Date/Time: Mon, 25 Nov 2024 09:44:53 +0000
[Programming Help] - GDI Flickering
View Count: 273
[2024-03-15 20:24:51] |
TPH_Main - Posts: 13 |
I have tried the code below with Open GL enabled and not enabled. Basically if I have two charts open 1. apply this study. 2. change x/y inputs of the study on one chart 3. Flickering happens or the indicator is being redrawn in both the old input settings and the new input settings. #pragma once struct LabelSettings { int xPosition; int yPosition; int alignment; int fontSize; COLORREF fontColor; COLORREF bgColor; COLORREF invalidBgColor; }; LabelSettings LabelSettings; // FUNCTION: Draw Info void DrawLabel(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc) { // Set drawing font n_ACSIL::s_GraphicsFont GraphicsFont; GraphicsFont.m_FaceName = sc.ChartTextFont(); GraphicsFont.m_Height = LabelSettings.fontSize; GraphicsFont.m_Weight = FW_BOLD; sc.Graphics.SetTextFont(GraphicsFont); // Set colors n_ACSIL::s_GraphicsColor fontColor; fontColor.SetColorValue(LabelSettings.fontColor); sc.Graphics.SetTextColor(fontColor); n_ACSIL::s_GraphicsColor GraphicsColor; GraphicsColor.SetColorValue(LabelSettings.bgColor); sc.Graphics.SetBackgroundColor(GraphicsColor); // Set position int width = sc.ChartRegion1RightCoordinate - sc.ChartRegion1LeftCoordinate; int height = sc.ChartRegion1BottomCoordinate - sc.ChartRegion1TopCoordinate; int xPosition = width * LabelSettings.xPosition / 100.00; int yPosition = height * LabelSettings.yPosition / 100.00; switch (LabelSettings.alignment) { case 0: sc.Graphics.SetTextAlign(TA_LEFT); break; case 1: sc.Graphics.SetTextAlign(TA_CENTER); break; case 2: sc.Graphics.SetTextAlign(TA_RIGHT); break; default: sc.Graphics.SetTextAlign(TA_CENTER); break; } // Draw sc.Graphics.DrawTextAt("testing 123", xPosition, yPosition); } SCSFExport scsf_Test_GDILabels(SCStudyInterfaceRef sc) { int inputNum = -1; SCInputRef Input_FontxPOS = sc.Input[++inputNum]; SCInputRef Input_FontyPOS = sc.Input[++inputNum]; SCInputRef Input_FontAlignment = sc.Input[++inputNum]; SCInputRef Input_FontSize = sc.Input[++inputNum]; SCInputRef Input_FontColorCSS = sc.Input[++inputNum]; SCInputRef Input_BgColorCSS = sc.Input[++inputNum]; SCInputRef Input_InvalidBgColorCSS = sc.Input[++inputNum]; if (sc.SetDefaults) { sc.GraphName = "Test"; sc.GraphRegion = 0; sc.AutoLoop = 0; // sc.UpdateAlways = 1; sc.HideDLLAndFunctionNames = 1; sc.HideStudy = 0; sc.IncludeInStudySummary = 0; sc.IncludeInSpreadsheet = 0; sc.AlertConditionEnabled = 0; sc.DisplayStudyInputValues = 0; sc.DisplayStudyName = 0; sc.GlobalDisplayStudySubgraphsNameAndValue = 0; sc.ProtectStudy = 1; sc.CalculationPrecedence = STD_PREC_LEVEL; Input_FontxPOS.Name = "Label x Position"; Input_FontxPOS.SetInt(100); Input_FontxPOS.SetIntLimits(1, 100); Input_FontyPOS.Name = "Label y Position"; Input_FontyPOS.SetInt(3); Input_FontyPOS.SetIntLimits(1, 100); Input_FontAlignment.Name = "Label Alignment"; Input_FontAlignment.SetCustomInputStrings("Left;Center;Right"); Input_FontAlignment.SetCustomInputIndex(2); Input_FontSize.Name = "Font Size"; Input_FontSize.SetInt(10); Input_FontSize.SetIntLimits(6, 36); Input_FontColorCSS.Name = "Font Color"; Input_FontColorCSS.SetColor(255, 255, 255); Input_BgColorCSS.Name = "Background Color"; Input_BgColorCSS.SetColor(90, 100, 113); Input_InvalidBgColorCSS.Name = "Invalid Background Color"; Input_InvalidBgColorCSS.SetColor(255, 0, 255); } // Set Colors LabelSettings.xPosition = Input_FontxPOS.GetInt(); LabelSettings.yPosition = Input_FontyPOS.GetInt(); LabelSettings.alignment = Input_FontAlignment.GetIndex(); LabelSettings.fontSize = Input_FontSize.GetInt(); LabelSettings.fontColor = Input_FontColorCSS.GetColor(); LabelSettings.bgColor = Input_BgColorCSS.GetColor(); LabelSettings.invalidBgColor = Input_InvalidBgColorCSS.GetColor(); // Hook drawing function sc.p_GDIFunction = DrawLabel; } |
[2024-03-15 21:08:10] |
Charts do not need to be in the same chartbook either.
[2024-03-15 21:17:01] |
User431178 - Posts: 541 |
Your Labelsettings structure is a global variable shared by all copies of the study. Unless the settings are the same in both studies, it will flicker/move each time the differing settings are changed. You need separate for each copy of the study, or just read the inputs directly in the drawing function. |
[2024-03-15 21:47:48] |
// #pragma once void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc); SCSFExport scsf_Test_GDILabels(SCStudyInterfaceRef sc) { int inputNum = -1; SCInputRef Input_FontxPOS = sc.Input[++inputNum]; SCInputRef Input_FontyPOS = sc.Input[++inputNum]; SCInputRef Input_FontAlignment = sc.Input[++inputNum]; SCInputRef Input_FontSize = sc.Input[++inputNum]; SCInputRef Input_FontColorCSS = sc.Input[++inputNum]; SCInputRef Input_BgColorCSS = sc.Input[++inputNum]; SCInputRef Input_InvalidBgColorCSS = sc.Input[++inputNum]; if (sc.SetDefaults) { sc.GraphName = "Test"; sc.GraphRegion = 0; // sc.AutoLoop = 1; // sc.UpdateAlways = 1; sc.HideDLLAndFunctionNames = 1; sc.HideStudy = 0; sc.IncludeInStudySummary = 0; sc.IncludeInSpreadsheet = 0; sc.AlertConditionEnabled = 0; sc.DisplayStudyInputValues = 0; sc.DisplayStudyName = 0; sc.GlobalDisplayStudySubgraphsNameAndValue = 0; sc.ProtectStudy = 1; sc.CalculationPrecedence = STD_PREC_LEVEL; Input_FontxPOS.Name = "Label x Position"; Input_FontxPOS.SetInt(100); Input_FontxPOS.SetIntLimits(1, 100); Input_FontyPOS.Name = "Label y Position"; Input_FontyPOS.SetInt(3); Input_FontyPOS.SetIntLimits(1, 100); Input_FontAlignment.Name = "Label Alignment"; Input_FontAlignment.SetCustomInputStrings("Left;Center;Right"); Input_FontAlignment.SetCustomInputIndex(2); Input_FontSize.Name = "Font Size"; Input_FontSize.SetInt(10); Input_FontSize.SetIntLimits(6, 36); Input_FontColorCSS.Name = "Font Color"; Input_FontColorCSS.SetColor(255, 255, 255); Input_BgColorCSS.Name = "Background Color"; Input_BgColorCSS.SetColor(90, 100, 113); Input_InvalidBgColorCSS.Name = "Invalid Background Color"; Input_InvalidBgColorCSS.SetColor(255, 0, 255); } // Hook drawing function sc.p_GDIFunction = DrawToChart; } void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc) { // Inputs int inputNum = -1; SCInputRef Input_FontxPOS = sc.Input[++inputNum]; SCInputRef Input_FontyPOS = sc.Input[++inputNum]; SCInputRef Input_FontAlignment = sc.Input[++inputNum]; SCInputRef Input_FontSize = sc.Input[++inputNum]; SCInputRef Input_FontColorCSS = sc.Input[++inputNum]; SCInputRef Input_BgColorCSS = sc.Input[++inputNum]; SCInputRef Input_InvalidBgColorCSS = sc.Input[++inputNum]; // Set drawing font n_ACSIL::s_GraphicsFont GraphicsFont; GraphicsFont.m_FaceName = sc.ChartTextFont(); GraphicsFont.m_Height = Input_FontSize.GetInt(); GraphicsFont.m_Weight = FW_BOLD; sc.Graphics.SetTextFont(GraphicsFont); // Set colors n_ACSIL::s_GraphicsColor fontColor; fontColor.SetColorValue(Input_FontColorCSS.GetColor()); sc.Graphics.SetTextColor(fontColor); n_ACSIL::s_GraphicsColor GraphicsColor; GraphicsColor.SetColorValue(Input_BgColorCSS.GetColor()); sc.Graphics.SetBackgroundColor(GraphicsColor); // Set position int width = sc.ChartRegion1RightCoordinate - sc.ChartRegion1LeftCoordinate; int height = sc.ChartRegion1BottomCoordinate - sc.ChartRegion1TopCoordinate; int xPosition = width * Input_FontxPOS.GetInt() / 100.00; int yPosition = height * Input_FontyPOS.GetInt() / 100.00; switch (Input_FontAlignment.GetIndex()) { case 0: sc.Graphics.SetTextAlign(TA_LEFT); break; case 1: sc.Graphics.SetTextAlign(TA_CENTER); break; case 2: sc.Graphics.SetTextAlign(TA_RIGHT); break; default: sc.Graphics.SetTextAlign(TA_CENTER); break; } // Draw sc.Graphics.DrawTextAt("testing 123", xPosition, yPosition); // Debug // SCString typeString; // typeString.Format("TEST:%d", // Input_FontxPOS.GetInt()); // sc.AddMessageToLog(typeString, 0); } So this is working correctly it just seems strange to define inputs twice...idk maybe Sierra Chart Engineers could explain why to help clarify. Thank you. |
[2024-03-15 22:31:34] |
The scope of the inputs, and all other variable, is limited to the function in which they are declared. The study and drawing are separate functions. Date Time Of Last Edit: 2024-03-16 09:09:17
[2024-03-16 00:12:34] |
For anybody else who stumbles upon this, to not define the inputs twice you can still use the struct just use a persistent int for it. Again don't know if this is the best solution, but it works for me. Inside SCSFExport Function // Create persistent storage s_Data *Data = (s_Data *)sc.GetPersistentPointer(0); if (Data == NULL) { Data = new s_Data(); sc.SetPersistentPointer(0, Data); } // Example Setting data Data->xPOS = Input_FontxPOS.GetInt(); Data->yPOS = Input_FontyPOS.GetInt(); Data->alignment = Input_FontAlignment.GetInt(); Data->fontSize = Input_FontSize.GetInt(); Data->fontColor = Input_FontColorCSS.GetColor(); Data->bgColor = Input_BgColorCSS.GetColor(); Data->invalidBgColor = Input_InvalidBgColorCSS.GetColor(); Drawing Function void DrawTradeCopierLabels(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc) { // Fetch Data from main function s_Data *Data = (s_Data *)sc.GetPersistentPointer(0); if (Data == NULL) return; // Using data int width = sc.ChartRegion1RightCoordinate - sc.ChartRegion1LeftCoordinate; int height = sc.ChartRegion1BottomCoordinate - sc.ChartRegion1TopCoordinate; int xPosition = static_cast<int>(width * CopyTradingData->xPOS / 100.00); int yPosition = static_cast<int>(height * CopyTradingData->yPOS / 100.00); } |
