Date/Time: Mon, 25 Nov 2024 06:58:54 +0000
ACSIL - Function to get the value of 'Custom Title Bar Name'
View Count: 254
[2024-03-17 08:32:31] |
gtaranti - Posts: 67 |
Is there a function or a sc member that I can use to get the value of Custom Title Bar Name? This value is set by the user in General Settings -> GUI -> Application GUI |
[2024-03-18 14:49:24] |
Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.CustomChartTitleBarName For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-21 11:13:41] |
I'm refering to the value set by the user in General Settings -> GUI -> Application GUI NOT the one in the Chart Settings |
[2024-03-21 16:08:58] |
Sorry - we answer a lot of questions all day and we sometimes do not ready thoroughly. There is not a way to access that information through ACSIL. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-21 16:16:42] |
It's OK, thanks. Can you please consider adding a function to get this information?? When running many copies of SC it's critical to discern some custom log files my study creates and this very information is essential. Otherwise I need to rename the charts every time I make a chartbook copy to get a different info, which is a pain. |
