Date/Time: Mon, 25 Nov 2024 09:47:20 +0000
Problem with setting up the Telegram alert
View Count: 197
[2024-03-15 20:29:19] |
sadramistes - Posts: 11 |
Hi, i tried to set up the new alert om telegram but unfortunately i run into a software problem and i couldnt complete the process. More specifically, i got to the point where i could get notifications in the SC chatbox but no alerts where going to the Telegram even though i had complete all the steps. The reason is that the option in the SC chat group settings "Relay to Telegram" was keep switching to OFF no matter how many times i tried to reset it. It must be a bug or something.
[2024-03-16 05:39:00] |
Sierra_Chart Engineering - Posts: 17172 |
Follow through the instructions here: Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts | Post: 375689 You need to update Sierra Chart to 2616. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
