Date/Time: Mon, 25 Nov 2024 06:20:15 +0000
Vertical Lines different color to the text of Date and Time
View Count: 255
[2024-03-17 13:45:59] |
User186889 - Posts: 53 |
Hello Sierra TOPIC - Vertical Lines different color to the text of Date and Time In one of your updates, you have added a 'Vertical' Text/Date function to vertically drawn lines (Very good). BUT - Are you aware that sometimes the text is the same color as the line, and sometimes it is not. If I set it on the toolbar in the Configure Button, it works. But if I then right click and change color on the line - only the line changes color, not the text. I have to jig about with it until they are both the same Cheers - mark B (UK - 17 mar 24 |
[2024-03-19 02:25:21] |
Sierra_Chart Engineering - Posts: 17170 |
We are checking on this.
[2024-03-19 21:19:01] |
This will be resolved in version 2620.
