Date/Time: Mon, 25 Nov 2024 09:35:30 +0000
No Chartbooks listed to open
View Count: 262
[2024-03-16 20:44:09] |
User682444 - Posts: 8 |
I have not used Sierra for perhaps 2 years. Signed up again and have denali stock composite. did an update. Set up charts and chartbooks and saved all . Clicked file / new instance closed program and reopened. There are chart books in both the 1st instance data folder and the 2nd instance data folder but there are no chartbooks listed when I "open Chartbook" If I click File ; under "Print" there is a list of the last 14 CHt. files When I click one it does open the chartbook. How do I get the existing charbooks to list in the "open Chartbook" window However if I use Open Cbook there are no files listed and if I type in the name of a chartbook , eg Amd which is a collection of 8 charts I get the single chart for AMD I saved a Chartbook "test" and when I type test into the box I get "Download failed" as it tried to open a daily chart called test The CHT files are in the data folder ; how do I get the files into the "open Chartbook" list? |
CHT files in Data folder but not in list.pdf - Attached On 2024-03-16 20:41:47 UTC - Size: 204.77 KB - 101 views |
[2024-03-16 23:22:05] |
User303857 - Posts: 74 |
I think the charts have to be in a chart book before you open the saved chartbook that opens on startup Try GLOBAL SETTINGS > GENERAL SETTINGS > OPEN FILES ON STARTUP Select the CHARTBOOKS to Open on start up Add go the folder where your chart books are Multiple Selection , Select them Open Button Then arrange them THEN HIT THE OK BUTTON TO SAVE THE CHANGES You will have do this for each instance. Date Time Of Last Edit: 2024-03-16 23:29:20
[2024-03-17 00:26:40] |
Sierra_Chart Engineering - Posts: 17172 |
Refer to: Missing Files After Upgrading Software Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
