Date/Time: Mon, 25 Nov 2024 07:44:22 +0000
FAILURE TO CONNECT
View Count: 216
[2024-03-17 18:09:29] |
User138418 - Posts: 16 |
Continuation of yesterday. Cannot open SierraChart. Waiting impatiently. Log again attached. Computer ~ 2 weeks old, not a smooth conversion. No anti-virus app, Firewall turned off. Obviously Error 10061. 2024-03-17 10:47:10.755 | Trade activity files set size: 0 2024-03-17 10:47:10.779 | Requested symbol settings for service code . Request ID: 1. 2024-03-17 10:47:10.809 | Reading Internal Order ID file. 2024-03-17 10:47:10.827 | Reading Trade Orders file. 2024-03-17 10:47:10.830 | Reading Trade Positions file. 2024-03-17 10:47:10.833 | Reading Trade Account Data files. 2024-03-17 10:47:10.836 | UDPListener (1668). Port 22903 | Listening on UDP port 22903. 2024-03-17 10:47:10.836 | Software version: 2616 64-bit 2024-03-17 10:47:10.836 | Primary Thread ID: 12652 2024-03-17 10:47:10.836 | Usage end date: 2024-04-16 2024-03-17 10:47:10.836 | Enabled for: Sierra Chart Historical Data Service. 2024-03-17 10:47:10.836 | Enabled for: Delayed Denali Exchange Data Feed. 2024-03-17 10:47:10.836 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-03-17 10:47:10.836 | Current selected Data/Trading service: DTC - Sub Instance 2024-03-17 10:47:10.836 | Custom symbol settings values: disabled 2024-03-17 10:47:10.836 | Chart Update Interval: 500 2024-03-17 10:47:10.836 | Intraday Data Storage Time Unit: 0 2024-03-17 10:47:10.836 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-03-17 10:47:10.836 | 2024-03-17 17:47:10 Local computer time in UTC 2024-03-17 10:47:10.836 | 2024-03-17 10:47:10 Local computer time in SC Time Zone 2024-03-17 10:47:10.836 | 2024-03-17 17:47:12 Server time in UTC 2024-03-17 10:47:10.836 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-03-17 10:47:10.836 | Program path: C:\SierraChart\SierraChartInstance_2\ 2024-03-17 10:47:10.836 | Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ 2024-03-17 10:47:10.836 | OS Version Number: 10.0 2024-03-17 10:47:10.836 | Locale Setting: C 2024-03-17 10:47:10.837 | DLLs: #170531_FirstCut.dll, AMA.dll, AMA_SD.dll, Base_Ranger.dll, IP_AMA_SD.dll, IP_DaterTimer.dll, IP_dir_3.dll, IP_DT_1.dll, IP_July23_dbugger.dll, IP_Loops.dll, IP_OrderFlow_1.dll, IP_Persistent.dll, IP_Shell.dll, IP_SlopeDraw.dll, IP_TestBabyStep_4.dll, IP_TestBabyStep_5.dll, IP_TestBabyStep_6.dll, IP_TestBabyStep_7.dll, IP_Test_BabyStep_1.dll, IP_Test_BabyStep_2.dll, IP_Test_BabyStep_3.dll, IP_TradeBones_1.dll, IP_TradeBones_2.dll, IP_TradeBones_3.dll, IP_TradeBones_4.dll, IP_TradeBones_5.dll, IP_TradeBones_6.dll 2024-03-17 10:47:10.837 | Allowed protected custom studies: 2024-03-17 10:47:10.837 | Crash reporter started: true 2024-03-17 10:47:10.837 | 2024-03-17 10:47:10.876 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-03-17 10:47:10.900 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-03-17 10:47:10.900 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-03-17 10:47:10.962 | Received 5 login tokens. 2024-03-17 10:47:11.023 | Symbol settings received. Request ID: 1. 2024-03-17 10:47:11.023 | The response for symbol settings was empty, so the symbol settings file was not created or modified. * 2024-03-17 10:47:13.345 | Requested user files to download. 2024-03-17 10:47:15.360 | 2024-03-17 10:47:15.362 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:15.362 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:15.363 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:15.363 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:17.381 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:17.381 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:17.382 | DTC - Sub Instance | Failed connections: 1 2024-03-17 10:47:17.382 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:17.382 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:17.382 | DTC Client socket (1) | Closed. 2024-03-17 10:47:17.396 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:17.396 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:17.396 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:19.403 | 2024-03-17 10:47:19.403 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:19.403 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:19.403 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:19.403 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:21.452 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:21.452 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:21.452 | DTC - Sub Instance | Failed connections: 2 2024-03-17 10:47:21.452 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:21.452 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:21.452 | DTC Client socket (1) | Closed. 2024-03-17 10:47:21.468 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:21.468 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:21.468 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:23.468 | 2024-03-17 10:47:23.468 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:23.468 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:23.469 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:23.469 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:25.486 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:25.486 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:25.486 | DTC - Sub Instance | Failed connections: 3 2024-03-17 10:47:25.486 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:25.486 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:25.486 | DTC Client socket (1) | Closed. 2024-03-17 10:47:25.502 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:25.502 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:25.502 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:27.503 | 2024-03-17 10:47:27.503 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:27.504 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:27.504 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:27.504 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:29.521 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:29.522 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:29.522 | DTC - Sub Instance | Failed connections: 4 2024-03-17 10:47:29.522 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:29.522 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:29.522 | DTC Client socket (1) | Closed. 2024-03-17 10:47:29.537 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:29.537 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:29.537 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:31.539 | 2024-03-17 10:47:31.539 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:31.539 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:31.540 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:31.540 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:33.572 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:33.572 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:33.572 | DTC - Sub Instance | Failed connections: 5 2024-03-17 10:47:33.572 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:33.572 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:33.572 | DTC Client socket (1) | Closed. 2024-03-17 10:47:33.587 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:33.587 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:33.587 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:35.575 | 2024-03-17 10:47:35.575 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:35.575 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:35.575 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:35.576 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:37.623 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:37.623 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:37.623 | DTC - Sub Instance | Failed connections: 6 2024-03-17 10:47:37.623 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:37.623 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:37.623 | DTC Client socket (1) | Closed. 2024-03-17 10:47:37.639 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:37.639 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:37.639 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:39.641 | 2024-03-17 10:47:39.641 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:39.641 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:39.641 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:39.641 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:41.659 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:41.659 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:41.659 | DTC - Sub Instance | Failed connections: 7 2024-03-17 10:47:41.659 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:41.659 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:41.659 | DTC Client socket (1) | Closed. 2024-03-17 10:47:41.674 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:41.674 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:41.674 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:43.692 | 2024-03-17 10:47:43.693 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:43.693 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:43.693 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:43.693 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:45.741 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:45.742 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:45.742 | DTC Client socket (1) | Closed. 2024-03-17 10:47:45.743 | DTC - Sub Instance | Failed connections: 8 2024-03-17 10:47:45.743 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:45.743 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:45.757 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:45.757 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:45.757 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:47.775 | 2024-03-17 10:47:47.775 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:47.775 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:47.775 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:47.775 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:49.793 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:49.793 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:49.793 | DTC - Sub Instance | Failed connections: 9 2024-03-17 10:47:49.793 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:49.793 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:49.793 | DTC Client socket (1) | Closed. 2024-03-17 10:47:49.809 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:49.809 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:49.809 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:51.810 | 2024-03-17 10:47:51.811 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:51.811 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:51.811 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:51.811 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:53.839 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:53.839 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:53.839 | DTC - Sub Instance | Failed connections: 10 2024-03-17 10:47:53.839 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:53.839 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:53.839 | DTC Client socket (1) | Closed. 2024-03-17 10:47:53.854 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:53.854 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:53.854 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:55.869 | 2024-03-17 10:47:55.870 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:55.870 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:55.870 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:55.870 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:47:57.888 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:47:57.888 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:47:57.888 | DTC - Sub Instance | Failed connections: 11 2024-03-17 10:47:57.888 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:47:57.888 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:57.888 | DTC Client socket (1) | Closed. 2024-03-17 10:47:57.904 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:47:57.904 | DTC - Sub Instance | Disconnected. 2024-03-17 10:47:57.904 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:47:59.905 | 2024-03-17 10:47:59.905 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:47:59.905 | DTC Client socket (1) | Creating socket. 2024-03-17 10:47:59.905 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:47:59.905 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:01.937 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:01.937 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:01.937 | DTC - Sub Instance | Failed connections: 12 2024-03-17 10:48:01.937 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:01.937 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:01.937 | DTC Client socket (1) | Closed. 2024-03-17 10:48:01.953 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:01.953 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:01.953 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:03.953 | 2024-03-17 10:48:03.954 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:03.954 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:03.954 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:03.954 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:05.985 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:05.985 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:05.985 | DTC - Sub Instance | Failed connections: 13 2024-03-17 10:48:05.985 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:05.985 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:05.985 | DTC Client socket (1) | Closed. 2024-03-17 10:48:06.001 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:06.001 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:06.001 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:08.002 | 2024-03-17 10:48:08.002 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:08.003 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:08.003 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:08.003 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:10.019 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:10.019 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:10.019 | DTC - Sub Instance | Failed connections: 14 2024-03-17 10:48:10.019 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:10.019 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:10.019 | DTC Client socket (1) | Closed. 2024-03-17 10:48:10.034 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:10.034 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:10.034 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:12.036 | 2024-03-17 10:48:12.037 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:12.037 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:12.037 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:12.037 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:14.071 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:14.072 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:14.072 | DTC - Sub Instance | Failed connections: 15 2024-03-17 10:48:14.072 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:14.072 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:14.072 | DTC Client socket (1) | Closed. 2024-03-17 10:48:14.087 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:14.087 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:14.087 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:16.076 | 2024-03-17 10:48:16.076 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:16.077 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:16.077 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:16.077 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:18.102 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:18.103 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:18.103 | DTC - Sub Instance | Failed connections: 16 2024-03-17 10:48:18.103 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:18.103 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:18.103 | DTC Client socket (1) | Closed. 2024-03-17 10:48:18.118 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:18.118 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:18.118 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:20.115 | 2024-03-17 10:48:20.115 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:20.115 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:20.115 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:20.115 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:22.133 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:22.133 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:22.133 | DTC - Sub Instance | Failed connections: 17 2024-03-17 10:48:22.133 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:22.133 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:22.133 | DTC Client socket (1) | Closed. 2024-03-17 10:48:22.148 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:22.148 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:22.148 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:24.150 | 2024-03-17 10:48:24.150 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:24.150 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:24.150 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:24.150 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:26.169 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:26.169 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:26.169 | DTC - Sub Instance | Failed connections: 18 2024-03-17 10:48:26.169 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:26.169 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:26.169 | DTC Client socket (1) | Closed. 2024-03-17 10:48:26.185 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:26.185 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:26.185 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:28.202 | 2024-03-17 10:48:28.202 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:28.202 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:28.202 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:28.202 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:30.248 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:30.248 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:30.248 | DTC - Sub Instance | Failed connections: 19 2024-03-17 10:48:30.248 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:30.248 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:30.248 | DTC Client socket (1) | Closed. 2024-03-17 10:48:30.264 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:30.264 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:30.264 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:32.283 | 2024-03-17 10:48:32.283 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:32.284 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:32.284 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:32.284 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:34.315 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:34.316 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:34.316 | DTC - Sub Instance | Failed connections: 20 2024-03-17 10:48:34.316 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:34.316 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:34.316 | DTC Client socket (1) | Closed. 2024-03-17 10:48:34.331 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:34.331 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:34.331 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:36.332 | 2024-03-17 10:48:36.332 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:36.332 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:36.333 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:36.333 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:38.351 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:38.351 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:38.351 | DTC - Sub Instance | Failed connections: 21 2024-03-17 10:48:38.351 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:38.351 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:38.351 | DTC Client socket (1) | Closed. 2024-03-17 10:48:38.367 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:38.367 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:38.367 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:40.369 | 2024-03-17 10:48:40.369 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:40.369 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:40.369 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:40.369 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:42.401 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:42.402 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:42.402 | DTC - Sub Instance | Failed connections: 22 2024-03-17 10:48:42.402 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:42.402 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:42.402 | DTC Client socket (1) | Closed. 2024-03-17 10:48:42.417 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:42.417 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:42.417 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:44.415 | 2024-03-17 10:48:44.415 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:44.415 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:44.416 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:44.416 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:46.449 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:46.449 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:46.449 | DTC - Sub Instance | Failed connections: 23 2024-03-17 10:48:46.449 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:46.449 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:46.449 | DTC Client socket (1) | Closed. 2024-03-17 10:48:46.465 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:46.465 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:46.465 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:48.485 | 2024-03-17 10:48:48.485 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:48.485 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:48.485 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:48.485 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:50.490 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:50.491 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:50.491 | DTC - Sub Instance | Failed connections: 24 2024-03-17 10:48:50.491 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:50.491 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:50.491 | DTC Client socket (1) | Closed. 2024-03-17 10:48:50.506 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:50.506 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:50.506 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:52.523 | 2024-03-17 10:48:52.523 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:52.523 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:52.523 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:52.523 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:54.570 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:54.571 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:54.571 | DTC - Sub Instance | Failed connections: 25 2024-03-17 10:48:54.571 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:54.571 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:54.571 | DTC Client socket (1) | Closed. 2024-03-17 10:48:54.586 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:54.586 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:54.586 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:56.577 | 2024-03-17 10:48:56.577 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:48:56.577 | DTC Client socket (1) | Creating socket. 2024-03-17 10:48:56.577 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:48:56.577 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:48:58.600 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:48:58.600 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:48:58.600 | DTC - Sub Instance | Failed connections: 26 2024-03-17 10:48:58.600 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:48:58.600 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:48:58.600 | DTC Client socket (1) | Closed. 2024-03-17 10:48:58.619 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:48:58.619 | DTC - Sub Instance | Disconnected. 2024-03-17 10:48:58.619 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:00.606 | 2024-03-17 10:49:00.606 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:00.606 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:00.606 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:00.606 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:02.631 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:02.631 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:02.631 | DTC - Sub Instance | Failed connections: 27 2024-03-17 10:49:02.631 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:02.631 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:02.631 | DTC Client socket (1) | Closed. 2024-03-17 10:49:02.646 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:02.646 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:02.646 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:04.636 | 2024-03-17 10:49:04.636 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:04.636 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:04.636 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:04.637 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:06.653 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:06.654 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:06.654 | DTC - Sub Instance | Failed connections: 28 2024-03-17 10:49:06.654 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:06.654 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:06.654 | DTC Client socket (1) | Closed. 2024-03-17 10:49:06.669 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:06.669 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:06.669 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:08.685 | 2024-03-17 10:49:08.685 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:08.685 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:08.685 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:08.685 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:10.694 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:10.694 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:10.694 | DTC - Sub Instance | Failed connections: 29 2024-03-17 10:49:10.694 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:10.694 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:10.694 | DTC Client socket (1) | Closed. 2024-03-17 10:49:10.710 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:10.710 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:10.710 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:12.711 | 2024-03-17 10:49:12.712 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:12.712 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:12.712 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:12.712 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:14.745 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:14.746 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:14.746 | DTC Client socket (1) | Closed. 2024-03-17 10:49:14.747 | DTC - Sub Instance | Failed connections: 30 2024-03-17 10:49:14.747 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:14.747 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:14.761 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:14.761 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:14.762 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:16.782 | 2024-03-17 10:49:16.782 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:16.782 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:16.783 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:16.783 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:18.807 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:18.807 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:18.807 | DTC - Sub Instance | Failed connections: 31 2024-03-17 10:49:18.807 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:18.807 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:18.807 | DTC Client socket (1) | Closed. 2024-03-17 10:49:18.823 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:18.823 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:18.824 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:20.811 | 2024-03-17 10:49:20.812 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:20.812 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:20.812 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:20.812 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:22.844 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:22.844 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:22.844 | DTC - Sub Instance | Failed connections: 32 2024-03-17 10:49:22.844 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:22.844 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:22.844 | DTC Client socket (1) | Closed. 2024-03-17 10:49:22.861 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:22.861 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:22.861 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:24.869 | 2024-03-17 10:49:24.870 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:24.870 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:24.870 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:24.870 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:26.889 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:26.889 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:26.889 | DTC - Sub Instance | Failed connections: 33 2024-03-17 10:49:26.889 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:26.889 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:26.889 | DTC Client socket (1) | Closed. 2024-03-17 10:49:26.905 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:26.905 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:26.905 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:28.906 | 2024-03-17 10:49:28.906 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:28.906 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:28.906 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:28.906 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:30.937 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:30.938 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:30.938 | DTC - Sub Instance | Failed connections: 34 2024-03-17 10:49:30.938 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:30.938 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:30.938 | DTC Client socket (1) | Closed. 2024-03-17 10:49:30.953 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:30.953 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:30.953 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:32.971 | 2024-03-17 10:49:32.971 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:32.971 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:32.972 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:32.972 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:34.991 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:34.991 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:34.992 | DTC - Sub Instance | Failed connections: 35 2024-03-17 10:49:34.992 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:34.992 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:34.992 | DTC Client socket (1) | Closed. 2024-03-17 10:49:35.007 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:35.007 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:35.007 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:37.026 | 2024-03-17 10:49:37.026 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:37.026 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:37.026 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:37.026 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:39.072 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:39.072 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:39.072 | DTC - Sub Instance | Failed connections: 36 2024-03-17 10:49:39.072 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:39.072 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:39.072 | DTC Client socket (1) | Closed. 2024-03-17 10:49:39.088 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:39.088 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:39.088 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:41.090 | 2024-03-17 10:49:41.090 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:41.091 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:41.091 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:41.091 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:43.123 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:43.123 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:43.123 | DTC - Sub Instance | Failed connections: 37 2024-03-17 10:49:43.123 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:43.123 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:43.123 | DTC Client socket (1) | Closed. 2024-03-17 10:49:43.139 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:43.139 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:43.139 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:45.140 | 2024-03-17 10:49:45.140 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:45.141 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:45.141 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:45.141 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:47.174 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:47.174 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:47.174 | DTC - Sub Instance | Failed connections: 38 2024-03-17 10:49:47.174 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:47.174 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:47.174 | DTC Client socket (1) | Closed. 2024-03-17 10:49:47.190 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:47.190 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:47.190 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:49.213 | 2024-03-17 10:49:49.213 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:49.213 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:49.213 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:49.213 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:51.215 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:51.216 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:51.216 | DTC - Sub Instance | Failed connections: 39 2024-03-17 10:49:51.216 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:51.216 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:51.216 | DTC Client socket (1) | Closed. 2024-03-17 10:49:51.231 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:51.231 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:51.231 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:53.234 | 2024-03-17 10:49:53.234 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:53.234 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:53.235 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:53.235 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-03-17 10:49:55.242 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2024-03-17 10:49:55.243 | DTC Client socket (1) | CloseSocket call. 2024-03-17 10:49:55.243 | DTC - Sub Instance | Failed connections: 40 2024-03-17 10:49:55.243 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-03-17 10:49:55.243 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:55.243 | DTC Client socket (1) | Closed. 2024-03-17 10:49:55.258 | DTC Client socket (0) | CloseSocket call. 2024-03-17 10:49:55.258 | DTC - Sub Instance | Disconnected. 2024-03-17 10:49:55.258 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-03-17 10:49:57.275 | 2024-03-17 10:49:57.275 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-03-17 10:49:57.275 | DTC Client socket (1) | Creating socket. 2024-03-17 10:49:57.275 | DTC Client socket (1) | New receive buffer size: 0 2024-03-17 10:49:57.275 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. Date Time Of Last Edit: 2024-03-18 15:34:27
[2024-03-17 21:08:39] |
Sierra_Chart Engineering - Posts: 17172 |
This log is from a sub instance of Sierra Chart: 2024-03-17 10:47:10.836 | Program path: C:\SierraChart\SierraChartInstance_2\ You need to start the main instance of Sierra Chart in: C:\SierraChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
