Date/Time: Mon, 25 Nov 2024 09:47:51 +0000
Chart Calculator
View Count: 255
[2024-03-16 10:06:53] |
Tin43 - Posts: 90 |
I'm sorry... I tried everything, config tools, Graphic setting, Global graphic settings etc... Don't know why, but Chart Calculator is not showing the data. Nothing, only the line. i draw in the chart I went to Properties etc, even selecting a color that really contrast with the background color, but nothing. Maybe is a silly thing but I can't find what it is. Thanks in advance. Edit: another question related to this. If I rename the Sierra4.config it would reset to default all the custom bars, drawing configurations etc? Because I want this. I want to ERASE all the buttons, and most important the config tools, CDT etc etc etc... I want to wipe that. Date Time Of Last Edit: 2024-03-16 10:34:56
[2024-03-16 14:21:40] |
For the Chart Calculator, please draw the line and then right click on the line and select "Chart Drawing Properties". Make sure that the items you want to view are selected with a "Yes". If these are still not showing, then select "Tools >> Tool Settings >> General" and select the entry for the "Global Chart Drawing Font" and make sure this is set to a reasonable font, particularly the size, but also the font itself (make sure it is not something silly like "webdings"). If none of the above works, then please get us your chartbook with a single chart that has the Chart Calculator drawing on it. Refer to the following for how to get us a Chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart Refer to the following regarding getting back to a "default state": Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Resetting Sierra Chart to a Default State For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-16 17:21:58] |
Tin43 - Posts: 90 |
Don't ask me what happened buy maybe due updates or something the properties menu changed? All was set to NO. Weird if that was the cause, because other "tools" doesn't changed. Problem solved, thanks as always. |
