Date/Time: Mon, 25 Nov 2024 07:56:58 +0000
Volume At Price Threshold Alert V2 Values from the Top?
View Count: 332
[2024-03-17 06:56:36] |
User384855 - Posts: 5 |
I Have been Trying to get value for For Single Bid & Ask from the top of the bar, I can Easily get it from the bottom because the bar starts from bottom. I'm able to get the Values from the Top 1 value if I keep " Highlight Adjacent Alerts Minimum Group Size " = 1 by using SG50, but I'm not able to get the values for Top 2, Top 3 and Top 4 Is there something I'm missing ? Thanks
[2024-03-17 07:13:48] |
And how to add more Price levels because subgraph are ending on SG47 so lets say there is a big bar on the chart I cant get the data after it goes beyond Trigger 46. Is there any Setting for that ? Thanks
[2024-03-18 14:48:34] |
The alerts for the "Volume at Price Threshold Alert V2" start at the bottom of the bar. The only way to find the alert at the top would be to look at the subgraphs and find the first zero value and then go back one. This would really need to be done in the Spreadsheet Study. And when you state "I'm able to get the Values from the Top 1 value if I keep " Highlight Adjacent Alerts Minimum Group Size " = 1 by using SG50" will only work if you adjacent alerts all the way to the top. If there is a break, then the bottom group will be found by SG50, but the next group uses the next set of subgraphs and so on. And how to add more Price levels because subgraph are ending on SG47 so lets say there is a big bar on the chart I cant get the data after it goes beyond Trigger 46. Is there any Setting for that ? Thanks
There are only a total of 60 subgraphs available, therefore what is implemented is the best available option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
