 10:40:45.155
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:45.156
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:45.156
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:45.156
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:45.156
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:45.157
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:45.291
DTC Client socket (3) | Closed. | 2024-03-17 10:40:45.292
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:47.169
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:47.171
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:47.171
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:40:47.171
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:47.318
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:47.318
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:47.318
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:47.487
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:47.487
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:47.623
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Failed connections: 9494 | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:47.624
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:47.624
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:47.624
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:47.624
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:47.774
DTC Client socket (3) | Closed. | 2024-03-17 10:40:47.774
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:40:49.621
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:49.622
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:49.622
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:40:49.622
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:49.755
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:49.755
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:49.755
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:49.929
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:49.929
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:50.071
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:50.071
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:50.071
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:50.071
SC DTC Delayed Exchange Data | Failed connections: 9495 | 2024-03-17 10:40:50.071
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:50.071
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:50.072
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:50.072
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:50.072
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:50.072
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:50.211
DTC Client socket (3) | Closed. | 2024-03-17 10:40:50.211
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:40:52.097
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:52.098
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:52.098
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:40:52.098
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:52.243
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:52.243
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:52.244
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:52.397
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:52.397
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:52.547
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:52.547
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:52.547
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:52.547
SC DTC Delayed Exchange Data | Failed connections: 9496 | 2024-03-17 10:40:52.547
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:52.547
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:52.548
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:52.548
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:52.548
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:52.548
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:52.691
DTC Client socket (3) | Closed. | 2024-03-17 10:40:52.691
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:40:54.556
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:54.557
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:54.558
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:40:54.558
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:54.759
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:54.759
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:54.759
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:54.946
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:54.946
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:55.135
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:55.135
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:55.135
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:40:55.135
SC DTC Delayed Exchange Data | Failed connections: 9497 | 2024-03-17 10:40:55.135
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:55.135
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:55.136
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:55.136
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:55.136
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:55.136
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:55.322
DTC Client socket (3) | Closed. | 2024-03-17 10:40:55.322
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:40:57.148
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:57.149
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:57.149
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:40:57.149
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:57.295
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:57.295
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:57.295
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:57.469
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:57.469
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:40:57.606
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:40:57.606
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:40:57.606
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:40:57.606
SC DTC Delayed Exchange Data | Failed connections: 9498 | 2024-03-17 10:40:57.606
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:40:57.606
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:40:57.607
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:40:57.607
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:40:57.607
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:40:57.607
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:40:57.751
DTC Client socket (3) | Closed. | 2024-03-17 10:40:57.751
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:40:59.630
DTC Client socket (3) | Creating socket. | 2024-03-17 10:40:59.632
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:40:59.632
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:40:59.632
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:40:59.776
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:40:59.776
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:40:59.776
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:40:59.944
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:40:59.944
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:00.092
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:00.092
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:00.092
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:00.092
SC DTC Delayed Exchange Data | Failed connections: 9499 | 2024-03-17 10:41:00.092
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:00.092
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:00.093
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:00.093
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:00.093
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:00.094
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:00.231
DTC Client socket (3) | Closed. | 2024-03-17 10:41:00.232
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:02.114
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:02.115
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:02.115
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:41:02.115
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:02.350
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:02.350
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:02.350
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:02.627
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:02.627
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:02.778
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:02.778
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:02.778
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:02.778
SC DTC Delayed Exchange Data | Failed connections: 9500 | 2024-03-17 10:41:02.778
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:02.778
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:02.779
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:02.779
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:02.779
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:02.779
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:02.962
DTC Client socket (3) | Closed. | 2024-03-17 10:41:02.963
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:41:04.827
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:04.828
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:04.828
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:41:04.828
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:05.016
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:05.016
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:05.016
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:05.156
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:05.156
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:05.304
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:05.304
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:05.304
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:05.304
SC DTC Delayed Exchange Data | Failed connections: 9501 | 2024-03-17 10:41:05.304
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:05.304
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:05.305
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:05.305
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:05.305
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:05.305
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:05.441
DTC Client socket (3) | Closed. | 2024-03-17 10:41:05.441
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:41:07.312
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:07.313
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:07.313
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:41:07.314
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:07.464
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:07.464
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:07.465
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:07.942
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:07.942
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Failed connections: 9502 | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:08.127
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:08.127
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:08.127
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:08.127
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:08.262
DTC Client socket (3) | Closed. | 2024-03-17 10:41:08.262
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:41:10.134
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:10.135
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:10.135
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:41:10.135
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:10.284
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:10.284
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:10.284
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:10.486
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:10.486
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:10.640
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:10.640
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:10.640
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:10.640
SC DTC Delayed Exchange Data | Failed connections: 9503 | 2024-03-17 10:41:10.640
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:10.640
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:10.641
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:10.641
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:10.641
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:10.641
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:10.780
DTC Client socket (3) | Closed. | 2024-03-17 10:41:10.780
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:12.648
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:12.650
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:12.650
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:41:12.650
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:12.797
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:12.797
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:12.797
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:12.973
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:12.973
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:13.114
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:13.114
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:13.114
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:13.114
SC DTC Delayed Exchange Data | Failed connections: 9504 | 2024-03-17 10:41:13.114
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:13.114
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:13.115
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:13.115
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:13.115
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:13.115
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:13.250
DTC Client socket (3) | Closed. | 2024-03-17 10:41:13.250
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:15.116
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:15.118
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:15.118
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:41:15.118
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:15.265
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:15.265
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:15.265
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:15.428
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:15.428
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:15.568
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:15.568
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:15.568
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:15.568
SC DTC Delayed Exchange Data | Failed connections: 9505 | 2024-03-17 10:41:15.568
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:15.568
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:15.569
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:15.569
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:15.569
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:15.569
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:15.700
DTC Client socket (3) | Closed. | 2024-03-17 10:41:15.700
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:17.588
DTC Client socket (3) | Creating socket. | 2024-03-17 10:41:17.589
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:41:17.589
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:41:17.589
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:17.732
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:17.732
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:17.732
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:17.875
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:17.875
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:18.006
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:18.006
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:18.006
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:18.006
SC DTC Delayed Exchange Data | Failed connections: 9506 | 2024-03-17 10:41:18.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:18.006
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:41:18.006
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:18.007
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:18.007
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:18.007
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:41:18.149
DTC Client socket (3) | Closed. | 2024-03-17 10:41:18.149
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:41:20.002
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:20.003
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:20.003
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:41:20.003
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:20.156
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:20.156
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:20.156
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:20.322
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:20.322
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:20.459
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:20.459
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:20.459
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:20.459
SC DTC Delayed Exchange Data | Failed connections: 9507 | 2024-03-17 10:41:20.459
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:20.459
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:20.460
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:20.460
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:20.460
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:20.460
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:20.600
DTC Client socket (1) | Closed. | 2024-03-17 10:41:20.600
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:41:22.463
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:22.464
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:22.465
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:41:22.465
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:22.654
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:22.654
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:22.654
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:22.843
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:22.843
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:23.031
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:23.031
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:23.032
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:23.032
SC DTC Delayed Exchange Data | Failed connections: 9508 | 2024-03-17 10:41:23.032
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:23.032
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:23.032
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:23.032
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:23.032
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:23.033
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:23.220
DTC Client socket (1) | Closed. | 2024-03-17 10:41:23.220
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:41:25.049
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:25.091
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:25.091
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:41:25.091
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:25.235
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:25.235
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:25.236
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:25.395
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:25.395
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:25.539
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:25.539
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:25.539
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:25.539
SC DTC Delayed Exchange Data | Failed connections: 9509 | 2024-03-17 10:41:25.539
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:25.539
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:25.540
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:25.540
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:25.540
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:25.540
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:25.680
DTC Client socket (1) | Closed. | 2024-03-17 10:41:25.680
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:41:27.548
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:27.549
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:27.549
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:41:27.549
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:27.694
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:27.694
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:27.694
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:27.835
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:27.835
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:27.972
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:27.972
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:27.972
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:27.972
SC DTC Delayed Exchange Data | Failed connections: 9510 | 2024-03-17 10:41:27.972
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:27.972
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:27.973
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:27.973
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:27.973
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:27.973
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:28.114
DTC Client socket (1) | Closed. | 2024-03-17 10:41:28.114
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:29.974
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:29.975
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:29.975
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:41:29.975
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:30.127
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:30.127
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:30.127
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:30.375
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:30.375
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:30.524
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:30.524
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:30.524
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:30.524
SC DTC Delayed Exchange Data | Failed connections: 9511 | 2024-03-17 10:41:30.524
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:30.524
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:30.525
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:30.525
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:30.525
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:30.525
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:30.671
DTC Client socket (1) | Closed. | 2024-03-17 10:41:30.672
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:41:32.532
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:32.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:32.534
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:41:32.534
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:32.686
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:32.686
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:32.686
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:32.843
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:32.843
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:32.991
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:32.991
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:32.991
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:32.991
SC DTC Delayed Exchange Data | Failed connections: 9512 | 2024-03-17 10:41:32.991
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:32.991
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:32.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:32.992
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:32.992
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:32.992
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:33.132
DTC Client socket (1) | Closed. | 2024-03-17 10:41:33.132
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:41:34.991
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:34.991
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:34.992
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:41:34.992
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:35.130
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:35.130
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:35.130
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:35.332
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:35.332
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:35.582
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:35.582
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:35.582
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:35.582
SC DTC Delayed Exchange Data | Failed connections: 9513 | 2024-03-17 10:41:35.582
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:35.582
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:35.583
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:35.583
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:35.583
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:35.583
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:35.719
DTC Client socket (1) | Closed. | 2024-03-17 10:41:35.719
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:41:37.603
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:37.605
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:37.605
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:41:37.605
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:37.751
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:37.751
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:37.752
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:37.984
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:37.984
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Failed connections: 9514 | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:38.264
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:38.264
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:38.264
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:38.265
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:38.409
DTC Client socket (1) | Closed. | 2024-03-17 10:41:38.409
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:40.297
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:40.331
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:40.331
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:41:40.331
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:40.470
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:40.470
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:40.470
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:40.615
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:40.615
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:40.765
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:40.765
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:40.765
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:40.765
SC DTC Delayed Exchange Data | Failed connections: 9515 | 2024-03-17 10:41:40.765
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:40.765
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:40.766
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:40.766
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:40.766
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:40.766
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:40.899
DTC Client socket (1) | Closed. | 2024-03-17 10:41:40.899
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:42.766
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:42.804
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:42.804
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:41:42.804
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:42.949
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:42.949
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:42.949
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:43.085
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:43.085
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:43.218
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:43.218
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:43.218
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:43.218
SC DTC Delayed Exchange Data | Failed connections: 9516 | 2024-03-17 10:41:43.218
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:43.218
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:43.219
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:43.220
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:43.220
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:43.220
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:43.360
DTC Client socket (1) | Closed. | 2024-03-17 10:41:43.360
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:45.222
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:45.222
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:45.223
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:41:45.223
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:45.364
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:45.364
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:45.365
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:45.531
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:45.531
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:45.671
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:45.671
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:45.671
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:45.671
SC DTC Delayed Exchange Data | Failed connections: 9517 | 2024-03-17 10:41:45.671
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:45.671
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:45.673
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:45.673
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:45.673
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:45.673
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:45.809
DTC Client socket (1) | Closed. | 2024-03-17 10:41:45.809
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:41:47.693
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:47.695
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:47.695
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:41:47.695
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:47.846
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:47.846
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:47.846
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:48.004
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:48.004
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:48.142
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:48.142
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:48.142
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:48.142
SC DTC Delayed Exchange Data | Failed connections: 9518 | 2024-03-17 10:41:48.142
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:48.142
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:48.143
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:48.143
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:48.143
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:48.143
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:48.282
DTC Client socket (1) | Closed. | 2024-03-17 10:41:48.282
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:41:50.140
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:50.141
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:50.142
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:41:50.142
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:50.331
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:50.331
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:50.331
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:50.524
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:50.524
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:50.721
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:50.721
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:50.721
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:50.721
SC DTC Delayed Exchange Data | Failed connections: 9519 | 2024-03-17 10:41:50.721
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:50.721
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:50.722
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:50.722
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:50.722
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:50.723
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:50.911
DTC Client socket (1) | Closed. | 2024-03-17 10:41:50.911
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:41:52.720
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:52.721
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:52.722
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:41:52.722
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:52.872
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:52.872
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:52.872
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:53.056
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:53.056
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:53.196
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:53.196
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:53.196
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:53.196
SC DTC Delayed Exchange Data | Failed connections: 9520 | 2024-03-17 10:41:53.196
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:53.196
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:53.197
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:53.197
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:53.197
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:53.197
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:53.338
DTC Client socket (1) | Closed. | 2024-03-17 10:41:53.338
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:41:55.210
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:55.211
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:55.211
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:41:55.211
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:55.351
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:55.351
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:55.352
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:55.482
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:55.482
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:55.616
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:55.616
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:55.616
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:41:55.616
SC DTC Delayed Exchange Data | Failed connections: 9521 | 2024-03-17 10:41:55.616
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:55.616
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:55.617
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:55.617
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:55.617
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:55.617
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:55.749
DTC Client socket (1) | Closed. | 2024-03-17 10:41:55.750
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:41:57.619
DTC Client socket (1) | Creating socket. | 2024-03-17 10:41:57.620
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:41:57.620
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:41:57.620
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:41:57.762
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:41:57.762
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:41:57.762
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:41:58.104
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:41:58.104
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:41:58.234
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:41:58.234
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:41:58.234
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:41:58.234
SC DTC Delayed Exchange Data | Failed connections: 9522 | 2024-03-17 10:41:58.234
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:41:58.234
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:41:58.235
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:41:58.235
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:41:58.235
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:41:58.235
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:41:58.418
DTC Client socket (1) | Closed. | 2024-03-17 10:41:58.418
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:42:00.245
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:00.248
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:00.248
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:42:00.248
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:00.383
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:00.383
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:00.383
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:00.521
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:00.521
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:00.654
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:00.654
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:00.654
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:00.654
SC DTC Delayed Exchange Data | Failed connections: 9523 | 2024-03-17 10:42:00.654
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:00.654
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:00.655
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:00.655
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:00.655
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:00.655
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:00.788
DTC Client socket (1) | Closed. | 2024-03-17 10:42:00.788
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:42:02.669
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:02.671
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:02.671
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:42:02.671
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:02.823
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:02.823
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:02.823
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:03.243
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:03.243
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Failed connections: 9524 | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:03.369
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:03.369
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:03.369
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:03.369
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:03.508
DTC Client socket (1) | Closed. | 2024-03-17 10:42:03.508
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:42:05.369
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:05.371
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:05.371
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:42:05.371
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:05.519
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:05.519
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:05.519
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:05.745
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:05.745
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:05.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:05.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:05.879
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:05.879
SC DTC Delayed Exchange Data | Failed connections: 9525 | 2024-03-17 10:42:05.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:05.879
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:05.880
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:05.880
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:05.880
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:05.880
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:06.018
DTC Client socket (1) | Closed. | 2024-03-17 10:42:06.018
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:07.881
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:07.883
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:07.883
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:42:07.884
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:08.031
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:08.031
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:08.032
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:08.175
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:08.175
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:08.313
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:08.313
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:08.314
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:08.314
SC DTC Delayed Exchange Data | Failed connections: 9526 | 2024-03-17 10:42:08.314
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:08.314
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:08.314
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:08.315
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:08.315
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:08.315
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:08.460
DTC Client socket (1) | Closed. | 2024-03-17 10:42:08.460
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:10.319
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:10.320
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:10.320
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:42:10.320
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:10.462
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:10.462
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:10.462
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:10.631
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:10.631
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:10.775
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:10.775
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:10.775
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:10.775
SC DTC Delayed Exchange Data | Failed connections: 9527 | 2024-03-17 10:42:10.775
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:10.775
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:10.776
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:10.776
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:10.776
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:10.776
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:10.908
DTC Client socket (1) | Closed. | 2024-03-17 10:42:10.908
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:12.764
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:12.765
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:12.765
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:42:12.765
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:12.912
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:12.912
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:12.912
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:13.055
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:13.055
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:13.190
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:13.190
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:13.190
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:13.190
SC DTC Delayed Exchange Data | Failed connections: 9528 | 2024-03-17 10:42:13.190
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:13.190
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:13.191
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:13.191
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:13.191
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:13.192
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:13.328
DTC Client socket (1) | Closed. | 2024-03-17 10:42:13.328
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:42:15.207
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:15.209
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:15.209
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:42:15.209
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:15.361
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:15.361
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:15.362
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:15.534
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:15.534
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:15.675
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:15.675
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:15.675
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:15.675
SC DTC Delayed Exchange Data | Failed connections: 9529 | 2024-03-17 10:42:15.675
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:15.675
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:15.676
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:15.676
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:15.676
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:15.676
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:15.818
DTC Client socket (1) | Closed. | 2024-03-17 10:42:15.818
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:42:17.667
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:17.668
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:17.668
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:42:17.668
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:17.860
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:17.860
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:17.860
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:18.055
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:18.055
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:18.253
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:18.253
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:18.253
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:18.253
SC DTC Delayed Exchange Data | Failed connections: 9530 | 2024-03-17 10:42:18.253
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:18.253
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:18.254
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:18.254
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:18.254
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:18.254
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:18.439
DTC Client socket (1) | Closed. | 2024-03-17 10:42:18.439
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:42:20.271
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:20.272
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:20.272
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:42:20.272
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:20.411
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:20.411
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:20.411
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:20.573
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:20.573
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:20.707
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:20.707
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:20.707
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:20.707
SC DTC Delayed Exchange Data | Failed connections: 9531 | 2024-03-17 10:42:20.707
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:20.707
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:20.708
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:20.708
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:20.708
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:20.708
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:20.847
DTC Client socket (1) | Closed. | 2024-03-17 10:42:20.848
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:42:22.703
DTC Client socket (1) | Creating socket. | 2024-03-17 10:42:22.703
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:42:22.703
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:42:22.703
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:22.839
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:22.839
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:22.839
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:23.012
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:23.012
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Failed connections: 9532 | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:23.154
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:23.154
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:23.154
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:23.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:42:23.289
DTC Client socket (1) | Closed. | 2024-03-17 10:42:23.290
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:25.179
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:25.236
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:25.236
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:42:25.236
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:25.380
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:25.380
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:25.380
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:25.623
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:25.623
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Failed connections: 9533 | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:25.759
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:25.759
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:25.759
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:25.760
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:25.897
DTC Client socket (2) | Closed. | 2024-03-17 10:42:25.897
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:42:27.753
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:27.755
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:27.755
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:42:27.755
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:27.899
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:27.899
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:27.899
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:28.073
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:28.073
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:28.219
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:28.219
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:28.219
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:28.219
SC DTC Delayed Exchange Data | Failed connections: 9534 | 2024-03-17 10:42:28.219
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:28.219
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:28.220
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:28.220
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:28.220
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:28.220
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:28.357
DTC Client socket (2) | Closed. | 2024-03-17 10:42:28.357
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:42:30.227
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:30.228
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:30.228
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:42:30.228
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:30.387
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:30.387
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:30.387
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:30.745
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:30.745
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:30.886
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:30.886
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:30.886
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:30.886
SC DTC Delayed Exchange Data | Failed connections: 9535 | 2024-03-17 10:42:30.886
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:30.886
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:30.887
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:30.887
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:30.887
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:30.887
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:31.097
DTC Client socket (2) | Closed. | 2024-03-17 10:42:31.097
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:42:32.905
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:32.906
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:32.906
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:42:32.906
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:33.048
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:33.048
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:33.048
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:33.262
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:33.262
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:33.397
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:33.397
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:33.397
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:33.397
SC DTC Delayed Exchange Data | Failed connections: 9536 | 2024-03-17 10:42:33.397
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:33.397
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:33.398
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:33.398
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:33.398
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:33.399
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:33.536
DTC Client socket (2) | Closed. | 2024-03-17 10:42:33.536
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:35.385
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:35.386
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:35.387
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:42:35.387
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:35.532
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:35.532
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:35.532
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:35.693
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:35.693
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:35.828
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Failed connections: 9537 | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:35.829
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:35.829
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:35.829
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:35.829
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:35.975
DTC Client socket (2) | Closed. | 2024-03-17 10:42:35.975
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:37.831
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:37.832
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:37.832
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:42:37.832
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:37.969
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:37.969
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:37.969
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:38.141
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:38.141
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:38.273
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:38.273
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:38.273
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:38.273
SC DTC Delayed Exchange Data | Failed connections: 9538 | 2024-03-17 10:42:38.273
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:38.273
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:38.274
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:38.274
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:38.274
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:38.274
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:38.407
DTC Client socket (2) | Closed. | 2024-03-17 10:42:38.407
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:40.278
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:40.279
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:40.279
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:42:40.279
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:40.439
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:40.439
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:40.440
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:40.581
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:40.581
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:40.708
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:40.708
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:40.708
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:40.708
SC DTC Delayed Exchange Data | Failed connections: 9539 | 2024-03-17 10:42:40.708
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:40.708
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:40.709
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:40.709
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:40.709
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:40.709
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:40.856
DTC Client socket (2) | Closed. | 2024-03-17 10:42:40.856
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:42:42.700
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:42.701
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:42.701
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:42:42.701
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:42.854
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:42.854
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:42.854
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:43.032
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:43.032
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Failed connections: 9540 | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:43.165
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:43.165
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:43.166
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:43.166
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:43.306
DTC Client socket (2) | Closed. | 2024-03-17 10:42:43.306
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:42:45.181
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:45.182
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:45.182
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:42:45.182
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:45.370
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:45.370
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:45.370
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:45.562
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:45.562
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:45.759
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:45.759
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:45.759
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:45.759
SC DTC Delayed Exchange Data | Failed connections: 9541 | 2024-03-17 10:42:45.759
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:45.759
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:45.760
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:45.760
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:45.760
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:45.760
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:45.946
DTC Client socket (2) | Closed. | 2024-03-17 10:42:45.946
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:42:47.757
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:47.758
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:47.758
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:42:47.758
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:47.897
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:47.897
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:47.898
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:48.034
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:48.034
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:48.182
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:48.182
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:48.182
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:48.182
SC DTC Delayed Exchange Data | Failed connections: 9542 | 2024-03-17 10:42:48.182
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:48.183
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:48.183
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:48.183
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:48.183
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:48.184
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:48.319
DTC Client socket (2) | Closed. | 2024-03-17 10:42:48.319
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:42:50.204
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:50.205
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:50.206
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:42:50.206
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:50.360
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:50.360
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:50.360
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:50.541
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:50.541
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:50.685
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:50.685
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:50.685
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:50.685
SC DTC Delayed Exchange Data | Failed connections: 9543 | 2024-03-17 10:42:50.685
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:50.685
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:50.686
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:50.686
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:50.686
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:50.686
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:50.826
DTC Client socket (2) | Closed. | 2024-03-17 10:42:50.826
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:42:52.711
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:52.712
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:52.712
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:42:52.712
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:52.849
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:52.849
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:52.849
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:53.132
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:53.132
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:53.270
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:53.270
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:53.270
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:53.270
SC DTC Delayed Exchange Data | Failed connections: 9544 | 2024-03-17 10:42:53.270
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:53.270
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:53.271
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:53.271
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:53.271
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:53.271
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:53.406
DTC Client socket (2) | Closed. | 2024-03-17 10:42:53.406
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:42:55.290
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:55.291
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:55.291
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:42:55.292
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:55.430
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:55.430
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:55.430
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:55.571
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:55.572
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:55.718
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:55.718
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:55.718
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:42:55.718
SC DTC Delayed Exchange Data | Failed connections: 9545 | 2024-03-17 10:42:55.718
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:55.718
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:55.719
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:55.719
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:55.719
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:55.719
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:55.865
DTC Client socket (2) | Closed. | 2024-03-17 10:42:55.866
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:42:57.715
DTC Client socket (2) | Creating socket. | 2024-03-17 10:42:57.716
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:42:57.717
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:42:57.717
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:42:57.868
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:42:57.868
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:42:57.869
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:42:58.091
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:42:58.091
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Failed connections: 9546 | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:42:58.257
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:42:58.257
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:42:58.257
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:42:58.258
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:42:58.425
DTC Client socket (2) | Closed. | 2024-03-17 10:42:58.425
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:43:00.260
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:00.261
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:00.261
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:43:00.261
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:00.402
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:00.402
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:00.402
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:00.611
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:00.611
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:00.751
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:00.751
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:00.751
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:00.751
SC DTC Delayed Exchange Data | Failed connections: 9547 | 2024-03-17 10:43:00.751
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:00.751
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:00.752
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:00.752
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:00.752
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:00.752
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:00.906
DTC Client socket (2) | Closed. | 2024-03-17 10:43:00.906
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:02.759
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:02.760
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:02.760
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:43:02.760
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:02.900
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:02.900
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:02.900
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:03.038
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:03.038
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:03.183
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:03.183
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:03.183
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:03.183
SC DTC Delayed Exchange Data | Failed connections: 9548 | 2024-03-17 10:43:03.183
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:03.183
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:03.184
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:03.184
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:03.184
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:03.184
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:03.327
DTC Client socket (2) | Closed. | 2024-03-17 10:43:03.327
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:05.205
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:05.206
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:05.206
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:43:05.206
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:05.349
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:05.349
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:05.349
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:05.488
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:05.488
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:05.639
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:05.639
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:05.639
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:05.639
SC DTC Delayed Exchange Data | Failed connections: 9549 | 2024-03-17 10:43:05.639
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:05.639
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:05.640
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:05.640
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:05.640
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:05.640
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:05.775
DTC Client socket (2) | Closed. | 2024-03-17 10:43:05.776
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:07.661
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:07.662
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:07.662
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:43:07.662
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:07.799
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:07.799
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:07.799
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:07.961
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:07.961
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:08.099
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:08.099
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:08.099
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:08.099
SC DTC Delayed Exchange Data | Failed connections: 9550 | 2024-03-17 10:43:08.099
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:08.099
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:08.100
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:08.100
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:08.100
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:08.101
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:08.235
DTC Client socket (2) | Closed. | 2024-03-17 10:43:08.235
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:43:10.089
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:10.090
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:10.090
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:43:10.090
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:10.220
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:10.220
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:10.220
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:10.371
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:10.371
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:10.520
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:10.521
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:10.521
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:10.521
SC DTC Delayed Exchange Data | Failed connections: 9551 | 2024-03-17 10:43:10.521
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:10.521
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:10.521
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:10.522
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:10.522
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:10.522
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:10.665
DTC Client socket (2) | Closed. | 2024-03-17 10:43:10.666
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:43:12.517
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:12.519
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:12.519
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:43:12.519
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:12.719
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:12.719
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:12.720
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:12.933
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:12.933
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:13.125
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:13.125
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:13.125
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:13.125
SC DTC Delayed Exchange Data | Failed connections: 9552 | 2024-03-17 10:43:13.125
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:13.125
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:13.126
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:13.126
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:13.126
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:13.126
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:13.315
DTC Client socket (2) | Closed. | 2024-03-17 10:43:13.315
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:43:15.130
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:15.131
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:15.131
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:43:15.131
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:15.269
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:15.269
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:15.269
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:15.451
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:15.451
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:15.587
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:15.587
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:15.587
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:15.587
SC DTC Delayed Exchange Data | Failed connections: 9553 | 2024-03-17 10:43:15.587
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:15.588
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:15.588
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:15.588
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:15.588
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:15.589
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:15.725
DTC Client socket (2) | Closed. | 2024-03-17 10:43:15.725
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:43:17.587
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:17.588
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:17.588
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:43:17.589
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:17.727
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:17.727
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:17.727
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:17.873
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:17.873
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:18.023
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:18.023
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:18.023
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:18.023
SC DTC Delayed Exchange Data | Failed connections: 9554 | 2024-03-17 10:43:18.023
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:18.023
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:18.024
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:18.024
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:18.024
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:18.024
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:18.165
DTC Client socket (2) | Closed. | 2024-03-17 10:43:18.165
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:20.020
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:20.021
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:20.021
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:43:20.021
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:20.170
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:20.170
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:20.170
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:20.460
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:20.460
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:20.618
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:20.618
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:20.618
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:20.618
SC DTC Delayed Exchange Data | Failed connections: 9555 | 2024-03-17 10:43:20.618
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:20.618
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:20.619
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:20.619
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:20.619
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:20.619
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:20.777
DTC Client socket (2) | Closed. | 2024-03-17 10:43:20.777
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:43:22.620
DTC Client socket (2) | Creating socket. | 2024-03-17 10:43:22.622
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:43:22.622
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:43:22.622
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:22.769
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:22.769
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:22.770
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:22.931
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:22.931
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:23.075
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:23.075
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:23.075
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:23.075
SC DTC Delayed Exchange Data | Failed connections: 9556 | 2024-03-17 10:43:23.075
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:23.075
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:43:23.076
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:23.076
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:23.076
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:23.076
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:43:23.215
DTC Client socket (2) | Closed. | 2024-03-17 10:43:23.215
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:43:25.101
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:25.103
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:25.103
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:43:25.103
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:25.236
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:25.236
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:25.236
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:25.530
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:25.530
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:25.666
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:25.666
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:25.666
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:25.666
SC DTC Delayed Exchange Data | Failed connections: 9557 | 2024-03-17 10:43:25.666
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:25.666
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:25.667
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:25.667
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:25.667
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:25.667
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:25.804
DTC Client socket (3) | Closed. | 2024-03-17 10:43:25.804
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:43:27.677
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:27.679
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:27.679
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:43:27.679
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:27.823
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:27.823
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:27.823
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:28.090
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:28.090
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:28.262
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:28.262
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:28.262
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:28.262
SC DTC Delayed Exchange Data | Failed connections: 9558 | 2024-03-17 10:43:28.262
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:28.262
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:28.263
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:28.263
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:28.263
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:28.263
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:28.424
DTC Client socket (3) | Closed. | 2024-03-17 10:43:28.424
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:30.263
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:30.264
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:30.264
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:43:30.264
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:30.408
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:30.408
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:30.408
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:30.579
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:30.579
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:30.731
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:30.731
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:30.731
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:30.731
SC DTC Delayed Exchange Data | Failed connections: 9559 | 2024-03-17 10:43:30.731
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:30.731
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:30.732
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:30.732
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:30.732
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:30.732
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:30.874
DTC Client socket (3) | Closed. | 2024-03-17 10:43:30.874
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:32.739
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:32.741
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:32.741
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:43:32.741
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:32.888
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:32.888
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:32.888
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:33.049
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:33.049
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:33.196
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:33.196
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:33.196
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:33.196
SC DTC Delayed Exchange Data | Failed connections: 9560 | 2024-03-17 10:43:33.196
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:33.196
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:33.197
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:33.197
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:33.197
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:33.197
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:33.337
DTC Client socket (3) | Closed. | 2024-03-17 10:43:33.337
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:35.200
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:35.201
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:35.201
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:43:35.201
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:35.349
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:35.349
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:35.349
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:35.529
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:35.529
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:35.672
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:35.672
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:35.672
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:35.672
SC DTC Delayed Exchange Data | Failed connections: 9561 | 2024-03-17 10:43:35.672
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:35.672
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:35.673
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:35.673
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:35.673
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:35.673
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:35.822
DTC Client socket (3) | Closed. | 2024-03-17 10:43:35.822
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:43:37.692
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:37.694
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:37.694
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:43:37.694
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:37.839
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:37.839
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:37.839
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:38.029
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:38.029
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:38.184
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:38.184
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:38.184
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:38.184
SC DTC Delayed Exchange Data | Failed connections: 9562 | 2024-03-17 10:43:38.184
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:38.184
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:38.185
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:38.185
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:38.185
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:38.185
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:38.326
DTC Client socket (3) | Closed. | 2024-03-17 10:43:38.326
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:43:40.195
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:40.197
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:40.197
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:43:40.197
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:40.389
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:40.389
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:40.389
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:40.609
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:40.609
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:40.811
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:40.811
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:40.811
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:40.811
SC DTC Delayed Exchange Data | Failed connections: 9563 | 2024-03-17 10:43:40.811
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:40.811
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:40.812
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:40.812
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:40.812
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:40.812
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:41.003
DTC Client socket (3) | Closed. | 2024-03-17 10:43:41.003
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:43:42.830
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:42.831
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:42.831
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:43:42.831
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:42.991
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:42.991
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:42.991
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:43.155
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:43.155
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:43.283
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:43.283
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:43.284
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:43.284
SC DTC Delayed Exchange Data | Failed connections: 9564 | 2024-03-17 10:43:43.284
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:43.284
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:43.284
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:43.284
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:43.284
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:43.284
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:43.413
DTC Client socket (3) | Closed. | 2024-03-17 10:43:43.413
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:43:45.299
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:45.300
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:45.300
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:43:45.300
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:45.437
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:45.437
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:45.437
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:45.596
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:45.596
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:45.740
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:45.740
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:45.740
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:45.740
SC DTC Delayed Exchange Data | Failed connections: 9565 | 2024-03-17 10:43:45.740
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:45.740
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:45.741
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:45.741
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:45.741
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:45.741
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:45.884
DTC Client socket (3) | Closed. | 2024-03-17 10:43:45.884
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:47.755
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:47.756
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:47.756
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:43:47.756
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:47.898
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:47.899
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:47.899
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:48.106
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:48.107
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:48.267
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:48.267
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:48.267
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:48.267
SC DTC Delayed Exchange Data | Failed connections: 9566 | 2024-03-17 10:43:48.267
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:48.267
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:48.268
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:48.268
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:48.268
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:48.268
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:48.405
DTC Client socket (3) | Closed. | 2024-03-17 10:43:48.406
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:43:50.263
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:50.264
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:50.264
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:43:50.265
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:50.408
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:50.408
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:50.409
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:50.576
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:50.576
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:50.721
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:50.721
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:50.721
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:50.721
SC DTC Delayed Exchange Data | Failed connections: 9567 | 2024-03-17 10:43:50.721
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:50.721
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:50.722
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:50.722
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:50.722
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:50.722
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:50.863
DTC Client socket (3) | Closed. | 2024-03-17 10:43:50.863
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:43:52.735
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:52.736
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:52.736
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:43:52.736
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:52.877
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:52.877
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:52.877
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:53.274
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:53.274
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Failed connections: 9568 | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:53.424
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:53.424
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:53.424
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:53.424
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:53.595
DTC Client socket (3) | Closed. | 2024-03-17 10:43:53.596
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:43:55.418
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:55.419
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:55.419
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:43:55.419
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:55.565
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:55.565
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:55.565
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:55.816
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:55.816
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:55.955
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:55.955
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:55.955
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:43:55.955
SC DTC Delayed Exchange Data | Failed connections: 9569 | 2024-03-17 10:43:55.955
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:55.955
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:55.956
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:55.956
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:55.956
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:55.956
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:56.093
DTC Client socket (3) | Closed. | 2024-03-17 10:43:56.093
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:43:57.963
DTC Client socket (3) | Creating socket. | 2024-03-17 10:43:57.964
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:43:57.964
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:43:57.964
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:43:58.108
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:43:58.108
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:43:58.108
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:43:58.257
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:43:58.257
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:43:58.402
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:43:58.402
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:43:58.402
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:43:58.403
SC DTC Delayed Exchange Data | Failed connections: 9570 | 2024-03-17 10:43:58.403
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:43:58.403
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:43:58.403
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:43:58.403
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:43:58.403
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:43:58.403
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:43:58.542
DTC Client socket (3) | Closed. | 2024-03-17 10:43:58.542
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:00.426
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:00.427
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:00.427
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:44:00.427
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:00.565
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:00.565
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:00.565
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:00.740
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:00.740
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Failed connections: 9571 | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:00.878
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:00.878
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:00.878
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:00.878
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:01.013
DTC Client socket (3) | Closed. | 2024-03-17 10:44:01.013
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:02.887
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:02.891
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:02.892
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:44:02.892
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:03.036
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:03.036
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:03.036
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:03.205
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:03.205
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:03.352
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:03.352
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:03.352
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:03.352
SC DTC Delayed Exchange Data | Failed connections: 9572 | 2024-03-17 10:44:03.352
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:03.352
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:03.353
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:03.353
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:03.353
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:03.353
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:03.495
DTC Client socket (3) | Closed. | 2024-03-17 10:44:03.495
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:44:05.347
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:05.348
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:05.348
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:44:05.348
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:05.499
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:05.499
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:05.499
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:05.655
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:05.655
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:05.799
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:05.799
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:05.799
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:05.799
SC DTC Delayed Exchange Data | Failed connections: 9573 | 2024-03-17 10:44:05.799
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:05.799
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:05.800
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:05.800
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:05.800
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:05.800
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:05.943
DTC Client socket (3) | Closed. | 2024-03-17 10:44:05.943
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:44:07.810
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:07.811
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:07.811
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:44:07.811
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:08.007
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:08.007
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:08.007
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:08.225
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:08.225
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:08.419
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:08.419
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:08.419
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:08.419
SC DTC Delayed Exchange Data | Failed connections: 9574 | 2024-03-17 10:44:08.419
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:08.419
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:08.420
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:08.420
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:08.420
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:08.421
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:08.613
DTC Client socket (3) | Closed. | 2024-03-17 10:44:08.613
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:44:10.430
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:10.431
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:10.431
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:44:10.431
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:10.575
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:10.575
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:10.575
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:10.747
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:10.747
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:10.892
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:10.892
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:10.892
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:10.892
SC DTC Delayed Exchange Data | Failed connections: 9575 | 2024-03-17 10:44:10.892
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:10.892
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:10.894
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:10.894
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:10.894
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:10.894
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:11.032
DTC Client socket (3) | Closed. | 2024-03-17 10:44:11.033
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:44:12.911
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:12.912
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:12.912
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:44:12.912
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:13.056
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:13.056
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:13.057
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:13.228
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:13.228
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:13.358
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:13.358
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:13.358
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:13.358
SC DTC Delayed Exchange Data | Failed connections: 9576 | 2024-03-17 10:44:13.358
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:13.358
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:13.359
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:13.359
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:13.359
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:13.359
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:13.492
DTC Client socket (3) | Closed. | 2024-03-17 10:44:13.492
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:15.358
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:15.360
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:15.360
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:44:15.360
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:15.507
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:15.507
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:15.507
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:15.758
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:15.758
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:15.900
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:15.900
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:15.900
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:15.900
SC DTC Delayed Exchange Data | Failed connections: 9577 | 2024-03-17 10:44:15.900
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:15.900
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:15.901
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:15.901
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:15.901
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:15.901
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:16.172
DTC Client socket (3) | Closed. | 2024-03-17 10:44:16.172
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:44:17.893
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:17.894
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:17.894
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:44:17.894
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:18.036
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:18.036
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:18.036
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:18.198
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:18.198
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Failed connections: 9578 | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:18.339
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:18.339
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:18.339
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:18.339
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:18.482
DTC Client socket (3) | Closed. | 2024-03-17 10:44:18.482
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:44:20.345
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:20.346
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:20.346
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:44:20.346
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:20.487
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:20.487
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:20.487
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:20.865
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:20.865
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:21.172
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:21.172
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:21.173
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:21.173
SC DTC Delayed Exchange Data | Failed connections: 9579 | 2024-03-17 10:44:21.173
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:21.173
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:21.173
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:21.173
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:21.173
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:21.174
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:21.372
DTC Client socket (3) | Closed. | 2024-03-17 10:44:21.372
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:44:23.179
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:23.180
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:23.180
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:44:23.180
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:23.326
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:23.326
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:23.326
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:23.578
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:23.578
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:23.712
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:23.712
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:23.712
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:23.712
SC DTC Delayed Exchange Data | Failed connections: 9580 | 2024-03-17 10:44:23.712
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:23.712
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:23.713
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:23.713
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:23.713
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:23.714
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:23.894
DTC Client socket (3) | Closed. | 2024-03-17 10:44:23.894
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:25.708
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:25.709
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:25.710
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:44:25.710
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:25.855
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:25.855
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:25.856
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:25.995
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:25.995
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:26.126
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:26.126
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:26.126
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:26.126
SC DTC Delayed Exchange Data | Failed connections: 9581 | 2024-03-17 10:44:26.126
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:26.126
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:26.127
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:26.127
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:26.127
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:26.127
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:26.262
DTC Client socket (3) | Closed. | 2024-03-17 10:44:26.262
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:28.143
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:28.145
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:28.145
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:44:28.145
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:28.288
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:28.288
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:28.288
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:28.447
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:28.447
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Failed connections: 9582 | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:28.583
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:28.583
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:28.583
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:28.583
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:28.723
DTC Client socket (3) | Closed. | 2024-03-17 10:44:28.723
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:30.591
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:30.594
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:30.594
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:44:30.594
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:30.746
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:30.746
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:30.746
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:30.924
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:30.924
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Failed connections: 9583 | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:31.086
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:31.086
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:31.086
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:31.086
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:31.232
DTC Client socket (3) | Closed. | 2024-03-17 10:44:31.232
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:44:33.115
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:33.116
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:33.116
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:44:33.116
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:33.267
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:33.267
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:33.267
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:33.417
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:33.417
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Failed connections: 9584 | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:33.581
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:33.581
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:33.581
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:33.581
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:33.722
DTC Client socket (3) | Closed. | 2024-03-17 10:44:33.722
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:44:35.602
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:35.603
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:35.603
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:44:35.603
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:35.792
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:35.793
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:35.793
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:35.998
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:35.998
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:36.181
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:36.181
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:36.181
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:36.181
SC DTC Delayed Exchange Data | Failed connections: 9585 | 2024-03-17 10:44:36.181
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:36.181
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:36.182
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:36.182
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:36.182
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:36.182
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:36.371
DTC Client socket (3) | Closed. | 2024-03-17 10:44:36.372
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:44:38.177
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:38.177
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:38.178
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:44:38.178
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:38.327
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:38.327
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:38.327
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:38.488
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:38.488
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:38.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:38.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:38.620
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:38.620
SC DTC Delayed Exchange Data | Failed connections: 9586 | 2024-03-17 10:44:38.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:38.620
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:38.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:38.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:38.621
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:38.621
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:38.767
DTC Client socket (3) | Closed. | 2024-03-17 10:44:38.767
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:44:40.669
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:40.670
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:40.670
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:44:40.670
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:40.814
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:40.814
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:40.814
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:40.957
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:40.957
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:41.084
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:41.084
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:41.084
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:41.084
SC DTC Delayed Exchange Data | Failed connections: 9587 | 2024-03-17 10:44:41.084
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:41.084
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:41.085
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:41.085
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:41.085
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:41.086
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:41.221
DTC Client socket (3) | Closed. | 2024-03-17 10:44:41.221
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:43.092
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:43.094
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:43.094
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:44:43.094
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:43.235
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:43.235
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:43.235
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:43.457
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:43.457
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:43.786
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:43.786
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:43.786
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:43.786
SC DTC Delayed Exchange Data | Failed connections: 9588 | 2024-03-17 10:44:43.786
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:43.786
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:43.787
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:43.787
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:43.787
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:43.787
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:43.951
DTC Client socket (3) | Closed. | 2024-03-17 10:44:43.951
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:44:45.793
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:45.795
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:45.795
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:44:45.795
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:45.934
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:45.934
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:45.934
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:46.107
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:46.107
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:46.249
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:46.249
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:46.249
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:46.249
SC DTC Delayed Exchange Data | Failed connections: 9589 | 2024-03-17 10:44:46.249
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:46.250
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:46.250
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:46.250
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:46.250
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:46.251
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:46.391
DTC Client socket (3) | Closed. | 2024-03-17 10:44:46.391
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:44:48.259
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:48.261
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:48.261
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:44:48.261
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:48.406
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:48.406
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:48.406
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:48.667
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:48.667
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:48.849
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:48.849
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:48.849
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:48.849
SC DTC Delayed Exchange Data | Failed connections: 9590 | 2024-03-17 10:44:48.849
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:48.849
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:48.850
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:48.850
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:48.850
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:48.850
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:48.991
DTC Client socket (3) | Closed. | 2024-03-17 10:44:48.991
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:44:50.850
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:50.851
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:50.851
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:44:50.851
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:51.022
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:51.022
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:51.022
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:51.233
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:51.233
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:51.372
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:51.372
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:51.372
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:51.372
SC DTC Delayed Exchange Data | Failed connections: 9591 | 2024-03-17 10:44:51.372
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:51.372
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:51.373
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:51.373
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:51.373
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:51.373
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:51.510
DTC Client socket (3) | Closed. | 2024-03-17 10:44:51.510
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:53.381
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:53.382
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:53.382
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:44:53.382
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:53.525
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:53.525
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:53.526
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:53.683
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:53.683
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Failed connections: 9592 | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:53.827
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:53.827
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:53.827
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:53.827
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:53.970
DTC Client socket (3) | Closed. | 2024-03-17 10:44:53.970
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:55.849
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:55.850
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:55.850
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:44:55.850
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:55.982
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:55.982
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:55.982
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:56.142
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:56.142
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Failed connections: 9593 | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:56.276
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:56.276
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:56.276
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:56.276
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:56.416
DTC Client socket (3) | Closed. | 2024-03-17 10:44:56.416
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:44:58.296
DTC Client socket (3) | Creating socket. | 2024-03-17 10:44:58.296
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:44:58.296
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:44:58.296
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:44:58.437
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:44:58.437
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:44:58.437
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:44:58.605
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:44:58.605
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:44:58.745
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:44:58.745
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:44:58.745
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:44:58.745
SC DTC Delayed Exchange Data | Failed connections: 9594 | 2024-03-17 10:44:58.745
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:44:58.745
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:44:58.746
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:44:58.746
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:44:58.746
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:44:58.746
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:44:58.885
DTC Client socket (3) | Closed. | 2024-03-17 10:44:58.885
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:45:00.761
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:00.772
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:00.772
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:45:00.772
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:00.925
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:00.925
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:00.925
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:01.125
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:01.125
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:01.281
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:01.281
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:01.281
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:01.281
SC DTC Delayed Exchange Data | Failed connections: 9595 | 2024-03-17 10:45:01.281
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:01.281
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:01.282
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:01.282
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:01.282
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:01.282
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:01.431
DTC Client socket (3) | Closed. | 2024-03-17 10:45:01.431
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:45:03.305
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:03.307
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:03.307
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:45:03.307
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:03.503
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:03.503
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:03.503
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:03.714
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:03.714
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Failed connections: 9596 | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:03.897
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:03.897
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:03.897
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:03.897
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:04.083
DTC Client socket (3) | Closed. | 2024-03-17 10:45:04.083
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:45:05.899
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:05.899
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:05.900
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:45:05.900
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:06.046
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:06.046
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:06.046
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:06.213
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:06.213
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:06.357
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:06.357
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:06.357
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:06.357
SC DTC Delayed Exchange Data | Failed connections: 9597 | 2024-03-17 10:45:06.357
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:06.357
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:06.359
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:06.359
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:06.359
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:06.359
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:06.500
DTC Client socket (3) | Closed. | 2024-03-17 10:45:06.500
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:45:08.364
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:08.366
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:08.366
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:45:08.366
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:08.511
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:08.511
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:08.511
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:08.686
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:08.686
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:08.819
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:08.819
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:08.819
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:08.819
SC DTC Delayed Exchange Data | Failed connections: 9598 | 2024-03-17 10:45:08.819
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:08.819
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:08.819
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:08.820
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:08.820
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:08.820
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:08.960
DTC Client socket (3) | Closed. | 2024-03-17 10:45:08.960
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:10.824
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:10.825
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:10.825
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:45:10.825
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:10.961
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:10.961
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:10.961
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:11.175
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:11.175
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:11.327
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:11.327
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:11.327
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:11.327
SC DTC Delayed Exchange Data | Failed connections: 9599 | 2024-03-17 10:45:11.327
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:11.327
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:11.328
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:11.328
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:11.328
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:11.328
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:11.470
DTC Client socket (3) | Closed. | 2024-03-17 10:45:11.470
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:45:13.343
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:13.346
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:13.346
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:45:13.346
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:13.484
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:13.484
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:13.484
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:13.653
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:13.653
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:13.794
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:13.794
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:13.794
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:13.794
SC DTC Delayed Exchange Data | Failed connections: 9600 | 2024-03-17 10:45:13.794
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:13.794
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:13.796
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:13.796
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:13.796
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:13.796
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:13.930
DTC Client socket (3) | Closed. | 2024-03-17 10:45:13.930
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:45:15.795
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:15.796
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:15.796
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:45:15.796
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:15.937
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:15.937
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:15.938
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:16.755
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:16.755
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Failed connections: 9601 | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:17.647
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:17.647
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:17.647
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:17.647
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:17.809
DTC Client socket (3) | Closed. | 2024-03-17 10:45:17.810
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:45:19.646
DTC Client socket (1) | Creating socket. | 2024-03-17 10:45:19.646
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:45:19.646
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:45:19.646
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:19.791
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:19.791
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:19.791
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:19.990
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:19.990
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:20.133
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:20.133
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:20.133
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:20.133
SC DTC Delayed Exchange Data | Failed connections: 9602 | 2024-03-17 10:45:20.133
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:20.133
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:45:20.134
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:20.134
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:20.134
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:20.134
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:45:20.319
DTC Client socket (1) | Closed. | 2024-03-17 10:45:20.319
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:22.144
DTC Client socket (1) | Creating socket. | 2024-03-17 10:45:22.146
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:45:22.146
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:45:22.146
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:22.293
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:22.293
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:22.293
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:22.465
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:22.465
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:22.606
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:22.606
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:22.606
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:22.606
SC DTC Delayed Exchange Data | Failed connections: 9603 | 2024-03-17 10:45:22.606
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:22.606
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:45:22.607
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:22.607
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:22.607
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:22.607
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:45:22.749
DTC Client socket (1) | Closed. | 2024-03-17 10:45:22.749
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:24.631
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:24.632
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:24.632
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:45:24.632
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:24.776
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:24.776
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:24.776
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:24.947
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:24.947
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:25.097
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:25.097
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:25.097
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:25.097
SC DTC Delayed Exchange Data | Failed connections: 9604 | 2024-03-17 10:45:25.097
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:25.097
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:25.098
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:25.098
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:25.098
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:25.098
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:25.229
DTC Client socket (3) | Closed. | 2024-03-17 10:45:25.229
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:27.100
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:27.101
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:27.102
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:45:27.102
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:27.242
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:27.242
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:27.242
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:27.404
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:27.404
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:27.553
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:27.553
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:27.553
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:27.553
SC DTC Delayed Exchange Data | Failed connections: 9605 | 2024-03-17 10:45:27.553
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:27.553
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:27.554
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:27.554
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:27.554
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:27.554
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:27.689
DTC Client socket (3) | Closed. | 2024-03-17 10:45:27.689
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:45:29.544
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:29.546
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:29.546
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:45:29.546
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:29.693
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:29.693
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:29.694
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:29.859
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:29.859
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:29.996
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:29.996
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:29.996
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:29.996
SC DTC Delayed Exchange Data | Failed connections: 9606 | 2024-03-17 10:45:29.996
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:29.996
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:29.997
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:29.997
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:29.997
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:29.997
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:30.140
DTC Client socket (3) | Closed. | 2024-03-17 10:45:30.140
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:45:32.004
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:32.027
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:32.027
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:45:32.027
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:32.229
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:32.229
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:32.229
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:32.451
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:32.451
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:32.642
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:32.642
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:32.642
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:32.642
SC DTC Delayed Exchange Data | Failed connections: 9607 | 2024-03-17 10:45:32.642
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:32.642
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:32.642
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:32.643
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:32.643
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:32.643
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:32.833
DTC Client socket (3) | Closed. | 2024-03-17 10:45:32.833
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:45:34.683
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:34.683
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:34.684
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:45:34.684
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:34.838
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:34.838
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:34.838
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:35.011
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:35.011
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:35.150
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:35.150
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:35.150
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:35.150
SC DTC Delayed Exchange Data | Failed connections: 9608 | 2024-03-17 10:45:35.150
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:35.150
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:35.151
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:35.151
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:35.151
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:35.151
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:35.289
DTC Client socket (3) | Closed. | 2024-03-17 10:45:35.289
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:45:37.168
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:37.169
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:37.169
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:45:37.169
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:37.313
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:37.313
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:37.313
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:37.487
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:37.487
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:37.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:37.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:37.620
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:37.620
SC DTC Delayed Exchange Data | Failed connections: 9609 | 2024-03-17 10:45:37.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:37.620
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:37.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:37.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:37.621
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:37.621
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:37.758
DTC Client socket (3) | Closed. | 2024-03-17 10:45:37.759
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:39.661
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:39.661
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:39.661
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:45:39.661
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:39.803
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:39.803
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:39.803
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:40.034
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:40.034
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:40.173
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:40.173
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:40.173
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:40.173
SC DTC Delayed Exchange Data | Failed connections: 9610 | 2024-03-17 10:45:40.173
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:40.174
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:40.174
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:40.174
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:40.174
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:40.175
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:40.308
DTC Client socket (3) | Closed. | 2024-03-17 10:45:40.309
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:45:42.170
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:42.170
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:42.171
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:45:42.171
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:42.312
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:42.312
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:42.312
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:42.494
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:42.494
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:42.662
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:42.662
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:42.662
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:42.662
SC DTC Delayed Exchange Data | Failed connections: 9611 | 2024-03-17 10:45:42.662
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:42.662
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:42.663
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:42.663
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:42.663
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:42.663
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:42.798
DTC Client socket (3) | Closed. | 2024-03-17 10:45:42.798
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:45:44.661
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:44.662
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:44.662
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:45:44.662
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:44.804
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:44.804
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:44.804
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:45.753
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:45.753
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:46.053
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:46.053
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:46.053
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:46.053
SC DTC Delayed Exchange Data | Failed connections: 9612 | 2024-03-17 10:45:46.053
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:46.053
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:46.054
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:46.054
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:46.054
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:46.054
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:46.202
DTC Client socket (3) | Closed. | 2024-03-17 10:45:46.202
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:45:48.066
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:48.068
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:48.068
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:45:48.068
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:48.212
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:48.212
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:48.212
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:48.459
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:48.459
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:48.618
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:48.618
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:48.618
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:48.618
SC DTC Delayed Exchange Data | Failed connections: 9613 | 2024-03-17 10:45:48.618
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:48.618
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:48.619
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:48.620
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:48.620
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:48.620
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:48.778
DTC Client socket (3) | Closed. | 2024-03-17 10:45:48.778
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:50.621
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:50.622
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:50.623
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:45:50.623
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:50.772
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:50.772
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:50.772
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:50.965
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:50.965
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:51.100
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:51.100
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:51.100
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:51.100
SC DTC Delayed Exchange Data | Failed connections: 9614 | 2024-03-17 10:45:51.100
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:51.100
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:51.101
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:51.101
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:51.101
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:51.101
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:51.238
DTC Client socket (3) | Closed. | 2024-03-17 10:45:51.238
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:53.105
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:53.106
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:53.107
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:45:53.107
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:53.252
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:53.252
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:53.253
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:53.413
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:53.413
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:53.553
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:53.553
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:53.553
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:45:53.553
SC DTC Delayed Exchange Data | Failed connections: 9615 | 2024-03-17 10:45:53.553
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:53.553
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:53.554
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:53.554
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:53.554
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:53.554
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:53.688
DTC Client socket (3) | Closed. | 2024-03-17 10:45:53.688
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:45:55.550
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:55.551
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:55.551
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:45:55.551
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:55.697
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:55.697
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:55.697
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:55.850
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:55.850
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:55.994
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:55.994
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:55.994
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:55.994
SC DTC Delayed Exchange Data | Failed connections: 9616 | 2024-03-17 10:45:55.994
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:55.994
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:55.995
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:55.995
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:55.995
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:55.995
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:56.138
DTC Client socket (3) | Closed. | 2024-03-17 10:45:56.138
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:45:58.003
DTC Client socket (3) | Creating socket. | 2024-03-17 10:45:58.004
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:45:58.004
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:45:58.004
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:45:58.151
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:45:58.151
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:45:58.151
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:45:58.313
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:45:58.313
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:45:58.453
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:45:58.453
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:45:58.453
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:45:58.453
SC DTC Delayed Exchange Data | Failed connections: 9617 | 2024-03-17 10:45:58.453
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:45:58.453
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:45:58.454
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:45:58.454
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:45:58.454
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:45:58.454
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:45:58.587
DTC Client socket (3) | Closed. | 2024-03-17 10:45:58.588
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:46:00.473
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:00.474
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:00.475
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:46:00.475
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:00.672
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:00.672
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:00.672
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:00.863
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:00.863
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:01.050
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:01.050
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:01.050
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:01.050
SC DTC Delayed Exchange Data | Failed connections: 9618 | 2024-03-17 10:46:01.050
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:01.050
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:01.051
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:01.051
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:01.051
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:01.051
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:01.240
DTC Client socket (3) | Closed. | 2024-03-17 10:46:01.241
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:46:03.058
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:03.059
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:03.059
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:46:03.060
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:03.202
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:03.202
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:03.202
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:03.362
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:03.362
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:03.503
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:03.503
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:03.503
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:03.503
SC DTC Delayed Exchange Data | Failed connections: 9619 | 2024-03-17 10:46:03.503
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:03.503
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:03.503
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:03.504
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:03.504
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:03.504
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:03.647
DTC Client socket (3) | Closed. | 2024-03-17 10:46:03.648
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:46:05.503
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:05.504
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:05.505
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:46:05.505
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:05.653
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:05.654
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:05.654
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:05.793
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:05.793
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Failed connections: 9620 | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:05.920
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:05.920
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:05.920
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:05.920
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:06.057
DTC Client socket (3) | Closed. | 2024-03-17 10:46:06.058
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:07.933
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:07.934
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:07.934
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:46:07.934
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:08.069
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:08.069
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:08.069
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:08.295
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:08.295
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Failed connections: 9621 | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:08.510
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:08.510
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:08.511
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:08.511
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:08.511
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:08.649
DTC Client socket (3) | Closed. | 2024-03-17 10:46:08.649
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:46:10.534
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:10.535
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:10.535
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:46:10.535
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:10.680
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:10.680
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:10.680
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:10.822
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:10.822
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Failed connections: 9622 | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:10.970
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:10.970
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:10.970
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:10.970
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:11.107
DTC Client socket (3) | Closed. | 2024-03-17 10:46:11.107
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:46:12.992
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:12.993
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:12.993
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:46:12.993
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:13.131
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:13.131
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:13.131
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:13.402
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:13.402
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Failed connections: 9623 | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:13.542
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:13.542
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:13.542
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:13.542
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:13.687
DTC Client socket (3) | Closed. | 2024-03-17 10:46:13.687
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:46:15.548
DTC Client socket (3) | Creating socket. | 2024-03-17 10:46:15.549
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:46:15.549
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:46:15.549
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:15.696
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:15.696
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:15.696
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:15.902
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:15.902
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:16.048
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:16.048
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:16.048
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:16.048
SC DTC Delayed Exchange Data | Failed connections: 9624 | 2024-03-17 10:46:16.048
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:16.049
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:46:16.049
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:16.049
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:16.049
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:16.050
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:46:16.187
DTC Client socket (3) | Closed. | 2024-03-17 10:46:16.187
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:18.044
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:18.045
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:18.045
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:46:18.045
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:18.192
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:18.192
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:18.192
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:18.362
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:18.362
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:18.506
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:18.506
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:18.506
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:18.506
SC DTC Delayed Exchange Data | Failed connections: 9625 | 2024-03-17 10:46:18.506
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:18.506
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:18.507
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:18.507
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:18.507
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:18.507
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:18.647
DTC Client socket (2) | Closed. | 2024-03-17 10:46:18.647
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:20.524
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:20.525
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:20.526
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:46:20.526
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:20.672
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:20.672
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:20.672
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:20.832
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:20.832
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:20.966
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:20.966
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:20.966
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:20.966
SC DTC Delayed Exchange Data | Failed connections: 9626 | 2024-03-17 10:46:20.966
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:20.966
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:20.967
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:20.967
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:20.967
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:20.968
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:21.106
DTC Client socket (2) | Closed. | 2024-03-17 10:46:21.106
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:22.975
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:22.976
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:22.976
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:46:22.976
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:23.122
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:23.123
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:23.123
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:23.262
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:23.262
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:23.401
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:23.401
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:23.401
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:23.401
SC DTC Delayed Exchange Data | Failed connections: 9627 | 2024-03-17 10:46:23.401
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:23.401
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:23.402
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:23.402
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:23.402
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:23.402
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:23.537
DTC Client socket (2) | Closed. | 2024-03-17 10:46:23.537
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:46:25.423
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:25.424
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:25.424
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:46:25.424
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:25.571
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:25.571
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:25.571
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:25.719
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:25.719
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Failed connections: 9628 | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:25.857
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:25.857
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:25.857
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:25.857
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:25.996
DTC Client socket (2) | Closed. | 2024-03-17 10:46:25.996
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:46:27.864
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:27.864
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:27.865
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:46:27.865
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:28.061
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:28.061
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:28.061
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:28.248
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:28.248
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:28.435
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:28.435
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:28.435
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:28.435
SC DTC Delayed Exchange Data | Failed connections: 9629 | 2024-03-17 10:46:28.435
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:28.435
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:28.436
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:28.436
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:28.436
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:28.437
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:28.626
DTC Client socket (2) | Closed. | 2024-03-17 10:46:28.627
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:46:30.434
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:30.436
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:30.436
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:46:30.436
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:30.584
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:30.584
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:30.584
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:30.729
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:30.729
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:30.875
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:30.875
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:30.875
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:30.875
SC DTC Delayed Exchange Data | Failed connections: 9630 | 2024-03-17 10:46:30.875
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:30.875
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:30.876
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:30.876
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:30.876
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:30.876
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:31.016
DTC Client socket (2) | Closed. | 2024-03-17 10:46:31.016
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:46:32.878
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:32.879
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:32.879
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:46:32.879
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:33.020
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:33.020
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:33.020
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:33.193
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:33.193
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:33.348
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:33.348
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:33.348
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:33.348
SC DTC Delayed Exchange Data | Failed connections: 9631 | 2024-03-17 10:46:33.348
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:33.348
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:33.349
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:33.349
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:33.349
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:33.349
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:33.486
DTC Client socket (2) | Closed. | 2024-03-17 10:46:33.486
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:35.367
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:35.368
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:35.368
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:46:35.368
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:35.510
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:35.510
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:35.510
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:35.792
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:35.792
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:36.012
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Failed connections: 9632 | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:36.013
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:36.013
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:36.014
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:36.014
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:36.136
DTC Client socket (2) | Closed. | 2024-03-17 10:46:36.136
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:46:38.024
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:38.025
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:38.025
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:46:38.026
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:38.170
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:38.170
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:38.170
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:38.322
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:38.322
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:38.465
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:38.465
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:38.465
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:38.465
SC DTC Delayed Exchange Data | Failed connections: 9633 | 2024-03-17 10:46:38.465
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:38.465
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:38.466
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:38.466
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:38.466
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:38.466
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:38.606
DTC Client socket (2) | Closed. | 2024-03-17 10:46:38.606
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:46:40.487
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:40.488
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:40.489
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:46:40.489
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:40.630
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:40.630
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:40.630
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:40.832
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:40.832
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Failed connections: 9634 | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:40.972
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:40.972
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:40.972
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:40.972
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:41.110
DTC Client socket (2) | Closed. | 2024-03-17 10:46:41.110
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:46:42.964
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:42.965
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:42.965
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:46:42.965
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:43.110
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:43.110
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:43.110
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:43.342
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:43.342
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:43.521
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:43.521
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:43.521
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:43.521
SC DTC Delayed Exchange Data | Failed connections: 9635 | 2024-03-17 10:46:43.521
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:43.521
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:43.522
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:43.522
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:43.522
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:43.522
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:43.666
DTC Client socket (2) | Closed. | 2024-03-17 10:46:43.666
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:45.519
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:45.520
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:45.520
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:46:45.520
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:45.660
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:45.660
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:45.660
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:45.828
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:45.828
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:45.968
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:45.968
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:45.968
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:45.968
SC DTC Delayed Exchange Data | Failed connections: 9636 | 2024-03-17 10:46:45.968
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:45.968
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:45.969
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:45.969
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:45.969
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:45.969
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:46.105
DTC Client socket (2) | Closed. | 2024-03-17 10:46:46.105
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:47.985
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:47.986
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:47.986
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:46:47.987
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:48.135
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:48.135
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:48.136
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:48.287
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:48.287
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:48.426
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:48.426
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:48.426
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:48.426
SC DTC Delayed Exchange Data | Failed connections: 9637 | 2024-03-17 10:46:48.426
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:48.426
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:48.427
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:48.427
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:48.427
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:48.427
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:48.565
DTC Client socket (2) | Closed. | 2024-03-17 10:46:48.565
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:46:50.420
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:50.421
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:50.422
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:46:50.422
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:50.557
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:50.557
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:50.557
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:50.707
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:50.707
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:50.851
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:50.851
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:50.851
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:50.851
SC DTC Delayed Exchange Data | Failed connections: 9638 | 2024-03-17 10:46:50.851
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:50.851
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:50.852
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:50.852
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:50.852
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:50.852
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:50.995
DTC Client socket (2) | Closed. | 2024-03-17 10:46:50.995
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:46:52.846
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:52.848
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:52.848
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:46:52.848
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:52.993
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:52.993
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:52.993
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:53.183
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:53.183
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:53.316
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:53.316
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:53.316
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:53.316
SC DTC Delayed Exchange Data | Failed connections: 9639 | 2024-03-17 10:46:53.316
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:53.316
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:53.317
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:53.317
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:53.317
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:53.317
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:53.455
DTC Client socket (2) | Closed. | 2024-03-17 10:46:53.455
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:46:55.336
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:55.337
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:55.337
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:46:55.337
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:55.529
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:55.529
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:55.529
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:55.751
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:55.751
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:55.938
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:55.938
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:55.938
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:46:55.938
SC DTC Delayed Exchange Data | Failed connections: 9640 | 2024-03-17 10:46:55.938
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:55.938
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:55.939
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:55.939
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:55.939
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:55.939
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:56.127
DTC Client socket (2) | Closed. | 2024-03-17 10:46:56.127
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:46:57.957
DTC Client socket (2) | Creating socket. | 2024-03-17 10:46:57.958
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:46:57.958
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:46:57.959
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:46:58.096
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:46:58.096
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:46:58.097
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:46:58.266
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:46:58.266
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:46:58.398
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:46:58.398
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:46:58.398
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:46:58.398
SC DTC Delayed Exchange Data | Failed connections: 9641 | 2024-03-17 10:46:58.398
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:46:58.398
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:46:58.399
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:46:58.399
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:46:58.399
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:46:58.399
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:46:58.535
DTC Client socket (2) | Closed. | 2024-03-17 10:46:58.536
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:47:00.401
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:00.402
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:00.402
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:47:00.402
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:00.549
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:00.549
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:00.550
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:00.692
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:00.692
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:00.840
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:00.841
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:00.841
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:00.841
SC DTC Delayed Exchange Data | Failed connections: 9642 | 2024-03-17 10:47:00.841
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:00.841
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:00.842
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:00.842
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:00.842
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:00.842
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:00.975
DTC Client socket (2) | Closed. | 2024-03-17 10:47:00.975
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:02.851
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:02.852
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:02.853
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:47:02.853
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:02.999
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:02.999
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:03.000
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:03.254
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:03.255
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Failed connections: 9643 | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:03.386
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:03.386
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:03.386
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:03.386
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:03.527
DTC Client socket (2) | Closed. | 2024-03-17 10:47:03.528
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:47:05.406
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:05.407
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:05.408
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:47:05.408
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:05.561
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:05.561
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:05.561
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:05.736
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:05.736
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:05.884
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:05.884
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:05.884
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:05.884
SC DTC Delayed Exchange Data | Failed connections: 9644 | 2024-03-17 10:47:05.884
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:05.884
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:05.885
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:05.885
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:05.885
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:05.885
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:06.025
DTC Client socket (2) | Closed. | 2024-03-17 10:47:06.025
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:47:07.881
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:07.882
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:07.883
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:47:07.883
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:08.021
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:08.021
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:08.021
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:08.323
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:08.323
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:08.466
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:08.466
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:08.466
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:08.466
SC DTC Delayed Exchange Data | Failed connections: 9645 | 2024-03-17 10:47:08.466
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:08.466
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:08.468
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:08.468
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:08.468
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:08.468
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:08.664
DTC Client socket (2) | Closed. | 2024-03-17 10:47:08.665
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:47:10.476
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:10.477
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:10.478
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:47:10.478
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:10.628
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:10.628
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:10.629
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:10.890
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:10.890
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:11.038
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:11.038
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:11.038
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:11.038
SC DTC Delayed Exchange Data | Failed connections: 9646 | 2024-03-17 10:47:11.038
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:11.038
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:11.039
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:11.039
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:11.039
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:11.039
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:11.205
DTC Client socket (2) | Closed. | 2024-03-17 10:47:11.205
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:13.029
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:13.031
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:13.031
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:47:13.031
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:13.169
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:13.169
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:13.169
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:13.330
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:13.330
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:13.468
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:13.468
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:13.468
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:13.468
SC DTC Delayed Exchange Data | Failed connections: 9647 | 2024-03-17 10:47:13.468
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:13.468
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:13.469
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:13.469
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:13.469
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:13.469
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:13.607
DTC Client socket (2) | Closed. | 2024-03-17 10:47:13.608
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:15.481
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:15.483
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:15.483
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:47:15.483
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:15.628
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:15.628
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:15.628
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:15.769
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:15.769
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:15.923
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:15.923
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:15.923
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:15.923
SC DTC Delayed Exchange Data | Failed connections: 9648 | 2024-03-17 10:47:15.923
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:15.923
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:15.924
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:15.924
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:15.924
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:15.924
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:16.064
DTC Client socket (2) | Closed. | 2024-03-17 10:47:16.064
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:17.934
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:17.935
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:17.936
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:47:17.936
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:18.079
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:18.079
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:18.079
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:18.220
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:18.220
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Failed connections: 9649 | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:18.358
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:18.358
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:18.358
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:18.358
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:18.495
DTC Client socket (2) | Closed. | 2024-03-17 10:47:18.496
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:47:20.389
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:20.390
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:20.390
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:47:20.390
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:20.538
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:20.538
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:20.538
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:20.720
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:20.720
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:20.886
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:20.886
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:20.886
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:20.886
SC DTC Delayed Exchange Data | Failed connections: 9650 | 2024-03-17 10:47:20.886
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:20.886
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:20.887
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:20.887
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:20.887
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:20.887
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:21.034
DTC Client socket (2) | Closed. | 2024-03-17 10:47:21.034
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:47:22.892
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:22.893
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:22.893
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:47:22.893
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:23.088
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:23.088
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:23.088
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:23.300
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:23.300
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:23.478
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:23.478
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:23.478
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:23.478
SC DTC Delayed Exchange Data | Failed connections: 9651 | 2024-03-17 10:47:23.478
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:23.478
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:23.479
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:23.479
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:23.479
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:23.479
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:23.664
DTC Client socket (2) | Closed. | 2024-03-17 10:47:23.664
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:47:25.466
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:25.466
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:25.467
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:47:25.467
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:25.608
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:25.608
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:25.608
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:25.779
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:25.779
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:25.923
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Failed connections: 9652 | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:25.924
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:25.924
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:25.924
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:25.925
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:26.064
DTC Client socket (2) | Closed. | 2024-03-17 10:47:26.064
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:47:27.945
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:27.947
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:27.947
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:47:27.947
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:28.109
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:28.109
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:28.109
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:28.272
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:28.272
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:28.406
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:28.406
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:28.406
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:28.406
SC DTC Delayed Exchange Data | Failed connections: 9653 | 2024-03-17 10:47:28.406
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:28.406
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:28.407
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:28.407
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:28.407
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:28.407
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:28.543
DTC Client socket (2) | Closed. | 2024-03-17 10:47:28.544
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:30.427
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:30.429
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:30.429
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:47:30.429
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:30.578
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:30.578
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:30.578
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:30.780
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:30.780
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:30.930
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:30.930
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:30.930
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:30.930
SC DTC Delayed Exchange Data | Failed connections: 9654 | 2024-03-17 10:47:30.930
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:30.930
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:30.931
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:30.931
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:30.931
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:30.931
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:31.073
DTC Client socket (2) | Closed. | 2024-03-17 10:47:31.073
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:47:32.929
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:32.930
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:32.930
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:47:32.930
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:33.070
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:33.070
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:33.070
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:33.251
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:33.251
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:33.390
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:33.390
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:33.390
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:33.390
SC DTC Delayed Exchange Data | Failed connections: 9655 | 2024-03-17 10:47:33.390
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:33.390
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:33.391
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:33.391
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:33.391
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:33.392
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:33.523
DTC Client socket (2) | Closed. | 2024-03-17 10:47:33.523
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:47:35.411
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:35.449
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:35.449
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:47:35.449
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:35.588
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:35.588
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:35.588
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:35.789
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:35.789
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:36.016
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:36.016
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:36.016
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:36.016
SC DTC Delayed Exchange Data | Failed connections: 9656 | 2024-03-17 10:47:36.016
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:36.016
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:36.017
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:36.017
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:36.017
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:36.017
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:36.176
DTC Client socket (2) | Closed. | 2024-03-17 10:47:36.177
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:47:38.017
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:38.018
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:38.019
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:47:38.019
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:38.171
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:38.172
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:38.172
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:38.388
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:38.388
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:38.559
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:38.559
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:38.559
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:38.559
SC DTC Delayed Exchange Data | Failed connections: 9657 | 2024-03-17 10:47:38.559
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:38.559
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:38.560
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:38.560
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:38.560
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:38.560
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:38.703
DTC Client socket (2) | Closed. | 2024-03-17 10:47:38.703
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:40.561
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:40.562
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:40.562
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:47:40.562
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:40.705
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:40.705
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:40.705
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:40.879
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:40.879
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:41.017
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:41.017
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:41.017
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:41.017
SC DTC Delayed Exchange Data | Failed connections: 9658 | 2024-03-17 10:47:41.017
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:41.017
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:41.018
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:41.018
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:41.018
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:41.018
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:41.163
DTC Client socket (2) | Closed. | 2024-03-17 10:47:41.163
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:43.035
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:43.036
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:43.036
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:47:43.036
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:43.179
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:43.179
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:43.179
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:43.350
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:43.350
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:43.490
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:43.490
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:43.491
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:43.491
SC DTC Delayed Exchange Data | Failed connections: 9659 | 2024-03-17 10:47:43.491
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:43.491
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:43.492
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:43.492
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:43.492
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:43.492
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:43.633
DTC Client socket (2) | Closed. | 2024-03-17 10:47:43.633
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:45.482
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:45.484
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:45.484
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:47:45.484
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:45.641
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:45.641
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:45.642
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:45.806
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:45.806
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:45.957
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:45.957
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:45.957
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:45.957
SC DTC Delayed Exchange Data | Failed connections: 9660 | 2024-03-17 10:47:45.957
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:45.957
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:45.958
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:45.958
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:45.958
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:45.958
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:46.103
DTC Client socket (2) | Closed. | 2024-03-17 10:47:46.103
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:47:47.978
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:47.979
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:47.979
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:47:47.979
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:48.127
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:48.127
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:48.127
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:48.286
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:48.286
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:48.424
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:48.424
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:48.424
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:48.424
SC DTC Delayed Exchange Data | Failed connections: 9661 | 2024-03-17 10:47:48.424
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:48.425
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:48.425
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:48.426
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:48.426
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:48.426
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:48.562
DTC Client socket (2) | Closed. | 2024-03-17 10:47:48.563
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:47:50.429
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:50.431
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:50.431
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:47:50.431
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:50.625
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:50.625
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:50.625
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:50.836
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:50.836
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:51.020
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:51.020
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:51.020
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:51.020
SC DTC Delayed Exchange Data | Failed connections: 9662 | 2024-03-17 10:47:51.020
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:51.020
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:51.021
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:51.021
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:51.021
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:51.021
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:51.213
DTC Client socket (2) | Closed. | 2024-03-17 10:47:51.213
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:47:53.019
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:53.019
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:53.020
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:47:53.020
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:53.167
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:53.167
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:53.167
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:53.410
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:53.410
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Failed connections: 9663 | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:53.565
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:53.565
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:53.565
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:53.566
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:53.705
DTC Client socket (2) | Closed. | 2024-03-17 10:47:53.705
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:47:55.586
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:55.636
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:55.636
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:47:55.636
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:55.786
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:55.786
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:55.786
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:55.947
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:55.947
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:56.087
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:56.087
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:56.087
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:47:56.087
SC DTC Delayed Exchange Data | Failed connections: 9664 | 2024-03-17 10:47:56.087
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:56.088
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:56.088
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:56.088
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:56.088
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:56.089
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:56.232
DTC Client socket (2) | Closed. | 2024-03-17 10:47:56.232
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:47:58.090
DTC Client socket (2) | Creating socket. | 2024-03-17 10:47:58.091
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:47:58.091
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:47:58.092
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:47:58.240
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:47:58.240
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:47:58.241
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:47:58.448
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:47:58.448
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:47:58.652
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:47:58.652
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:47:58.653
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:47:58.653
SC DTC Delayed Exchange Data | Failed connections: 9665 | 2024-03-17 10:47:58.653
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:47:58.653
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:47:58.654
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:47:58.654
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:47:58.654
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:47:58.654
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:47:58.792
DTC Client socket (2) | Closed. | 2024-03-17 10:47:58.792
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:48:00.669
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:00.671
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:00.671
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:48:00.671
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:00.816
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:00.816
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:00.816
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:00.978
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:00.978
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:01.114
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:01.114
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:01.114
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:01.114
SC DTC Delayed Exchange Data | Failed connections: 9666 | 2024-03-17 10:48:01.114
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:01.114
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:01.115
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:01.115
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:01.115
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:01.115
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:01.263
DTC Client socket (2) | Closed. | 2024-03-17 10:48:01.263
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:48:03.115
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:03.117
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:03.117
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:48:03.117
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:03.256
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:03.256
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:03.256
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:03.725
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:03.725
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:03.884
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:03.884
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:03.884
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:03.884
SC DTC Delayed Exchange Data | Failed connections: 9667 | 2024-03-17 10:48:03.884
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:03.884
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:03.885
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:03.885
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:03.885
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:03.885
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:04.074
DTC Client socket (2) | Closed. | 2024-03-17 10:48:04.074
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:48:05.874
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:05.875
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:05.876
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:48:05.876
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:06.027
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:06.027
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:06.027
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:06.358
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:06.358
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:06.537
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:06.537
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:06.537
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:06.537
SC DTC Delayed Exchange Data | Failed connections: 9668 | 2024-03-17 10:48:06.537
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:06.537
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:06.538
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:06.538
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:06.538
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:06.538
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:06.685
DTC Client socket (2) | Closed. | 2024-03-17 10:48:06.685
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:08.538
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:08.539
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:08.539
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:48:08.539
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:08.678
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:08.678
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:08.679
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:08.848
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:08.848
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:08.986
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:08.986
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:08.986
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:08.986
SC DTC Delayed Exchange Data | Failed connections: 9669 | 2024-03-17 10:48:08.986
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:08.986
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:08.987
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:08.987
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:08.987
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:08.987
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:09.122
DTC Client socket (2) | Closed. | 2024-03-17 10:48:09.122
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:10.987
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:10.988
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:10.988
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:48:10.988
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:11.126
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:11.126
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:11.126
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:11.298
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:11.298
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:11.431
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:11.431
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:11.431
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:11.431
SC DTC Delayed Exchange Data | Failed connections: 9670 | 2024-03-17 10:48:11.431
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:11.431
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:11.432
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:11.432
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:11.432
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:11.432
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:11.562
DTC Client socket (2) | Closed. | 2024-03-17 10:48:11.562
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:13.439
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:13.441
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:13.442
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:48:13.442
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:13.585
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:13.585
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:13.586
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:13.758
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:13.758
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:13.905
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:13.905
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:13.906
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:13.906
SC DTC Delayed Exchange Data | Failed connections: 9671 | 2024-03-17 10:48:13.906
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:13.906
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:13.906
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:13.906
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:13.907
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:13.907
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:14.051
DTC Client socket (2) | Closed. | 2024-03-17 10:48:14.052
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:48:15.920
DTC Client socket (2) | Creating socket. | 2024-03-17 10:48:15.921
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:48:15.921
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:48:15.921
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:16.063
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:16.063
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:16.063
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:16.227
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:16.227
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:16.363
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:16.363
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:16.363
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:16.363
SC DTC Delayed Exchange Data | Failed connections: 9672 | 2024-03-17 10:48:16.363
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:16.363
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:48:16.364
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:16.364
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:16.364
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:16.365
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:48:16.514
DTC Client socket (2) | Closed. | 2024-03-17 10:48:16.515
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:48:18.373
DTC Client socket (1) | Creating socket. | 2024-03-17 10:48:18.375
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:48:18.375
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:48:18.375
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:18.582
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:18.582
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:18.582
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:18.805
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:18.805
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:18.988
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:18.988
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:18.988
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:18.988
SC DTC Delayed Exchange Data | Failed connections: 9673 | 2024-03-17 10:48:18.988
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:18.988
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:48:18.989
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:18.989
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:18.989
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:18.989
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:48:19.182
DTC Client socket (1) | Closed. | 2024-03-17 10:48:19.183
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:48:20.994
DTC Client socket (1) | Creating socket. | 2024-03-17 10:48:20.996
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:48:20.996
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:48:20.996
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:21.148
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:21.148
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:21.149
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:21.327
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:21.327
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:21.461
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:21.461
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:21.461
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:21.461
SC DTC Delayed Exchange Data | Failed connections: 9674 | 2024-03-17 10:48:21.461
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:21.461
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:48:21.462
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:21.462
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:21.462
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:21.463
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:48:21.601
DTC Client socket (1) | Closed. | 2024-03-17 10:48:21.601
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:48:23.465
DTC Client socket (1) | Creating socket. | 2024-03-17 10:48:23.467
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:48:23.467
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:48:23.467
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:23.606
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:23.606
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:23.606
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:23.767
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:23.767
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Failed connections: 9675 | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:23.897
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:48:23.897
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:23.897
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:23.898
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:48:24.031
DTC Client socket (1) | Closed. | 2024-03-17 10:48:24.031
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:25.891
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:25.893
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:25.893
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:48:25.893
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:26.035
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:26.035
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:26.035
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:26.336
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:26.336
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:26.505
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:26.505
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:26.505
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:26.505
SC DTC Delayed Exchange Data | Failed connections: 9676 | 2024-03-17 10:48:26.505
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:26.505
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:26.506
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:26.506
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:26.506
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:26.506
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:26.642
DTC Client socket (3) | Closed. | 2024-03-17 10:48:26.642
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:48:28.518
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:28.519
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:28.519
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:48:28.519
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:28.655
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:28.655
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:28.655
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:28.823
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:28.823
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Failed connections: 9677 | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:28.962
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:28.962
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:28.962
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:28.963
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:29.102
DTC Client socket (3) | Closed. | 2024-03-17 10:48:29.103
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:48:30.952
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:30.953
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:30.953
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:48:30.953
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:31.095
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:31.095
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:31.095
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:31.477
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:31.477
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:32.037
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:32.037
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:32.037
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:32.037
SC DTC Delayed Exchange Data | Failed connections: 9678 | 2024-03-17 10:48:32.037
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:32.037
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:32.038
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:32.038
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:32.038
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:32.038
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:32.201
DTC Client socket (3) | Closed. | 2024-03-17 10:48:32.201
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:48:34.036
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:34.038
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:34.038
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:48:34.038
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:34.182
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:34.183
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:34.183
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:34.443
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:34.443
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:34.644
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:34.644
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:34.644
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:34.644
SC DTC Delayed Exchange Data | Failed connections: 9679 | 2024-03-17 10:48:34.644
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:34.644
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:34.645
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:34.645
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:34.645
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:34.645
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:34.781
DTC Client socket (3) | Closed. | 2024-03-17 10:48:34.781
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:36.638
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:36.639
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:36.639
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:48:36.639
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:36.785
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:36.785
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:36.785
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:36.949
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:36.949
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:37.082
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:37.082
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:37.082
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:37.082
SC DTC Delayed Exchange Data | Failed connections: 9680 | 2024-03-17 10:48:37.082
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:37.082
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:37.083
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:37.083
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:37.083
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:37.083
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:37.221
DTC Client socket (3) | Closed. | 2024-03-17 10:48:37.221
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:39.085
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:39.086
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:39.086
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:48:39.086
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:39.224
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:39.224
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:39.224
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:39.366
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:39.366
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:39.517
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:39.517
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:39.517
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:39.517
SC DTC Delayed Exchange Data | Failed connections: 9681 | 2024-03-17 10:48:39.517
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:39.517
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:39.518
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:39.518
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:39.518
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:39.518
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:39.651
DTC Client socket (3) | Closed. | 2024-03-17 10:48:39.651
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:41.520
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:41.522
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:41.522
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:48:41.522
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:41.665
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:41.665
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:41.665
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:41.809
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:41.809
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:41.942
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:41.942
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:41.942
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:41.942
SC DTC Delayed Exchange Data | Failed connections: 9682 | 2024-03-17 10:48:41.942
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:41.942
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:41.943
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:41.943
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:41.943
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:41.943
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:42.082
DTC Client socket (3) | Closed. | 2024-03-17 10:48:42.082
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:48:43.971
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:43.973
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:43.973
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:48:43.973
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:44.152
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:44.152
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:44.152
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:44.336
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:44.336
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:44.468
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:44.468
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:44.468
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:44.468
SC DTC Delayed Exchange Data | Failed connections: 9683 | 2024-03-17 10:48:44.468
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:44.468
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:44.469
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:44.469
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:44.469
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:44.469
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:44.613
DTC Client socket (3) | Closed. | 2024-03-17 10:48:44.613
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:48:46.484
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:46.485
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:46.485
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:48:46.485
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:46.684
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:46.684
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:46.684
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:46.876
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:46.876
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:47.062
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:47.062
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:47.062
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:47.062
SC DTC Delayed Exchange Data | Failed connections: 9684 | 2024-03-17 10:48:47.062
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:47.062
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:47.063
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:47.063
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:47.063
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:47.063
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:47.250
DTC Client socket (3) | Closed. | 2024-03-17 10:48:47.250
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:48:49.067
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:49.068
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:49.068
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:48:49.068
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:49.215
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:49.215
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:49.215
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:49.435
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:49.435
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:49.610
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:49.610
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:49.610
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:49.611
SC DTC Delayed Exchange Data | Failed connections: 9685 | 2024-03-17 10:48:49.611
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:49.611
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:49.611
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:49.611
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:49.611
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:49.612
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:49.750
DTC Client socket (3) | Closed. | 2024-03-17 10:48:49.750
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:48:51.631
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:51.632
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:51.632
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:48:51.632
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:51.775
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:51.775
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:51.775
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:51.923
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:51.923
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:52.085
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:52.085
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:52.085
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:52.085
SC DTC Delayed Exchange Data | Failed connections: 9686 | 2024-03-17 10:48:52.085
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:52.085
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:52.086
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:52.086
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:52.086
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:52.086
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:52.292
DTC Client socket (3) | Closed. | 2024-03-17 10:48:52.292
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:48:54.088
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:54.089
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:54.089
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:48:54.089
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:54.232
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:54.232
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:54.232
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:54.474
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:54.474
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:54.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:54.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:54.620
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:54.620
SC DTC Delayed Exchange Data | Failed connections: 9687 | 2024-03-17 10:48:54.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:54.620
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:54.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:54.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:54.621
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:54.621
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:54.760
DTC Client socket (3) | Closed. | 2024-03-17 10:48:54.760
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:48:56.644
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:56.646
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:56.646
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:48:56.646
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:56.784
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:56.784
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:56.784
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:56.927
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:56.927
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:57.057
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:57.057
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:57.057
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:48:57.057
SC DTC Delayed Exchange Data | Failed connections: 9688 | 2024-03-17 10:48:57.057
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:57.057
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:57.059
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:57.059
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:57.059
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:57.059
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:48:57.199
DTC Client socket (3) | Closed. | 2024-03-17 10:48:57.199
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:48:59.062
DTC Client socket (3) | Creating socket. | 2024-03-17 10:48:59.063
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:48:59.063
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:48:59.063
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:48:59.204
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:48:59.204
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:48:59.204
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:48:59.706
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:48:59.706
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:48:59.871
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:48:59.871
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:48:59.871
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:48:59.871
SC DTC Delayed Exchange Data | Failed connections: 9689 | 2024-03-17 10:48:59.871
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:48:59.871
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:48:59.872
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:48:59.872
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:48:59.872
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:48:59.872
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:00.051
DTC Client socket (3) | Closed. | 2024-03-17 10:49:00.051
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:49:01.884
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:01.885
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:01.885
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:49:01.885
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:02.033
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:02.033
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:02.034
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:02.253
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:02.253
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:02.393
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:02.393
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:02.393
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:02.393
SC DTC Delayed Exchange Data | Failed connections: 9690 | 2024-03-17 10:49:02.393
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:02.393
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:02.394
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:02.394
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:02.394
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:02.394
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:02.540
DTC Client socket (3) | Closed. | 2024-03-17 10:49:02.540
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:04.405
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:04.406
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:04.406
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:49:04.406
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:04.553
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:04.553
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:04.554
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:04.696
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:04.696
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Failed connections: 9691 | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:04.830
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:04.830
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:04.831
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:04.831
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:04.969
DTC Client socket (3) | Closed. | 2024-03-17 10:49:04.970
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:06.837
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:06.838
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:06.839
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:49:06.839
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:06.985
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:06.985
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:06.985
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:07.164
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:07.164
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:07.301
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:07.301
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:07.301
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:07.301
SC DTC Delayed Exchange Data | Failed connections: 9692 | 2024-03-17 10:49:07.301
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:07.301
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:07.303
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:07.303
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:07.303
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:07.303
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:07.459
DTC Client socket (3) | Closed. | 2024-03-17 10:49:07.459
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:09.319
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:09.320
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:09.320
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:49:09.320
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:09.465
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:09.465
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:09.465
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:09.607
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:09.607
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:09.757
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:09.757
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:09.757
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:09.757
SC DTC Delayed Exchange Data | Failed connections: 9693 | 2024-03-17 10:49:09.757
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:09.757
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:09.759
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:09.759
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:09.759
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:09.759
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:09.899
DTC Client socket (3) | Closed. | 2024-03-17 10:49:09.899
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:49:11.751
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:11.752
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:11.752
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:49:11.752
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:11.903
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:11.903
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:11.903
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:12.055
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:12.055
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:12.202
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:12.202
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:12.202
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:12.202
SC DTC Delayed Exchange Data | Failed connections: 9694 | 2024-03-17 10:49:12.202
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:12.202
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:12.203
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:12.203
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:12.203
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:12.203
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:12.349
DTC Client socket (3) | Closed. | 2024-03-17 10:49:12.349
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:49:14.203
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:14.204
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:14.204
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:49:14.204
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:14.393
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:14.393
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:14.393
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:14.617
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:14.617
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:14.812
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:14.812
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:14.812
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:14.812
SC DTC Delayed Exchange Data | Failed connections: 9695 | 2024-03-17 10:49:14.812
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:14.812
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:14.813
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:14.813
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:14.813
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:14.813
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:15.012
DTC Client socket (3) | Closed. | 2024-03-17 10:49:15.012
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:49:16.813
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:16.814
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:16.814
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:49:16.814
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:16.953
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:16.953
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:16.953
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:17.124
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:17.124
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Failed connections: 9696 | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:17.274
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:17.274
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:17.274
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:17.274
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:17.399
DTC Client socket (3) | Closed. | 2024-03-17 10:49:17.400
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:49:19.269
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:19.270
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:19.270
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:49:19.270
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:19.415
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:19.415
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:19.415
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:19.555
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:19.555
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:19.693
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:19.693
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:19.693
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:19.693
SC DTC Delayed Exchange Data | Failed connections: 9697 | 2024-03-17 10:49:19.693
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:19.693
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:19.694
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:19.694
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:19.694
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:19.694
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:19.830
DTC Client socket (3) | Closed. | 2024-03-17 10:49:19.830
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:21.689
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:21.691
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:21.691
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:49:21.691
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:21.852
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:21.852
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:21.853
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:22.143
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:22.143
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Failed connections: 9698 | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:22.279
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:22.279
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:22.279
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:22.280
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:22.460
DTC Client socket (3) | Closed. | 2024-03-17 10:49:22.460
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:49:24.299
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:24.300
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:24.300
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:49:24.300
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:24.444
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:24.444
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:24.444
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:24.605
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:24.605
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:24.747
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:24.747
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:24.747
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:24.747
SC DTC Delayed Exchange Data | Failed connections: 9699 | 2024-03-17 10:49:24.747
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:24.747
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:24.748
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:24.748
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:24.748
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:24.748
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:24.889
DTC Client socket (3) | Closed. | 2024-03-17 10:49:24.889
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:49:26.750
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:26.751
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:26.751
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:49:26.751
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:26.954
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:26.954
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:26.954
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:27.264
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:27.264
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:27.397
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:27.397
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:27.397
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:27.397
SC DTC Delayed Exchange Data | Failed connections: 9700 | 2024-03-17 10:49:27.397
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:27.397
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:27.398
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:27.398
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:27.398
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:27.398
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:27.548
DTC Client socket (3) | Closed. | 2024-03-17 10:49:27.548
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:49:29.413
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:29.414
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:29.414
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:49:29.414
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:29.567
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:29.567
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:29.567
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:29.785
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:29.785
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:29.989
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:29.989
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:29.989
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:29.989
SC DTC Delayed Exchange Data | Failed connections: 9701 | 2024-03-17 10:49:29.989
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:29.989
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:29.990
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:29.990
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:29.990
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:29.990
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:30.158
DTC Client socket (3) | Closed. | 2024-03-17 10:49:30.158
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:32.000
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:32.002
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:32.002
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:49:32.002
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:32.153
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:32.153
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:32.153
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:32.294
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:32.294
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:32.439
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:32.439
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:32.439
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:32.439
SC DTC Delayed Exchange Data | Failed connections: 9702 | 2024-03-17 10:49:32.439
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:32.439
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:32.440
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:32.440
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:32.440
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:32.440
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:32.578
DTC Client socket (3) | Closed. | 2024-03-17 10:49:32.578
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:34.462
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:34.463
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:34.463
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:49:34.463
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:34.600
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:34.600
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:34.601
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:34.776
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:34.776
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:34.929
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:34.929
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:34.929
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:34.929
SC DTC Delayed Exchange Data | Failed connections: 9703 | 2024-03-17 10:49:34.929
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:34.929
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:34.930
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:34.930
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:34.930
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:34.930
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:35.068
DTC Client socket (3) | Closed. | 2024-03-17 10:49:35.068
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:36.926
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:36.928
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:36.928
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:49:36.928
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:37.077
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:37.077
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:37.078
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:37.255
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:37.255
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:37.394
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:37.394
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:37.394
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:37.394
SC DTC Delayed Exchange Data | Failed connections: 9704 | 2024-03-17 10:49:37.394
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:37.394
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:37.395
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:37.395
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:37.395
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:37.395
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:37.537
DTC Client socket (3) | Closed. | 2024-03-17 10:49:37.538
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:49:39.409
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:39.410
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:39.410
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:49:39.410
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:39.557
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:39.557
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:39.557
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:39.710
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:39.710
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:39.860
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:39.860
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:39.860
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:39.860
SC DTC Delayed Exchange Data | Failed connections: 9705 | 2024-03-17 10:49:39.860
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:39.860
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:39.861
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:39.861
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:39.861
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:39.861
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:39.998
DTC Client socket (3) | Closed. | 2024-03-17 10:49:39.998
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:49:41.872
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:41.874
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:41.874
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:49:41.874
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:42.067
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:42.067
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:42.067
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:42.253
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:42.253
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:42.453
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:42.453
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:42.453
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:42.453
SC DTC Delayed Exchange Data | Failed connections: 9706 | 2024-03-17 10:49:42.453
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:42.453
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:42.454
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:42.454
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:42.454
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:42.454
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:42.649
DTC Client socket (3) | Closed. | 2024-03-17 10:49:42.649
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:49:44.464
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:44.465
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:44.465
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:49:44.465
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:44.614
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:44.614
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:44.614
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:44.789
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:44.789
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:44.931
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:44.931
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:44.931
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:44.931
SC DTC Delayed Exchange Data | Failed connections: 9707 | 2024-03-17 10:49:44.931
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:44.931
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:44.931
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:44.932
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:44.932
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:44.932
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:45.067
DTC Client socket (3) | Closed. | 2024-03-17 10:49:45.067
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:49:46.941
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:46.943
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:46.943
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:49:46.943
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:47.092
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:47.092
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:47.092
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:47.263
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:47.263
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:47.404
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:47.404
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:47.404
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:47.404
SC DTC Delayed Exchange Data | Failed connections: 9708 | 2024-03-17 10:49:47.404
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:47.404
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:47.405
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:47.405
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:47.405
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:47.405
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:47.547
DTC Client socket (3) | Closed. | 2024-03-17 10:49:47.547
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:49.421
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:49.422
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:49.423
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:49:49.423
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:49.572
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:49.572
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:49.572
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:49.843
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:49.843
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:50.037
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:50.037
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:50.037
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:50.037
SC DTC Delayed Exchange Data | Failed connections: 9709 | 2024-03-17 10:49:50.037
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:50.037
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:50.038
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:50.038
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:50.038
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:50.038
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:50.218
DTC Client socket (3) | Closed. | 2024-03-17 10:49:50.219
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:49:52.049
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:52.051
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:52.051
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:49:52.051
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:52.201
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:52.201
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:52.201
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:52.362
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:52.362
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:52.507
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:52.507
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:52.507
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:49:52.507
SC DTC Delayed Exchange Data | Failed connections: 9710 | 2024-03-17 10:49:52.507
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:52.507
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:52.508
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:52.508
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:52.508
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:52.508
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:52.667
DTC Client socket (3) | Closed. | 2024-03-17 10:49:52.667
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:49:54.514
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:54.515
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:54.515
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:49:54.515
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:54.660
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:54.660
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:54.661
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:54.913
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:54.913
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:55.052
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:55.052
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:55.052
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:55.052
SC DTC Delayed Exchange Data | Failed connections: 9711 | 2024-03-17 10:49:55.052
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:55.052
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:55.053
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:55.053
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:55.053
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:55.053
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:55.197
DTC Client socket (3) | Closed. | 2024-03-17 10:49:55.198
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:49:57.047
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:57.048
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:57.048
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:49:57.048
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:57.192
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:57.192
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:57.193
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:57.409
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:57.409
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:49:57.577
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:49:57.577
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:49:57.577
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:49:57.577
SC DTC Delayed Exchange Data | Failed connections: 9712 | 2024-03-17 10:49:57.577
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:49:57.577
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:49:57.578
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:49:57.578
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:49:57.578
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:49:57.578
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:49:57.717
DTC Client socket (3) | Closed. | 2024-03-17 10:49:57.717
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:49:59.584
DTC Client socket (3) | Creating socket. | 2024-03-17 10:49:59.586
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:49:59.586
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:49:59.586
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:49:59.732
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:49:59.732
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:49:59.732
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:49:59.904
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:49:59.904
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:00.039
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:00.039
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:00.039
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:00.039
SC DTC Delayed Exchange Data | Failed connections: 9713 | 2024-03-17 10:50:00.039
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:00.039
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:00.040
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:00.040
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:00.040
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:00.040
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:00.187
DTC Client socket (3) | Closed. | 2024-03-17 10:50:00.187
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:02.049
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:02.050
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:02.050
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:50:02.050
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:02.198
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:02.198
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:02.198
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:02.359
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:02.359
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:02.502
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:02.502
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:02.502
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:02.502
SC DTC Delayed Exchange Data | Failed connections: 9714 | 2024-03-17 10:50:02.502
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:02.502
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:02.503
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:02.503
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:02.503
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:02.503
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:02.647
DTC Client socket (3) | Closed. | 2024-03-17 10:50:02.647
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:04.509
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:04.510
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:04.510
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:50:04.510
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:04.661
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:04.661
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:04.661
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:04.800
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:04.800
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:04.938
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:04.938
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:04.938
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:04.938
SC DTC Delayed Exchange Data | Failed connections: 9715 | 2024-03-17 10:50:04.938
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:04.938
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:04.938
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:04.939
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:04.939
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:04.939
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:05.077
DTC Client socket (3) | Closed. | 2024-03-17 10:50:05.077
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:50:06.951
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:06.952
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:06.952
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:50:06.952
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:07.101
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:07.101
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:07.101
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:07.249
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:07.249
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:07.392
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:07.392
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:07.392
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:07.392
SC DTC Delayed Exchange Data | Failed connections: 9716 | 2024-03-17 10:50:07.392
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:07.392
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:07.393
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:07.393
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:07.393
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:07.393
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:07.527
DTC Client socket (3) | Closed. | 2024-03-17 10:50:07.527
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:50:09.411
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:09.412
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:09.412
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:50:09.412
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:09.611
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:09.611
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:09.611
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:09.800
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:09.800
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:09.997
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:09.997
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:09.997
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:09.997
SC DTC Delayed Exchange Data | Failed connections: 9717 | 2024-03-17 10:50:09.997
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:09.997
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:09.998
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:09.998
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:09.998
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:09.998
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:10.196
DTC Client socket (3) | Closed. | 2024-03-17 10:50:10.196
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:50:12.007
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:12.008
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:12.008
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:50:12.008
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:12.150
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:12.150
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:12.150
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:12.302
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:12.302
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Failed connections: 9718 | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:12.437
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:12.437
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:12.437
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:12.437
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:12.577
DTC Client socket (3) | Closed. | 2024-03-17 10:50:12.577
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:50:14.440
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:14.441
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:14.441
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:50:14.441
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:14.580
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:14.580
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:14.581
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:14.743
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:14.743
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:14.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:14.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:14.879
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:14.879
SC DTC Delayed Exchange Data | Failed connections: 9719 | 2024-03-17 10:50:14.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:14.879
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:14.880
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:14.880
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:14.880
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:14.880
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:15.026
DTC Client socket (3) | Closed. | 2024-03-17 10:50:15.026
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:16.888
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:16.890
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:16.890
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:50:16.890
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:17.035
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:17.035
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:17.035
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:17.273
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:17.273
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:17.464
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:17.464
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:17.464
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:17.464
SC DTC Delayed Exchange Data | Failed connections: 9720 | 2024-03-17 10:50:17.464
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:17.464
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:17.465
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:17.465
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:17.465
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:17.465
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:17.656
DTC Client socket (3) | Closed. | 2024-03-17 10:50:17.657
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:50:19.489
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:19.490
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:19.490
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:50:19.490
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:19.631
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:19.631
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:19.631
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:19.768
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:19.768
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Failed connections: 9721 | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:19.911
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:19.911
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:19.911
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:19.911
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:20.046
DTC Client socket (3) | Closed. | 2024-03-17 10:50:20.046
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:50:21.915
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:21.917
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:21.917
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:50:21.917
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:22.061
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:22.061
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:22.061
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:22.373
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:22.373
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:22.526
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:22.527
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:22.527
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:22.527
SC DTC Delayed Exchange Data | Failed connections: 9722 | 2024-03-17 10:50:22.527
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:22.527
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:22.528
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:22.528
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:22.528
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:22.528
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:22.677
DTC Client socket (3) | Closed. | 2024-03-17 10:50:22.677
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:50:24.551
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:24.552
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:24.552
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:50:24.552
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:24.700
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:24.700
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:24.700
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:24.938
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:24.938
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:25.088
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Failed connections: 9723 | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:25.089
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:25.089
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:25.089
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:25.090
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:25.256
DTC Client socket (3) | Closed. | 2024-03-17 10:50:25.256
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:27.095
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:27.096
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:27.096
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:50:27.096
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:27.239
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:27.239
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:27.240
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:27.386
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:27.386
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Failed connections: 9724 | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:27.528
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:27.528
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:27.528
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:27.528
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:27.666
DTC Client socket (3) | Closed. | 2024-03-17 10:50:27.666
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:29.554
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:29.555
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:29.555
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:50:29.555
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:29.699
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:29.699
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:29.700
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:29.861
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:29.861
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:30.006
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:30.006
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:30.006
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:30.006
SC DTC Delayed Exchange Data | Failed connections: 9725 | 2024-03-17 10:50:30.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:30.006
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:30.007
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:30.007
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:30.007
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:30.007
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:30.146
DTC Client socket (3) | Closed. | 2024-03-17 10:50:30.146
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:32.005
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:32.007
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:32.007
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:50:32.007
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:32.150
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:32.150
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:32.150
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:32.291
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:32.291
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:32.427
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:32.427
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:32.427
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:32.427
SC DTC Delayed Exchange Data | Failed connections: 9726 | 2024-03-17 10:50:32.427
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:32.427
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:32.428
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:32.428
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:32.428
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:32.428
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:32.577
DTC Client socket (3) | Closed. | 2024-03-17 10:50:32.577
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:50:34.417
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:34.419
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:34.419
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:50:34.420
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:34.570
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:34.570
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:34.570
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:34.751
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:34.751
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Failed connections: 9727 | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:34.879
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:34.879
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:34.880
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:34.880
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:35.015
DTC Client socket (3) | Closed. | 2024-03-17 10:50:35.015
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:50:36.887
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:36.888
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:36.888
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:50:36.888
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:37.090
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:37.090
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:37.090
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:37.317
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:37.317
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:37.507
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:37.507
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:37.507
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:37.507
SC DTC Delayed Exchange Data | Failed connections: 9728 | 2024-03-17 10:50:37.507
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:37.507
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:37.508
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:37.508
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:37.508
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:37.508
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:37.707
DTC Client socket (3) | Closed. | 2024-03-17 10:50:37.707
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:50:39.520
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:39.522
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:39.522
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:50:39.522
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:39.668
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:39.668
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:39.668
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:39.830
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:39.830
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:39.979
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:39.979
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:39.979
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:39.979
SC DTC Delayed Exchange Data | Failed connections: 9729 | 2024-03-17 10:50:39.979
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:39.979
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:39.980
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:39.980
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:39.980
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:39.980
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:40.115
DTC Client socket (3) | Closed. | 2024-03-17 10:50:40.115
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:50:41.996
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:41.997
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:41.998
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:50:41.998
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:42.137
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:42.137
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:42.137
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:42.280
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:42.281
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:42.434
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:42.434
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:42.434
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:42.434
SC DTC Delayed Exchange Data | Failed connections: 9730 | 2024-03-17 10:50:42.434
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:42.434
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:42.435
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:42.435
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:42.435
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:42.435
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:42.577
DTC Client socket (3) | Closed. | 2024-03-17 10:50:42.577
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:44.452
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:44.453
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:44.453
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:50:44.453
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:44.597
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:44.597
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:44.597
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:44.801
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:44.801
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:44.942
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:44.942
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:44.942
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:44.942
SC DTC Delayed Exchange Data | Failed connections: 9731 | 2024-03-17 10:50:44.942
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:44.942
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:44.943
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:44.943
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:44.943
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:44.943
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:45.089
DTC Client socket (3) | Closed. | 2024-03-17 10:50:45.089
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:50:46.936
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:46.937
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:46.937
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:50:46.937
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:47.077
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:47.077
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:47.077
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:47.223
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:47.223
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:47.362
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:47.362
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:47.362
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:47.362
SC DTC Delayed Exchange Data | Failed connections: 9732 | 2024-03-17 10:50:47.362
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:47.362
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:47.363
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:47.363
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:47.364
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:47.364
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:47.505
DTC Client socket (3) | Closed. | 2024-03-17 10:50:47.505
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:50:49.370
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:49.371
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:49.371
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:50:49.371
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:49.510
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:49.510
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:49.510
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:50.247
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:50.247
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:50.384
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:50.384
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:50.384
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:50.384
SC DTC Delayed Exchange Data | Failed connections: 9733 | 2024-03-17 10:50:50.384
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:50.384
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:50.385
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:50.385
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:50.385
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:50.385
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:50.596
DTC Client socket (3) | Closed. | 2024-03-17 10:50:50.596
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:50:52.404
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:52.405
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:52.405
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:50:52.405
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:52.551
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:52.551
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:52.552
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:52.819
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:52.819
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:52.962
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:52.962
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:52.962
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:52.962
SC DTC Delayed Exchange Data | Failed connections: 9734 | 2024-03-17 10:50:52.962
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:52.962
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:52.963
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:52.963
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:52.963
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:52.963
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:53.127
DTC Client socket (3) | Closed. | 2024-03-17 10:50:53.127
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:54.970
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:54.972
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:54.972
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:50:54.972
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:55.109
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:55.109
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:55.109
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:55.277
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:55.277
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:55.417
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:55.417
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:55.417
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:50:55.417
SC DTC Delayed Exchange Data | Failed connections: 9735 | 2024-03-17 10:50:55.417
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:55.417
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:55.418
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:55.418
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:55.418
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:55.418
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:55.554
DTC Client socket (3) | Closed. | 2024-03-17 10:50:55.555
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:57.445
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:57.447
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:57.447
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:50:57.447
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:50:57.579
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:50:57.579
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:50:57.579
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:50:57.751
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:50:57.751
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:50:57.893
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:50:57.893
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:50:57.893
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:50:57.893
SC DTC Delayed Exchange Data | Failed connections: 9736 | 2024-03-17 10:50:57.893
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:50:57.893
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:50:57.894
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:50:57.894
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:50:57.894
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:50:57.894
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:50:58.034
DTC Client socket (3) | Closed. | 2024-03-17 10:50:58.034
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:50:59.892
DTC Client socket (3) | Creating socket. | 2024-03-17 10:50:59.893
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:50:59.893
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:50:59.893
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:00.037
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:00.037
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:00.037
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:00.180
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:00.180
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Failed connections: 9737 | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:00.328
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:00.328
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:00.328
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:00.328
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:00.464
DTC Client socket (3) | Closed. | 2024-03-17 10:51:00.464
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:51:02.352
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:02.353
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:02.353
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:51:02.353
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:02.498
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:02.498
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:02.498
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:02.689
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:02.689
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:02.818
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Failed connections: 9738 | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:02.819
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:02.819
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:02.819
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:02.820
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:02.964
DTC Client socket (3) | Closed. | 2024-03-17 10:51:02.964
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:51:04.832
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:04.834
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:04.834
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:51:04.834
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:05.028
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:05.028
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:05.028
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:05.221
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:05.221
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:05.418
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:05.418
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:05.418
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:05.418
SC DTC Delayed Exchange Data | Failed connections: 9739 | 2024-03-17 10:51:05.418
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:05.418
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:05.419
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:05.419
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:05.419
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:05.419
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:05.594
DTC Client socket (3) | Closed. | 2024-03-17 10:51:05.594
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:51:07.418
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:07.419
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:07.419
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:51:07.419
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:07.558
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:07.559
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:07.559
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:07.730
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:07.730
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:07.856
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:07.856
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:07.856
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:07.856
SC DTC Delayed Exchange Data | Failed connections: 9740 | 2024-03-17 10:51:07.856
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:07.856
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:07.858
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:07.858
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:07.858
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:07.858
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:07.998
DTC Client socket (3) | Closed. | 2024-03-17 10:51:07.998
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:51:09.857
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:09.858
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:09.858
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:51:09.858
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:09.999
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:09.999
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:09.999
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:10.139
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:10.139
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:10.272
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:10.272
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:10.272
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:10.272
SC DTC Delayed Exchange Data | Failed connections: 9741 | 2024-03-17 10:51:10.272
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:10.272
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:10.273
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:10.273
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:10.273
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:10.273
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:10.404
DTC Client socket (3) | Closed. | 2024-03-17 10:51:10.404
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:12.278
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:12.280
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:12.280
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:51:12.280
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:12.416
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:12.416
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:12.416
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:12.637
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:12.637
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Failed connections: 9742 | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:12.789
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:12.789
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:12.789
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:12.789
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:12.943
DTC Client socket (3) | Closed. | 2024-03-17 10:51:12.944
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:51:14.792
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:14.794
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:14.795
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:51:14.795
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:14.936
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:14.936
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:14.936
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:15.099
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:15.099
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:15.235
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:15.235
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:15.235
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:15.235
SC DTC Delayed Exchange Data | Failed connections: 9743 | 2024-03-17 10:51:15.235
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:15.235
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:15.236
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:15.236
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:15.236
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:15.236
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:15.374
DTC Client socket (3) | Closed. | 2024-03-17 10:51:15.374
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:51:17.256
DTC Client socket (3) | Creating socket. | 2024-03-17 10:51:17.257
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-17 10:51:17.257
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:51:17.257
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:17.396
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:17.396
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:17.396
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:17.620
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:17.620
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Failed connections: 9744 | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:17.780
DTC Client socket (3) | CloseSocket call. | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:17.780
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:17.780
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:17.781
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-17 10:51:17.923
DTC Client socket (3) | Closed. | 2024-03-17 10:51:17.924
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:51:19.794
DTC Client socket (1) | Creating socket. | 2024-03-17 10:51:19.795
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:51:19.795
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:51:19.795
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:19.939
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:19.939
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:19.939
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:20.219
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:20.219
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:20.402
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:20.402
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:20.402
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:20.402
SC DTC Delayed Exchange Data | Failed connections: 9745 | 2024-03-17 10:51:20.402
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:20.402
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:51:20.403
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:20.403
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:20.403
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:20.403
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:51:20.544
DTC Client socket (1) | Closed. | 2024-03-17 10:51:20.544
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:22.411
DTC Client socket (1) | Creating socket. | 2024-03-17 10:51:22.413
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 10:51:22.413
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:51:22.413
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:22.557
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:22.557
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:22.558
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:22.719
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:22.719
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:22.870
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:22.870
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:22.870
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:22.870
SC DTC Delayed Exchange Data | Failed connections: 9746 | 2024-03-17 10:51:22.870
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:22.870
DTC Client socket (1) | CloseSocket call. | 2024-03-17 10:51:22.871
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:22.871
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:22.871
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:22.871
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 10:51:23.013
DTC Client socket (1) | Closed. | 2024-03-17 10:51:23.013
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:24.874
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:24.876
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:24.876
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:51:24.876
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:25.016
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:25.016
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:25.016
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:25.178
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:25.178
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Failed connections: 9747 | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:25.317
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:25.317
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:25.318
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:25.318
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:25.453
DTC Client socket (2) | Closed. | 2024-03-17 10:51:25.453
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:27.330
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:27.331
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:27.331
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:51:27.331
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:27.476
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:27.476
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:27.476
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:27.618
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:27.618
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Failed connections: 9748 | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:27.754
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:27.754
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:27.754
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:27.754
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:27.902
DTC Client socket (2) | Closed. | 2024-03-17 10:51:27.902
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:51:29.748
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:29.750
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:29.750
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:51:29.750
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:29.897
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:29.897
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:29.897
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:30.101
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:30.101
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:30.250
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:30.250
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:30.250
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:30.250
SC DTC Delayed Exchange Data | Failed connections: 9749 | 2024-03-17 10:51:30.250
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:30.250
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:30.251
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:30.251
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:30.251
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:30.252
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:30.393
DTC Client socket (2) | Closed. | 2024-03-17 10:51:30.393
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:51:32.248
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:32.249
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:32.249
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:51:32.249
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:32.467
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:32.468
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:32.468
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:32.679
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:32.679
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:32.871
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:32.871
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:32.871
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:32.871
SC DTC Delayed Exchange Data | Failed connections: 9750 | 2024-03-17 10:51:32.871
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:32.871
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:32.872
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:32.872
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:32.872
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:32.873
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:33.063
DTC Client socket (2) | Closed. | 2024-03-17 10:51:33.063
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:51:34.872
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:34.912
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:34.912
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:51:34.912
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:35.056
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:35.056
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:35.056
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:35.199
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:35.199
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:35.338
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:35.338
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:35.338
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:35.338
SC DTC Delayed Exchange Data | Failed connections: 9751 | 2024-03-17 10:51:35.338
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:35.338
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:35.339
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:35.339
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:35.339
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:35.339
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:35.496
DTC Client socket (2) | Closed. | 2024-03-17 10:51:35.497
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:51:37.353
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:37.354
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:37.354
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:51:37.354
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:37.496
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:37.496
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:37.497
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:37.636
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:37.636
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:37.778
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:37.778
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:37.778
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:37.778
SC DTC Delayed Exchange Data | Failed connections: 9752 | 2024-03-17 10:51:37.778
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:37.778
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:37.779
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:37.779
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:37.779
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:37.779
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:37.923
DTC Client socket (2) | Closed. | 2024-03-17 10:51:37.923
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:39.782
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:39.783
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:39.784
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:51:39.784
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:39.927
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:39.927
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:39.927
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:40.208
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:40.208
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Failed connections: 9753 | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:40.347
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:40.347
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:40.348
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:40.348
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:40.348
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:40.483
DTC Client socket (2) | Closed. | 2024-03-17 10:51:40.483
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:51:42.340
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:42.342
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:42.342
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:51:42.342
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:42.487
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:42.487
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:42.487
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:42.644
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:42.644
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:42.790
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:42.790
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:42.790
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:42.790
SC DTC Delayed Exchange Data | Failed connections: 9754 | 2024-03-17 10:51:42.790
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:42.790
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:42.791
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:42.791
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:42.791
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:42.791
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:42.922
DTC Client socket (2) | Closed. | 2024-03-17 10:51:42.923
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:51:44.802
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:44.803
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:44.804
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:51:44.804
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:44.946
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:44.946
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:44.946
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:45.187
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:45.187
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:45.406
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:45.406
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:45.406
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:45.406
SC DTC Delayed Exchange Data | Failed connections: 9755 | 2024-03-17 10:51:45.406
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:45.406
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:45.407
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:45.407
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:45.407
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:45.407
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:45.572
DTC Client socket (2) | Closed. | 2024-03-17 10:51:45.572
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:51:47.425
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:47.426
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:47.426
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:51:47.426
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:47.576
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:47.576
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:47.576
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:47.818
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:47.818
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:47.993
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:47.993
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:47.993
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:47.993
SC DTC Delayed Exchange Data | Failed connections: 9756 | 2024-03-17 10:51:47.993
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:47.993
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:47.994
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:47.994
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:47.994
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:47.994
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:48.142
DTC Client socket (2) | Closed. | 2024-03-17 10:51:48.142
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:50.008
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:50.078
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:50.078
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:51:50.078
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:50.215
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:50.215
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:50.215
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:50.358
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:50.358
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:50.484
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:50.484
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:50.484
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:50.484
SC DTC Delayed Exchange Data | Failed connections: 9757 | 2024-03-17 10:51:50.484
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:50.484
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:50.485
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:50.485
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:50.485
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:50.485
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:50.622
DTC Client socket (2) | Closed. | 2024-03-17 10:51:50.623
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:52.494
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:52.531
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:52.531
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:51:52.531
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:52.676
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:52.676
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:52.677
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:52.837
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:52.838
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:52.977
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:52.977
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:52.977
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:51:52.977
SC DTC Delayed Exchange Data | Failed connections: 9758 | 2024-03-17 10:51:52.977
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:52.977
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:52.979
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:52.979
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:52.979
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:52.979
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:53.122
DTC Client socket (2) | Closed. | 2024-03-17 10:51:53.122
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:51:54.973
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:54.974
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:54.974
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:51:54.974
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:55.119
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:55.119
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:55.119
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:55.277
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:55.277
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:55.423
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:55.423
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:55.423
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:55.423
SC DTC Delayed Exchange Data | Failed connections: 9759 | 2024-03-17 10:51:55.423
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:55.423
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:55.424
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:55.424
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:55.424
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:55.424
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:55.562
DTC Client socket (2) | Closed. | 2024-03-17 10:51:55.562
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:51:57.442
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:57.443
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:57.444
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:51:57.444
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:51:57.596
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:51:57.596
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:51:57.596
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:51:57.748
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:51:57.748
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:51:57.886
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:51:57.886
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:51:57.886
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:51:57.886
SC DTC Delayed Exchange Data | Failed connections: 9760 | 2024-03-17 10:51:57.886
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:51:57.886
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:51:57.887
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:51:57.887
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:51:57.887
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:51:57.887
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:51:58.022
DTC Client socket (2) | Closed. | 2024-03-17 10:51:58.022
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:51:59.914
DTC Client socket (2) | Creating socket. | 2024-03-17 10:51:59.915
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:51:59.915
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:51:59.915
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:00.125
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:00.125
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:00.126
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:00.338
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:00.338
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Failed connections: 9761 | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:00.538
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:00.538
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:00.539
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:00.539
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:00.539
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:00.732
DTC Client socket (2) | Closed. | 2024-03-17 10:52:00.732
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:52:02.553
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:02.555
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:02.555
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:52:02.555
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:02.709
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:02.709
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:02.709
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:02.887
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:02.887
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Failed connections: 9762 | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:03.023
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:03.023
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:03.023
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:03.024
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:03.162
DTC Client socket (2) | Closed. | 2024-03-17 10:52:03.162
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:52:05.020
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:05.021
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:05.021
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:52:05.021
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:05.167
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:05.167
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:05.168
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:05.307
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:05.307
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:05.457
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:05.457
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:05.457
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:05.457
SC DTC Delayed Exchange Data | Failed connections: 9763 | 2024-03-17 10:52:05.457
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:05.457
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:05.458
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:05.458
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:05.458
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:05.459
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:05.603
DTC Client socket (2) | Closed. | 2024-03-17 10:52:05.603
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:07.468
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:07.469
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:07.469
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:52:07.469
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:07.605
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:07.605
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:07.605
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:07.818
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:07.818
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Failed connections: 9764 | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:07.974
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:07.974
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:07.975
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:07.975
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:07.975
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:08.111
DTC Client socket (2) | Closed. | 2024-03-17 10:52:08.112
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:52:09.980
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:09.981
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:09.982
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:52:09.982
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:10.127
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:10.127
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:10.127
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:10.289
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:10.289
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:10.442
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:10.442
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:10.442
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:10.442
SC DTC Delayed Exchange Data | Failed connections: 9765 | 2024-03-17 10:52:10.442
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:10.442
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:10.443
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:10.443
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:10.443
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:10.443
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:10.583
DTC Client socket (2) | Closed. | 2024-03-17 10:52:10.583
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:52:12.458
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:12.459
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:12.460
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:52:12.460
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:12.605
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:12.605
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:12.605
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:12.809
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:12.809
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Failed connections: 9766 | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:12.942
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:12.942
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:12.942
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:12.942
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:13.081
DTC Client socket (2) | Closed. | 2024-03-17 10:52:13.082
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:52:14.937
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:14.938
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:14.938
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:52:14.938
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:15.085
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:15.085
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:15.085
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:15.308
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:15.308
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:15.447
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:15.447
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:15.447
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:15.447
SC DTC Delayed Exchange Data | Failed connections: 9767 | 2024-03-17 10:52:15.447
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:15.447
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:15.448
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:15.448
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:15.448
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:15.448
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:15.591
DTC Client socket (2) | Closed. | 2024-03-17 10:52:15.591
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:17.454
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:17.455
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:17.456
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:52:17.456
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:17.600
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:17.600
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:17.600
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:17.756
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:17.756
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Failed connections: 9768 | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:17.897
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:17.897
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:17.897
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:17.897
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:18.041
DTC Client socket (2) | Closed. | 2024-03-17 10:52:18.041
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:19.887
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:19.889
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:19.889
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:52:19.889
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:20.034
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:20.034
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:20.034
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:20.173
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:20.173
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:20.310
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:20.310
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:20.310
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:20.310
SC DTC Delayed Exchange Data | Failed connections: 9769 | 2024-03-17 10:52:20.310
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:20.310
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:20.311
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:20.311
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:20.311
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:20.311
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:20.451
DTC Client socket (2) | Closed. | 2024-03-17 10:52:20.451
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:22.323
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:22.324
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:22.325
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:52:22.325
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:22.465
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:22.465
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:22.465
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:22.606
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:22.607
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:22.751
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:22.751
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:22.751
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:22.751
SC DTC Delayed Exchange Data | Failed connections: 9770 | 2024-03-17 10:52:22.751
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:22.751
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:22.752
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:22.752
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:22.752
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:22.752
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:22.891
DTC Client socket (2) | Closed. | 2024-03-17 10:52:22.891
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:52:24.767
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:24.769
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:24.769
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:52:24.769
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:24.915
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:24.915
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:24.915
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:25.069
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:25.069
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:25.219
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:25.219
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:25.219
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:25.219
SC DTC Delayed Exchange Data | Failed connections: 9771 | 2024-03-17 10:52:25.219
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:25.219
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:25.220
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:25.220
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:25.220
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:25.220
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:25.361
DTC Client socket (2) | Closed. | 2024-03-17 10:52:25.361
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:52:27.223
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:27.224
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:27.225
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:52:27.225
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:27.415
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:27.415
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:27.415
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:27.636
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:27.636
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:27.821
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:27.821
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:27.821
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:27.821
SC DTC Delayed Exchange Data | Failed connections: 9772 | 2024-03-17 10:52:27.822
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:27.822
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:27.822
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:27.822
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:27.822
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:27.823
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:28.013
DTC Client socket (2) | Closed. | 2024-03-17 10:52:28.013
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:52:29.811
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:29.811
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:29.812
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:52:29.812
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:29.955
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:29.955
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:29.955
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:30.094
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:30.094
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:30.229
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:30.229
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:30.229
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:30.229
SC DTC Delayed Exchange Data | Failed connections: 9773 | 2024-03-17 10:52:30.229
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:30.229
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:30.230
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:30.230
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:30.230
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:30.230
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:30.371
DTC Client socket (2) | Closed. | 2024-03-17 10:52:30.372
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:52:32.234
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:32.234
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:32.234
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:52:32.234
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:32.374
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:32.374
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:32.374
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:32.576
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:32.576
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:32.721
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:32.721
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:32.721
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:32.721
SC DTC Delayed Exchange Data | Failed connections: 9774 | 2024-03-17 10:52:32.721
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:32.721
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:32.722
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:32.722
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:32.722
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:32.722
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:32.860
DTC Client socket (2) | Closed. | 2024-03-17 10:52:32.860
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:34.719
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:34.749
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:34.749
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:52:34.749
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:34.893
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:34.893
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:34.893
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:35.122
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:35.122
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:35.263
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:35.263
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:35.263
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:35.263
SC DTC Delayed Exchange Data | Failed connections: 9775 | 2024-03-17 10:52:35.263
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:35.263
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:35.264
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:35.264
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:35.264
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:35.264
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:35.400
DTC Client socket (2) | Closed. | 2024-03-17 10:52:35.400
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:52:37.287
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:37.289
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:37.289
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:52:37.289
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:37.433
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:37.433
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:37.433
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:37.593
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:37.593
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:37.732
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:37.732
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:37.732
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:37.732
SC DTC Delayed Exchange Data | Failed connections: 9776 | 2024-03-17 10:52:37.732
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:37.732
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:37.733
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:37.733
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:37.733
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:37.733
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:37.870
DTC Client socket (2) | Closed. | 2024-03-17 10:52:37.870
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:52:39.746
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:39.747
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:39.747
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:52:39.747
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:39.894
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:39.894
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:39.894
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:40.226
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:40.226
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:40.410
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:40.410
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:40.410
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:40.410
SC DTC Delayed Exchange Data | Failed connections: 9777 | 2024-03-17 10:52:40.410
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:40.411
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:40.411
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:40.411
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:40.412
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:40.412
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:40.550
DTC Client socket (2) | Closed. | 2024-03-17 10:52:40.550
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:52:42.426
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:42.428
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:42.428
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:52:42.428
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:42.574
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:42.574
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:42.574
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:42.766
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:42.766
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:42.914
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:42.914
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:42.914
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:42.914
SC DTC Delayed Exchange Data | Failed connections: 9778 | 2024-03-17 10:52:42.914
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:42.914
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:42.915
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:42.915
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:42.915
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:42.916
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:43.060
DTC Client socket (2) | Closed. | 2024-03-17 10:52:43.060
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:44.920
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:44.921
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:44.921
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:52:44.921
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:45.062
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:45.062
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:45.062
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:45.225
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:45.225
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:45.364
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:45.364
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:45.364
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:45.364
SC DTC Delayed Exchange Data | Failed connections: 9779 | 2024-03-17 10:52:45.364
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:45.364
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:45.365
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:45.365
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:45.365
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:45.365
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:45.500
DTC Client socket (2) | Closed. | 2024-03-17 10:52:45.500
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:47.357
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:47.358
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:47.358
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:52:47.359
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:47.504
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:47.504
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:47.504
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:47.685
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:47.685
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:47.817
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:47.817
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:47.817
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:47.817
SC DTC Delayed Exchange Data | Failed connections: 9780 | 2024-03-17 10:52:47.817
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:47.817
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:47.818
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:47.818
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:47.818
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:47.818
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:47.960
DTC Client socket (2) | Closed. | 2024-03-17 10:52:47.960
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:52:49.819
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:49.820
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:49.820
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:52:49.820
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:49.967
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:49.967
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:49.968
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:50.135
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:50.135
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:50.274
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:50.274
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:50.274
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:50.274
SC DTC Delayed Exchange Data | Failed connections: 9781 | 2024-03-17 10:52:50.274
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:50.274
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:50.275
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:50.275
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:50.275
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:50.275
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:50.410
DTC Client socket (2) | Closed. | 2024-03-17 10:52:50.410
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 10:52:52.277
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:52.278
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:52.278
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 10:52:52.278
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:52.424
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:52.424
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:52.424
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:52.583
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:52.583
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Failed connections: 9782 | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:52.726
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:52.726
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:52.727
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:52.727
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:52.869
DTC Client socket (2) | Closed. | 2024-03-17 10:52:52.870
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 10:52:54.717
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:54.719
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:54.719
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 10:52:54.719
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:54.914
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:54.914
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:54.914
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:55.104
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:55.104
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:55.302
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:55.302
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:55.302
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:52:55.302
SC DTC Delayed Exchange Data | Failed connections: 9783 | 2024-03-17 10:52:55.302
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:55.302
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:55.302
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:55.303
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:55.303
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:55.303
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:55.489
DTC Client socket (2) | Closed. | 2024-03-17 10:52:55.489
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 10:52:57.295
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:57.296
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:57.296
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 10:52:57.296
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:57.443
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:57.444
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:57.444
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:52:57.606
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:52:57.606
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:52:57.749
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:52:57.749
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:52:57.749
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:52:57.749
SC DTC Delayed Exchange Data | Failed connections: 9784 | 2024-03-17 10:52:57.749
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:52:57.749
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:52:57.750
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:52:57.750
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:52:57.750
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:52:57.750
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:52:57.900
DTC Client socket (2) | Closed. | 2024-03-17 10:52:57.900
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:52:59.756
DTC Client socket (2) | Creating socket. | 2024-03-17 10:52:59.757
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:52:59.757
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:52:59.757
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:52:59.913
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:52:59.913
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:52:59.913
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:00.082
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:00.082
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Failed connections: 9785 | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:00.230
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:00.230
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:00.231
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:00.231
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:00.231
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:00.369
DTC Client socket (2) | Closed. | 2024-03-17 10:53:00.369
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 10:53:02.241
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:02.242
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:02.242
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 10:53:02.242
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:02.381
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:02.381
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:02.381
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:02.594
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:02.594
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:02.830
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:02.830
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:02.830
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:53:02.830
SC DTC Delayed Exchange Data | Failed connections: 9786 | 2024-03-17 10:53:02.830
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:02.830
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:02.832
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:02.832
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:02.833
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:02.833
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:03.019
DTC Client socket (2) | Closed. | 2024-03-17 10:53:03.019
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 10:53:04.828
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:04.829
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:04.829
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 10:53:04.829
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:04.975
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:04.975
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:04.975
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:05.114
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:05.114
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Failed connections: 9787 | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:05.250
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:05.250
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:05.250
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:05.250
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:05.389
DTC Client socket (2) | Closed. | 2024-03-17 10:53:05.389
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 10:53:07.246
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:07.247
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:07.247
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 10:53:07.247
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:07.404
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:07.404
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:07.404
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:07.646
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:07.646
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Failed connections: 9788 | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:07.784
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:07.784
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:07.784
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:07.785
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:07.922
DTC Client socket (2) | Closed. | 2024-03-17 10:53:07.923
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 10:53:09.825
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:09.826
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:09.826
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 10:53:09.826
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:09.973
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:09.973
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:09.973
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:10.165
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:10.165
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Failed connections: 9789 | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:10.327
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:10.327
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:10.327
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:10.328
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:10.498
DTC Client socket (2) | Closed. | 2024-03-17 10:53:10.498
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 10:53:12.345
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:12.346
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:12.346
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 10:53:12.346
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:12.493
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:12.493
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:12.493
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:12.655
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:12.655
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:12.786
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:12.786
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:12.786
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 10:53:12.786
SC DTC Delayed Exchange Data | Failed connections: 9790 | 2024-03-17 10:53:12.786
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:12.786
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:12.787
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:12.787
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:12.787
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:12.787
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:12.929
DTC Client socket (2) | Closed. | 2024-03-17 10:53:12.929
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 10:53:14.781
DTC Client socket (2) | Creating socket. | 2024-03-17 10:53:14.795
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 10:53:14.795
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-17 10:53:14.795
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 10:53:14.993
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 10:53:14.993
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 10:53:14.993
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 10:53:15.163
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 10:53:15.163
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 10:53:15.327
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 10:53:15.327
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 10:53:15.327
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 10:53:15.327
SC DTC Delayed Exchange Data | Failed connections: 9791 | 2024-03-17 10:53:15.327
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 10:53:15.327
DTC Client socket (2) | CloseSocket call. | 2024-03-17 10:53:15.328
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 10:53:15.328
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 10:53:15.328
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 10:53:15.328
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 10:53:15.472
DTC Client socket (2) | Closed. | 2024-03-17 10:53:15.473
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:10:50.533
DTC Client socket (2) | Using previously cached IP address because unable to resolve domain name | 2024-03-17 20:10:53.605
DTC Client socket (2) | Creating socket. | 2024-03-17 20:10:53.605
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:10:53.605
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:10:53.605
DTC Client socket (2) | Connect event error. Windows error code 10065: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnym hoście. | 2024-03-17 20:10:53.605 *
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:10:53.701
SC DTC Delayed Exchange Data | Failed connections: 9792 | 2024-03-17 20:10:53.701
DTC Client socket (0) | CloseSocket call. | 2024-03-17 20:10:53.701
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:10:53.701
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:10:53.701
DTC Client socket (2) | Closed. | 2024-03-17 20:10:53.734
Notice: Detected that the system has resumed from a low-power state. | 2024-03-17 20:10:55.413
Re-connecting to the Data/Trading service. | 2024-03-17 20:10:55.413
DTC Client socket (0) | CloseSocket call. | 2024-03-17 20:10:56.723
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:10:56.727
SC Data - All Services | Disconnected. | 2024-03-17 20:10:56.728
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2024-03-17 20:10:56.731
SC Data - All Services | Connected to server complete. | 2024-03-17 20:10:59.194
Triggering next historical data download in queue. | 2024-03-17 20:10:59.195
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2024-03-17 20:10:59.195
No download requests in the queue to start downloads for. | 2024-03-17 20:10:59.331
Mapping ESH24-CME to ESH24. Service code: cme | 2024-03-17 20:10:59.332
Using symbol data fast lookup vector | 2024-03-17 20:10:59.332
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESH24-CME (ESH24). ID: 1 Service code: cme | 2024-03-17 20:10:59.332
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:10:59.332
SC DTC Delayed Exchange Data | Requesting security definition data for: ESH24-CME (ESH24). ID: 1 | 2024-03-17 20:10:59.332
Requesting market depth updates for: ESH24-CME if supported. | 2024-03-17 20:10:59.332
Separate subscription for market depth updates not supported. ESH24-CME | 2024-03-17 20:10:59.332
Added historical Intraday data request for ESH24-CME to the queue. | 2024-03-17 20:10:59.332
Intraday data recording state for symbol ESH24-CME is set to download 'Pending'. | 2024-03-17 20:10:59.332
Triggering next historical data download in queue. | 2024-03-17 20:10:59.332
Delaying start of download for ESH24-CME. | 2024-03-17 20:10:59.334
DTC Client socket (2) | Creating socket. | 2024-03-17 20:10:59.426
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:10:59.426
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:10:59.426
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:10:59.612
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:10:59.612
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:10:59.612
Mapping MESH24-CME to MESH24. Service code: cme | 2024-03-17 20:10:59.768
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH24-CME (MESH24). ID: 2 Service code: cme | 2024-03-17 20:10:59.769
SC DTC Delayed Exchange Data | Requesting security definition data for: MESH24-CME (MESH24). ID: 2 | 2024-03-17 20:10:59.769
Added historical Intraday data request for MESH24-CME to the queue. | 2024-03-17 20:10:59.769
Intraday data recording state for symbol MESH24-CME is set to download 'Pending'. | 2024-03-17 20:10:59.769
Triggering next historical data download in queue. | 2024-03-17 20:10:59.769
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:10:59.867
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:10:59.867
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:00.012
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:00.012
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:00.012
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:00.012
SC DTC Delayed Exchange Data | Failed connections: 9793 | 2024-03-17 20:11:00.012
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:00.012
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:00.012
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:00.013
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:00.013
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:00.013
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:00.172
DTC Client socket (2) | Closed. | 2024-03-17 20:11:00.172
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:11:02.044
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:02.155
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:02.155
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:11:02.155
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:02.358
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:02.358
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:02.358
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:02.616
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:02.616
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:02.806
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:02.806
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:02.806
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:02.806
SC DTC Delayed Exchange Data | Failed connections: 9794 | 2024-03-17 20:11:02.806
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:02.806
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:02.806
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:02.807
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:02.807
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:02.807
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:03.015
DTC Client socket (2) | Closed. | 2024-03-17 20:11:03.016
Requesting market depth updates for: MESH24-CME if supported. | 2024-03-17 20:11:04.203
Separate subscription for market depth updates not supported. MESH24-CME | 2024-03-17 20:11:04.203
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:11:04.826
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:04.896
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:04.896
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:11:04.896
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:05.062
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:05.062
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:05.062
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:05.233
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:05.233
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:05.380
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:05.380
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:05.380
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:05.380
SC DTC Delayed Exchange Data | Failed connections: 9795 | 2024-03-17 20:11:05.380
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:05.380
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:05.381
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:05.381
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:05.381
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:05.381
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:05.526
DTC Client socket (2) | Closed. | 2024-03-17 20:11:05.526
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:11:07.374
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:07.444
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:07.444
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:11:07.444
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:07.605
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:07.605
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:07.605
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:07.770
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:07.770
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:07.921
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:07.921
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:07.921
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:07.922
SC DTC Delayed Exchange Data | Failed connections: 9796 | 2024-03-17 20:11:07.922
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:07.922
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:07.922
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:07.922
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:07.922
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:07.922
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:08.052
DTC Client socket (2) | Closed. | 2024-03-17 20:11:08.052
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:09.928
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:09.978
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:09.978
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:11:09.978
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:10.119
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:10.119
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:10.120
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:10.396
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:10.396
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:10.744
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:10.744
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:10.744
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:10.744
SC DTC Delayed Exchange Data | Failed connections: 9797 | 2024-03-17 20:11:10.744
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:10.744
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:10.745
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:10.745
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:10.745
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:10.745
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:10.987
DTC Client socket (2) | Closed. | 2024-03-17 20:11:10.987
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:11:12.770
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:12.771
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:12.771
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:11:12.771
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:12.916
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:12.916
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:12.916
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:13.082
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:13.082
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:13.224
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:13.224
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:13.224
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:13.224
SC DTC Delayed Exchange Data | Failed connections: 9798 | 2024-03-17 20:11:13.224
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:13.224
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:13.225
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:13.225
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:13.225
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:13.225
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:13.355
DTC Client socket (2) | Closed. | 2024-03-17 20:11:13.355
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:11:15.239
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:15.295
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:15.295
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:11:15.295
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:15.435
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:15.435
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:15.435
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:15.716
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:15.716
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:15.852
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:15.852
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:15.852
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:15.852
SC DTC Delayed Exchange Data | Failed connections: 9799 | 2024-03-17 20:11:15.852
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:15.852
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:15.853
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:15.853
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:15.853
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:15.853
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:15.994
DTC Client socket (2) | Closed. | 2024-03-17 20:11:15.994
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:11:17.868
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:17.910
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:17.910
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:11:17.910
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:18.055
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:18.055
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:18.055
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:18.327
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:18.327
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Failed connections: 9800 | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:18.466
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:18.466
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:18.466
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:18.466
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:18.612
DTC Client socket (2) | Closed. | 2024-03-17 20:11:18.612
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:20.476
DTC Client socket (2) | Creating socket. | 2024-03-17 20:11:20.513
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:20.513
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:11:20.513
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:20.654
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:20.654
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:20.654
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:20.812
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:20.812
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:20.952
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:20.952
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:20.952
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:20.952
SC DTC Delayed Exchange Data | Failed connections: 9801 | 2024-03-17 20:11:20.952
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:20.952
DTC Client socket (2) | CloseSocket call. | 2024-03-17 20:11:20.953
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:20.953
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:20.953
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:20.953
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:21.092
DTC Client socket (2) | Closed. | 2024-03-17 20:11:21.092
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:22.954
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:22.974
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:22.974
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:11:22.974
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:23.116
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:23.116
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:23.116
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:23.260
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:23.260
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:23.404
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Failed connections: 9802 | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:23.405
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:23.405
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:23.405
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:23.405
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:23.543
DTC Client socket (1) | Closed. | 2024-03-17 20:11:23.543
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:25.415
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:25.416
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:25.416
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:11:25.416
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:25.554
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:25.554
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:25.554
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:25.709
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:25.709
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Failed connections: 9803 | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:25.849
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:25.849
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:25.849
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:25.849
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:25.981
DTC Client socket (1) | Closed. | 2024-03-17 20:11:25.981
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:11:27.858
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:27.863
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:27.863
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:11:27.863
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:28.005
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:28.005
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:28.005
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:28.173
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:28.173
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Failed connections: 9804 | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:28.305
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:28.305
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:28.305
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:28.305
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:28.441
DTC Client socket (1) | Closed. | 2024-03-17 20:11:28.441
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:11:30.294
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:30.294
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:30.294
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:11:30.294
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:30.493
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:30.493
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:30.493
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:30.684
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:30.684
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Failed connections: 9805 | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:30.900
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:30.900
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:30.900
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:30.901
HD Request # 44 | Downloading Intraday chart data for ESH24-CME to the file ESH24-CME.scid. Service: cme | 2024-03-17 20:11:30.930
HD Request # 44 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.847001 | 2024-03-17 20:11:30.930
HD Request # 44 | Using server: ds26.sierracharts.com port 10150 | 2024-03-17 20:11:30.930
Socket (2) | Creating socket. | 2024-03-17 20:11:30.931
Socket (2) | New receive buffer size: 5242880 | 2024-03-17 20:11:30.931
Socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:11:30.931
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:31.092
DTC Client socket (1) | Closed. | 2024-03-17 20:11:31.092
HD Request # 44 | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:31.212
HD Request # 44 | Sending historical data logon request message. | 2024-03-17 20:11:31.212
HD Request # 44 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: ESH24 | 2024-03-17 20:11:31.591
HD Request # 44 | Decompressing data. | 2024-03-17 20:11:31.733
HD Request # 44 | Receiving Intraday data for ESH24-CME starting at 2024-03-15 13:29:59.110000 | 2024-03-17 20:11:31.854
Socket (2) | CloseSocket call. | 2024-03-17 20:11:31.854
Historical data download thread signaled to stop. | 2024-03-17 20:11:31.854
Socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:31.854
HD Request # 44 | Received 31 Intraday data records from 2024-03-15 13:29:59.110000 to 2024-03-15 13:29:59.847001 (0.7 seconds. Delay: 2.3 days) and wrote 0 records for ESH24-CME | 2024-03-17 20:11:31.854
HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.847001 | 2024-03-17 20:11:31.854
HD Request # 44 | Completion time: 1s. | 2024-03-17 20:11:31.855
HD Request # 44 | Intraday data download complete for ESH24-CME. Unique request ID: 44 | 2024-03-17 20:11:31.855
Removing historical data download ID 44. | 2024-03-17 20:11:31.855
Real-time Intraday chart data file updates started for ESH24-CME | 2024-03-17 20:11:31.855
Intraday chart data file opened for ESH24-CME | 2024-03-17 20:11:31.855
HD Request # 44 | Enabling Intraday chart updating for symbol. | 2024-03-17 20:11:31.855
Triggering next historical data download in queue. | 2024-03-17 20:11:31.855
Historical data for ESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-17 20:11:31.855
HD Request # 45 | Downloading Intraday chart data for MESH24-CME to the file MESH24-CME.scid. Service: cme | 2024-03-17 20:11:31.855
HD Request # 45 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.465000 | 2024-03-17 20:11:31.861
HD Request # 45 | Using server: ds28.sierracharts.com port 10149 | 2024-03-17 20:11:31.861
Socket (1) | Creating socket. | 2024-03-17 20:11:31.862
Socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:31.862
Socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:11:31.862
Socket (2) | Socket gracefully closed by remote side. | 2024-03-17 20:11:31.991
Socket (2) | Closed. | 2024-03-17 20:11:31.991
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-17 20:11:32.027
Chart #1 has tagged chart #14 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.034
Chart #1 has tagged chart #6 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.034
Chart #1 has tagged chart #8 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.034
Chart #1 has tagged chart #9 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.034
ESH24-CME[M] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-17 20:11:32.041
HD Request # 45 | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:32.142
HD Request # 45 | Sending historical data logon request message. | 2024-03-17 20:11:32.142
Chart #1 has tagged chart #2 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-17 20:11:32.390
ESH24-CME[M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-17 20:11:32.513
HD Request # 45 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: MESH24 | 2024-03-17 20:11:32.516
ESH24-CME[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.574
HD Request # 45 | Decompressing data. | 2024-03-17 20:11:32.653
ESH24-CME[M] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.693
ESH24-CME[M] 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:32.732
HD Request # 45 | Receiving Intraday data for MESH24-CME starting at 2024-03-15 13:29:59.188000 | 2024-03-17 20:11:32.779
Socket (1) | CloseSocket call. | 2024-03-17 20:11:32.779
Socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:32.779
Socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:32.911
Socket (1) | Closed. | 2024-03-17 20:11:32.911
Historical data download thread signaled to stop. | 2024-03-17 20:11:32.996
HD Request # 45 | Received 2 Intraday data records from 2024-03-15 13:29:59.188000 to 2024-03-15 13:29:59.465000 (0.3 seconds. Delay: 2.3 days) and wrote 0 records for MESH24-CME | 2024-03-17 20:11:32.997
HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.465000 | 2024-03-17 20:11:32.997
HD Request # 45 | Completion time: 1s. | 2024-03-17 20:11:32.997
HD Request # 45 | Intraday data download complete for MESH24-CME. Unique request ID: 45 | 2024-03-17 20:11:32.997
Removing historical data download ID 45. | 2024-03-17 20:11:32.997
Real-time Intraday chart data file updates started for MESH24-CME | 2024-03-17 20:11:32.997
Intraday chart data file opened for MESH24-CME | 2024-03-17 20:11:32.997
HD Request # 45 | Enabling Intraday chart updating for symbol. | 2024-03-17 20:11:32.997
Triggering next historical data download in queue. | 2024-03-17 20:11:32.997
Historical data for MESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-17 20:11:32.997
No download requests in the queue to start downloads for. | 2024-03-17 20:11:32.997
ESH24-CME[M] 5 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-17 20:11:33.001
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:11:33.050
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:33.051
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:33.051
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:11:33.051
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:33.184
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:33.184
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:33.184
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:33.326
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:33.326
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Failed connections: 9806 | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:33.471
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:33.471
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:33.471
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:33.471
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:33.611
DTC Client socket (1) | Closed. | 2024-03-17 20:11:33.611
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:11:35.468
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:35.469
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:35.469
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:11:35.469
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:35.613
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:35.613
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:35.613
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:35.754
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:35.754
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Failed connections: 9807 | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:35.887
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:35.887
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:35.887
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:35.887
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:36.031
DTC Client socket (1) | Closed. | 2024-03-17 20:11:36.031
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:37.905
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:37.905
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:37.906
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:11:37.906
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:38.043
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:38.043
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:38.043
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:38.374
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:38.374
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Failed connections: 9808 | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:38.601
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:38.601
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:38.602
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:38.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:38.602
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:38.761
DTC Client socket (1) | Closed. | 2024-03-17 20:11:38.761
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:11:40.614
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:40.618
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:40.618
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:11:40.618
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:40.754
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:40.754
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:40.754
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:40.923
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:40.923
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:41.063
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:41.063
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:41.063
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:41.063
SC DTC Delayed Exchange Data | Failed connections: 9809 | 2024-03-17 20:11:41.063
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:41.063
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:41.064
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:41.064
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:41.064
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:41.064
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:41.201
DTC Client socket (1) | Closed. | 2024-03-17 20:11:41.201
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:11:43.063
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:43.063
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:43.063
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:11:43.063
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:43.202
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:43.202
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:43.202
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:43.522
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:43.522
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Failed connections: 9810 | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:43.670
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:43.670
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:43.670
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:43.670
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:43.821
DTC Client socket (1) | Closed. | 2024-03-17 20:11:43.821
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:11:45.680
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:45.681
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:45.681
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:11:45.681
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:45.823
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:45.823
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:45.823
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:46.063
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:46.063
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Failed connections: 9811 | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:46.212
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:46.212
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:46.212
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:46.212
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:46.350
DTC Client socket (1) | Closed. | 2024-03-17 20:11:46.350
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:48.226
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:48.227
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:48.227
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:11:48.227
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:48.373
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:48.373
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:48.373
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:48.546
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:48.546
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Failed connections: 9812 | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:48.686
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:48.686
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:48.686
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:48.686
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:48.830
DTC Client socket (1) | Closed. | 2024-03-17 20:11:48.831
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:50.713
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:50.714
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:50.714
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:11:50.714
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:50.853
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:50.853
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:50.853
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:50.992
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:50.992
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Failed connections: 9813 | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:51.132
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:51.132
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:51.132
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:51.132
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:51.273
DTC Client socket (1) | Closed. | 2024-03-17 20:11:51.273
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:11:53.133
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:53.134
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:53.134
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:11:53.134
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:53.283
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:53.283
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:53.283
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:53.453
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:53.453
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Failed connections: 9814 | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:53.596
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:53.596
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:53.596
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:53.596
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:53.761
DTC Client socket (1) | Closed. | 2024-03-17 20:11:53.762
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:11:55.593
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:55.594
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:55.594
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:11:55.594
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:55.732
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:55.732
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:55.732
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:55.903
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:55.903
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:56.048
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:56.048
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:56.048
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:56.048
SC DTC Delayed Exchange Data | Failed connections: 9815 | 2024-03-17 20:11:56.048
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:56.048
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:56.049
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:56.049
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:56.049
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:56.049
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:56.190
DTC Client socket (1) | Closed. | 2024-03-17 20:11:56.190
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:11:58.057
DTC Client socket (1) | Creating socket. | 2024-03-17 20:11:58.058
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:11:58.058
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:11:58.058
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:11:58.252
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:11:58.252
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:11:58.252
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:11:58.443
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:11:58.443
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Failed connections: 9816 | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:11:58.621
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:11:58.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:11:58.621
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:11:58.621
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:11:58.810
DTC Client socket (1) | Closed. | 2024-03-17 20:11:58.810
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:12:00.633
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:00.634
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:00.634
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:12:00.634
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:00.774
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:00.774
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:00.774
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:00.942
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:00.942
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Failed connections: 9817 | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:01.071
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:01.071
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:01.071
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:01.071
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:01.210
DTC Client socket (1) | Closed. | 2024-03-17 20:12:01.210
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:12:03.073
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:03.074
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:03.074
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:12:03.074
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:03.213
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:03.213
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:03.213
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:03.360
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:03.360
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:03.490
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:03.490
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:03.490
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:03.490
SC DTC Delayed Exchange Data | Failed connections: 9818 | 2024-03-17 20:12:03.490
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:03.490
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:03.491
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:03.491
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:03.491
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:03.491
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:03.633
DTC Client socket (1) | Closed. | 2024-03-17 20:12:03.633
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:05.506
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:05.506
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:05.507
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:12:05.507
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:05.654
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:05.654
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:05.654
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:05.901
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:05.901
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Failed connections: 9819 | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:06.049
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:06.049
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:06.049
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:06.049
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:06.195
DTC Client socket (1) | Closed. | 2024-03-17 20:12:06.195
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:12:08.055
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:08.056
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:08.056
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:12:08.056
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:08.193
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:08.194
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:08.194
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:08.362
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:08.362
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Failed connections: 9820 | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:08.504
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:08.504
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:08.504
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:08.504
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:08.640
DTC Client socket (1) | Closed. | 2024-03-17 20:12:08.640
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:12:10.517
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:10.518
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:10.518
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:12:10.518
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:10.651
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:10.651
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:10.651
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:11.082
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:11.082
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Failed connections: 9821 | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:11.222
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:11.222
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:11.222
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:11.222
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:11.362
DTC Client socket (1) | Closed. | 2024-03-17 20:12:11.362
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:12:13.225
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:13.226
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:13.226
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:12:13.226
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:13.374
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:13.374
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:13.374
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:14.095
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:14.095
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:14.386
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:14.386
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:14.386
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:14.386
SC DTC Delayed Exchange Data | Failed connections: 9822 | 2024-03-17 20:12:14.386
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:14.386
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:14.387
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:14.388
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:14.388
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:14.388
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:14.629
DTC Client socket (1) | Closed. | 2024-03-17 20:12:14.629
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:16.387
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:16.390
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:16.390
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:12:16.390
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:16.611
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:16.611
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:16.611
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:16.785
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:16.785
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:16.919
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:16.919
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:16.919
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:16.919
SC DTC Delayed Exchange Data | Failed connections: 9823 | 2024-03-17 20:12:16.919
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:16.920
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:16.920
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:16.920
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:16.920
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:16.920
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:17.069
DTC Client socket (1) | Closed. | 2024-03-17 20:12:17.069
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:18.922
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:18.923
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:18.923
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:12:18.923
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:19.061
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:19.061
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:19.061
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:19.204
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:19.204
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:19.351
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:19.351
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:19.351
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:19.351
SC DTC Delayed Exchange Data | Failed connections: 9824 | 2024-03-17 20:12:19.351
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:19.351
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:19.352
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:19.352
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:19.352
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:19.352
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:19.492
DTC Client socket (1) | Closed. | 2024-03-17 20:12:19.492
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:21.354
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:21.355
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:21.355
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:12:21.355
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:21.501
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:21.501
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:21.501
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:21.652
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:21.652
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Failed connections: 9825 | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:21.784
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:21.784
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:21.784
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:21.784
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:21.920
DTC Client socket (1) | Closed. | 2024-03-17 20:12:21.920
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:12:23.788
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:23.790
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:23.790
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:12:23.790
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:23.942
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:23.942
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:23.942
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:24.132
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:24.132
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Failed connections: 9826 | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:24.271
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:24.271
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:24.271
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:24.272
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:24.409
DTC Client socket (1) | Closed. | 2024-03-17 20:12:24.409
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:12:26.290
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:26.292
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:26.292
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:12:26.292
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:26.481
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:26.481
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:26.481
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:26.693
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:26.693
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Failed connections: 9827 | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:26.878
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:26.878
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:26.878
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:26.879
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:27.070
DTC Client socket (1) | Closed. | 2024-03-17 20:12:27.070
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:12:28.873
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:28.874
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:28.875
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:12:28.875
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:29.024
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:29.024
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:29.024
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:29.191
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:29.191
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:29.329
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:29.329
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:29.329
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:29.329
SC DTC Delayed Exchange Data | Failed connections: 9828 | 2024-03-17 20:12:29.329
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:29.329
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:29.330
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:29.330
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:29.330
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:29.330
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:29.468
DTC Client socket (1) | Closed. | 2024-03-17 20:12:29.469
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:12:31.339
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:31.340
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:31.340
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:12:31.340
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:31.482
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:31.482
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:31.482
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:31.641
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:31.641
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:31.792
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Failed connections: 9829 | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:31.793
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:31.793
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:31.793
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:31.793
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:31.930
DTC Client socket (1) | Closed. | 2024-03-17 20:12:31.930
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:33.820
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:33.821
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:33.821
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:12:33.821
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:33.963
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:33.963
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:33.964
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:34.222
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:34.222
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Failed connections: 9830 | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:34.350
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:34.350
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:34.350
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:34.350
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:34.488
DTC Client socket (1) | Closed. | 2024-03-17 20:12:34.488
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:12:36.351
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:36.352
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:36.352
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:12:36.352
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:36.490
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:36.490
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:36.490
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:36.654
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:36.655
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:36.798
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:36.798
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:36.798
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:36.798
SC DTC Delayed Exchange Data | Failed connections: 9831 | 2024-03-17 20:12:36.798
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:36.798
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:36.799
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:36.799
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:36.799
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:36.799
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:36.938
DTC Client socket (1) | Closed. | 2024-03-17 20:12:36.939
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:12:38.806
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:38.808
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:38.809
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:12:38.809
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:38.963
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:38.964
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:38.964
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:39.264
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:39.264
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:39.468
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:39.468
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:39.468
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:39.468
SC DTC Delayed Exchange Data | Failed connections: 9832 | 2024-03-17 20:12:39.468
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:39.468
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:39.469
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:39.469
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:39.469
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:39.469
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:39.658
DTC Client socket (1) | Closed. | 2024-03-17 20:12:39.659
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:12:41.467
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:41.468
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:41.468
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:12:41.468
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:41.613
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:41.613
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:41.613
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:41.972
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:41.972
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:42.239
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:42.239
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:42.239
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:42.239
SC DTC Delayed Exchange Data | Failed connections: 9833 | 2024-03-17 20:12:42.239
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:42.239
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:42.240
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:42.240
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:42.240
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:42.240
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:42.388
DTC Client socket (1) | Closed. | 2024-03-17 20:12:42.389
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:44.240
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:44.241
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:44.241
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:12:44.241
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:44.380
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:44.380
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:44.380
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:44.550
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:44.550
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:44.700
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:44.700
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:44.700
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:44.701
SC DTC Delayed Exchange Data | Failed connections: 9834 | 2024-03-17 20:12:44.701
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:44.701
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:44.701
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:44.702
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:44.702
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:44.702
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:44.838
DTC Client socket (1) | Closed. | 2024-03-17 20:12:44.838
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:46.714
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:46.715
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:46.715
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:12:46.715
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:46.860
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:46.860
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:46.860
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:47.020
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:47.020
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:47.159
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:47.159
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:47.159
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:47.159
SC DTC Delayed Exchange Data | Failed connections: 9835 | 2024-03-17 20:12:47.159
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:47.159
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:47.160
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:47.160
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:47.160
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:47.160
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:47.298
DTC Client socket (1) | Closed. | 2024-03-17 20:12:47.298
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:12:49.152
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:49.153
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:49.153
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:12:49.153
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:49.299
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:49.299
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:49.299
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:49.439
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:49.439
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Failed connections: 9836 | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:49.588
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:49.588
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:49.588
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:49.588
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:49.727
DTC Client socket (1) | Closed. | 2024-03-17 20:12:49.728
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:12:51.593
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:51.594
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:51.594
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:12:51.594
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:51.741
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:51.741
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:51.742
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:51.910
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:51.910
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Failed connections: 9837 | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:52.045
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:52.045
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:52.045
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:52.045
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:52.188
DTC Client socket (1) | Closed. | 2024-03-17 20:12:52.188
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:12:54.052
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:54.052
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:54.053
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:12:54.053
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:54.240
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:54.240
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:54.240
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:54.463
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:54.463
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Failed connections: 9838 | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:54.645
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:54.645
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:54.645
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:54.645
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:54.839
DTC Client socket (1) | Closed. | 2024-03-17 20:12:54.839
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:12:56.640
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:56.641
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:56.641
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:12:56.641
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:56.799
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:56.799
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:56.799
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:56.941
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:56.941
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:57.094
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:57.094
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:57.094
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:12:57.094
SC DTC Delayed Exchange Data | Failed connections: 9839 | 2024-03-17 20:12:57.094
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:57.095
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:57.095
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:57.095
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:57.095
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:57.095
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:57.237
DTC Client socket (1) | Closed. | 2024-03-17 20:12:57.237
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:12:59.096
DTC Client socket (1) | Creating socket. | 2024-03-17 20:12:59.096
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:12:59.097
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:12:59.097
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:12:59.239
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:12:59.239
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:12:59.239
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:12:59.379
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:12:59.379
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Failed connections: 9840 | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:12:59.519
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:12:59.519
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:12:59.519
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:12:59.520
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:12:59.667
DTC Client socket (1) | Closed. | 2024-03-17 20:12:59.668
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:01.537
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:01.537
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:01.537
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:13:01.537
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:01.683
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:01.683
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:01.683
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:02.001
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:02.002
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Failed connections: 9841 | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:02.138
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:02.138
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:02.138
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:02.138
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:02.347
DTC Client socket (1) | Closed. | 2024-03-17 20:13:02.347
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:13:04.161
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:04.162
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:04.163
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:13:04.163
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:04.314
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:04.314
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:04.315
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:04.496
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:04.496
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Failed connections: 9842 | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:04.630
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:04.630
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:04.630
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:04.630
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:04.762
DTC Client socket (1) | Closed. | 2024-03-17 20:13:04.762
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:13:06.636
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:06.649
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:06.649
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:13:06.649
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:06.802
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:06.802
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:06.802
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:07.280
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:07.280
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:08.260
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:08.260
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:08.260
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:08.260
SC DTC Delayed Exchange Data | Failed connections: 9843 | 2024-03-17 20:13:08.260
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:08.260
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:08.261
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:08.261
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:08.261
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:08.261
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:08.497
DTC Client socket (1) | Closed. | 2024-03-17 20:13:08.497
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:13:10.266
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:10.282
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:10.283
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:13:10.283
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:10.438
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:10.438
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:10.438
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:10.703
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:10.703
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:10.876
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:10.876
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:10.876
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:10.876
SC DTC Delayed Exchange Data | Failed connections: 9844 | 2024-03-17 20:13:10.876
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:10.876
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:10.876
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:10.877
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:10.877
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:10.877
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:11.022
DTC Client socket (1) | Closed. | 2024-03-17 20:13:11.022
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:12.883
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:12.884
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:12.884
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:13:12.884
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:13.029
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:13.029
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:13.029
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:13.171
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:13.171
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Failed connections: 9845 | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:13.310
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:13.310
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:13.310
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:13.311
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:13.446
DTC Client socket (1) | Closed. | 2024-03-17 20:13:13.447
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:15.330
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:15.330
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:15.331
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:13:15.331
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:15.468
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:15.468
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:15.468
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:15.598
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:15.598
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:15.741
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:15.741
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:15.741
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:15.741
SC DTC Delayed Exchange Data | Failed connections: 9846 | 2024-03-17 20:13:15.741
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:15.741
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:15.742
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:15.742
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:15.742
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:15.742
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:15.877
DTC Client socket (1) | Closed. | 2024-03-17 20:13:15.877
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:17.751
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:17.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:17.778
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:13:17.778
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:17.938
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:17.938
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:17.938
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:18.090
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:18.090
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:18.237
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:18.237
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:18.237
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:18.237
SC DTC Delayed Exchange Data | Failed connections: 9847 | 2024-03-17 20:13:18.237
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:18.237
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:18.238
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:18.238
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:18.238
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:18.238
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:18.390
DTC Client socket (1) | Closed. | 2024-03-17 20:13:18.390
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:13:20.236
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:20.237
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:20.238
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:13:20.238
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:20.384
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:20.384
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:20.384
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:20.547
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:20.547
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:20.696
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:20.696
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:20.696
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:20.696
SC DTC Delayed Exchange Data | Failed connections: 9848 | 2024-03-17 20:13:20.696
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:20.696
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:20.697
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:20.697
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:20.697
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:20.697
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:20.836
DTC Client socket (1) | Closed. | 2024-03-17 20:13:20.837
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:13:22.686
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:22.687
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:22.687
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:13:22.687
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:22.883
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:22.883
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:22.883
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:23.083
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:23.083
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:23.260
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:23.260
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:23.260
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:23.260
SC DTC Delayed Exchange Data | Failed connections: 9849 | 2024-03-17 20:13:23.260
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:23.260
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:23.261
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:23.261
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:23.261
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:23.261
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:23.446
DTC Client socket (1) | Closed. | 2024-03-17 20:13:23.447
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:13:25.266
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:25.267
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:25.267
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:13:25.267
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:25.422
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:25.422
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:25.423
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:25.579
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:25.579
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:25.719
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Failed connections: 9850 | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:25.720
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:25.720
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:25.720
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:25.720
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:25.861
DTC Client socket (1) | Closed. | 2024-03-17 20:13:25.861
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:13:27.724
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:27.725
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:27.725
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:13:27.725
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:27.859
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:27.859
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:27.859
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:28.031
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:28.031
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Failed connections: 9851 | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:28.167
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:28.167
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:28.167
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:28.167
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:28.306
DTC Client socket (1) | Closed. | 2024-03-17 20:13:28.306
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:30.174
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:30.175
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:30.175
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:13:30.175
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:30.312
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:30.312
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:30.312
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:30.608
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:30.608
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Failed connections: 9852 | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:30.795
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:30.795
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:30.795
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:30.795
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:30.937
DTC Client socket (1) | Closed. | 2024-03-17 20:13:30.937
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:13:32.805
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:32.806
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:32.806
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:13:32.806
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:32.949
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:32.949
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:32.949
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:33.089
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:33.089
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:33.222
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Failed connections: 9853 | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:33.223
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:33.223
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:33.223
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:33.223
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:33.366
DTC Client socket (1) | Closed. | 2024-03-17 20:13:33.366
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:13:35.214
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:35.215
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:35.215
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:13:35.215
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:35.358
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:35.358
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:35.358
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:35.730
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:35.730
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Failed connections: 9854 | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:35.859
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:35.859
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:35.859
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:35.859
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:35.996
DTC Client socket (1) | Closed. | 2024-03-17 20:13:35.996
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:13:37.864
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:37.905
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:37.905
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:13:37.905
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:38.089
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:38.089
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:38.089
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:38.305
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:38.305
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:38.441
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:38.441
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:38.441
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:38.441
SC DTC Delayed Exchange Data | Failed connections: 9855 | 2024-03-17 20:13:38.441
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:38.441
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:38.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:38.442
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:38.442
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:38.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:38.605
DTC Client socket (1) | Closed. | 2024-03-17 20:13:38.605
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:40.454
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:40.458
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:40.459
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:13:40.459
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:40.599
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:40.599
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:40.599
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:40.762
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:40.762
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:40.911
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:40.911
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:40.911
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:40.911
SC DTC Delayed Exchange Data | Failed connections: 9856 | 2024-03-17 20:13:40.911
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:40.911
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:40.912
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:40.912
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:40.912
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:40.912
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:41.063
DTC Client socket (1) | Closed. | 2024-03-17 20:13:41.063
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:42.920
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:42.921
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:42.921
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:13:42.921
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:43.078
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:43.078
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:43.078
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:43.262
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:43.262
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Failed connections: 9857 | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:43.426
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:43.426
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:43.427
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:43.427
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:43.691
DTC Client socket (1) | Closed. | 2024-03-17 20:13:43.691
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:45.426
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:45.426
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:45.427
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:13:45.427
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:45.567
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:45.567
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:45.567
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:45.730
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:45.730
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:45.866
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:45.866
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:45.866
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:45.866
SC DTC Delayed Exchange Data | Failed connections: 9858 | 2024-03-17 20:13:45.866
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:45.866
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:45.867
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:45.867
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:45.867
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:45.867
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:46.006
DTC Client socket (1) | Closed. | 2024-03-17 20:13:46.006
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:13:47.869
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:47.870
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:47.870
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:13:47.870
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:48.017
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:48.017
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:48.017
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:48.188
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:48.188
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:48.322
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:48.322
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:48.322
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:48.322
SC DTC Delayed Exchange Data | Failed connections: 9859 | 2024-03-17 20:13:48.322
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:48.322
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:48.323
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:48.324
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:48.324
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:48.324
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:48.465
DTC Client socket (1) | Closed. | 2024-03-17 20:13:48.465
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:13:50.351
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:50.352
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:50.352
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:13:50.353
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:50.538
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:50.538
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:50.539
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:50.779
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:50.779
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:50.971
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:50.971
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:50.971
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:50.971
SC DTC Delayed Exchange Data | Failed connections: 9860 | 2024-03-17 20:13:50.971
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:50.971
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:50.972
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:50.972
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:50.972
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:50.972
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:51.157
DTC Client socket (1) | Closed. | 2024-03-17 20:13:51.157
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:13:52.972
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:52.973
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:52.973
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:13:52.973
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:53.117
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:53.117
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:53.117
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:53.289
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:53.289
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:53.439
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:53.439
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:53.439
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:53.439
SC DTC Delayed Exchange Data | Failed connections: 9861 | 2024-03-17 20:13:53.439
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:53.439
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:53.440
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:53.440
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:53.440
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:53.440
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:53.585
DTC Client socket (1) | Closed. | 2024-03-17 20:13:53.585
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:13:55.448
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:55.449
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:55.449
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:13:55.449
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:55.586
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:55.586
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:55.586
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:55.761
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:55.761
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Failed connections: 9862 | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:55.901
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:55.901
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:55.901
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:55.901
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:56.045
DTC Client socket (1) | Closed. | 2024-03-17 20:13:56.045
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:13:57.924
DTC Client socket (1) | Creating socket. | 2024-03-17 20:13:57.925
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:13:57.925
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:13:57.925
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:13:58.067
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:13:58.067
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:13:58.067
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:13:58.469
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:13:58.469
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Failed connections: 9863 | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:13:58.694
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:13:58.694
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:13:58.694
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:13:58.694
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:13:58.837
DTC Client socket (1) | Closed. | 2024-03-17 20:13:58.837
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:14:00.712
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:00.712
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:00.712
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:14:00.712
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:00.863
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:00.863
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:00.863
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:01.007
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:01.007
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Failed connections: 9864 | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:01.138
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:01.138
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:01.138
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:01.138
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:01.287
DTC Client socket (1) | Closed. | 2024-03-17 20:14:01.287
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:14:03.250
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:03.251
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:03.251
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:14:03.251
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:03.411
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:03.411
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:03.411
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:03.689
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:03.689
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:03.821
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:03.821
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:03.821
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:03.821
SC DTC Delayed Exchange Data | Failed connections: 9865 | 2024-03-17 20:14:03.821
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:03.821
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:03.822
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:03.822
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:03.822
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:03.822
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:04.014
DTC Client socket (1) | Closed. | 2024-03-17 20:14:04.014
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:14:05.826
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:05.827
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:05.828
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:14:05.828
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:05.976
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:05.976
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:05.976
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:06.198
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:06.198
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Failed connections: 9866 | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:06.470
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:06.470
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:06.470
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:06.470
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:06.605
DTC Client socket (1) | Closed. | 2024-03-17 20:14:06.605
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:14:08.581
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:08.582
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:08.582
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:14:08.582
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:08.723
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:08.723
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:08.723
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:08.890
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:08.890
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Failed connections: 9867 | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:09.013
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:09.013
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:09.013
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:09.014
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:09.155
DTC Client socket (1) | Closed. | 2024-03-17 20:14:09.155
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-17 20:14:11.136
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:11.136
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:11.136
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-17 20:14:11.136
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:11.276
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:11.276
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:11.276
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:11.477
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:11.477
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Failed connections: 9868 | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:11.621
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:11.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:11.621
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:11.621
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:11.754
DTC Client socket (1) | Closed. | 2024-03-17 20:14:11.754
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-17 20:14:13.645
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:13.645
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:13.645
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-17 20:14:13.645
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:13.786
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:13.786
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:13.786
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:13.990
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:13.990
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:14.148
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:14.148
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:14.148
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:14.148
SC DTC Delayed Exchange Data | Failed connections: 9869 | 2024-03-17 20:14:14.148
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:14.148
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:14.149
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:14.149
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:14.149
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:14.149
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:14.294
DTC Client socket (1) | Closed. | 2024-03-17 20:14:14.294
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-17 20:14:16.159
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:16.160
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:16.160
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-17 20:14:16.160
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:16.307
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:16.307
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:16.308
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:16.509
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:16.509
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:16.656
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:16.656
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:16.656
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:16.656
SC DTC Delayed Exchange Data | Failed connections: 9870 | 2024-03-17 20:14:16.656
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:16.656
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:16.657
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:16.657
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:16.657
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:16.657
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:16.804
DTC Client socket (1) | Closed. | 2024-03-17 20:14:16.804
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-17 20:14:18.696
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:18.697
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:18.697
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-17 20:14:18.697
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:18.906
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:18.906
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:18.906
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:19.136
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:19.136
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:19.429
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:19.429
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:19.429
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:19.429
SC DTC Delayed Exchange Data | Failed connections: 9871 | 2024-03-17 20:14:19.429
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:19.429
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:19.430
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:19.430
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:19.430
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:19.430
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:19.685
DTC Client socket (1) | Closed. | 2024-03-17 20:14:19.685
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-17 20:14:21.445
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:21.446
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:21.446
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-17 20:14:21.446
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:21.714
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:21.714
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:21.714
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:21.952
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:21.952
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:22.148
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:22.148
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:22.148
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:22.148
SC DTC Delayed Exchange Data | Failed connections: 9872 | 2024-03-17 20:14:22.148
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:22.148
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:22.149
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:22.149
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:22.149
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:22.149
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:22.305
DTC Client socket (1) | Closed. | 2024-03-17 20:14:22.305
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:14:24.326
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:24.327
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:24.327
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:14:24.327
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:24.468
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:24.468
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:24.468
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:24.632
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:24.632
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Failed connections: 9873 | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:24.815
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:24.815
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:24.815
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:24.816
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:24.991
DTC Client socket (1) | Closed. | 2024-03-17 20:14:24.991
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-17 20:14:26.860
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:26.861
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:26.861
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-17 20:14:26.861
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:27.008
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:27.008
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:27.008
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:27.355
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:27.355
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Failed connections: 9874 | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:27.546
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:27.546
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:27.546
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:27.547
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:27.683
DTC Client socket (1) | Closed. | 2024-03-17 20:14:27.683
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-17 20:14:29.545
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:29.546
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:29.546
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-17 20:14:29.546
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:29.696
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:29.696
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:29.696
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:29.866
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:29.866
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:30.006
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:30.006
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:30.006
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-17 20:14:30.006
SC DTC Delayed Exchange Data | Failed connections: 9875 | 2024-03-17 20:14:30.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:30.006
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:30.007
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:30.007
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:30.007
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:30.007
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:30.147
DTC Client socket (1) | Closed. | 2024-03-17 20:14:30.147
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-17 20:14:31.997
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:31.997
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:31.997
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-17 20:14:31.997
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:32.136
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:32.136
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:32.136
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:32.435
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:32.435
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Failed connections: 9876 | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:32.772
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:32.772
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:32.772
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:32.772
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:32.914
DTC Client socket (1) | Closed. | 2024-03-17 20:14:32.914
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-17 20:14:34.861
DTC Client socket (1) | Creating socket. | 2024-03-17 20:14:34.862
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-17 20:14:34.862
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-17 20:14:34.862
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-17 20:14:35.007
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-17 20:14:35.007
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-17 20:14:35.007
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-17 20:14:35.237
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-17 20:14:35.238
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-17 20:14:35.380
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-17 20:14:35.380
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-17 20:14:35.380
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-17 20:14:35.380
SC DTC Delayed Exchange Data | Failed connections: 9877 | 2024-03-17 20:14:35.380
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-17 20:14:35.380
DTC Client socket (1) | CloseSocket call. | 2024-03-17 20:14:35.381
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:35.381
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-17 20:14:35.381
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-17 20:14:35.381
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-17 20:14:35.523
DTC Client socket (1) | Closed. | 2024-03-17 20:14:35.523
File >> Disconnect selected. | 2024-03-17 20:14:36.474
DTC Client socket (0) | CloseSocket call. | 2024-03-17 20:14:36.504
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-17 20:14:36.504
SC Data - All Services | Disconnected. | 2024-03-17 20:14:36.504
Notice: Detected that the system has resumed from a low-power state. | 2024-03-18 06:11:18.029
SC Data - All Services | Connected to server complete. | 2024-03-18 06:13:08.619
Triggering next historical data download in queue. | 2024-03-18 06:13:08.619
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2024-03-18 06:13:08.619
No download requests in the queue to start downloads for. | 2024-03-18 06:13:08.669
Mapping ESH24-CME to ESH24. Service code: cme | 2024-03-18 06:13:08.673
Using symbol data fast lookup vector | 2024-03-18 06:13:08.673
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESH24-CME (ESH24). ID: 1 Service code: cme | 2024-03-18 06:13:08.673
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:08.673
SC DTC Delayed Exchange Data | Requesting security definition data for: ESH24-CME (ESH24). ID: 1 | 2024-03-18 06:13:08.674
Added historical Intraday data request for ESH24-CME to the queue. | 2024-03-18 06:13:08.674
Intraday data recording state for symbol ESH24-CME is set to download 'Pending'. | 2024-03-18 06:13:08.674
Triggering next historical data download in queue. | 2024-03-18 06:13:08.674
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:08.674
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:08.674
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:08.674
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:13:08.674
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:08.674 *
Delaying start of download for ESH24-CME. | 2024-03-18 06:13:08.675
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:08.675
SC DTC Delayed Exchange Data | Failed connections: 9878 | 2024-03-18 06:13:08.675
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:08.675
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:08.675
DTC Client socket (1) | Closed. | 2024-03-18 06:13:08.675
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:08.675
Requesting market depth updates for: ESH24-CME if supported. | 2024-03-18 06:13:09.090
Separate subscription for market depth updates not supported. ESH24-CME | 2024-03-18 06:13:09.090
Mapping MESH24-CME to MESH24. Service code: cme | 2024-03-18 06:13:09.098
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH24-CME (MESH24). ID: 2 Service code: cme | 2024-03-18 06:13:09.098
SC DTC Delayed Exchange Data | Requesting security definition data for: MESH24-CME (MESH24). ID: 2 | 2024-03-18 06:13:09.098
Added historical Intraday data request for MESH24-CME to the queue. | 2024-03-18 06:13:09.098
Intraday data recording state for symbol MESH24-CME is set to download 'Pending'. | 2024-03-18 06:13:09.098
Triggering next historical data download in queue. | 2024-03-18 06:13:09.098
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:10.689
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:10.690
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:10.690
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:10.690
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:13:10.690
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:10.690 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:10.690
SC DTC Delayed Exchange Data | Failed connections: 9879 | 2024-03-18 06:13:10.691
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:10.691
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:10.691
DTC Client socket (1) | Closed. | 2024-03-18 06:13:10.691
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:10.691
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:12.690
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:12.690
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:12.690
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:12.691
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:13:12.691
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:12.691 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:12.692
SC DTC Delayed Exchange Data | Failed connections: 9880 | 2024-03-18 06:13:12.692
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:12.692
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:12.692
DTC Client socket (1) | Closed. | 2024-03-18 06:13:12.692
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:12.692
Requesting market depth updates for: MESH24-CME if supported. | 2024-03-18 06:13:13.612
Separate subscription for market depth updates not supported. MESH24-CME | 2024-03-18 06:13:13.612
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:13:14.693
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:14.695
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:14.695
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:14.695
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:13:14.695
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:14.695 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:14.700
SC DTC Delayed Exchange Data | Failed connections: 9881 | 2024-03-18 06:13:14.700
DTC Client socket (1) | Closed. | 2024-03-18 06:13:14.700
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:14.700
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:14.700
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:14.700
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:13:16.710
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:16.727
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:16.727
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:16.727
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:13:16.727
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:16.727 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:16.727
SC DTC Delayed Exchange Data | Failed connections: 9882 | 2024-03-18 06:13:16.727
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:16.727
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:16.727
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:16.727
DTC Client socket (1) | Closed. | 2024-03-18 06:13:16.756
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:13:18.720
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:18.886
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:18.886
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:18.886
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:13:18.886
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:18.888 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:18.889
SC DTC Delayed Exchange Data | Failed connections: 9883 | 2024-03-18 06:13:18.890
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:18.890
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:18.890
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:18.890
DTC Client socket (1) | Closed. | 2024-03-18 06:13:18.958
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:13:21.232
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:21.233
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:21.233
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:21.233
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:13:21.233
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:21.233 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:21.235
SC DTC Delayed Exchange Data | Failed connections: 9884 | 2024-03-18 06:13:21.235
DTC Client socket (1) | Closed. | 2024-03-18 06:13:21.235
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:21.235
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:21.235
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:21.236
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:23.710
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:23.745
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:23.745
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:23.745
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:13:23.745
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:23.746 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:23.802
SC DTC Delayed Exchange Data | Failed connections: 9885 | 2024-03-18 06:13:23.802
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:23.802
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:23.802
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:23.802
DTC Client socket (1) | Closed. | 2024-03-18 06:13:23.826
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:13:26.138
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:26.138
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:26.138
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:26.139
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:13:26.139
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:26.139 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:26.141
DTC Client socket (1) | Closed. | 2024-03-18 06:13:26.141
SC DTC Delayed Exchange Data | Failed connections: 9886 | 2024-03-18 06:13:26.141
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:26.141
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:26.141
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:26.141
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:13:28.147
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:28.148
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:28.149
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:28.149
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:13:28.149
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:28.149 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:28.150
SC DTC Delayed Exchange Data | Failed connections: 9887 | 2024-03-18 06:13:28.151
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:28.151
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:28.151
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:28.151
DTC Client socket (1) | Closed. | 2024-03-18 06:13:28.151
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:13:30.138
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:30.139
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:30.139
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:30.143
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:13:30.143
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:30.143 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:30.144
DTC Client socket (1) | Closed. | 2024-03-18 06:13:30.144
SC DTC Delayed Exchange Data | Failed connections: 9888 | 2024-03-18 06:13:30.144
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:30.144
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:30.144
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:30.144
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:32.139
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 06:13:32.143
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:32.143
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:32.143
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:13:32.143
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 06:13:32.143 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:32.143
SC DTC Delayed Exchange Data | Failed connections: 9889 | 2024-03-18 06:13:32.143
DTC Client socket (1) | Closed. | 2024-03-18 06:13:32.143
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:13:32.143
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:32.143
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:32.143
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:34.145
HD Request # 46 | Downloading Intraday chart data for ESH24-CME to the file ESH24-CME.scid. Service: cme | 2024-03-18 06:13:39.218
HD Request # 46 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 06:13:39.219
HD Request # 46 | Using server: ds13.sierracharts.com port 10150 | 2024-03-18 06:13:39.219
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:42.925
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:42.925
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:13:42.925
Socket (2) | Creating socket. | 2024-03-18 06:13:50.475
Socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:13:50.475
Socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:13:50.475
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:13:50.515
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:13:50.515
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:13:50.515
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:13:50.772
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:13:50.772
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:13:51.478
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:13:51.478
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:13:51.478
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:13:51.478
SC DTC Delayed Exchange Data | Failed connections: 9890 | 2024-03-18 06:13:51.478
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:13:51.478
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:51.481
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:51.481
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:51.481
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:13:51.489
HD Request # 46 | Setting DTC encoding to Binary VLS | 2024-03-18 06:13:51.554
HD Request # 46 | Sending historical data logon request message. | 2024-03-18 06:13:51.554
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:13:51.662
DTC Client socket (1) | Closed. | 2024-03-18 06:13:51.662
HD Request # 46 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: ESH24 | 2024-03-18 06:13:51.990
HD Request # 46 | Decompressing data. | 2024-03-18 06:13:52.272
HD Request # 46 | Receiving Intraday data for ESH24-CME starting at 2024-03-15 13:29:59.110000 | 2024-03-18 06:13:52.562
Socket (2) | CloseSocket call. | 2024-03-18 06:13:52.562
Socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:13:52.562
Historical data download thread signaled to stop. | 2024-03-18 06:13:52.562
HD Request # 46 | Received 31 Intraday data records from 2024-03-15 13:29:59.110000 to 2024-03-15 13:29:59.847001 (0.7 seconds. Delay: 2.7 days) and wrote 0 records for ESH24-CME | 2024-03-18 06:13:52.563
HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 06:13:52.563
HD Request # 46 | Completion time: 13s. | 2024-03-18 06:13:52.564
HD Request # 46 | Intraday data download complete for ESH24-CME. Unique request ID: 46 | 2024-03-18 06:13:52.564
Removing historical data download ID 46. | 2024-03-18 06:13:52.564
Real-time Intraday chart data file updates started for ESH24-CME | 2024-03-18 06:13:52.564
Intraday chart data file opened for ESH24-CME | 2024-03-18 06:13:52.564
HD Request # 46 | Enabling Intraday chart updating for symbol. | 2024-03-18 06:13:52.564
Triggering next historical data download in queue. | 2024-03-18 06:13:52.564
Historical data for ESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 06:13:52.564
HD Request # 47 | Downloading Intraday chart data for MESH24-CME to the file MESH24-CME.scid. Service: cme | 2024-03-18 06:13:52.564
HD Request # 47 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 06:13:52.564
HD Request # 47 | Using server: ds23.sierracharts.com port 10149 | 2024-03-18 06:13:52.565
Socket (1) | Creating socket. | 2024-03-18 06:13:52.682
Socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:52.682
Socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:13:52.682
Socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:13:52.765
Socket (2) | Closed. | 2024-03-18 06:13:52.765
HD Request # 47 | Setting DTC encoding to Binary VLS | 2024-03-18 06:13:52.962
HD Request # 47 | Sending historical data logon request message. | 2024-03-18 06:13:52.962
HD Request # 47 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: MESH24 | 2024-03-18 06:13:53.340
HD Request # 47 | Decompressing data. | 2024-03-18 06:13:53.511
HD Request # 47 | Receiving Intraday data for MESH24-CME starting at 2024-03-15 13:29:59.188000 | 2024-03-18 06:13:53.644
Socket (1) | CloseSocket call. | 2024-03-18 06:13:53.644
Socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:13:53.695
Historical data download thread signaled to stop. | 2024-03-18 06:13:53.698
HD Request # 47 | Received 2 Intraday data records from 2024-03-15 13:29:59.188000 to 2024-03-15 13:29:59.465000 (0.3 seconds. Delay: 2.7 days) and wrote 0 records for MESH24-CME | 2024-03-18 06:13:53.698
HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 06:13:53.699
HD Request # 47 | Completion time: 1s. | 2024-03-18 06:13:53.699
HD Request # 47 | Intraday data download complete for MESH24-CME. Unique request ID: 47 | 2024-03-18 06:13:53.699
Removing historical data download ID 47. | 2024-03-18 06:13:53.699
Real-time Intraday chart data file updates started for MESH24-CME | 2024-03-18 06:13:53.699
Intraday chart data file opened for MESH24-CME | 2024-03-18 06:13:53.699
HD Request # 47 | Enabling Intraday chart updating for symbol. | 2024-03-18 06:13:53.699
Triggering next historical data download in queue. | 2024-03-18 06:13:53.700
Historical data for MESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 06:13:53.700
No download requests in the queue to start downloads for. | 2024-03-18 06:13:53.700
Socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:13:53.839
Socket (1) | Closed. | 2024-03-18 06:13:53.839
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:13:54.860
Chart #1 has tagged chart #14 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:54.921
Chart #1 has tagged chart #6 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:54.921
Chart #1 has tagged chart #8 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:54.921
Chart #1 has tagged chart #9 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:54.921
ESH24-CME[M] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:13:54.934
Chart #1 has tagged chart #2 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:13:56.199
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:13:56.231
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:56.274
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:56.274
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:13:56.274
ESH24-CME[M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:13:56.373
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:13:56.470
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:13:56.470
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:13:56.470
ESH24-CME[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:56.536
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:13:56.733
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:13:56.733
ESH24-CME[M] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:56.736
ESH24-CME[M] 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:56.780
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Failed connections: 9891 | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:13:57.397
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:13:57.397
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:13:57.397
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2024-03-18 06:13:57.397
DTC Client socket (1) | Closed. | 2024-03-18 06:13:57.397
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:13:57.398
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:13:57.398
ESH24-CME[M] 5 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:13:57.468
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:13:59.867
DTC Client socket (1) | Creating socket. | 2024-03-18 06:13:59.947
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:13:59.947
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:13:59.947
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:00.334
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:00.334
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:00.335
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:00.694
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:00.694
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:01.024
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:01.024
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:01.024
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:01.024
SC DTC Delayed Exchange Data | Failed connections: 9892 | 2024-03-18 06:14:01.024
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:01.025
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:14:01.025
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:01.025
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:01.025
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:01.055
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:14:01.055
DTC Client socket (1) | Closed. | 2024-03-18 06:14:01.055
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:14:03.388
DTC Client socket (1) | Creating socket. | 2024-03-18 06:14:03.421
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:14:03.421
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:14:03.421
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:04.903
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:04.903
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:04.903
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:05.332
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:05.332
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Failed connections: 9893 | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:05.798
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:05.798
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:05.798
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:05.825
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:14:05.836
DTC Client socket (1) | Closed. | 2024-03-18 06:14:05.836
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:14:07.829
DTC Client socket (1) | Creating socket. | 2024-03-18 06:14:07.830
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:14:07.830
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:14:07.830
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:07.977
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:07.977
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:07.977
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:08.163
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:08.163
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:08.331
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:08.331
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:08.331
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:08.331
SC DTC Delayed Exchange Data | Failed connections: 9894 | 2024-03-18 06:14:08.331
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:08.331
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:14:08.332
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:08.332
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:08.332
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:08.332
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:14:08.481
DTC Client socket (1) | Closed. | 2024-03-18 06:14:08.481
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:14:10.347
DTC Client socket (1) | Creating socket. | 2024-03-18 06:14:10.448
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:14:10.448
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:14:10.448
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:10.633
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:10.633
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:10.633
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:10.817
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:10.817
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Failed connections: 9895 | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:10.955
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:14:10.955
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:10.955
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:10.955
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:14:11.079
DTC Client socket (1) | Closed. | 2024-03-18 06:14:11.079
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:12.967
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:12.999
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:13.000
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:14:13.000
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:13.144
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:13.144
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:13.144
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:13.432
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:13.432
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:13.610
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:13.610
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:13.610
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:13.610
SC DTC Delayed Exchange Data | Failed connections: 9896 | 2024-03-18 06:14:13.610
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:13.610
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:13.611
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:13.611
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:13.611
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:13.611
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:13.811
DTC Client socket (2) | Closed. | 2024-03-18 06:14:13.812
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:14:16.074
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:16.087
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:16.087
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:14:16.087
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:16.217
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:16.217
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:16.217
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:16.406
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:16.406
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Failed connections: 9897 | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:16.843
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:16.843
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:16.843
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:16.884
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:17.025
DTC Client socket (2) | Closed. | 2024-03-18 06:14:17.026
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:14:18.862
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:18.904
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:18.904
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:14:18.904
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:19.026
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:19.026
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:19.026
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:19.222
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:19.222
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:19.386
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:19.386
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:19.386
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:19.386
SC DTC Delayed Exchange Data | Failed connections: 9898 | 2024-03-18 06:14:19.386
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:19.386
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:19.387
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:19.387
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:19.387
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:19.387
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:19.515
DTC Client socket (2) | Closed. | 2024-03-18 06:14:19.515
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:14:22.048
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:22.097
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:22.097
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:14:22.097
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:22.341
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:22.341
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:22.341
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:22.653
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:22.653
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:22.832
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:22.832
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:22.832
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:22.832
SC DTC Delayed Exchange Data | Failed connections: 9899 | 2024-03-18 06:14:22.832
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:22.832
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:22.833
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:22.833
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:22.833
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:22.833
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:23.074
DTC Client socket (2) | Closed. | 2024-03-18 06:14:23.074
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:25.015
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:25.016
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:25.016
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:14:25.016
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:25.150
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:25.150
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:25.150
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:25.340
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:25.340
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:25.476
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:25.476
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:25.476
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:25.476
SC DTC Delayed Exchange Data | Failed connections: 9900 | 2024-03-18 06:14:25.476
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:25.476
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:25.477
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:25.477
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:25.477
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:25.477
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:25.600
DTC Client socket (2) | Closed. | 2024-03-18 06:14:25.600
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:27.696
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:27.698
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:27.698
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:14:27.698
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:27.852
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:27.852
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:27.852
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:28.017
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:28.017
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Failed connections: 9901 | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:28.153
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:28.153
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:28.153
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:28.153
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:28.275
DTC Client socket (2) | Closed. | 2024-03-18 06:14:28.275
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:30.158
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:30.158
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:30.159
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:14:30.159
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:30.292
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:30.292
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:30.292
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:30.467
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:30.467
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:30.605
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:30.605
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:30.605
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:30.605
SC DTC Delayed Exchange Data | Failed connections: 9902 | 2024-03-18 06:14:30.605
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:30.605
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:30.606
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:30.606
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:30.606
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:30.606
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:30.739
DTC Client socket (2) | Closed. | 2024-03-18 06:14:30.739
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:14:32.667
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:32.668
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:32.668
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:14:32.668
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:32.798
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:32.798
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:32.798
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:32.938
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:32.938
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:33.082
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:33.082
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:33.082
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:33.082
SC DTC Delayed Exchange Data | Failed connections: 9903 | 2024-03-18 06:14:33.082
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:33.082
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:33.083
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:33.083
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:33.083
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:33.083
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:33.211
DTC Client socket (2) | Closed. | 2024-03-18 06:14:33.211
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:14:35.100
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:35.100
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:35.100
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:14:35.101
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:35.277
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:35.277
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:35.278
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:35.502
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:35.502
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:35.693
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:35.693
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:35.693
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:35.693
SC DTC Delayed Exchange Data | Failed connections: 9904 | 2024-03-18 06:14:35.693
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:35.693
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:35.693
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:35.694
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:35.694
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:35.694
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:35.867
DTC Client socket (2) | Closed. | 2024-03-18 06:14:35.867
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:14:37.693
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:37.694
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:37.694
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:14:37.694
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:37.817
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:37.818
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:37.818
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:37.981
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:37.981
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Failed connections: 9905 | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:38.110
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:38.110
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:38.110
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:38.110
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:38.234
DTC Client socket (2) | Closed. | 2024-03-18 06:14:38.234
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:14:40.113
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:40.114
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:40.114
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:14:40.114
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:40.243
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:40.243
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:40.243
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:40.393
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:40.393
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:40.518
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:40.518
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:40.518
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:40.518
SC DTC Delayed Exchange Data | Failed connections: 9906 | 2024-03-18 06:14:40.518
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:40.518
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:40.518
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:40.519
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:40.519
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:40.519
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:40.641
DTC Client socket (2) | Closed. | 2024-03-18 06:14:40.641
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:42.678
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:42.679
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:42.679
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:14:42.679
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:42.803
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:42.803
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:42.803
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:43.240
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:43.240
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Failed connections: 9907 | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:43.393
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:43.393
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:43.393
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:43.393
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:43.520
DTC Client socket (2) | Closed. | 2024-03-18 06:14:43.520
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:14:45.395
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:45.399
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:45.399
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:14:45.399
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:45.539
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:45.539
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:45.539
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:45.772
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:45.772
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:45.902
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:45.902
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:45.902
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:45.902
SC DTC Delayed Exchange Data | Failed connections: 9908 | 2024-03-18 06:14:45.902
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:45.902
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:45.903
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:45.903
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:45.903
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:45.903
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:46.024
DTC Client socket (2) | Closed. | 2024-03-18 06:14:46.024
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:14:47.923
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:47.924
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:47.924
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:14:47.924
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:48.075
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:48.075
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:48.075
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:48.318
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:48.318
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Failed connections: 9909 | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:48.588
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:48.588
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:48.588
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:48.588
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:48.713
DTC Client socket (2) | Closed. | 2024-03-18 06:14:48.713
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:14:50.792
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:50.792
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:50.792
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:14:50.792
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:50.923
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:50.923
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:50.923
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:51.542
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:51.542
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:51.777
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:51.777
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:51.777
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:51.777
SC DTC Delayed Exchange Data | Failed connections: 9910 | 2024-03-18 06:14:51.777
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:51.777
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:51.778
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:51.778
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:51.778
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:51.778
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:52.023
DTC Client socket (2) | Closed. | 2024-03-18 06:14:52.024
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:53.801
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:53.801
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:53.802
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:14:53.802
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:53.924
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:53.924
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:53.924
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:54.086
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:54.086
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:54.221
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:54.221
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:54.221
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:54.221
SC DTC Delayed Exchange Data | Failed connections: 9911 | 2024-03-18 06:14:54.221
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:54.221
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:54.221
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:54.222
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:54.222
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:54.222
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:54.344
DTC Client socket (2) | Closed. | 2024-03-18 06:14:54.344
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:56.391
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:56.392
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:56.392
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:14:56.392
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:56.519
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:56.519
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:56.519
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:56.782
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:56.782
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:56.945
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:56.945
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:56.945
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:14:56.945
SC DTC Delayed Exchange Data | Failed connections: 9912 | 2024-03-18 06:14:56.945
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:56.945
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:56.946
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:56.946
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:56.946
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:56.946
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:57.115
DTC Client socket (2) | Closed. | 2024-03-18 06:14:57.116
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:14:58.961
DTC Client socket (2) | Creating socket. | 2024-03-18 06:14:58.962
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:14:58.962
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:14:58.962
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:14:59.085
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:14:59.085
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:14:59.085
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:14:59.240
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:14:59.240
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:14:59.368
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:14:59.368
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:14:59.368
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:14:59.368
SC DTC Delayed Exchange Data | Failed connections: 9913 | 2024-03-18 06:14:59.368
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:14:59.368
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:14:59.368
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:14:59.369
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:14:59.369
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:14:59.369
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:14:59.489
DTC Client socket (2) | Closed. | 2024-03-18 06:14:59.489
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:15:01.405
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:01.406
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:01.406
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:15:01.406
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:01.540
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:01.540
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:01.540
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:01.730
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:01.730
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Failed connections: 9914 | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:01.872
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:01.872
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:01.872
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:01.872
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:01.994
DTC Client socket (2) | Closed. | 2024-03-18 06:15:01.994
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:15:03.872
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:03.874
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:03.874
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:15:03.874
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:04.050
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:04.050
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:04.050
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:04.263
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:04.263
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:04.443
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:04.443
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:04.443
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:04.443
SC DTC Delayed Exchange Data | Failed connections: 9915 | 2024-03-18 06:15:04.443
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:04.443
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:04.444
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:04.444
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:04.444
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:04.444
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:04.631
DTC Client socket (2) | Closed. | 2024-03-18 06:15:04.631
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:15:06.439
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:06.439
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:06.439
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:15:06.439
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:06.588
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:06.588
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:06.588
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:06.772
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:06.772
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:06.946
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:06.946
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:06.946
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:06.946
SC DTC Delayed Exchange Data | Failed connections: 9916 | 2024-03-18 06:15:06.946
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:06.946
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:06.946
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:06.947
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:06.947
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:06.947
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:07.074
DTC Client socket (2) | Closed. | 2024-03-18 06:15:07.074
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:15:08.958
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:08.959
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:08.959
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:15:08.959
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:09.249
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:09.249
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:09.249
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:09.453
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:09.453
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:09.626
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:09.626
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:09.626
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:09.626
SC DTC Delayed Exchange Data | Failed connections: 9917 | 2024-03-18 06:15:09.626
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:09.626
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:09.626
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:09.627
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:09.627
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:09.627
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:09.790
DTC Client socket (2) | Closed. | 2024-03-18 06:15:09.790
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:11.621
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:11.622
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:11.622
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:15:11.622
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:11.757
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:11.757
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:11.758
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:12.015
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:12.015
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:12.186
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:12.186
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:12.186
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:12.186
SC DTC Delayed Exchange Data | Failed connections: 9918 | 2024-03-18 06:15:12.186
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:12.186
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:12.187
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:12.187
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:12.187
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:12.187
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:12.313
DTC Client socket (2) | Closed. | 2024-03-18 06:15:12.314
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:15:14.210
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:14.210
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:14.210
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:15:14.210
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:14.343
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:14.343
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:14.343
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:14.515
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:14.515
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Failed connections: 9919 | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:14.655
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:14.655
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:14.655
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:14.655
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:14.775
DTC Client socket (2) | Closed. | 2024-03-18 06:15:14.775
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:15:16.664
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:16.669
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:16.669
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:15:16.669
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:16.798
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:16.798
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:16.799
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:17.148
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:17.148
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:17.571
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:17.571
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:17.571
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:17.571
SC DTC Delayed Exchange Data | Failed connections: 9920 | 2024-03-18 06:15:17.571
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:17.571
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:17.571
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:17.572
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:17.572
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:17.572
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:17.673
DTC Client socket (2) | Closed. | 2024-03-18 06:15:17.673
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:15:19.569
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:19.569
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:19.569
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:15:19.569
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:19.700
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:19.700
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:19.700
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:19.960
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:19.960
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:20.112
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:20.112
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:20.112
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:20.112
SC DTC Delayed Exchange Data | Failed connections: 9921 | 2024-03-18 06:15:20.112
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:20.112
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:20.113
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:20.113
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:20.113
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:20.113
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:20.262
DTC Client socket (2) | Closed. | 2024-03-18 06:15:20.262
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:22.130
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:22.130
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:22.130
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:15:22.131
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:22.260
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:22.260
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:22.260
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:22.430
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:22.430
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:22.562
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:22.562
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:22.562
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:22.562
SC DTC Delayed Exchange Data | Failed connections: 9922 | 2024-03-18 06:15:22.562
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:22.562
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:22.562
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:22.563
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:22.563
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:22.563
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:22.708
DTC Client socket (2) | Closed. | 2024-03-18 06:15:22.708
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:24.641
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:24.642
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:24.642
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:15:24.642
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:24.768
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:24.768
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:24.768
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:24.956
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:24.956
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Failed connections: 9923 | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:25.122
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:25.122
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:25.122
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:25.122
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:25.275
DTC Client socket (2) | Closed. | 2024-03-18 06:15:25.275
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:27.172
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:27.173
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:27.173
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:15:27.173
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:27.304
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:27.304
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:27.304
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:27.445
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:27.445
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Failed connections: 9924 | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:27.597
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:27.597
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:27.597
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:27.597
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:27.767
DTC Client socket (2) | Closed. | 2024-03-18 06:15:27.767
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:15:29.703
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:29.704
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:29.704
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:15:29.704
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:29.832
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:29.832
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:29.832
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:29.986
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:29.986
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Failed connections: 9925 | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:30.149
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:30.149
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:30.149
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:30.150
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:30.150
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:30.274
DTC Client socket (2) | Closed. | 2024-03-18 06:15:30.274
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:15:32.214
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:32.216
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:32.216
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:15:32.216
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:32.392
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:32.392
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:32.392
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:32.605
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:32.605
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:32.791
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:32.791
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:32.791
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:32.791
SC DTC Delayed Exchange Data | Failed connections: 9926 | 2024-03-18 06:15:32.791
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:32.791
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:32.792
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:32.792
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:32.792
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:32.792
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:32.970
DTC Client socket (2) | Closed. | 2024-03-18 06:15:32.970
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:15:34.805
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:34.806
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:34.806
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:15:34.806
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:34.934
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:34.934
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:34.934
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:35.118
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:35.118
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:35.257
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:35.257
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:35.257
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:35.257
SC DTC Delayed Exchange Data | Failed connections: 9927 | 2024-03-18 06:15:35.257
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:35.257
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:35.258
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:35.258
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:35.258
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:35.258
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:35.384
DTC Client socket (2) | Closed. | 2024-03-18 06:15:35.384
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:15:37.278
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:37.278
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:37.278
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:15:37.278
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:37.404
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:37.404
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:37.404
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:37.527
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:37.527
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:37.658
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:37.658
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:37.658
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:37.658
SC DTC Delayed Exchange Data | Failed connections: 9928 | 2024-03-18 06:15:37.658
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:37.658
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:37.659
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:37.659
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:37.659
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:37.659
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:37.795
DTC Client socket (2) | Closed. | 2024-03-18 06:15:37.795
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:39.821
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:39.821
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:39.821
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:15:39.821
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:39.964
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:39.964
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:39.964
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:40.196
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:40.196
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:40.470
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:40.470
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:40.470
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:40.470
SC DTC Delayed Exchange Data | Failed connections: 9929 | 2024-03-18 06:15:40.470
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:40.470
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:40.471
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:40.471
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:40.471
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:40.471
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:40.596
DTC Client socket (2) | Closed. | 2024-03-18 06:15:40.596
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:15:42.471
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:42.472
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:42.472
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:15:42.472
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:42.603
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:42.603
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:42.603
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:42.783
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:42.783
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Failed connections: 9930 | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:42.928
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:42.928
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:42.928
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:42.929
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:43.054
DTC Client socket (2) | Closed. | 2024-03-18 06:15:43.054
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:15:44.929
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:44.930
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:44.930
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:15:44.930
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:45.071
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:45.071
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:45.071
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:45.335
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:45.335
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:45.492
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:45.492
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:45.492
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:45.492
SC DTC Delayed Exchange Data | Failed connections: 9931 | 2024-03-18 06:15:45.492
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:45.492
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:45.493
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:45.493
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:45.493
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:45.493
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:45.655
DTC Client socket (2) | Closed. | 2024-03-18 06:15:45.655
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:15:47.479
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:47.480
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:47.480
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:15:47.480
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:47.609
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:47.609
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:47.610
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:47.926
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:47.926
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:48.138
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:48.138
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:48.138
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:48.138
SC DTC Delayed Exchange Data | Failed connections: 9932 | 2024-03-18 06:15:48.138
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:48.138
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:48.139
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:48.139
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:48.139
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:48.139
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:48.290
DTC Client socket (2) | Closed. | 2024-03-18 06:15:48.290
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:50.136
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:50.137
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:50.137
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:15:50.137
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:50.282
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:50.282
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:50.282
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:50.439
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:50.439
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:50.586
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:50.586
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:50.586
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:50.587
SC DTC Delayed Exchange Data | Failed connections: 9933 | 2024-03-18 06:15:50.587
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:50.587
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:50.587
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:50.588
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:50.588
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:50.588
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:50.708
DTC Client socket (2) | Closed. | 2024-03-18 06:15:50.708
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:52.576
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:52.577
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:52.577
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:15:52.577
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:52.704
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:52.704
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:52.704
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:52.848
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:52.849
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Failed connections: 9934 | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:53.006
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:53.006
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:53.006
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:53.006
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:53.129
DTC Client socket (2) | Closed. | 2024-03-18 06:15:53.129
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:15:55.025
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:55.025
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:55.026
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:15:55.026
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:55.156
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:55.156
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:55.156
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:55.290
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:55.290
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:55.452
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:55.452
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:55.452
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:55.452
SC DTC Delayed Exchange Data | Failed connections: 9935 | 2024-03-18 06:15:55.452
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:55.452
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:55.453
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:55.453
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:55.453
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:55.453
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:55.576
DTC Client socket (2) | Closed. | 2024-03-18 06:15:55.576
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:15:57.580
DTC Client socket (2) | Creating socket. | 2024-03-18 06:15:57.580
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:15:57.580
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:15:57.580
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:15:57.707
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:15:57.707
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:15:57.707
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:15:57.879
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:15:57.879
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Failed connections: 9936 | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:15:58.038
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:15:58.038
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:15:58.038
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:15:58.038
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:15:58.177
DTC Client socket (2) | Closed. | 2024-03-18 06:15:58.177
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:16:00.216
DTC Client socket (2) | Creating socket. | 2024-03-18 06:16:00.217
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:16:00.217
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:16:00.218
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:00.414
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:00.414
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:00.414
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:00.650
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:00.650
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Failed connections: 9937 | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:00.846
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:16:00.846
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:00.846
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:00.846
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:16:01.021
DTC Client socket (2) | Closed. | 2024-03-18 06:16:01.021
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:16:02.838
DTC Client socket (2) | Creating socket. | 2024-03-18 06:16:02.839
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:16:02.839
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:16:02.839
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:02.977
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:02.977
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:02.977
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:03.119
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:03.119
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:03.269
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:03.269
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:03.269
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:03.269
SC DTC Delayed Exchange Data | Failed connections: 9938 | 2024-03-18 06:16:03.269
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:03.269
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:16:03.270
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:03.270
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:03.270
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:03.270
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:16:03.405
DTC Client socket (2) | Closed. | 2024-03-18 06:16:03.405
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:16:05.271
DTC Client socket (2) | Creating socket. | 2024-03-18 06:16:05.272
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:16:05.272
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:16:05.272
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:05.403
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:05.403
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:05.403
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:05.569
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:05.569
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Failed connections: 9939 | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:05.707
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:05.707
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:05.707
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:05.707
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:16:05.841
DTC Client socket (2) | Closed. | 2024-03-18 06:16:05.842
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:07.757
DTC Client socket (2) | Creating socket. | 2024-03-18 06:16:07.757
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:16:07.757
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:16:07.758
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:07.887
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:07.887
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:07.888
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:08.298
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:08.298
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Failed connections: 9940 | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:08.435
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:08.435
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:08.435
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:08.436
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:16:08.559
DTC Client socket (2) | Closed. | 2024-03-18 06:16:08.559
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:16:10.454
DTC Client socket (2) | Creating socket. | 2024-03-18 06:16:10.456
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:16:10.456
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:16:10.456
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:10.583
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:10.583
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:10.583
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:10.757
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:10.757
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:10.896
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:10.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:10.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:10.897
SC DTC Delayed Exchange Data | Failed connections: 9941 | 2024-03-18 06:16:10.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:10.897
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:16:10.898
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:10.898
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:10.898
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:10.898
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:16:11.022
DTC Client socket (2) | Closed. | 2024-03-18 06:16:11.022
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:16:12.906
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:12.907
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:12.907
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:16:12.908
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:13.035
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:13.035
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:13.035
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:13.325
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:13.325
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:13.495
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:13.495
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:13.495
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:13.495
SC DTC Delayed Exchange Data | Failed connections: 9942 | 2024-03-18 06:16:13.495
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:13.495
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:13.496
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:13.496
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:13.496
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:13.496
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:13.624
DTC Client socket (3) | Closed. | 2024-03-18 06:16:13.625
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:16:15.508
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:15.509
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:15.509
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:16:15.509
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:15.697
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:15.697
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:15.697
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:15.953
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:15.953
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:16.104
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:16.104
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:16.104
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:16.104
SC DTC Delayed Exchange Data | Failed connections: 9943 | 2024-03-18 06:16:16.104
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:16.104
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:16.105
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:16.105
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:16.105
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:16.106
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:16.258
DTC Client socket (3) | Closed. | 2024-03-18 06:16:16.258
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:18.127
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:18.128
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:18.129
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:16:18.129
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:18.264
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:18.264
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:18.264
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:18.465
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:18.465
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Failed connections: 9944 | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:18.600
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:18.600
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:18.600
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:18.601
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:18.731
DTC Client socket (3) | Closed. | 2024-03-18 06:16:18.731
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:20.605
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:20.607
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:20.607
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:16:20.607
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:20.754
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:20.754
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:20.754
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:20.909
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:20.909
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:21.049
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:21.049
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:21.049
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:21.049
SC DTC Delayed Exchange Data | Failed connections: 9945 | 2024-03-18 06:16:21.049
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:21.049
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:21.050
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:21.050
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:21.050
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:21.050
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:21.179
DTC Client socket (3) | Closed. | 2024-03-18 06:16:21.179
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:23.049
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:23.049
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:23.049
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:16:23.049
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:23.177
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:23.178
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:23.178
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:23.320
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:23.320
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:23.446
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:23.446
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:23.446
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:23.446
SC DTC Delayed Exchange Data | Failed connections: 9946 | 2024-03-18 06:16:23.446
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:23.446
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:23.447
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:23.447
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:23.447
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:23.447
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:23.568
DTC Client socket (3) | Closed. | 2024-03-18 06:16:23.568
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:16:25.437
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:25.438
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:25.438
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:16:25.438
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:25.569
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:25.569
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:25.569
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:25.700
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:25.700
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Failed connections: 9947 | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:25.859
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:25.859
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:25.859
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:25.860
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:25.989
DTC Client socket (3) | Closed. | 2024-03-18 06:16:25.989
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:16:27.978
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:27.978
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:27.978
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:16:27.978
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:28.156
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:28.156
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:28.157
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:28.341
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:28.341
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Failed connections: 9948 | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:28.560
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:28.560
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:28.560
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:28.560
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:28.737
DTC Client socket (3) | Closed. | 2024-03-18 06:16:28.737
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:16:30.572
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:30.572
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:30.573
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:16:30.573
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:30.699
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:30.699
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:30.699
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:30.873
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:30.873
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Failed connections: 9949 | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:31.057
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:31.057
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:31.057
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:31.057
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:31.179
DTC Client socket (3) | Closed. | 2024-03-18 06:16:31.179
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:16:33.124
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:33.125
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:33.125
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:16:33.125
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:33.255
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:33.255
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:33.256
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:33.397
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:33.397
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:33.546
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Failed connections: 9950 | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:33.547
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:33.547
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:33.547
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:33.547
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:33.676
DTC Client socket (3) | Closed. | 2024-03-18 06:16:33.676
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:35.604
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:35.605
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:35.605
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:16:35.605
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:35.736
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:35.736
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:35.736
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:36.048
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:36.048
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:36.223
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:36.223
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:36.223
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:36.223
SC DTC Delayed Exchange Data | Failed connections: 9951 | 2024-03-18 06:16:36.223
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:36.223
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:36.224
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:36.224
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:36.224
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:36.224
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:36.373
DTC Client socket (3) | Closed. | 2024-03-18 06:16:36.373
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:16:38.229
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:38.230
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:38.231
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:16:38.231
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:38.358
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:38.358
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:38.358
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:38.522
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:38.522
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:38.656
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:38.656
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:38.656
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:38.656
SC DTC Delayed Exchange Data | Failed connections: 9952 | 2024-03-18 06:16:38.656
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:38.656
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:38.657
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:38.657
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:38.657
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:38.657
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:38.783
DTC Client socket (3) | Closed. | 2024-03-18 06:16:38.783
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:16:40.673
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:40.674
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:40.674
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:16:40.674
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:40.807
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:40.807
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:40.807
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:41.093
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:41.093
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:41.235
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:41.235
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:41.235
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:41.235
SC DTC Delayed Exchange Data | Failed connections: 9953 | 2024-03-18 06:16:41.235
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:41.236
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:41.236
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:41.237
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:41.237
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:41.237
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:41.396
DTC Client socket (3) | Closed. | 2024-03-18 06:16:41.396
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:16:43.229
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:43.231
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:43.231
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:16:43.231
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:43.362
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:43.362
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:43.362
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:43.569
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:43.569
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:43.735
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:43.735
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:43.735
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:43.735
SC DTC Delayed Exchange Data | Failed connections: 9954 | 2024-03-18 06:16:43.735
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:43.735
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:43.736
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:43.736
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:43.736
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:43.736
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:43.863
DTC Client socket (3) | Closed. | 2024-03-18 06:16:43.863
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:45.737
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:45.738
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:45.738
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:16:45.738
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:45.866
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:45.866
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:45.867
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:45.998
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:45.998
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:46.165
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:46.165
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:46.165
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:46.165
SC DTC Delayed Exchange Data | Failed connections: 9955 | 2024-03-18 06:16:46.165
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:46.165
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:46.166
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:46.166
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:46.166
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:46.166
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:46.291
DTC Client socket (3) | Closed. | 2024-03-18 06:16:46.291
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:48.233
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:48.234
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:48.234
DTC Client socket (3) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:16:48.234
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:48.369
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:48.369
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:48.369
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:48.536
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:48.536
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Failed connections: 9956 | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:48.701
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:48.701
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:48.701
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:48.702
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:48.825
DTC Client socket (3) | Closed. | 2024-03-18 06:16:48.825
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:16:50.743
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:50.744
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:50.744
DTC Client socket (3) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:16:50.744
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:50.872
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:50.872
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:50.872
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:51.005
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:51.005
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:51.160
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:51.160
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:51.160
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:51.160
SC DTC Delayed Exchange Data | Failed connections: 9957 | 2024-03-18 06:16:51.160
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:51.160
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:51.161
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:51.161
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:51.161
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:51.161
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:51.286
DTC Client socket (3) | Closed. | 2024-03-18 06:16:51.286
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:16:53.241
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:53.241
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:53.241
DTC Client socket (3) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:16:53.241
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:53.373
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:53.373
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:53.373
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:53.526
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:53.526
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:53.676
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:53.676
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:53.676
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:53.676
SC DTC Delayed Exchange Data | Failed connections: 9958 | 2024-03-18 06:16:53.676
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:53.676
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:53.677
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:53.677
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:53.677
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:53.677
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:53.810
DTC Client socket (3) | Closed. | 2024-03-18 06:16:53.810
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:16:55.748
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:55.749
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:55.749
DTC Client socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:16:55.749
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:55.928
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:55.928
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:55.928
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:56.121
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:56.121
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Failed connections: 9959 | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:56.304
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:56.304
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:56.304
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:56.304
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:56.482
DTC Client socket (3) | Closed. | 2024-03-18 06:16:56.482
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:16:58.304
DTC Client socket (3) | Creating socket. | 2024-03-18 06:16:58.305
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:16:58.305
DTC Client socket (3) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:16:58.305
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:16:58.433
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:16:58.433
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:16:58.433
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:16:58.617
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:16:58.617
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:16:58.780
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:16:58.780
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:16:58.780
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:16:58.780
SC DTC Delayed Exchange Data | Failed connections: 9960 | 2024-03-18 06:16:58.780
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:16:58.780
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:16:58.780
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:16:58.781
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:16:58.781
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:16:58.781
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:16:58.900
DTC Client socket (3) | Closed. | 2024-03-18 06:16:58.900
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:17:00.800
DTC Client socket (3) | Creating socket. | 2024-03-18 06:17:00.801
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:17:00.801
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:17:00.801
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:00.925
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:00.925
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:00.926
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:01.067
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:01.067
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Failed connections: 9961 | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:01.229
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:01.229
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:01.229
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:01.229
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:17:01.356
DTC Client socket (3) | Closed. | 2024-03-18 06:17:01.356
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:03.323
DTC Client socket (3) | Creating socket. | 2024-03-18 06:17:03.324
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:17:03.324
DTC Client socket (3) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:17:03.324
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:03.481
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:03.481
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:03.482
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:03.731
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:03.731
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:04.007
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:04.007
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:04.007
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:04.007
SC DTC Delayed Exchange Data | Failed connections: 9962 | 2024-03-18 06:17:04.007
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:04.007
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:17:04.008
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:04.008
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:04.008
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:04.008
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:17:04.134
DTC Client socket (3) | Closed. | 2024-03-18 06:17:04.134
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:17:06.003
DTC Client socket (3) | Creating socket. | 2024-03-18 06:17:06.004
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:17:06.004
DTC Client socket (3) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:17:06.004
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:06.132
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:06.132
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:06.132
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:06.278
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:06.278
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:06.406
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:06.406
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:06.406
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:06.406
SC DTC Delayed Exchange Data | Failed connections: 9963 | 2024-03-18 06:17:06.406
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:06.406
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:17:06.407
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:06.407
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:06.407
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:06.407
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:17:06.555
DTC Client socket (3) | Closed. | 2024-03-18 06:17:06.556
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:17:08.413
DTC Client socket (3) | Creating socket. | 2024-03-18 06:17:08.414
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:17:08.414
DTC Client socket (3) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:17:08.414
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:08.544
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:08.544
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:08.544
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:08.765
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:08.765
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:08.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:08.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:08.897
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:08.897
SC DTC Delayed Exchange Data | Failed connections: 9964 | 2024-03-18 06:17:08.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:08.897
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:17:08.898
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:08.898
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:08.898
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:08.898
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:17:09.027
DTC Client socket (3) | Closed. | 2024-03-18 06:17:09.027
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:17:10.893
DTC Client socket (3) | Creating socket. | 2024-03-18 06:17:10.894
DTC Client socket (3) | New receive buffer size: 5242880 | 2024-03-18 06:17:10.894
DTC Client socket (3) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:17:10.894
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:11.024
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:11.024
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:11.024
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:11.496
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:11.496
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Failed connections: 9965 | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:11.638
DTC Client socket (3) | CloseSocket call. | 2024-03-18 06:17:11.638
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:11.638
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:11.639
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:11.639
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-03-18 06:17:11.793
DTC Client socket (3) | Closed. | 2024-03-18 06:17:11.794
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:13.658
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:13.660
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:13.660
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:17:13.660
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:13.794
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:13.794
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:13.794
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:13.940
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:13.940
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:14.089
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:14.089
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:14.089
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:14.089
SC DTC Delayed Exchange Data | Failed connections: 9966 | 2024-03-18 06:17:14.089
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:14.089
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:14.090
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:14.090
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:14.091
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:14.091
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:14.224
DTC Client socket (1) | Closed. | 2024-03-18 06:17:14.224
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:16.093
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:16.094
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:16.094
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:17:16.094
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:16.222
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:16.222
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:16.222
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:16.355
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:16.355
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Failed connections: 9967 | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:16.495
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:16.495
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:16.495
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:16.496
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:16.496
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:16.616
DTC Client socket (1) | Closed. | 2024-03-18 06:17:16.616
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:18.514
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:18.515
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:18.515
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:17:18.515
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:18.641
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:18.641
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:18.641
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:18.794
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:18.794
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:18.918
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:18.918
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:18.918
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:18.918
SC DTC Delayed Exchange Data | Failed connections: 9968 | 2024-03-18 06:17:18.918
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:18.918
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:18.919
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:18.919
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:18.919
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:18.919
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:19.040
DTC Client socket (1) | Closed. | 2024-03-18 06:17:19.040
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:17:20.964
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:20.965
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:20.965
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:17:20.965
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:21.095
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:21.095
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:21.095
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:21.227
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:21.227
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:21.370
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:21.370
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:21.370
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:21.370
SC DTC Delayed Exchange Data | Failed connections: 9969 | 2024-03-18 06:17:21.370
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:21.370
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:21.371
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:21.371
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:21.371
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:21.371
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:21.497
DTC Client socket (1) | Closed. | 2024-03-18 06:17:21.497
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:17:23.472
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:23.473
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:23.473
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:17:23.473
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:23.646
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:23.646
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:23.646
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:23.872
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:23.872
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:24.061
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:24.061
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:24.061
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:24.061
SC DTC Delayed Exchange Data | Failed connections: 9970 | 2024-03-18 06:17:24.061
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:24.061
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:24.062
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:24.062
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:24.063
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:24.063
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:24.235
DTC Client socket (1) | Closed. | 2024-03-18 06:17:24.235
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:17:26.070
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:26.071
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:26.071
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:17:26.071
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:26.261
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:26.261
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:26.262
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:26.424
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:26.424
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:26.558
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:26.558
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:26.558
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:26.558
SC DTC Delayed Exchange Data | Failed connections: 9971 | 2024-03-18 06:17:26.558
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:26.558
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:26.559
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:26.559
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:26.559
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:26.559
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:26.683
DTC Client socket (1) | Closed. | 2024-03-18 06:17:26.683
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:17:28.601
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:28.602
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:28.602
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:17:28.602
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:28.729
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:28.729
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:28.729
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:28.874
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:28.874
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:29.017
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:29.017
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:29.017
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:29.017
SC DTC Delayed Exchange Data | Failed connections: 9972 | 2024-03-18 06:17:29.017
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:29.017
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:29.018
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:29.018
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:29.018
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:29.018
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:29.140
DTC Client socket (1) | Closed. | 2024-03-18 06:17:29.140
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:31.042
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:31.042
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:31.042
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:17:31.042
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:31.170
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:31.170
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:31.170
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:31.459
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:31.459
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Failed connections: 9973 | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:31.593
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:31.593
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:31.593
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:31.593
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:31.715
DTC Client socket (1) | Closed. | 2024-03-18 06:17:31.715
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:17:33.602
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:33.604
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:33.604
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:17:33.604
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:33.732
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:33.732
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:33.732
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:33.893
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:33.893
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:34.025
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:34.025
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:34.025
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:34.025
SC DTC Delayed Exchange Data | Failed connections: 9974 | 2024-03-18 06:17:34.025
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:34.025
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:34.026
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:34.026
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:34.026
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:34.026
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:34.144
DTC Client socket (1) | Closed. | 2024-03-18 06:17:34.144
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:17:36.047
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:36.047
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:36.047
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:17:36.047
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:36.176
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:36.176
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:36.176
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:36.457
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:36.457
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:36.593
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:36.593
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:36.593
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:36.593
SC DTC Delayed Exchange Data | Failed connections: 9975 | 2024-03-18 06:17:36.594
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:36.594
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:36.594
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:36.594
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:36.594
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:36.594
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:36.719
DTC Client socket (1) | Closed. | 2024-03-18 06:17:36.719
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:17:38.730
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:38.731
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:38.731
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:17:38.731
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:38.861
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:38.861
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:38.861
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:39.117
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:39.117
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:39.266
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:39.266
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:39.266
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:39.266
SC DTC Delayed Exchange Data | Failed connections: 9976 | 2024-03-18 06:17:39.266
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:39.266
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:39.267
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:39.267
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:39.267
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:39.267
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:39.412
DTC Client socket (1) | Closed. | 2024-03-18 06:17:39.412
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:41.269
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:41.270
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:41.270
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:17:41.270
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:41.425
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:41.425
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:41.425
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:41.575
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:41.575
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Failed connections: 9977 | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:41.714
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:41.714
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:41.714
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:41.714
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:41.843
DTC Client socket (1) | Closed. | 2024-03-18 06:17:41.844
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:43.730
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:43.730
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:43.730
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:17:43.730
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:43.865
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:43.865
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:43.866
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:44.045
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:44.045
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:44.192
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:44.192
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:44.192
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:44.192
SC DTC Delayed Exchange Data | Failed connections: 9978 | 2024-03-18 06:17:44.192
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:44.192
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:44.193
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:44.193
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:44.193
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:44.193
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:44.322
DTC Client socket (1) | Closed. | 2024-03-18 06:17:44.323
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:46.184
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:46.185
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:46.185
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:17:46.185
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:46.315
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:46.315
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:46.315
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:46.451
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:46.451
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:46.592
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:46.592
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:46.592
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:46.592
SC DTC Delayed Exchange Data | Failed connections: 9979 | 2024-03-18 06:17:46.592
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:46.592
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:46.593
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:46.593
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:46.593
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:46.593
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:46.716
DTC Client socket (1) | Closed. | 2024-03-18 06:17:46.716
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:17:48.686
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:48.687
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:48.687
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:17:48.687
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:48.813
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:48.813
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:48.813
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:48.950
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:48.950
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Failed connections: 9980 | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:49.113
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:49.113
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:49.113
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:49.113
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:49.265
DTC Client socket (1) | Closed. | 2024-03-18 06:17:49.266
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:17:51.185
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:51.186
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:51.186
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:17:51.186
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:51.364
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:51.364
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:51.364
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:51.575
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:51.575
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:51.757
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:51.757
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:51.757
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:51.757
SC DTC Delayed Exchange Data | Failed connections: 9981 | 2024-03-18 06:17:51.757
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:51.757
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:51.758
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:51.758
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:51.758
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:51.758
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:51.937
DTC Client socket (1) | Closed. | 2024-03-18 06:17:51.937
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:17:53.751
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:53.751
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:53.752
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:17:53.752
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:53.875
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:53.875
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:53.875
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:54.032
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:54.032
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Failed connections: 9982 | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:54.168
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:54.168
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:54.168
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:54.168
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:54.294
DTC Client socket (1) | Closed. | 2024-03-18 06:17:54.294
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:17:56.265
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:56.266
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:56.266
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:17:56.266
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:56.388
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:56.388
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:56.389
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:56.514
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:56.514
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:56.655
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:56.655
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:56.655
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:17:56.655
SC DTC Delayed Exchange Data | Failed connections: 9983 | 2024-03-18 06:17:56.655
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:56.655
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:56.656
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:56.656
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:56.656
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:56.656
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:56.780
DTC Client socket (1) | Closed. | 2024-03-18 06:17:56.780
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:17:58.835
DTC Client socket (1) | Creating socket. | 2024-03-18 06:17:58.835
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:17:58.835
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:17:58.835
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:17:58.965
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:17:58.965
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:17:58.966
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:17:59.174
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:17:59.174
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Failed connections: 9984 | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:17:59.391
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:17:59.391
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:17:59.391
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:17:59.391
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:17:59.517
DTC Client socket (1) | Closed. | 2024-03-18 06:17:59.517
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:18:01.407
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:01.408
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:01.408
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:18:01.408
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:01.555
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:01.555
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:01.555
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:01.722
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:01.722
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Failed connections: 9985 | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:01.853
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:01.853
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:01.853
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:01.854
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:01.974
DTC Client socket (1) | Closed. | 2024-03-18 06:18:01.974
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:18:03.878
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:03.879
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:03.879
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:18:03.879
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:04.023
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:04.023
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:04.023
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:04.284
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:04.284
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Failed connections: 9986 | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:04.429
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:04.429
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:04.429
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:04.429
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:04.609
DTC Client socket (1) | Closed. | 2024-03-18 06:18:04.609
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:18:06.518
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:06.519
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:06.519
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:18:06.519
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:06.652
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:06.652
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:06.652
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:06.928
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:06.928
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:07.074
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:07.074
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:07.074
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:07.074
SC DTC Delayed Exchange Data | Failed connections: 9987 | 2024-03-18 06:18:07.074
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:07.074
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:07.075
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:07.075
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:07.075
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:07.075
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:07.209
DTC Client socket (1) | Closed. | 2024-03-18 06:18:07.209
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:09.082
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:09.083
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:09.083
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:18:09.083
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:09.210
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:09.210
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:09.210
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:09.369
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:09.369
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Failed connections: 9988 | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:09.511
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:09.511
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:09.511
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:09.511
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:09.639
DTC Client socket (1) | Closed. | 2024-03-18 06:18:09.639
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:11.516
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:11.517
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:11.517
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:18:11.517
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:11.656
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:11.656
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:11.656
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:11.830
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:11.830
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Failed connections: 9989 | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:12.012
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:12.012
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:12.012
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:12.012
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:12.140
DTC Client socket (1) | Closed. | 2024-03-18 06:18:12.140
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:14.070
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:14.071
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:14.071
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:18:14.071
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:14.194
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:14.194
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:14.194
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:14.363
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:14.363
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Failed connections: 9990 | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:14.518
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:14.518
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:14.518
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:14.518
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:14.641
DTC Client socket (1) | Closed. | 2024-03-18 06:18:14.641
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:18:16.674
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:16.675
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:16.675
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:18:16.675
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:16.826
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:16.826
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:16.826
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:16.975
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:16.975
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:17.114
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:17.114
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:17.114
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:17.114
SC DTC Delayed Exchange Data | Failed connections: 9991 | 2024-03-18 06:18:17.114
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:17.114
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:17.115
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:17.115
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:17.115
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:17.115
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:17.241
DTC Client socket (1) | Closed. | 2024-03-18 06:18:17.242
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:18:19.121
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:19.122
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:19.122
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:18:19.122
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:19.299
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:19.299
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:19.299
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:19.549
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:19.549
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:19.738
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:19.738
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:19.738
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:19.738
SC DTC Delayed Exchange Data | Failed connections: 9992 | 2024-03-18 06:18:19.738
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:19.738
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:19.739
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:19.739
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:19.739
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:19.739
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:19.916
DTC Client socket (1) | Closed. | 2024-03-18 06:18:19.917
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:18:21.742
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:21.743
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:21.744
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:18:21.744
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:21.897
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:21.897
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:21.897
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:22.046
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:22.046
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Failed connections: 9993 | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:22.192
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:22.192
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:22.192
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:22.192
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:22.322
DTC Client socket (1) | Closed. | 2024-03-18 06:18:22.322
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:18:24.196
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:24.196
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:24.196
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:18:24.196
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:24.321
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:24.321
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:24.321
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:24.474
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:24.474
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:24.620
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:24.620
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:24.620
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:24.620
SC DTC Delayed Exchange Data | Failed connections: 9994 | 2024-03-18 06:18:24.620
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:24.620
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:24.621
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:24.621
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:24.621
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:24.621
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:24.744
DTC Client socket (1) | Closed. | 2024-03-18 06:18:24.744
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:26.691
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:26.692
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:26.692
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:18:26.692
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:26.849
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:26.849
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:26.849
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:27.131
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:27.131
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:27.389
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:27.389
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:27.389
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:27.389
SC DTC Delayed Exchange Data | Failed connections: 9995 | 2024-03-18 06:18:27.389
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:27.389
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:27.390
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:27.390
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:27.390
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:27.390
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:27.550
DTC Client socket (1) | Closed. | 2024-03-18 06:18:27.550
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:18:29.415
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:29.416
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:29.417
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:18:29.417
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:29.568
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:29.568
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:29.568
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:29.710
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:29.710
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:29.846
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:29.846
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:29.846
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:29.846
SC DTC Delayed Exchange Data | Failed connections: 9996 | 2024-03-18 06:18:29.846
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:29.846
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:29.847
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:29.847
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:29.847
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:29.847
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:29.971
DTC Client socket (1) | Closed. | 2024-03-18 06:18:29.971
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:18:31.852
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:31.853
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:31.853
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:18:31.853
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:31.980
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:31.980
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:31.980
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:32.306
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:32.306
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Failed connections: 9997 | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:32.677
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:32.677
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:32.677
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:32.677
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:32.808
DTC Client socket (1) | Closed. | 2024-03-18 06:18:32.808
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:18:34.793
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:34.793
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:34.793
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:18:34.793
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:34.926
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:34.926
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:34.926
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:35.143
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:35.143
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:35.283
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:35.283
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:35.283
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:35.283
SC DTC Delayed Exchange Data | Failed connections: 9998 | 2024-03-18 06:18:35.283
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:35.283
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:35.284
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:35.284
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:35.284
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:35.284
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:35.428
DTC Client socket (1) | Closed. | 2024-03-18 06:18:35.428
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:37.330
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:37.330
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:37.330
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:18:37.331
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:37.466
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:37.466
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:37.466
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:37.648
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:37.648
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:37.816
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:37.816
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:37.816
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:37.816
SC DTC Delayed Exchange Data | Failed connections: 9999 | 2024-03-18 06:18:37.816
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:37.816
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:37.817
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:37.817
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:37.817
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:37.817
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:37.945
DTC Client socket (1) | Closed. | 2024-03-18 06:18:37.945
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:39.913
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:39.914
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:39.914
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:18:39.914
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:40.043
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:40.043
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:40.043
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:40.191
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:40.191
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:40.345
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:40.345
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:40.345
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:40.345
SC DTC Delayed Exchange Data | Failed connections: 10000 | 2024-03-18 06:18:40.345
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:40.345
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:40.346
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:40.346
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:40.346
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:40.346
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:40.471
DTC Client socket (1) | Closed. | 2024-03-18 06:18:40.471
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:42.471
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:42.472
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:42.472
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:18:42.472
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:42.601
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:42.601
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:42.601
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:42.763
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:42.763
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:42.897
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:42.897
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:42.897
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:42.897
SC DTC Delayed Exchange Data | Failed connections: 10001 | 2024-03-18 06:18:42.897
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:42.897
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:42.898
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:42.898
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:42.898
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:42.898
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:43.020
DTC Client socket (1) | Closed. | 2024-03-18 06:18:43.020
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:18:44.914
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:44.915
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:44.915
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:18:44.915
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:45.042
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:45.042
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:45.042
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:45.192
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:45.192
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Failed connections: 10002 | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:45.336
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:45.336
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:45.336
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:45.336
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:45.462
DTC Client socket (1) | Closed. | 2024-03-18 06:18:45.462
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:18:47.462
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:47.463
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:47.463
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:18:47.463
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:47.643
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:47.643
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:47.643
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:47.837
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:47.837
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:48.024
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:48.024
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:48.024
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:48.024
SC DTC Delayed Exchange Data | Failed connections: 10003 | 2024-03-18 06:18:48.024
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:48.024
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:48.025
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:48.025
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:48.025
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:48.025
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:48.199
DTC Client socket (1) | Closed. | 2024-03-18 06:18:48.199
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:18:50.035
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:50.035
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:50.036
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:18:50.036
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:50.162
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:50.162
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:50.163
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:50.318
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:50.318
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Failed connections: 10004 | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:50.476
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:50.476
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:50.476
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:50.477
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:50.601
DTC Client socket (1) | Closed. | 2024-03-18 06:18:50.601
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:18:52.486
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:52.487
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:52.487
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:18:52.487
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:52.656
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:52.656
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:52.657
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:52.816
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:52.816
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Failed connections: 10005 | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:53.029
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:53.029
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:53.029
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:53.029
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:53.162
DTC Client socket (1) | Closed. | 2024-03-18 06:18:53.162
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:18:55.026
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:55.026
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:55.027
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:18:55.027
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:55.294
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:55.294
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:55.294
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:55.494
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:55.494
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:55.673
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:55.673
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:55.673
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:18:55.673
SC DTC Delayed Exchange Data | Failed connections: 10006 | 2024-03-18 06:18:55.673
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:55.673
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:55.674
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:55.674
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:55.674
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:55.674
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:55.794
DTC Client socket (1) | Closed. | 2024-03-18 06:18:55.794
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:18:57.679
DTC Client socket (1) | Creating socket. | 2024-03-18 06:18:57.680
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:18:57.680
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:18:57.680
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:18:57.802
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:18:57.802
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:18:57.802
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:18:57.933
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:18:57.933
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Failed connections: 10007 | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:18:58.066
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:18:58.066
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:18:58.066
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:18:58.066
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:18:58.224
DTC Client socket (1) | Closed. | 2024-03-18 06:18:58.224
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:19:00.080
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:00.080
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:00.080
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:19:00.080
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:00.210
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:00.210
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:00.210
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:00.444
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:00.444
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:00.825
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:00.825
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:00.825
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:00.825
SC DTC Delayed Exchange Data | Failed connections: 10008 | 2024-03-18 06:19:00.825
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:00.825
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:00.826
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:00.826
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:00.826
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:00.826
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:00.954
DTC Client socket (1) | Closed. | 2024-03-18 06:19:00.954
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:19:02.840
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:02.842
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:02.842
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:19:02.842
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:02.977
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:02.977
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:02.977
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:03.193
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:03.193
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Failed connections: 10009 | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:03.330
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:03.330
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:03.330
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:03.330
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:03.499
DTC Client socket (1) | Closed. | 2024-03-18 06:19:03.499
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:05.350
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:05.351
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:05.351
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:19:05.351
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:05.515
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:05.515
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:05.515
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:05.660
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:05.660
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:05.797
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:05.797
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:05.797
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:05.797
SC DTC Delayed Exchange Data | Failed connections: 10010 | 2024-03-18 06:19:05.797
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:05.797
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:05.798
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:05.798
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:05.798
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:05.798
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:05.924
DTC Client socket (1) | Closed. | 2024-03-18 06:19:05.925
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:07.801
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:07.802
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:07.802
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:19:07.802
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:07.940
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:07.940
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:07.941
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:08.127
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:08.127
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:08.266
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:08.266
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:08.266
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:08.266
SC DTC Delayed Exchange Data | Failed connections: 10011 | 2024-03-18 06:19:08.266
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:08.266
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:08.267
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:08.267
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:08.267
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:08.267
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:08.394
DTC Client socket (1) | Closed. | 2024-03-18 06:19:08.395
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:10.275
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:10.276
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:10.277
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:19:10.277
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:10.406
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:10.406
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:10.406
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:10.568
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:10.568
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:10.701
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:10.702
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:10.702
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:10.702
SC DTC Delayed Exchange Data | Failed connections: 10012 | 2024-03-18 06:19:10.702
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:10.702
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:10.702
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:10.703
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:10.703
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:10.703
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:10.824
DTC Client socket (1) | Closed. | 2024-03-18 06:19:10.825
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:19:12.698
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:12.699
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:12.699
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:19:12.699
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:12.831
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:12.831
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:12.831
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:13.011
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:13.011
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Failed connections: 10013 | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:13.174
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:13.174
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:13.175
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:13.175
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:13.175
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:13.302
DTC Client socket (1) | Closed. | 2024-03-18 06:19:13.302
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:19:15.180
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:15.181
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:15.181
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:19:15.181
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:15.360
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:15.360
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:15.360
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:15.535
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:15.535
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:15.722
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:15.722
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:15.722
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:15.722
SC DTC Delayed Exchange Data | Failed connections: 10014 | 2024-03-18 06:19:15.722
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:15.722
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:15.723
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:15.723
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:15.723
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:15.723
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:15.898
DTC Client socket (1) | Closed. | 2024-03-18 06:19:15.899
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:19:17.733
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:17.733
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:17.733
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:19:17.733
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:17.861
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:17.861
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:17.861
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:18.023
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:18.023
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Failed connections: 10015 | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:18.162
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:18.162
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:18.162
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:18.162
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:18.291
DTC Client socket (1) | Closed. | 2024-03-18 06:19:18.291
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:19:20.525
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:20.525
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:20.526
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:19:20.526
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:20.679
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:20.679
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:20.679
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:20.816
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:20.816
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:20.943
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:20.943
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:20.943
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:20.943
SC DTC Delayed Exchange Data | Failed connections: 10016 | 2024-03-18 06:19:20.943
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:20.943
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:20.944
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:20.944
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:20.944
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:20.944
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:21.103
DTC Client socket (1) | Closed. | 2024-03-18 06:19:21.103
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:22.950
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:22.951
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:22.951
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:19:22.951
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:23.077
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:23.077
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:23.077
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:23.296
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:23.296
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:23.450
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:23.450
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:23.450
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:23.450
SC DTC Delayed Exchange Data | Failed connections: 10017 | 2024-03-18 06:19:23.450
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:23.450
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:23.451
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:23.451
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:23.451
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:23.451
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:23.646
DTC Client socket (1) | Closed. | 2024-03-18 06:19:23.646
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:19:25.460
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:25.461
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:25.461
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:19:25.461
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:25.591
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:25.591
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:25.591
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:25.754
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:25.754
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Failed connections: 10018 | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:25.905
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:25.905
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:25.905
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:25.905
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:26.029
DTC Client socket (1) | Closed. | 2024-03-18 06:19:26.029
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:19:27.916
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:27.917
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:27.917
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:19:27.917
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:28.044
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:28.044
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:28.044
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:28.320
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:28.320
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Failed connections: 10019 | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:28.481
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:28.481
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:28.481
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:28.481
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:28.611
DTC Client socket (1) | Closed. | 2024-03-18 06:19:28.612
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:19:30.504
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:30.506
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:30.506
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:19:30.506
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:30.640
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:30.640
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:30.640
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:30.855
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:30.855
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:30.986
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:30.986
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:30.986
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:30.986
SC DTC Delayed Exchange Data | Failed connections: 10020 | 2024-03-18 06:19:30.986
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:30.986
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:30.987
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:30.987
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:30.987
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:30.987
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:31.136
DTC Client socket (1) | Closed. | 2024-03-18 06:19:31.136
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:32.982
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:32.982
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:32.982
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:19:32.982
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:33.113
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:33.113
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:33.113
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:33.259
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:33.259
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:33.400
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:33.400
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:33.400
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:33.400
SC DTC Delayed Exchange Data | Failed connections: 10021 | 2024-03-18 06:19:33.400
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:33.400
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:33.401
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:33.401
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:33.401
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:33.401
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:33.523
DTC Client socket (1) | Closed. | 2024-03-18 06:19:33.523
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:35.551
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:35.551
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:35.552
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:19:35.552
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:35.680
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:35.680
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:35.680
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:35.841
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:35.842
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:35.983
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:35.983
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:35.983
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:35.983
SC DTC Delayed Exchange Data | Failed connections: 10022 | 2024-03-18 06:19:35.983
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:35.984
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:35.984
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:35.984
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:35.984
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:35.984
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:36.110
DTC Client socket (1) | Closed. | 2024-03-18 06:19:36.110
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:38.051
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:38.052
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:38.052
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:19:38.052
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:38.240
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:38.240
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:38.240
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:38.413
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:38.413
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:38.558
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Failed connections: 10023 | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:38.559
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:38.559
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:38.559
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:38.559
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:38.687
DTC Client socket (1) | Closed. | 2024-03-18 06:19:38.687
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:19:40.588
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:40.589
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:40.589
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:19:40.589
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:40.718
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:40.718
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:40.718
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:40.876
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:40.876
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Failed connections: 10024 | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:41.024
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:41.024
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:41.024
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:41.024
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:41.151
DTC Client socket (1) | Closed. | 2024-03-18 06:19:41.151
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:19:43.121
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:43.121
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:43.122
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:19:43.122
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:43.317
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:43.317
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:43.317
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:43.555
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:43.555
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:43.764
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:43.764
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:43.764
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:43.764
SC DTC Delayed Exchange Data | Failed connections: 10025 | 2024-03-18 06:19:43.764
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:43.764
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:43.765
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:43.765
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:43.765
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:43.765
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:43.951
DTC Client socket (1) | Closed. | 2024-03-18 06:19:43.952
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:19:45.770
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:45.771
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:45.771
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:19:45.771
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:45.916
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:45.916
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:45.916
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:46.089
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:46.089
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:46.228
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:46.228
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:46.228
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:46.228
SC DTC Delayed Exchange Data | Failed connections: 10026 | 2024-03-18 06:19:46.228
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:46.228
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:46.229
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:46.229
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:46.229
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:46.229
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:46.423
DTC Client socket (1) | Closed. | 2024-03-18 06:19:46.423
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:19:48.226
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:48.227
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:48.227
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:19:48.228
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:48.359
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:48.359
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:48.359
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:48.555
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:48.555
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:48.699
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:48.699
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:48.699
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:48.699
SC DTC Delayed Exchange Data | Failed connections: 10027 | 2024-03-18 06:19:48.699
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:48.700
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:48.700
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:48.700
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:48.700
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:48.700
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:48.843
DTC Client socket (1) | Closed. | 2024-03-18 06:19:48.843
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:19:50.713
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:50.714
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:50.714
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:19:50.714
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:50.860
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:50.860
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:50.860
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:51.681
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:51.681
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:52.013
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:52.013
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:52.013
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:52.013
SC DTC Delayed Exchange Data | Failed connections: 10028 | 2024-03-18 06:19:52.013
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:52.013
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:52.014
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:52.014
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:52.014
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:52.014
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:52.318
DTC Client socket (1) | Closed. | 2024-03-18 06:19:52.318
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:19:54.185
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:54.186
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:54.186
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:19:54.186
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:54.319
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:54.319
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:54.319
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:54.520
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:54.520
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Failed connections: 10029 | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:54.660
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:54.660
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:54.660
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:54.660
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:54.785
DTC Client socket (1) | Closed. | 2024-03-18 06:19:54.785
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:19:56.736
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:56.736
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:56.737
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:19:56.737
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:56.864
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:56.864
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:56.864
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:19:57.111
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:19:57.111
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:19:57.581
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:19:57.581
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:19:57.582
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:19:57.582
SC DTC Delayed Exchange Data | Failed connections: 10030 | 2024-03-18 06:19:57.582
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:19:57.582
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:19:57.582
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:19:57.582
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:19:57.582
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:19:57.583
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:19:57.710
DTC Client socket (1) | Closed. | 2024-03-18 06:19:57.710
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:19:59.769
DTC Client socket (1) | Creating socket. | 2024-03-18 06:19:59.770
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:19:59.770
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:19:59.770
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:19:59.898
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:19:59.898
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:19:59.898
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:00.173
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:00.173
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:00.317
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:00.317
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:00.317
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:00.317
SC DTC Delayed Exchange Data | Failed connections: 10031 | 2024-03-18 06:20:00.317
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:00.317
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:20:00.318
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:00.318
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:00.318
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:00.318
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:20:00.487
DTC Client socket (1) | Closed. | 2024-03-18 06:20:00.488
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:02.317
DTC Client socket (1) | Creating socket. | 2024-03-18 06:20:02.318
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:20:02.318
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:20:02.318
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:02.453
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:02.453
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:02.453
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:02.642
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:02.642
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:02.787
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:02.787
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:02.787
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:02.787
SC DTC Delayed Exchange Data | Failed connections: 10032 | 2024-03-18 06:20:02.788
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:02.788
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:20:02.788
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:02.789
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:02.789
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:02.789
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:20:02.931
DTC Client socket (1) | Closed. | 2024-03-18 06:20:02.931
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:04.982
DTC Client socket (1) | Creating socket. | 2024-03-18 06:20:04.983
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:20:04.983
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:20:04.983
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:05.124
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:05.124
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:05.125
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:05.279
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:05.279
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:05.422
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Failed connections: 10033 | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:05.423
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:05.423
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:05.423
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:05.424
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:20:05.549
DTC Client socket (1) | Closed. | 2024-03-18 06:20:05.550
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:07.421
DTC Client socket (1) | Creating socket. | 2024-03-18 06:20:07.422
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:20:07.422
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:20:07.422
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:07.546
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:07.546
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:07.546
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:07.676
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:07.676
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:07.805
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:07.805
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:07.805
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:07.805
SC DTC Delayed Exchange Data | Failed connections: 10034 | 2024-03-18 06:20:07.805
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:07.805
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:20:07.806
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:07.806
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:07.806
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:07.806
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:20:07.925
DTC Client socket (1) | Closed. | 2024-03-18 06:20:07.926
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:20:09.805
DTC Client socket (1) | Creating socket. | 2024-03-18 06:20:09.805
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:20:09.806
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:20:09.806
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:09.944
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:09.944
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:09.945
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:10.100
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:10.100
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Failed connections: 10035 | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:10.270
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:10.270
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:10.270
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:10.270
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:20:10.395
DTC Client socket (1) | Closed. | 2024-03-18 06:20:10.396
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:20:12.370
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:12.370
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:12.370
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:20:12.370
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:12.547
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:12.547
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:12.547
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:12.743
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:12.743
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:12.924
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:12.924
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:12.924
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:12.924
SC DTC Delayed Exchange Data | Failed connections: 10036 | 2024-03-18 06:20:12.924
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:12.924
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:12.925
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:12.925
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:12.925
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:12.925
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:13.098
DTC Client socket (2) | Closed. | 2024-03-18 06:20:13.098
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:20:14.926
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:14.928
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:14.928
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:20:14.928
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:15.058
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:15.058
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:15.058
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:15.196
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:15.196
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Failed connections: 10037 | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:15.347
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:15.347
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:15.347
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:15.347
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:15.474
DTC Client socket (2) | Closed. | 2024-03-18 06:20:15.475
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:20:17.395
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:17.395
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:17.396
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:20:17.396
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:17.522
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:17.522
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:17.522
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:17.701
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:17.701
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Failed connections: 10038 | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:17.840
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:17.840
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:17.840
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:17.840
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:17.964
DTC Client socket (2) | Closed. | 2024-03-18 06:20:17.964
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:19.906
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:19.907
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:19.907
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:20:19.907
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:20.035
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:20.035
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:20.035
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:20.295
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:20.295
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Failed connections: 10039 | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:20.508
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:20.508
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:20.509
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:20.509
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:20.509
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:20.665
DTC Client socket (2) | Closed. | 2024-03-18 06:20:20.665
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:20:22.504
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:22.505
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:22.506
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:20:22.506
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:22.636
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:22.636
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:22.636
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:22.818
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:22.818
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:22.958
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:22.958
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:22.958
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:22.958
SC DTC Delayed Exchange Data | Failed connections: 10040 | 2024-03-18 06:20:22.958
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:22.958
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:22.959
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:22.959
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:22.959
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:22.959
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:23.083
DTC Client socket (2) | Closed. | 2024-03-18 06:20:23.084
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:20:24.973
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:24.974
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:24.974
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:20:24.974
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:25.101
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:25.101
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:25.101
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:25.355
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:25.355
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:25.523
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:25.523
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:25.523
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:25.523
SC DTC Delayed Exchange Data | Failed connections: 10041 | 2024-03-18 06:20:25.523
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:25.523
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:25.524
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:25.524
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:25.524
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:25.524
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:25.658
DTC Client socket (2) | Closed. | 2024-03-18 06:20:25.658
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:20:27.531
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:27.532
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:27.533
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:20:27.533
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:27.690
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:27.690
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:27.690
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:27.956
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:27.956
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:28.125
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:28.125
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:28.125
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:28.125
SC DTC Delayed Exchange Data | Failed connections: 10042 | 2024-03-18 06:20:28.125
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:28.125
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:28.126
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:28.126
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:28.126
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:28.126
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:28.259
DTC Client socket (2) | Closed. | 2024-03-18 06:20:28.259
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:30.133
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:30.134
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:30.134
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:20:30.134
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:30.309
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:30.309
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:30.310
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:30.468
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:30.468
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:30.640
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:30.640
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:30.640
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:30.640
SC DTC Delayed Exchange Data | Failed connections: 10043 | 2024-03-18 06:20:30.640
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:30.640
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:30.641
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:30.641
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:30.641
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:30.641
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:30.766
DTC Client socket (2) | Closed. | 2024-03-18 06:20:30.766
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:32.664
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:32.664
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:32.664
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:20:32.664
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:32.810
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:32.810
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:32.810
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:32.958
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:32.958
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Failed connections: 10044 | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:33.083
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:33.083
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:33.083
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:33.083
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:33.216
DTC Client socket (2) | Closed. | 2024-03-18 06:20:33.216
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:35.092
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:35.093
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:35.093
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:20:35.093
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:35.224
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:35.224
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:35.224
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:35.376
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:35.376
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:35.516
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:35.516
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:35.516
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:35.516
SC DTC Delayed Exchange Data | Failed connections: 10045 | 2024-03-18 06:20:35.516
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:35.516
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:35.517
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:35.517
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:35.517
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:35.517
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:35.677
DTC Client socket (2) | Closed. | 2024-03-18 06:20:35.678
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:20:37.518
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:37.519
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:37.519
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:20:37.519
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:37.651
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:37.651
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:37.651
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:37.797
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:37.797
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:37.963
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:37.963
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:37.963
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:37.963
SC DTC Delayed Exchange Data | Failed connections: 10046 | 2024-03-18 06:20:37.963
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:37.963
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:37.964
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:37.964
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:37.964
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:37.964
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:38.099
DTC Client socket (2) | Closed. | 2024-03-18 06:20:38.099
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:20:40.069
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:40.070
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:40.070
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:20:40.070
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:40.245
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:40.245
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:40.245
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:40.473
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:40.473
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Failed connections: 10047 | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:40.673
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:40.673
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:40.673
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:40.674
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:40.849
DTC Client socket (2) | Closed. | 2024-03-18 06:20:40.849
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:20:42.679
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:42.680
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:42.680
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:20:42.680
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:42.810
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:42.810
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:42.810
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:42.965
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:42.965
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Failed connections: 10048 | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:43.115
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:43.115
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:43.115
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:43.115
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:43.257
DTC Client socket (2) | Closed. | 2024-03-18 06:20:43.257
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:20:45.174
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:45.174
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:45.175
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:20:45.175
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:45.301
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:45.302
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:45.302
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:45.512
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:45.512
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:45.668
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:45.668
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:45.668
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:45.668
SC DTC Delayed Exchange Data | Failed connections: 10049 | 2024-03-18 06:20:45.668
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:45.668
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:45.669
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:45.669
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:45.669
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:45.669
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:45.793
DTC Client socket (2) | Closed. | 2024-03-18 06:20:45.793
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:47.674
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:47.674
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:47.674
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:20:47.674
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:47.804
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:47.804
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:47.805
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:48.083
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:48.083
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:48.271
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:48.271
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:48.271
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:48.271
SC DTC Delayed Exchange Data | Failed connections: 10050 | 2024-03-18 06:20:48.271
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:48.271
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:48.272
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:48.272
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:48.272
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:48.272
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:48.396
DTC Client socket (2) | Closed. | 2024-03-18 06:20:48.396
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:20:50.264
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:50.265
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:50.265
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:20:50.265
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:50.394
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:50.394
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:50.395
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:50.567
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:50.567
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:50.707
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:50.707
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:50.707
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:50.707
SC DTC Delayed Exchange Data | Failed connections: 10051 | 2024-03-18 06:20:50.707
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:50.707
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:50.708
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:50.708
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:50.708
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:50.708
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:50.829
DTC Client socket (2) | Closed. | 2024-03-18 06:20:50.829
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:20:52.740
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:52.741
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:52.741
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:20:52.741
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:52.875
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:52.876
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:52.876
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:53.569
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:53.569
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:53.886
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:53.886
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:53.886
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:53.886
SC DTC Delayed Exchange Data | Failed connections: 10052 | 2024-03-18 06:20:53.886
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:53.886
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:53.887
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:53.887
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:53.887
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:53.887
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:54.031
DTC Client socket (2) | Closed. | 2024-03-18 06:20:54.031
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:20:55.894
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:55.895
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:55.895
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:20:55.895
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:56.025
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:56.025
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:56.026
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:56.245
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:56.245
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Failed connections: 10053 | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:56.444
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:56.444
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:56.444
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:56.444
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:56.580
DTC Client socket (2) | Closed. | 2024-03-18 06:20:56.581
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:20:58.439
DTC Client socket (2) | Creating socket. | 2024-03-18 06:20:58.440
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:20:58.440
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:20:58.440
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:20:58.589
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:20:58.589
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:20:58.589
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:20:58.730
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:20:58.730
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:20:58.874
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:20:58.874
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:20:58.874
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:20:58.874
SC DTC Delayed Exchange Data | Failed connections: 10054 | 2024-03-18 06:20:58.874
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:20:58.874
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:20:58.875
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:20:58.875
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:20:58.875
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:20:58.875
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:20:59.006
DTC Client socket (2) | Closed. | 2024-03-18 06:20:59.007
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:00.877
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:00.877
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:00.877
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:21:00.877
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:01.006
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:01.006
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:01.006
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:01.180
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:01.180
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Failed connections: 10055 | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:01.325
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:01.325
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:01.325
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:01.325
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:01.458
DTC Client socket (2) | Closed. | 2024-03-18 06:21:01.458
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:03.372
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:03.373
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:03.373
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:21:03.373
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:03.509
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:03.509
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:03.509
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:03.660
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:03.660
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Failed connections: 10056 | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:03.848
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:03.848
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:03.848
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:03.848
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:03.969
DTC Client socket (2) | Closed. | 2024-03-18 06:21:03.969
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:21:05.929
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:05.929
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:05.929
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:21:05.929
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:06.059
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:06.059
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:06.059
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:06.239
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:06.239
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:06.379
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:06.379
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:06.379
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:06.379
SC DTC Delayed Exchange Data | Failed connections: 10057 | 2024-03-18 06:21:06.379
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:06.379
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:06.380
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:06.380
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:06.380
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:06.380
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:06.510
DTC Client socket (2) | Closed. | 2024-03-18 06:21:06.511
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:21:08.394
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:08.394
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:08.394
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:21:08.394
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:08.622
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:08.622
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:08.622
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:08.816
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:08.816
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:09.004
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:09.004
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:09.004
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:09.004
SC DTC Delayed Exchange Data | Failed connections: 10058 | 2024-03-18 06:21:09.004
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:09.004
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:09.005
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:09.005
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:09.005
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:09.005
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:09.207
DTC Client socket (2) | Closed. | 2024-03-18 06:21:09.207
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:21:11.006
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:11.007
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:11.007
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:21:11.007
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:11.138
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:11.138
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:11.139
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:11.283
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:11.283
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Failed connections: 10059 | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:11.434
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:11.434
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:11.434
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:11.434
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:11.559
DTC Client socket (2) | Closed. | 2024-03-18 06:21:11.560
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:21:13.497
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:13.498
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:13.498
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:21:13.498
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:13.621
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:13.621
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:13.622
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:13.763
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:13.763
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Failed connections: 10060 | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:13.900
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:13.900
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:13.900
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:13.900
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:14.050
DTC Client socket (2) | Closed. | 2024-03-18 06:21:14.050
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:16.053
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:16.054
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:16.054
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:21:16.054
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:16.210
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:16.210
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:16.210
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:16.472
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:16.472
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:16.600
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:16.600
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:16.600
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:16.600
SC DTC Delayed Exchange Data | Failed connections: 10061 | 2024-03-18 06:21:16.600
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:16.600
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:16.601
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:16.601
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:16.601
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:16.601
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:16.743
DTC Client socket (2) | Closed. | 2024-03-18 06:21:16.743
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:21:18.618
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:18.618
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:18.618
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:21:18.618
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:18.745
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:18.745
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:18.745
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:18.920
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:18.920
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Failed connections: 10062 | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:19.099
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:19.099
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:19.099
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:19.099
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:19.223
DTC Client socket (2) | Closed. | 2024-03-18 06:21:19.223
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:21:21.171
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:21.171
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:21.172
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:21:21.172
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:21.296
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:21.296
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:21.296
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:21.706
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:21.706
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Failed connections: 10063 | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:22.476
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:22.476
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:22.476
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:22.476
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:22.614
DTC Client socket (2) | Closed. | 2024-03-18 06:21:22.615
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:21:24.626
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:24.626
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:24.626
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:21:24.626
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:24.762
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:24.762
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:24.762
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:25.018
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:25.018
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Failed connections: 10064 | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:25.183
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:25.183
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:25.183
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:25.183
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:25.313
DTC Client socket (2) | Closed. | 2024-03-18 06:21:25.313
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:27.192
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:27.193
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:27.193
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:21:27.193
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:27.319
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:27.319
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:27.319
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:27.530
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:27.530
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Failed connections: 10065 | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:27.676
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:27.676
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:27.676
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:27.676
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:27.810
DTC Client socket (2) | Closed. | 2024-03-18 06:21:27.810
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:29.674
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:29.674
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:29.674
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:21:29.674
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:29.801
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:29.801
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:29.801
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:29.945
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:29.945
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Failed connections: 10066 | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:30.106
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:30.106
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:30.106
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:30.106
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:30.231
DTC Client socket (2) | Closed. | 2024-03-18 06:21:30.231
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:32.200
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:32.200
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:32.200
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:21:32.200
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:32.333
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:32.333
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:32.333
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:32.521
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:32.521
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:32.671
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:32.671
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:32.671
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:32.671
SC DTC Delayed Exchange Data | Failed connections: 10067 | 2024-03-18 06:21:32.671
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:32.671
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:32.672
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:32.672
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:32.672
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:32.672
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:32.794
DTC Client socket (2) | Closed. | 2024-03-18 06:21:32.794
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:21:34.752
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:34.753
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:34.754
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:21:34.754
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:34.884
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:34.884
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:34.885
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:35.064
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:35.064
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:35.195
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:35.195
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:35.195
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:35.195
SC DTC Delayed Exchange Data | Failed connections: 10068 | 2024-03-18 06:21:35.195
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:35.195
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:35.196
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:35.196
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:35.196
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:35.196
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:35.320
DTC Client socket (2) | Closed. | 2024-03-18 06:21:35.320
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:21:37.237
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:37.238
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:37.238
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:21:37.238
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:37.419
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:37.419
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:37.419
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:37.627
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:37.627
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Failed connections: 10069 | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:37.821
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:37.821
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:37.821
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:37.821
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:38.014
DTC Client socket (2) | Closed. | 2024-03-18 06:21:38.014
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:21:39.815
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:39.815
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:39.816
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:21:39.816
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:39.946
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:39.946
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:39.946
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:40.161
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:40.161
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:40.289
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:40.289
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:40.289
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:40.289
SC DTC Delayed Exchange Data | Failed connections: 10070 | 2024-03-18 06:21:40.289
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:40.289
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:40.290
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:40.290
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:40.290
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:40.290
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:40.585
DTC Client socket (2) | Closed. | 2024-03-18 06:21:40.585
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:21:42.281
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:42.281
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:42.281
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:21:42.281
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:42.409
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:42.409
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:42.409
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:42.578
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:42.578
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:42.711
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:42.711
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:42.711
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:42.711
SC DTC Delayed Exchange Data | Failed connections: 10071 | 2024-03-18 06:21:42.711
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:42.711
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:42.712
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:42.712
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:42.712
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:42.712
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:42.832
DTC Client socket (2) | Closed. | 2024-03-18 06:21:42.832
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:44.811
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:44.811
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:44.811
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:21:44.811
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:44.940
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:44.940
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:44.940
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:45.218
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:45.218
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Failed connections: 10072 | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:45.514
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:45.514
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:45.514
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:45.514
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:45.638
DTC Client socket (2) | Closed. | 2024-03-18 06:21:45.638
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:21:47.519
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:47.522
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:47.522
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:21:47.522
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:47.659
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:47.659
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:47.659
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:47.807
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:47.807
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Failed connections: 10073 | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:47.950
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:47.950
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:47.951
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:47.951
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:48.079
DTC Client socket (2) | Closed. | 2024-03-18 06:21:48.079
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:21:49.949
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:49.950
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:49.950
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:21:49.950
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:50.077
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:50.077
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:50.077
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:50.699
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:50.699
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Failed connections: 10074 | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:50.918
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:50.918
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:50.918
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:50.918
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:51.096
DTC Client socket (2) | Closed. | 2024-03-18 06:21:51.096
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:21:52.931
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:52.933
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:52.933
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:21:52.934
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:53.072
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:53.072
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:53.072
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:53.270
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:53.270
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Failed connections: 10075 | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:53.412
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:53.412
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:53.412
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:53.412
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:53.540
DTC Client socket (2) | Closed. | 2024-03-18 06:21:53.540
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:55.421
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:55.422
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:55.422
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:21:55.422
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:55.554
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:55.554
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:55.554
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:55.694
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:55.694
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:55.871
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:55.871
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:55.871
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:21:55.871
SC DTC Delayed Exchange Data | Failed connections: 10076 | 2024-03-18 06:21:55.871
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:55.871
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:55.871
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:55.872
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:55.872
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:55.872
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:56.036
DTC Client socket (2) | Closed. | 2024-03-18 06:21:56.036
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:21:57.921
DTC Client socket (2) | Creating socket. | 2024-03-18 06:21:57.922
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:21:57.922
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:21:57.922
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:21:58.051
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:21:58.051
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:21:58.051
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:21:58.193
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:21:58.193
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Failed connections: 10077 | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:21:58.333
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:21:58.333
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:21:58.333
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:21:58.334
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:21:58.334
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:21:58.462
DTC Client socket (2) | Closed. | 2024-03-18 06:21:58.462
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:00.422
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:00.422
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:00.422
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:22:00.422
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:00.547
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:00.547
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:00.547
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:00.701
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:00.701
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Failed connections: 10078 | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:00.863
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:00.863
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:00.863
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:00.863
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:00.986
DTC Client socket (2) | Closed. | 2024-03-18 06:22:00.986
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:22:02.964
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:02.965
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:02.965
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:22:02.965
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:03.099
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:03.099
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:03.099
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:03.234
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:03.234
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:03.398
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:03.398
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:03.398
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:03.398
SC DTC Delayed Exchange Data | Failed connections: 10079 | 2024-03-18 06:22:03.398
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:03.398
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:03.399
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:03.399
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:03.399
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:03.399
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:03.531
DTC Client socket (2) | Closed. | 2024-03-18 06:22:03.532
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:22:05.474
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:05.475
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:05.475
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:22:05.475
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:05.660
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:05.660
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:05.661
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:05.863
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:05.863
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Failed connections: 10080 | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:06.056
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:06.056
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:06.056
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:06.056
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:06.234
DTC Client socket (2) | Closed. | 2024-03-18 06:22:06.234
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:22:08.065
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:08.066
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:08.066
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:22:08.066
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:08.186
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:08.186
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:08.186
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:08.349
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:08.349
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:08.473
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:08.473
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:08.473
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:08.473
SC DTC Delayed Exchange Data | Failed connections: 10081 | 2024-03-18 06:22:08.473
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:08.473
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:08.474
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:08.475
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:08.475
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:08.475
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:08.594
DTC Client socket (2) | Closed. | 2024-03-18 06:22:08.594
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:22:10.505
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:10.506
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:10.506
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:22:10.506
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:10.632
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:10.632
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:10.632
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:10.783
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:10.783
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Failed connections: 10082 | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:10.941
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:10.941
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:10.941
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:10.941
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:11.063
DTC Client socket (2) | Closed. | 2024-03-18 06:22:11.063
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:13.066
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:13.067
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:13.067
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:22:13.067
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:13.193
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:13.193
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:13.194
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:13.558
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:13.558
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:13.764
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:13.764
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:13.764
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:13.764
SC DTC Delayed Exchange Data | Failed connections: 10083 | 2024-03-18 06:22:13.764
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:13.764
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:13.764
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:13.765
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:13.765
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:13.765
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:13.894
DTC Client socket (2) | Closed. | 2024-03-18 06:22:13.895
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:22:15.767
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:15.768
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:15.768
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:22:15.768
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:15.890
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:15.890
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:15.890
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:16.051
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:16.051
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:16.194
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:16.194
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:16.194
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:16.194
SC DTC Delayed Exchange Data | Failed connections: 10084 | 2024-03-18 06:22:16.194
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:16.194
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:16.195
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:16.195
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:16.195
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:16.195
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:16.319
DTC Client socket (2) | Closed. | 2024-03-18 06:22:16.319
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:22:18.191
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:18.192
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:18.192
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:22:18.192
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:18.317
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:18.317
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:18.317
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:18.564
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:18.564
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:18.709
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:18.709
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:18.709
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:18.709
SC DTC Delayed Exchange Data | Failed connections: 10085 | 2024-03-18 06:22:18.709
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:18.709
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:18.710
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:18.710
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:18.710
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:18.710
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:18.860
DTC Client socket (2) | Closed. | 2024-03-18 06:22:18.860
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:22:20.714
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:20.714
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:20.714
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:22:20.714
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:20.843
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:20.843
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:20.843
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:21.196
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:21.196
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Failed connections: 10086 | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:21.670
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:21.670
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:21.670
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:21.670
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:21.809
DTC Client socket (2) | Closed. | 2024-03-18 06:22:21.810
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:23.735
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:23.736
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:23.736
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:22:23.736
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:23.871
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:23.871
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:23.871
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:24.013
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:24.013
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:24.156
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:24.156
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:24.156
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:24.157
SC DTC Delayed Exchange Data | Failed connections: 10087 | 2024-03-18 06:22:24.157
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:24.157
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:24.157
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:24.157
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:24.157
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:24.157
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:24.277
DTC Client socket (2) | Closed. | 2024-03-18 06:22:24.277
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:26.202
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:26.203
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:26.203
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:22:26.203
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:26.330
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:26.330
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:26.330
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:26.471
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:26.471
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:26.633
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:26.633
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:26.633
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:26.633
SC DTC Delayed Exchange Data | Failed connections: 10088 | 2024-03-18 06:22:26.633
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:26.633
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:26.634
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:26.634
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:26.634
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:26.635
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:26.758
DTC Client socket (2) | Closed. | 2024-03-18 06:22:26.758
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:28.937
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:28.944
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:28.944
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:22:28.944
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:29.094
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:29.094
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:29.095
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:29.262
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:29.262
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:29.410
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:29.410
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:29.410
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:29.410
SC DTC Delayed Exchange Data | Failed connections: 10089 | 2024-03-18 06:22:29.410
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:29.410
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:29.411
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:29.411
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:29.411
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:29.411
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:29.539
DTC Client socket (2) | Closed. | 2024-03-18 06:22:29.539
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:22:31.423
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:31.424
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:31.424
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:22:31.424
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:31.578
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:31.578
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:31.578
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:31.744
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:31.744
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:31.879
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:31.879
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:31.879
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:31.879
SC DTC Delayed Exchange Data | Failed connections: 10090 | 2024-03-18 06:22:31.879
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:31.879
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:31.880
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:31.880
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:31.880
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:31.880
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:32.029
DTC Client socket (2) | Closed. | 2024-03-18 06:22:32.029
File >> Disconnect selected. | 2024-03-18 06:22:32.152
DTC Client socket (0) | CloseSocket call. | 2024-03-18 06:22:32.194
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:32.194
SC Data - All Services | Disconnected. | 2024-03-18 06:22:32.203
SC Data - All Services | Connected to server complete. | 2024-03-18 06:22:34.818
Triggering next historical data download in queue. | 2024-03-18 06:22:34.818
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2024-03-18 06:22:34.818
No download requests in the queue to start downloads for. | 2024-03-18 06:22:34.862
No download requests in the queue to start downloads for. | 2024-03-18 06:22:34.863
Mapping ESH24-CME to ESH24. Service code: cme | 2024-03-18 06:22:34.885
Using symbol data fast lookup vector | 2024-03-18 06:22:34.885
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESH24-CME (ESH24). ID: 1 Service code: cme | 2024-03-18 06:22:34.885
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:22:34.886
SC DTC Delayed Exchange Data | Requesting security definition data for: ESH24-CME (ESH24). ID: 1 | 2024-03-18 06:22:34.886
Added historical Intraday data request for ESH24-CME to the queue. | 2024-03-18 06:22:34.886
Intraday data recording state for symbol ESH24-CME is set to download 'Pending'. | 2024-03-18 06:22:34.886
Triggering next historical data download in queue. | 2024-03-18 06:22:34.886
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:34.886
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:34.886
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:22:34.886
Delaying start of download for ESH24-CME. | 2024-03-18 06:22:34.910
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:35.063
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:35.063
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:35.063
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:35.280
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:35.280
Requesting market depth updates for: ESH24-CME if supported. | 2024-03-18 06:22:35.281
Separate subscription for market depth updates not supported. ESH24-CME | 2024-03-18 06:22:35.281
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Failed connections: 10091 | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:35.492
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:35.492
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:35.492
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:35.493
Mapping MESH24-CME to MESH24. Service code: cme | 2024-03-18 06:22:35.621
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH24-CME (MESH24). ID: 2 Service code: cme | 2024-03-18 06:22:35.621
SC DTC Delayed Exchange Data | Requesting security definition data for: MESH24-CME (MESH24). ID: 2 | 2024-03-18 06:22:35.621
Added historical Intraday data request for MESH24-CME to the queue. | 2024-03-18 06:22:35.622
Intraday data recording state for symbol MESH24-CME is set to download 'Pending'. | 2024-03-18 06:22:35.622
Triggering next historical data download in queue. | 2024-03-18 06:22:35.622
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:35.666
DTC Client socket (2) | Closed. | 2024-03-18 06:22:35.666
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:22:37.678
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:37.679
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:37.679
DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:22:37.679
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:37.816
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:37.816
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:37.816
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:37.949
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:37.949
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:38.095
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:38.095
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:38.095
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:38.095
SC DTC Delayed Exchange Data | Failed connections: 10092 | 2024-03-18 06:22:38.095
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:38.095
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:38.096
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:38.096
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:38.096
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:38.096
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:38.223
DTC Client socket (2) | Closed. | 2024-03-18 06:22:38.223
Requesting market depth updates for: MESH24-CME if supported. | 2024-03-18 06:22:39.907
Separate subscription for market depth updates not supported. MESH24-CME | 2024-03-18 06:22:39.907
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:22:40.093
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:40.094
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:40.094
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:22:40.094
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:40.244
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:40.244
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:40.244
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:40.401
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:40.401
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:40.542
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:40.542
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:40.542
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:40.542
SC DTC Delayed Exchange Data | Failed connections: 10093 | 2024-03-18 06:22:40.542
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:40.542
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:40.542
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:40.543
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:40.543
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:40.543
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:40.670
DTC Client socket (2) | Closed. | 2024-03-18 06:22:40.670
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:42.557
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:42.558
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:42.559
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:22:42.559
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:42.687
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:42.687
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:42.688
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:42.931
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:42.931
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:43.072
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:43.072
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:43.072
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:43.072
SC DTC Delayed Exchange Data | Failed connections: 10094 | 2024-03-18 06:22:43.072
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:43.072
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:43.073
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:43.073
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:43.073
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:43.073
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:43.208
DTC Client socket (2) | Closed. | 2024-03-18 06:22:43.208
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:22:45.092
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:45.093
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:45.093
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:22:45.093
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:45.221
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:45.221
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:45.221
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:45.388
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:45.388
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:45.514
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:45.514
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:45.514
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:45.514
SC DTC Delayed Exchange Data | Failed connections: 10095 | 2024-03-18 06:22:45.514
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:45.514
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:45.515
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:45.515
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:45.515
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:45.515
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:45.638
DTC Client socket (2) | Closed. | 2024-03-18 06:22:45.638
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:22:47.526
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:47.528
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:47.528
DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:22:47.528
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:47.661
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:47.661
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:47.661
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:47.924
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:47.924
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:48.156
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:48.156
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:48.156
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:48.156
SC DTC Delayed Exchange Data | Failed connections: 10096 | 2024-03-18 06:22:48.156
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:48.156
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:48.157
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:48.157
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:48.157
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:48.157
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:48.285
DTC Client socket (2) | Closed. | 2024-03-18 06:22:48.285
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:22:50.155
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:50.156
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:50.156
DTC Client socket (2) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:22:50.156
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:50.290
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:50.290
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:50.291
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:50.578
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:50.578
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:50.716
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:50.716
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:50.716
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:50.716
SC DTC Delayed Exchange Data | Failed connections: 10097 | 2024-03-18 06:22:50.716
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:50.716
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:50.717
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:50.717
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:50.717
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:50.717
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:50.843
DTC Client socket (2) | Closed. | 2024-03-18 06:22:50.843
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:52.735
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:52.736
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:52.736
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:22:52.736
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:52.911
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:52.911
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:52.911
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:53.059
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:53.059
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:53.200
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:53.200
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:53.200
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:53.200
SC DTC Delayed Exchange Data | Failed connections: 10098 | 2024-03-18 06:22:53.200
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:53.200
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:53.201
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:53.201
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:53.201
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:53.201
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:53.332
DTC Client socket (2) | Closed. | 2024-03-18 06:22:53.333
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:55.206
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:55.207
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:55.207
DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:22:55.207
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:55.337
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:55.337
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:55.337
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:55.522
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:55.522
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Failed connections: 10099 | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:55.654
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:55.654
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:55.654
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:55.655
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:55.783
DTC Client socket (2) | Closed. | 2024-03-18 06:22:55.783
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:22:57.681
DTC Client socket (2) | Creating socket. | 2024-03-18 06:22:57.681
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:22:57.681
DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:22:57.681
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:22:57.809
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:22:57.809
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:22:57.809
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:22:57.956
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:22:57.956
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:22:58.095
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:22:58.095
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:22:58.095
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:22:58.095
SC DTC Delayed Exchange Data | Failed connections: 10100 | 2024-03-18 06:22:58.095
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:22:58.095
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:22:58.096
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:22:58.096
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:22:58.096
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:22:58.096
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:22:58.217
DTC Client socket (2) | Closed. | 2024-03-18 06:22:58.217
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:23:00.250
DTC Client socket (2) | Creating socket. | 2024-03-18 06:23:00.251
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:23:00.251
DTC Client socket (2) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:23:00.251
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:00.379
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:00.379
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:00.380
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:00.568
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:00.568
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:00.725
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:00.725
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:00.725
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:00.725
SC DTC Delayed Exchange Data | Failed connections: 10101 | 2024-03-18 06:23:00.725
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:00.725
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:23:00.726
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:00.726
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:00.726
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:00.726
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:23:00.857
DTC Client socket (2) | Closed. | 2024-03-18 06:23:00.857
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:23:02.728
DTC Client socket (2) | Creating socket. | 2024-03-18 06:23:02.728
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:23:02.729
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:23:02.729
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:02.908
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:02.908
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:02.908
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:03.113
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:03.113
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:03.302
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:03.302
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:03.302
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:03.302
SC DTC Delayed Exchange Data | Failed connections: 10102 | 2024-03-18 06:23:03.302
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:03.302
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:23:03.303
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:03.303
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:03.303
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:03.303
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:23:03.474
DTC Client socket (2) | Closed. | 2024-03-18 06:23:03.474
HD Request # 48 | Downloading Intraday chart data for ESH24-CME to the file ESH24-CME.scid. Service: cme | 2024-03-18 06:23:05.209
HD Request # 48 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 06:23:05.210
HD Request # 48 | Using server: ds26.sierracharts.com port 10150 | 2024-03-18 06:23:05.210
Socket (2) | Creating socket. | 2024-03-18 06:23:05.210
Socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:23:05.210
Socket (2) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:23:05.210
HD Request # 48 | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:05.463
HD Request # 48 | Sending historical data logon request message. | 2024-03-18 06:23:05.463
HD Request # 48 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: ESH24 | 2024-03-18 06:23:05.838
HD Request # 48 | Decompressing data. | 2024-03-18 06:23:05.966
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:23:06.030
DTC Client socket (4) | Creating socket. | 2024-03-18 06:23:06.031
DTC Client socket (4) | New receive buffer size: 5242880 | 2024-03-18 06:23:06.031
DTC Client socket (4) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:23:06.031
HD Request # 48 | Receiving Intraday data for ESH24-CME starting at 2024-03-15 13:29:59.110000 | 2024-03-18 06:23:06.089
Socket (2) | CloseSocket call. | 2024-03-18 06:23:06.089
Socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:06.089
Historical data download thread signaled to stop. | 2024-03-18 06:23:06.101
HD Request # 48 | Received 31 Intraday data records from 2024-03-15 13:29:59.110000 to 2024-03-15 13:29:59.847001 (0.7 seconds. Delay: 2.7 days) and wrote 0 records for ESH24-CME | 2024-03-18 06:23:06.101
HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 06:23:06.102
HD Request # 48 | Completion time: 1s. | 2024-03-18 06:23:06.102
HD Request # 48 | Intraday data download complete for ESH24-CME. Unique request ID: 48 | 2024-03-18 06:23:06.102
Removing historical data download ID 48. | 2024-03-18 06:23:06.102
Real-time Intraday chart data file updates started for ESH24-CME | 2024-03-18 06:23:06.102
Intraday chart data file opened for ESH24-CME | 2024-03-18 06:23:06.102
HD Request # 48 | Enabling Intraday chart updating for symbol. | 2024-03-18 06:23:06.102
Triggering next historical data download in queue. | 2024-03-18 06:23:06.102
Historical data for ESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 06:23:06.102
HD Request # 49 | Downloading Intraday chart data for MESH24-CME to the file MESH24-CME.scid. Service: cme | 2024-03-18 06:23:06.102
HD Request # 49 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 06:23:06.103
HD Request # 49 | Using server: ds28.sierracharts.com port 10149 | 2024-03-18 06:23:06.103
Socket (5) | Creating socket. | 2024-03-18 06:23:06.106
Socket (5) | New receive buffer size: 5242880 | 2024-03-18 06:23:06.106
Socket (5) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:23:06.106
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:06.167
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:06.167
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:06.167
Socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:23:06.214
Socket (2) | Closed. | 2024-03-18 06:23:06.214
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:06.358
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:06.358
HD Request # 49 | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:06.386
HD Request # 49 | Sending historical data logon request message. | 2024-03-18 06:23:06.386
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:06.540
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:06.540
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:06.540
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:06.540
SC DTC Delayed Exchange Data | Failed connections: 10103 | 2024-03-18 06:23:06.540
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:06.540
DTC Client socket (4) | CloseSocket call. | 2024-03-18 06:23:06.541
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:06.541
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:06.541
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:06.541
DTC Client socket (4) | Socket gracefully closed by remote side. | 2024-03-18 06:23:06.665
DTC Client socket (4) | Closed. | 2024-03-18 06:23:06.666
HD Request # 49 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: MESH24 | 2024-03-18 06:23:06.761
HD Request # 49 | Decompressing data. | 2024-03-18 06:23:06.897
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:23:06.900
HD Request # 49 | Receiving Intraday data for MESH24-CME starting at 2024-03-15 13:29:59.188000 | 2024-03-18 06:23:07.020
Socket (5) | CloseSocket call. | 2024-03-18 06:23:07.020
Socket (5) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:07.020
Historical data download thread signaled to stop. | 2024-03-18 06:23:07.037
HD Request # 49 | Received 2 Intraday data records from 2024-03-15 13:29:59.188000 to 2024-03-15 13:29:59.465000 (0.3 seconds. Delay: 2.7 days) and wrote 0 records for MESH24-CME | 2024-03-18 06:23:07.037
HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 06:23:07.038
HD Request # 49 | Completion time: 1s. | 2024-03-18 06:23:07.038
HD Request # 49 | Intraday data download complete for MESH24-CME. Unique request ID: 49 | 2024-03-18 06:23:07.038
Removing historical data download ID 49. | 2024-03-18 06:23:07.038
Real-time Intraday chart data file updates started for MESH24-CME | 2024-03-18 06:23:07.038
Intraday chart data file opened for MESH24-CME | 2024-03-18 06:23:07.038
HD Request # 49 | Enabling Intraday chart updating for symbol. | 2024-03-18 06:23:07.038
Triggering next historical data download in queue. | 2024-03-18 06:23:07.038
Historical data for MESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 06:23:07.038
No download requests in the queue to start downloads for. | 2024-03-18 06:23:07.038
Chart #1 has tagged chart #14 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.045
Chart #1 has tagged chart #6 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.045
Chart #1 has tagged chart #8 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.045
Chart #1 has tagged chart #9 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.045
ESH24-CME[M] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:23:07.055
Socket (5) | Socket gracefully closed by remote side. | 2024-03-18 06:23:07.142
Socket (5) | Closed. | 2024-03-18 06:23:07.142
Chart #1 has tagged chart #2 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:23:07.280
ESH24-CME[M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 06:23:07.376
ESH24-CME[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.459
ESH24-CME[M] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.521
ESH24-CME[M] 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.542
ESH24-CME[M] 5 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 06:23:07.702
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:23:08.549
DTC Client socket (2) | Creating socket. | 2024-03-18 06:23:08.550
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:23:08.550
DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:23:08.550
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:08.693
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:08.693
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:08.693
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:08.842
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:08.842
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Failed connections: 10104 | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:08.998
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:08.998
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:08.999
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:08.999
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:23:09.126
DTC Client socket (2) | Closed. | 2024-03-18 06:23:09.126
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 06:23:11.003
DTC Client socket (2) | Creating socket. | 2024-03-18 06:23:11.004
DTC Client socket (2) | New receive buffer size: 5242880 | 2024-03-18 06:23:11.004
DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2024-03-18 06:23:11.004
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:11.137
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:11.137
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:11.137
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:11.366
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:11.366
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Failed connections: 10105 | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:11.523
DTC Client socket (2) | CloseSocket call. | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:11.523
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:11.523
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:11.524
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-03-18 06:23:11.696
DTC Client socket (2) | Closed. | 2024-03-18 06:23:11.696
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:23:13.525
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:13.526
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:13.527
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:23:13.527
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:13.669
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:13.669
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:13.669
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:13.801
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:13.801
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:13.938
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:13.938
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:13.938
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:13.939
SC DTC Delayed Exchange Data | Failed connections: 10106 | 2024-03-18 06:23:13.939
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:13.939
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:13.939
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:13.939
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:13.939
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:13.940
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:14.065
DTC Client socket (1) | Closed. | 2024-03-18 06:23:14.065
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 06:23:15.939
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:15.940
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:15.940
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 06:23:15.940
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:16.075
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:16.075
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:16.076
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:16.267
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:16.267
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Failed connections: 10107 | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:16.675
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:16.675
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:16.675
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:16.675
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:16.847
DTC Client socket (1) | Closed. | 2024-03-18 06:23:16.848
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 06:23:18.857
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:18.858
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:18.858
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 06:23:18.858
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:18.988
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:18.988
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:18.988
Saved Chartbook: Kiu - ES_HeatMap.Cht. Time: 0.0941 seconds. | 2024-03-18 06:23:19.177
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:19.195
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:19.195
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Failed connections: 10108 | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:19.422
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:19.422
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:19.422
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:19.422
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:19.558
DTC Client socket (1) | Closed. | 2024-03-18 06:23:19.558
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:23:21.423
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:21.424
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:21.424
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:23:21.424
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:21.553
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:21.553
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:21.553
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:21.735
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:21.735
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:21.882
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:21.882
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:21.883
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:21.883
SC DTC Delayed Exchange Data | Failed connections: 10109 | 2024-03-18 06:23:21.883
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:21.883
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:21.883
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:21.883
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:21.883
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:21.883
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:22.006
DTC Client socket (1) | Closed. | 2024-03-18 06:23:22.006
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 06:23:23.895
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:23.896
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:23.896
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 06:23:23.896
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:24.020
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:24.020
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:24.020
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:24.153
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:24.153
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:24.295
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:24.295
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:24.295
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:24.295
SC DTC Delayed Exchange Data | Failed connections: 10110 | 2024-03-18 06:23:24.295
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:24.295
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:24.295
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:24.296
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:24.296
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:24.296
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:24.417
DTC Client socket (1) | Closed. | 2024-03-18 06:23:24.418
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 06:23:26.383
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:26.384
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:26.384
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 06:23:26.384
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:26.532
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:26.532
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:26.532
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:26.710
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:26.710
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:26.926
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:26.926
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:26.926
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:26.926
SC DTC Delayed Exchange Data | Failed connections: 10111 | 2024-03-18 06:23:26.926
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:26.926
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:26.927
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:26.927
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:26.927
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:26.928
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:27.029
DTC Client socket (1) | Closed. | 2024-03-18 06:23:27.029
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 06:23:28.959
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:28.960
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:28.960
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 06:23:28.960
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:29.089
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:29.089
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:29.089
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:29.230
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:29.230
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:29.387
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:29.387
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:29.387
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:29.387
SC DTC Delayed Exchange Data | Failed connections: 10112 | 2024-03-18 06:23:29.387
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:29.387
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:29.388
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:29.388
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:29.388
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:29.388
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:29.514
DTC Client socket (1) | Closed. | 2024-03-18 06:23:29.514
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 06:23:31.565
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:31.566
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:31.566
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 06:23:31.566
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:31.809
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:31.809
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:31.809
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:32.037
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:32.037
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Failed connections: 10113 | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:32.247
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:32.247
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:32.247
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:32.247
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:32.453
DTC Client socket (1) | Closed. | 2024-03-18 06:23:32.453
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 06:23:34.254
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:34.255
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:34.256
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 06:23:34.256
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:34.386
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:34.386
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:34.386
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:34.578
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:34.578
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:34.752
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:34.752
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:34.752
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 06:23:34.752
SC DTC Delayed Exchange Data | Failed connections: 10114 | 2024-03-18 06:23:34.752
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:34.752
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:34.753
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:34.753
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:34.753
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:34.753
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:34.874
DTC Client socket (1) | Closed. | 2024-03-18 06:23:34.874
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 06:23:36.755
DTC Client socket (1) | Creating socket. | 2024-03-18 06:23:36.757
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 06:23:36.758
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 06:23:36.758
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 06:23:36.930
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 06:23:36.930
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 06:23:36.930
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 06:23:37.116
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 06:23:37.116
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 06:23:37.287
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 06:23:37.287
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 06:23:37.287
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 06:23:37.288
SC DTC Delayed Exchange Data | Failed connections: 10115 | 2024-03-18 06:23:37.288
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 06:23:37.288
DTC Client socket (1) | CloseSocket call. | 2024-03-18 06:23:37.288
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 06:23:37.288
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 06:23:37.288
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 06:23:37.288
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 06:23:37.414
DTC Client socket (1) | Closed. | 2024-03-18 06:23:37.414
Notice: Detected that the system has resumed from a low-power state. | 2024-03-18 17:45:05.994
Re-connecting to the Data/Trading service. | 2024-03-18 17:45:05.994
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:06.094
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:06.094
SC Data - All Services | Disconnected. | 2024-03-18 17:45:06.094
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2024-03-18 17:45:06.094
SC Data - All Services | Connected to server complete. | 2024-03-18 17:45:09.191
Triggering next historical data download in queue. | 2024-03-18 17:45:09.192
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2024-03-18 17:45:09.192
No download requests in the queue to start downloads for. | 2024-03-18 17:45:09.273
Mapping ESH24-CME to ESH24. Service code: cme | 2024-03-18 17:45:09.274
Using symbol data fast lookup vector | 2024-03-18 17:45:09.274
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESH24-CME (ESH24). ID: 1 Service code: cme | 2024-03-18 17:45:09.274
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:09.274
SC DTC Delayed Exchange Data | Requesting security definition data for: ESH24-CME (ESH24). ID: 1 | 2024-03-18 17:45:09.275
Added historical Intraday data request for ESH24-CME to the queue. | 2024-03-18 17:45:09.275
Intraday data recording state for symbol ESH24-CME is set to download 'Pending'. | 2024-03-18 17:45:09.275
Triggering next historical data download in queue. | 2024-03-18 17:45:09.275
Delaying start of download for ESH24-CME. | 2024-03-18 17:45:09.357
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:09.364
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:09.364
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:09.364
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:45:09.364
DTC Client socket (1) | Connect event error. Windows error code 10065: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnym hoście. | 2024-03-18 17:45:09.364 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:09.426
SC DTC Delayed Exchange Data | Failed connections: 10116 | 2024-03-18 17:45:09.427
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:09.427
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:09.427
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:09.427
DTC Client socket (1) | Closed. | 2024-03-18 17:45:09.442
Requesting market depth updates for: ESH24-CME if supported. | 2024-03-18 17:45:10.259
Separate subscription for market depth updates not supported. ESH24-CME | 2024-03-18 17:45:10.259
Mapping MESH24-CME to MESH24. Service code: cme | 2024-03-18 17:45:10.275
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH24-CME (MESH24). ID: 2 Service code: cme | 2024-03-18 17:45:10.275
SC DTC Delayed Exchange Data | Requesting security definition data for: MESH24-CME (MESH24). ID: 2 | 2024-03-18 17:45:10.275
Added historical Intraday data request for MESH24-CME to the queue. | 2024-03-18 17:45:10.275
Intraday data recording state for symbol MESH24-CME is set to download 'Pending'. | 2024-03-18 17:45:10.275
Triggering next historical data download in queue. | 2024-03-18 17:45:10.275
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:45:11.432
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:11.436
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:11.436
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:11.436
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:45:11.436
DTC Client socket (1) | Connect event error. Windows error code 10065: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnym hoście. | 2024-03-18 17:45:11.437 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:11.437
SC DTC Delayed Exchange Data | Failed connections: 10117 | 2024-03-18 17:45:11.437
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:11.437
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:11.437
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:11.437
DTC Client socket (1) | Closed. | 2024-03-18 17:45:11.439
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:45:13.445
Requesting market depth updates for: MESH24-CME if supported. | 2024-03-18 17:45:14.325
Separate subscription for market depth updates not supported. MESH24-CME | 2024-03-18 17:45:14.325
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:16.711
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:16.711
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:45:16.711
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:16.919
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:16.919
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:16.919
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:18.526
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:18.526
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Failed connections: 10118 | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:18.861
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:18.861
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:18.861
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:18.892
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:19.318
DTC Client socket (1) | Closed. | 2024-03-18 17:45:19.318
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:45:20.933
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:20.938
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:20.938
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:20.938
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:45:20.938
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 17:45:20.939 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:20.939
SC DTC Delayed Exchange Data | Failed connections: 10119 | 2024-03-18 17:45:20.939
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:20.939
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:20.939
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:20.939
DTC Client socket (1) | Closed. | 2024-03-18 17:45:20.942
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:22.936
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:22.937
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:22.937
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:22.937
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:45:22.937
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 17:45:22.937 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:22.939
DTC Client socket (1) | Closed. | 2024-03-18 17:45:22.939
SC DTC Delayed Exchange Data | Failed connections: 10120 | 2024-03-18 17:45:22.939
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:22.939
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:22.939
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:22.939
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:24.961
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:24.961
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:24.961
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:24.962
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:45:24.962
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 17:45:24.962 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:24.964
SC DTC Delayed Exchange Data | Failed connections: 10121 | 2024-03-18 17:45:24.964
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:24.964
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:24.964
DTC Client socket (1) | Closed. | 2024-03-18 17:45:24.964
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:24.964
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:27.007
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:27.009
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:27.009
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:27.010
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:45:27.010
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 17:45:27.010 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:27.010
SC DTC Delayed Exchange Data | Failed connections: 10122 | 2024-03-18 17:45:27.010
DTC Client socket (1) | Closed. | 2024-03-18 17:45:27.010
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:27.010
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:27.010
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:27.010
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:45:29.016
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-03-18 17:45:29.017
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:29.017
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:29.018
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:45:29.018
DTC Client socket (1) | Connect event error. Windows error code 10051: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnej sieci. | 2024-03-18 17:45:29.018 *
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:29.019
SC DTC Delayed Exchange Data | Failed connections: 10123 | 2024-03-18 17:45:29.019
DTC Client socket (1) | Closed. | 2024-03-18 17:45:29.019
DTC Client socket (0) | CloseSocket call. | 2024-03-18 17:45:29.019
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:29.019
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:29.019
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:45:31.180
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:31.279
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:31.279
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:45:31.279
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:31.464
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:31.464
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:31.465
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:31.661
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:31.661
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Failed connections: 10124 | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:31.866
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:31.866
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:31.866
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:31.868
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:32.047
DTC Client socket (1) | Closed. | 2024-03-18 17:45:32.047
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:45:34.034
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:34.053
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:34.053
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:45:34.053
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:34.176
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:34.176
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:34.176
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:34.368
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:34.368
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:34.506
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:34.506
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:34.506
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:34.506
SC DTC Delayed Exchange Data | Failed connections: 10125 | 2024-03-18 17:45:34.506
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:34.506
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:34.507
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:34.507
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:34.507
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:34.507
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:34.629
DTC Client socket (1) | Closed. | 2024-03-18 17:45:34.629
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:45:36.632
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:36.676
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:36.676
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:45:36.676
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:36.843
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:36.843
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:36.843
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:36.997
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:36.997
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Failed connections: 10126 | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:37.138
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:37.138
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:37.138
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:37.138
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:37.262
DTC Client socket (1) | Closed. | 2024-03-18 17:45:37.262
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:39.148
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:39.181
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:39.181
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:45:39.182
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:39.331
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:39.331
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:39.332
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:40.000
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:40.000
HD Request # 50 | Downloading Intraday chart data for ESH24-CME to the file ESH24-CME.scid. Service: cme | 2024-03-18 17:45:40.043
HD Request # 50 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 17:45:40.044
HD Request # 50 | Using server: ds13.sierracharts.com port 10150 | 2024-03-18 17:45:40.044
Socket (3) | Creating socket. | 2024-03-18 17:45:40.044
Socket (3) | New receive buffer size: 5242880 | 2024-03-18 17:45:40.045
Socket (3) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:45:40.045
HD Request # 50 | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:40.404
HD Request # 50 | Sending historical data logon request message. | 2024-03-18 17:45:40.404
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:40.529
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:40.529
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:40.529
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:40.529
SC DTC Delayed Exchange Data | Failed connections: 10127 | 2024-03-18 17:45:40.529
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:40.529
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:40.530
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:40.530
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:40.530
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:40.535
HD Request # 50 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: ESH24 | 2024-03-18 17:45:40.624
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:40.665
DTC Client socket (1) | Closed. | 2024-03-18 17:45:40.665
HD Request # 50 | Decompressing data. | 2024-03-18 17:45:40.798
HD Request # 50 | Receiving Intraday data for ESH24-CME starting at 2024-03-15 13:29:59.110000 | 2024-03-18 17:45:40.980
Socket (3) | CloseSocket call. | 2024-03-18 17:45:40.980
Socket (3) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:40.980
Historical data download thread signaled to stop. | 2024-03-18 17:45:40.999
HD Request # 50 | Received 31 Intraday data records from 2024-03-15 13:29:59.110000 to 2024-03-15 13:29:59.847001 (0.7 seconds. Delay: 3.2 days) and wrote 0 records for ESH24-CME | 2024-03-18 17:45:40.999
HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.847001 | 2024-03-18 17:45:41.000
HD Request # 50 | Completion time: 1s. | 2024-03-18 17:45:41.000
HD Request # 50 | Intraday data download complete for ESH24-CME. Unique request ID: 50 | 2024-03-18 17:45:41.000
Removing historical data download ID 50. | 2024-03-18 17:45:41.000
Real-time Intraday chart data file updates started for ESH24-CME | 2024-03-18 17:45:41.000
Intraday chart data file opened for ESH24-CME | 2024-03-18 17:45:41.000
HD Request # 50 | Enabling Intraday chart updating for symbol. | 2024-03-18 17:45:41.000
Triggering next historical data download in queue. | 2024-03-18 17:45:41.000
Historical data for ESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 17:45:41.000
HD Request # 51 | Downloading Intraday chart data for MESH24-CME to the file MESH24-CME.scid. Service: cme | 2024-03-18 17:45:41.000
HD Request # 51 | Download start date-time: 2024-03-15 13:29:59.000000. File last date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 17:45:41.001
HD Request # 51 | Using server: ds23.sierracharts.com port 10149 | 2024-03-18 17:45:41.001
Socket (1) | Creating socket. | 2024-03-18 17:45:41.001
Socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:41.001
Socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:45:41.001
Socket (3) | Socket gracefully closed by remote side. | 2024-03-18 17:45:41.165
Socket (3) | Closed. | 2024-03-18 17:45:41.165
HD Request # 51 | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:41.252
HD Request # 51 | Sending historical data logon request message. | 2024-03-18 17:45:41.252
HD Request # 51 | Requesting Intraday data. Start date-time: 2024-03-15 13:29:59. Record interval: 0. Symbol: MESH24 | 2024-03-18 17:45:41.615
HD Request # 51 | Decompressing data. | 2024-03-18 17:45:41.737
HD Request # 51 | Receiving Intraday data for MESH24-CME starting at 2024-03-15 13:29:59.188000 | 2024-03-18 17:45:41.860
Socket (1) | CloseSocket call. | 2024-03-18 17:45:41.860
Socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:41.860
Historical data download thread signaled to stop. | 2024-03-18 17:45:41.861
HD Request # 51 | Received 2 Intraday data records from 2024-03-15 13:29:59.188000 to 2024-03-15 13:29:59.465000 (0.3 seconds. Delay: 3.2 days) and wrote 0 records for MESH24-CME | 2024-03-18 17:45:41.861
HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2024-03-15 13:29:59.465000 | 2024-03-18 17:45:41.862
HD Request # 51 | Completion time: 0s. | 2024-03-18 17:45:41.862
HD Request # 51 | Intraday data download complete for MESH24-CME. Unique request ID: 51 | 2024-03-18 17:45:41.862
Removing historical data download ID 51. | 2024-03-18 17:45:41.862
Real-time Intraday chart data file updates started for MESH24-CME | 2024-03-18 17:45:41.862
Intraday chart data file opened for MESH24-CME | 2024-03-18 17:45:41.862
HD Request # 51 | Enabling Intraday chart updating for symbol. | 2024-03-18 17:45:41.862
Triggering next historical data download in queue. | 2024-03-18 17:45:41.862
Historical data for MESH24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2024-03-18 17:45:41.862
No download requests in the queue to start downloads for. | 2024-03-18 17:45:41.862
Chart #1 has tagged chart #14 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:41.968
Chart #1 has tagged chart #6 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:41.968
Chart #1 has tagged chart #8 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:41.968
Chart #1 has tagged chart #9 for full recalculation. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:41.968
Chart #1 has tagged chart #2 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:41.976
Socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:41.984
Socket (1) | Closed. | 2024-03-18 17:45:41.984
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:42.005
ESH24-CME[M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:42.160
ESH24-CME[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:42.275
ESH24-CME[M] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:42.388
ESH24-CME[M] 30 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:42.421
ESH24-CME[M] 5 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_NQ_Trade.Cht | 2024-03-18 17:45:42.605
ESH24-CME[M] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:42.643
Chart #1 has tagged chart #2 for full recalculation. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:42.960
ESH24-CME[M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Kiu - ES_HeatMap.Cht | 2024-03-18 17:45:43.108
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:45:43.165
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:43.166
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:43.166
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:45:43.166
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:43.298
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:43.298
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:43.298
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:43.454
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:43.454
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Failed connections: 10128 | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:43.578
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:43.578
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:43.578
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:43.578
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:43.699
DTC Client socket (1) | Closed. | 2024-03-18 17:45:43.699
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:45:45.693
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:45.694
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:45.694
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:45:45.694
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:45.839
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:45.839
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:45.839
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:46.567
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:46.567
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:48.293
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:48.293
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:48.293
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:48.293
SC DTC Delayed Exchange Data | Failed connections: 10129 | 2024-03-18 17:45:48.293
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:48.293
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:48.294
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:48.294
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:48.294
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:48.316
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:48.501
DTC Client socket (1) | Closed. | 2024-03-18 17:45:48.502
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:45:50.293
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:50.322
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:50.322
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:45:50.322
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:50.468
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:50.468
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:50.468
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:50.943
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:50.943
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:51.245
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:51.245
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:51.245
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:51.245
SC DTC Delayed Exchange Data | Failed connections: 10130 | 2024-03-18 17:45:51.245
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:51.245
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:51.246
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:51.246
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:51.246
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:51.246
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:51.398
DTC Client socket (1) | Closed. | 2024-03-18 17:45:51.398
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:53.262
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:53.301
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:53.301
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:45:53.301
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:53.423
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:53.423
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:53.423
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:53.571
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:53.571
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Failed connections: 10131 | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:53.699
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:53.699
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:53.699
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:53.700
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:53.700
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:53.820
DTC Client socket (1) | Closed. | 2024-03-18 17:45:53.820
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:55.720
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:55.756
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:55.756
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:45:55.756
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:55.886
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:55.886
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:55.886
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:56.037
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:56.037
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Failed connections: 10132 | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:56.174
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:56.174
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:56.174
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:56.174
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:56.290
DTC Client socket (1) | Closed. | 2024-03-18 17:45:56.290
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:45:58.193
DTC Client socket (1) | Creating socket. | 2024-03-18 17:45:58.193
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:45:58.193
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:45:58.193
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:45:58.318
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:45:58.318
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:45:58.318
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:45:58.456
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:45:58.456
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:45:58.621
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:45:58.621
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:45:58.621
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:45:58.621
SC DTC Delayed Exchange Data | Failed connections: 10133 | 2024-03-18 17:45:58.621
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:45:58.621
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:45:58.622
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:45:58.622
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:45:58.622
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:45:58.622
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:45:58.742
DTC Client socket (1) | Closed. | 2024-03-18 17:45:58.742
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:46:00.703
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:00.740
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:00.740
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:46:00.740
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:00.866
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:00.866
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:00.866
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:00.994
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:00.994
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:01.139
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:01.139
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:01.139
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:01.139
SC DTC Delayed Exchange Data | Failed connections: 10134 | 2024-03-18 17:46:01.139
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:01.139
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:01.140
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:01.140
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:01.140
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:01.140
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:01.262
DTC Client socket (1) | Closed. | 2024-03-18 17:46:01.262
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:46:03.216
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:03.216
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:03.216
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:46:03.216
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:03.392
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:03.392
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:03.392
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:03.627
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:03.627
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Failed connections: 10135 | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:03.809
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:03.809
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:03.809
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:03.809
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:03.983
DTC Client socket (1) | Closed. | 2024-03-18 17:46:03.983
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:46:05.848
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:05.854
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:05.854
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:46:05.854
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:05.975
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:05.975
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:05.975
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:06.175
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:06.175
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:06.316
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:06.316
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:06.316
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:06.316
SC DTC Delayed Exchange Data | Failed connections: 10136 | 2024-03-18 17:46:06.316
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:06.316
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:06.317
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:06.317
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:06.317
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:06.317
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:06.445
DTC Client socket (1) | Closed. | 2024-03-18 17:46:06.445
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:46:08.795
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:08.797
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:08.797
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:46:08.797
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:08.988
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:08.988
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:08.988
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:09.327
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:09.327
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:09.690
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:09.776
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:09.776
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:09.776
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:09.776
SC DTC Delayed Exchange Data | Failed connections: 10137 | 2024-03-18 17:46:09.776
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:09.776
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:09.777
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:09.777
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:09.777
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2024-03-18 17:46:09.793
DTC Client socket (1) | Closed. | 2024-03-18 17:46:09.793
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:46:12.874
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:12.906
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:12.906
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:46:12.906
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:13.112
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:13.112
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:13.115
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:13.607
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:13.607
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:14.050
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Failed connections: 10138 | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:14.051
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:14.051
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:14.051
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:14.073
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:14.074
DTC Client socket (1) | Closed. | 2024-03-18 17:46:14.074
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:46:16.349
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:16.349
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:16.349
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:46:16.349
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:16.481
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:16.481
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:16.481
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:16.603
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:16.603
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Failed connections: 10139 | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:16.729
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:16.729
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:16.729
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:16.729
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:16.850
DTC Client socket (1) | Closed. | 2024-03-18 17:46:16.850
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:46:18.757
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:18.757
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:18.757
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:46:18.757
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:18.882
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:18.882
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:18.882
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:19.261
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:19.261
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:20.021
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:20.021
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:20.021
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:20.021
SC DTC Delayed Exchange Data | Failed connections: 10140 | 2024-03-18 17:46:20.021
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:20.021
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:20.022
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:20.022
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:20.022
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:20.022
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:20.194
DTC Client socket (1) | Closed. | 2024-03-18 17:46:20.194
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:46:22.265
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:22.266
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:22.266
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:46:22.266
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:22.391
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:22.391
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:22.391
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:22.952
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:22.952
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Failed connections: 10141 | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:24.178
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:24.178
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:24.178
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:24.178
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:24.522
DTC Client socket (1) | Closed. | 2024-03-18 17:46:24.522
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:46:26.187
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:26.188
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:26.188
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:46:26.188
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:26.312
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:26.312
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:26.312
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:26.517
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:26.517
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:26.663
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:26.663
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:26.663
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:26.663
SC DTC Delayed Exchange Data | Failed connections: 10142 | 2024-03-18 17:46:26.663
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:26.663
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:26.664
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:26.664
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:26.664
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:26.664
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:26.792
DTC Client socket (1) | Closed. | 2024-03-18 17:46:26.792
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:46:28.683
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:28.683
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:28.683
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:46:28.683
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:28.807
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:28.807
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:28.808
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:28.942
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:28.942
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:29.077
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:29.077
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:29.077
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:29.077
SC DTC Delayed Exchange Data | Failed connections: 10143 | 2024-03-18 17:46:29.077
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:29.077
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:29.078
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:29.078
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:29.078
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:29.101
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:29.227
DTC Client socket (1) | Closed. | 2024-03-18 17:46:29.228
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:46:31.295
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:31.295
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:31.296
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:46:31.296
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:31.493
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:31.494
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:31.494
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:31.654
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:31.654
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:31.782
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:31.782
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:31.782
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:31.782
SC DTC Delayed Exchange Data | Failed connections: 10144 | 2024-03-18 17:46:31.782
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:31.782
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:31.783
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:31.783
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:31.783
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:31.783
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:31.904
DTC Client socket (1) | Closed. | 2024-03-18 17:46:31.905
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:46:33.780
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:33.781
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:33.781
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:46:33.781
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:33.910
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:33.910
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:33.910
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:34.049
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:34.049
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:34.194
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:34.194
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:34.194
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:34.194
SC DTC Delayed Exchange Data | Failed connections: 10145 | 2024-03-18 17:46:34.194
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:34.194
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:34.196
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:34.196
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:34.196
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:34.196
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:34.323
DTC Client socket (1) | Closed. | 2024-03-18 17:46:34.323
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:46:36.267
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:36.267
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:36.267
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:46:36.267
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:36.438
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:36.438
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:36.438
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:36.647
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:36.647
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Failed connections: 10146 | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:36.828
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:36.828
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:36.828
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:36.829
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:36.829
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:36.998
DTC Client socket (1) | Closed. | 2024-03-18 17:46:36.998
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:46:38.826
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:38.827
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:38.827
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:46:38.827
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:38.952
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:38.952
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:38.952
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:39.096
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:39.096
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Failed connections: 10147 | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:39.244
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:39.244
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:39.244
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:39.244
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:39.370
DTC Client socket (1) | Closed. | 2024-03-18 17:46:39.370
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:46:41.296
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:41.296
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:41.296
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:46:41.296
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:41.421
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:41.421
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:41.421
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:41.559
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:41.559
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Failed connections: 10148 | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:41.715
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:41.715
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:41.715
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:41.715
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:41.837
DTC Client socket (1) | Closed. | 2024-03-18 17:46:41.837
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:46:43.896
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:43.897
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:43.897
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:46:43.897
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:44.018
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:44.018
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:44.018
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:44.351
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:44.351
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:44.570
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:44.570
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:44.570
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:44.570
SC DTC Delayed Exchange Data | Failed connections: 10149 | 2024-03-18 17:46:44.570
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:44.570
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:44.571
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:44.571
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:44.571
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:44.571
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:44.727
DTC Client socket (1) | Closed. | 2024-03-18 17:46:44.727
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:46:46.576
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:46.577
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:46.577
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:46:46.577
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:46.701
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:46.701
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:46.701
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:46.844
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:46.844
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:46.985
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:46.985
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:46.985
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:46:46.985
SC DTC Delayed Exchange Data | Failed connections: 10150 | 2024-03-18 17:46:46.985
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:46.985
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:46.986
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:46.986
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:46.986
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:46.986
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:47.102
DTC Client socket (1) | Closed. | 2024-03-18 17:46:47.102
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:46:48.989
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:48.990
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:48.990
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:46:48.990
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:49.117
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:49.117
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:49.117
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:54.607
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:54.607
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Failed connections: 10151 | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:55.880
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:55.880
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:55.880
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:55.880
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:56.778
DTC Client socket (1) | Closed. | 2024-03-18 17:46:56.778
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:46:58.068
DTC Client socket (1) | Creating socket. | 2024-03-18 17:46:58.069
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:46:58.069
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:46:58.069
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:46:58.198
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:46:58.198
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:46:58.198
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:46:58.580
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:46:58.580
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:46:59.131
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:46:59.131
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:46:59.131
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:46:59.131
SC DTC Delayed Exchange Data | Failed connections: 10152 | 2024-03-18 17:46:59.131
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:46:59.131
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:46:59.132
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:46:59.132
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:46:59.132
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:46:59.132
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:46:59.287
DTC Client socket (1) | Closed. | 2024-03-18 17:46:59.287
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:01.126
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:01.129
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:01.130
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:47:01.130
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:01.255
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:01.255
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:01.255
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:01.412
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:01.412
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Failed connections: 10153 | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:01.557
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:01.557
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:01.557
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:01.557
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:01.679
DTC Client socket (1) | Closed. | 2024-03-18 17:47:01.679
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:03.610
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:03.611
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:03.611
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:47:03.611
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:03.736
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:03.736
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:03.736
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:03.870
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:03.870
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Failed connections: 10154 | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:04.013
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:04.013
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:04.013
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:04.013
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:04.135
DTC Client socket (1) | Closed. | 2024-03-18 17:47:04.135
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:06.211
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:06.217
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:06.217
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:47:06.217
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:06.338
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:06.338
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:06.338
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:06.493
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:06.493
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:06.661
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:06.661
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:06.661
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:06.661
SC DTC Delayed Exchange Data | Failed connections: 10155 | 2024-03-18 17:47:06.661
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:06.661
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:06.661
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:06.662
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:06.662
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:06.662
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:06.783
DTC Client socket (1) | Closed. | 2024-03-18 17:47:06.783
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:47:08.679
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:08.679
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:08.680
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:47:08.680
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:08.812
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:08.812
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:08.812
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:08.948
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:08.948
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Failed connections: 10156 | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:09.091
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:09.091
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:09.091
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:09.091
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:09.211
DTC Client socket (1) | Closed. | 2024-03-18 17:47:09.211
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:47:11.732
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:11.739
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:11.739
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:47:11.739
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:11.929
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:11.929
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:11.929
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:12.144
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:12.144
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:12.494
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:12.494
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:12.494
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:12.494
SC DTC Delayed Exchange Data | Failed connections: 10157 | 2024-03-18 17:47:12.494
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:12.494
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:12.495
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:12.495
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:12.495
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:12.530
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:12.570
DTC Client socket (1) | Closed. | 2024-03-18 17:47:12.570
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:47:14.485
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:14.486
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:14.486
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:47:14.486
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:14.639
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:14.639
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:14.639
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:14.815
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:14.815
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Failed connections: 10158 | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:14.982
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:14.982
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:14.982
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:14.982
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:15.107
DTC Client socket (1) | Closed. | 2024-03-18 17:47:15.107
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:47:16.998
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:16.998
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:16.998
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:47:16.998
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:17.123
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:17.123
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:17.123
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:17.309
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:17.309
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Failed connections: 10159 | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:17.441
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:17.441
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:17.442
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:17.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:17.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:17.562
DTC Client socket (1) | Closed. | 2024-03-18 17:47:17.562
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:19.442
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:19.443
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:19.443
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:47:19.443
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:19.564
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:19.564
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:19.564
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:19.832
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:19.832
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:20.468
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:20.468
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:20.468
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:20.468
SC DTC Delayed Exchange Data | Failed connections: 10160 | 2024-03-18 17:47:20.468
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:20.468
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:20.469
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:20.469
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:20.469
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:20.469
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:20.633
DTC Client socket (1) | Closed. | 2024-03-18 17:47:20.633
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:47:22.479
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:22.480
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:22.480
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:47:22.480
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:22.608
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:22.608
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:22.608
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:22.782
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:22.782
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Failed connections: 10161 | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:22.951
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:22.951
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:22.951
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:22.951
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:23.074
DTC Client socket (1) | Closed. | 2024-03-18 17:47:23.075
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:47:25.013
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:25.013
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:25.013
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:47:25.014
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:25.142
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:25.142
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:25.142
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:30.357
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:30.357
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:32.649
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:32.649
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:32.649
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:32.649
SC DTC Delayed Exchange Data | Failed connections: 10162 | 2024-03-18 17:47:32.649
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:32.649
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:32.650
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:32.650
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:32.650
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:32.650
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:33.840
DTC Client socket (1) | Closed. | 2024-03-18 17:47:33.840
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:47:34.636
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:34.637
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:34.637
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:47:34.637
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:34.771
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:34.771
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:34.771
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:36.179
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:36.179
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Failed connections: 10163 | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:36.668
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:36.668
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:36.668
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:36.668
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:36.955
DTC Client socket (1) | Closed. | 2024-03-18 17:47:36.955
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:38.685
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:38.686
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:38.686
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:47:38.686
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:38.809
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:38.809
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:38.809
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:38.948
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:38.948
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Failed connections: 10164 | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:39.127
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:39.127
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:39.127
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:39.127
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:39.248
DTC Client socket (1) | Closed. | 2024-03-18 17:47:39.248
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:41.253
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:41.253
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:41.253
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:47:41.253
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:41.380
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:41.380
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:41.380
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:41.539
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:41.539
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Failed connections: 10165 | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:41.708
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:41.708
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:41.708
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:41.708
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:41.833
DTC Client socket (1) | Closed. | 2024-03-18 17:47:41.833
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:43.712
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:43.713
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:43.713
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:47:43.713
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:43.836
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:43.836
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:43.836
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:43.965
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:43.965
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:44.129
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:44.129
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:44.129
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:44.129
SC DTC Delayed Exchange Data | Failed connections: 10166 | 2024-03-18 17:47:44.129
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:44.129
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:44.130
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:44.130
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:44.130
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:44.130
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:44.250
DTC Client socket (1) | Closed. | 2024-03-18 17:47:44.250
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:47:46.321
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:46.325
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:46.325
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:47:46.325
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:46.451
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:46.451
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:46.451
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:46.595
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:46.595
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Failed connections: 10167 | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:46.740
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:46.740
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:46.740
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:46.740
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:46.860
DTC Client socket (1) | Closed. | 2024-03-18 17:47:46.860
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:47:48.978
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:48.979
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:48.979
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:47:48.979
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:49.150
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:49.150
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:49.150
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:49.334
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:49.334
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:49.517
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:49.517
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:49.517
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:49.517
SC DTC Delayed Exchange Data | Failed connections: 10168 | 2024-03-18 17:47:49.517
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:49.517
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:49.518
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:49.518
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:49.518
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:49.518
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:49.689
DTC Client socket (1) | Closed. | 2024-03-18 17:47:49.689
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:47:51.531
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:51.532
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:51.532
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:47:51.532
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:51.656
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:51.656
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:51.656
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:51.814
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:51.814
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:51.953
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:51.953
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:51.953
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:47:51.953
SC DTC Delayed Exchange Data | Failed connections: 10169 | 2024-03-18 17:47:51.953
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:51.953
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:51.954
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:51.954
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:51.954
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:51.954
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:52.076
DTC Client socket (1) | Closed. | 2024-03-18 17:47:52.077
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:47:53.968
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:53.969
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:53.969
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:47:53.969
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:54.095
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:54.095
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:54.095
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:54.218
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:54.218
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:47:54.356
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:47:54.356
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:47:54.356
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:47:54.356
SC DTC Delayed Exchange Data | Failed connections: 10170 | 2024-03-18 17:47:54.356
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:47:54.356
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:47:54.357
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:47:54.357
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:47:54.357
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:47:54.357
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:47:54.476
DTC Client socket (1) | Closed. | 2024-03-18 17:47:54.476
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:47:56.537
DTC Client socket (1) | Creating socket. | 2024-03-18 17:47:56.544
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:47:56.544
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:47:56.544
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:47:56.674
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:47:56.674
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:47:56.675
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:47:57.573
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:47:57.573
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:02.144
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:02.144
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:02.144
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:02.144
SC DTC Delayed Exchange Data | Failed connections: 10171 | 2024-03-18 17:48:02.144
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:02.144
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:02.145
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:02.145
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:02.145
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:02.145
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:02.767
DTC Client socket (1) | Closed. | 2024-03-18 17:48:02.767
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:48:04.156
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:04.157
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:04.157
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:48:04.157
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:04.279
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:04.279
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:04.279
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:04.444
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:04.444
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Failed connections: 10172 | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:04.576
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:04.576
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:04.576
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:04.576
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:04.695
DTC Client socket (1) | Closed. | 2024-03-18 17:48:04.695
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:48:06.603
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:06.604
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:06.604
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:48:06.604
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:06.722
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:06.722
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:06.722
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:08.306
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:08.306
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Failed connections: 10173 | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:09.178
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:09.178
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:09.178
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:09.178
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:09.628
DTC Client socket (1) | Closed. | 2024-03-18 17:48:09.629
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:48:11.176
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:11.177
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:11.177
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:48:11.177
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:11.300
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:11.300
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:11.300
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:11.679
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:11.679
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Failed connections: 10174 | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:12.556
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:12.556
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:12.556
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:12.557
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:12.708
DTC Client socket (1) | Closed. | 2024-03-18 17:48:12.708
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:14.553
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:14.554
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:14.554
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:48:14.554
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:14.674
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:14.674
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:14.674
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:14.815
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:14.815
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:15.030
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:15.030
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:15.030
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:15.030
SC DTC Delayed Exchange Data | Failed connections: 10175 | 2024-03-18 17:48:15.030
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:15.031
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:15.031
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:15.031
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:15.031
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:15.031
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:15.114
DTC Client socket (1) | Closed. | 2024-03-18 17:48:15.114
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:17.162
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:17.162
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:17.162
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:48:17.162
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:17.286
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:17.286
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:17.286
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:17.454
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:17.454
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Failed connections: 10176 | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:17.619
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:17.619
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:17.619
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:17.619
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:17.740
DTC Client socket (1) | Closed. | 2024-03-18 17:48:17.740
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:19.692
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:19.693
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:19.693
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:48:19.693
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:19.818
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:19.818
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:19.818
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:19.962
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:19.962
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:20.115
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:20.115
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:20.115
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:20.115
SC DTC Delayed Exchange Data | Failed connections: 10177 | 2024-03-18 17:48:20.115
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:20.115
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:20.116
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:20.116
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:20.116
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:20.116
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:20.238
DTC Client socket (1) | Closed. | 2024-03-18 17:48:20.238
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:48:22.210
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:22.210
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:22.210
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:48:22.210
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:22.339
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:22.339
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:22.339
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:22.475
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:22.475
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Failed connections: 10178 | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:22.627
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:22.627
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:22.627
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:22.627
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:22.748
DTC Client socket (1) | Closed. | 2024-03-18 17:48:22.748
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:48:24.739
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:24.739
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:24.739
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:48:24.739
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:24.917
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:24.917
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:24.917
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:25.124
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:25.124
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:25.306
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:25.306
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:25.306
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:25.306
SC DTC Delayed Exchange Data | Failed connections: 10179 | 2024-03-18 17:48:25.306
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:25.306
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:25.307
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:25.307
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:25.307
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:25.307
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:25.480
DTC Client socket (1) | Closed. | 2024-03-18 17:48:25.480
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:48:27.293
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:27.293
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:27.293
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:48:27.293
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:27.413
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:27.413
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:27.414
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:27.560
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:27.560
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:27.705
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:27.705
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:27.705
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:27.705
SC DTC Delayed Exchange Data | Failed connections: 10180 | 2024-03-18 17:48:27.705
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:27.705
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:27.706
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:27.706
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:27.706
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:27.706
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:27.824
DTC Client socket (1) | Closed. | 2024-03-18 17:48:27.824
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:48:29.841
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:29.841
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:29.841
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:48:29.842
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:29.965
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:29.965
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:29.965
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:30.122
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:30.122
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:30.260
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:30.260
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:30.260
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:30.260
SC DTC Delayed Exchange Data | Failed connections: 10181 | 2024-03-18 17:48:30.260
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:30.260
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:30.261
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:30.261
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:30.261
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:30.261
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:30.382
DTC Client socket (1) | Closed. | 2024-03-18 17:48:30.382
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:32.437
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:32.437
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:32.437
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:48:32.437
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:32.563
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:32.563
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:32.563
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:33.815
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:33.815
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:35.892
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:35.892
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:35.892
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:35.892
SC DTC Delayed Exchange Data | Failed connections: 10182 | 2024-03-18 17:48:35.892
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:35.892
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:35.893
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:35.893
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:35.893
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:35.893
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:36.228
DTC Client socket (1) | Closed. | 2024-03-18 17:48:36.228
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:48:37.945
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:37.945
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:37.945
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:48:37.945
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:38.071
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:38.071
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:38.071
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:38.203
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:38.203
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Failed connections: 10183 | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:38.362
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:38.362
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:38.362
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:38.362
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:38.482
DTC Client socket (1) | Closed. | 2024-03-18 17:48:38.482
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:48:40.544
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:40.544
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:40.544
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:48:40.544
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:40.664
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:40.664
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:40.664
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:46.283
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:46.283
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Failed connections: 10184 | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:46.686
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:46.686
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:46.686
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:46.686
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:47.353
DTC Client socket (1) | Closed. | 2024-03-18 17:48:47.353
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:48:48.698
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:48.698
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:48.698
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:48:48.698
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:48.826
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:48.826
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:48.826
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:49.067
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:49.067
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:49.374
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:49.374
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:49.374
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:49.374
SC DTC Delayed Exchange Data | Failed connections: 10185 | 2024-03-18 17:48:49.374
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:49.374
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:49.375
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:49.375
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:49.375
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:49.375
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:49.559
DTC Client socket (1) | Closed. | 2024-03-18 17:48:49.559
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:51.381
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:51.382
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:51.382
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:48:51.382
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:51.511
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:51.511
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:51.512
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:51.660
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:51.660
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:51.795
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:51.795
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:51.795
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:51.795
SC DTC Delayed Exchange Data | Failed connections: 10186 | 2024-03-18 17:48:51.795
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:51.795
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:51.796
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:51.796
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:51.796
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:51.796
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:51.914
DTC Client socket (1) | Closed. | 2024-03-18 17:48:51.915
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:53.801
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:53.802
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:53.802
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:48:53.802
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:53.929
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:53.929
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:53.929
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:54.084
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:54.084
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Failed connections: 10187 | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:54.215
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:54.215
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:54.215
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:54.215
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:54.342
DTC Client socket (1) | Closed. | 2024-03-18 17:48:54.342
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:48:56.263
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:56.263
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:56.263
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:48:56.263
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:56.386
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:56.386
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:56.387
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:56.514
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:56.514
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:56.682
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:56.682
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:56.682
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:56.682
SC DTC Delayed Exchange Data | Failed connections: 10188 | 2024-03-18 17:48:56.682
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:56.682
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:56.683
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:56.683
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:56.683
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:56.683
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:56.802
DTC Client socket (1) | Closed. | 2024-03-18 17:48:56.802
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-18 17:48:58.831
DTC Client socket (1) | Creating socket. | 2024-03-18 17:48:58.835
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:48:58.835
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-18 17:48:58.835
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:48:58.959
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:48:58.959
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:48:58.959
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:48:59.243
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:48:59.243
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:48:59.501
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:48:59.501
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:48:59.501
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:48:59.501
SC DTC Delayed Exchange Data | Failed connections: 10189 | 2024-03-18 17:48:59.501
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:48:59.501
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:48:59.502
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:48:59.502
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:48:59.502
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:48:59.502
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:48:59.742
DTC Client socket (1) | Closed. | 2024-03-18 17:48:59.742
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-18 17:49:01.509
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:01.511
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:01.511
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-18 17:49:01.511
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:01.756
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:01.756
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:01.756
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:01.997
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:01.997
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:02.280
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:02.280
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:02.280
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:49:02.280
SC DTC Delayed Exchange Data | Failed connections: 10190 | 2024-03-18 17:49:02.280
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:02.280
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:02.282
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:02.283
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:02.283
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:02.283
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:02.454
DTC Client socket (1) | Closed. | 2024-03-18 17:49:02.454
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-18 17:49:04.405
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:04.406
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:04.406
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-18 17:49:04.406
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:04.526
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:04.526
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:04.526
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:04.680
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:04.680
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:04.824
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:04.824
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:04.824
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:49:04.824
SC DTC Delayed Exchange Data | Failed connections: 10191 | 2024-03-18 17:49:04.824
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:04.824
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:04.825
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:04.825
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:04.825
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:04.825
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:04.944
DTC Client socket (1) | Closed. | 2024-03-18 17:49:04.944
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:49:06.918
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:06.919
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:06.919
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:49:06.919
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:07.049
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:07.049
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:07.049
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:07.184
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:07.184
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:07.354
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:07.354
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:07.354
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:49:07.354
SC DTC Delayed Exchange Data | Failed connections: 10192 | 2024-03-18 17:49:07.354
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:07.354
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:07.355
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:07.355
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:07.355
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:07.355
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:07.475
DTC Client socket (1) | Closed. | 2024-03-18 17:49:07.475
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-18 17:49:09.378
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:09.379
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:09.379
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-18 17:49:09.379
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:09.501
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:09.501
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:09.501
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:09.941
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:09.941
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Failed connections: 10193 | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:10.220
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:10.220
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:10.220
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:10.220
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:10.517
DTC Client socket (1) | Closed. | 2024-03-18 17:49:10.517
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-18 17:49:12.217
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:12.217
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:12.217
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-18 17:49:12.217
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:12.349
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:12.349
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:12.349
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:12.474
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:12.474
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:12.617
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:12.617
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:12.617
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:49:12.617
SC DTC Delayed Exchange Data | Failed connections: 10194 | 2024-03-18 17:49:12.617
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:12.617
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:12.618
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:12.618
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:12.618
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:12.618
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:12.741
DTC Client socket (1) | Closed. | 2024-03-18 17:49:12.741
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-18 17:49:14.624
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:14.625
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:14.625
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-18 17:49:14.625
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:14.782
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:14.782
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:14.782
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:16.354
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:16.354
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:16.730
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:16.730
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:16.730
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:49:16.730
SC DTC Delayed Exchange Data | Failed connections: 10195 | 2024-03-18 17:49:16.730
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:16.730
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:16.731
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:16.732
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:16.732
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:16.732
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:17.547
DTC Client socket (1) | Closed. | 2024-03-18 17:49:17.548
SC DTC Delayed Exchange Data | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-18 17:49:18.741
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:18.741
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:18.741
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-18 17:49:18.741
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:18.875
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:18.875
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:18.875
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:19.704
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:19.704
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Failed connections: 10196 | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:19.846
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:19.846
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:19.846
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:19.846
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:20.197
DTC Client socket (1) | Closed. | 2024-03-18 17:49:20.197
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-18 17:49:22.022
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:22.023
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:22.023
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-18 17:49:22.023
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:22.149
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:22.149
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:22.149
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:22.287
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:22.287
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Failed connections: 10197 | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:22.428
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:22.428
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:22.428
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:22.428
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:22.551
DTC Client socket (1) | Closed. | 2024-03-18 17:49:22.551
SC DTC Delayed Exchange Data | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-18 17:49:24.510
DTC Client socket (1) | Creating socket. | 2024-03-18 17:49:24.514
DTC Client socket (1) | New receive buffer size: 5242880 | 2024-03-18 17:49:24.514
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-18 17:49:24.514
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-03-18 17:49:24.646
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-03-18 17:49:24.646
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-18 17:49:24.646
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-03-18 17:49:24.804
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-03-18 17:49:24.804
SC DTC Delayed Exchange Data | Received logon response. | 2024-03-18 17:49:24.951
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-03-18 17:49:24.951
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-03-18 17:49:24.951
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-03-18 17:49:24.951
SC DTC Delayed Exchange Data | Failed connections: 10198 | 2024-03-18 17:49:24.951
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-03-18 17:49:24.951
DTC Client socket (1) | CloseSocket call. | 2024-03-18 17:49:24.952
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-03-18 17:49:24.952
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-18 17:49:24.952
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-18 17:49:24.952
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-18 17:49:25.073
DTC Client socket (1) | Closed. | 2024-03-18 17:49:25.073
[2024-03-18 20:43:55]
You need to update to the latest release. Follow these instructions:
