Date/Time: Mon, 25 Nov 2024 06:47:11 +0000
Is full MBO data available for use via ACSIL?
View Count: 449
[2024-03-16 09:39:42] |
User370531 - Posts: 55 |
I understand that MBO data only provides orders above 3 contracts and shows them in the DOM. However, I'm wondering if having access to the MBO package allows a live stream of all orders realtime for use in ACSIL
[2024-03-18 03:53:01] |
Sierra_Chart Engineering - Posts: 17172 |
No, the minimum quantity is 2 or 3 in all cases. We would have to check what it is.
[2024-03-19 14:00:23] |
Let’s say the minimum is 3. Would I be able to access a real-time list of all orders, including size and price level within ACSIL? Where can I find documentation on how to do this? In a related note, let’s say the minimum is 3, is that for orders with an initial or current size of 3? If an order with initial size of 3 is partially filled and is now 1, does it fall off the list? |
[2024-03-20 21:22:34] |
LudaTrades - Posts: 26 |
sc.GetAskMarketLimitOrdersForPrice() sc.GetBidMarketLimitOrdersForPrice |
[2024-03-20 23:40:00] |
The documentation at post #4 is what you require. Yes this is the true: In a related note, let’s say the minimum is 3, is that for orders with an initial or current size of 3? If an order with initial size of 3 is partially filled and is now 1, does it fall off the list?
