Date/Time: Mon, 25 Nov 2024 08:38:04 +0000
Up/Down Arrow Scroll Amount
View Count: 175
[2024-03-15 19:23:35] |
User688525 - Posts: 257 |
Hello Sierra, How can the up/down arrow chart scroll amount be changed? I would like to reduce the amount compressed/expanded when using the arrow keys (or mouse on the bottom scale)? Thank you |
[2024-03-15 19:56:11] |
There are no settings that adjust how much the arrow keys or the mouse on the horizontal axis change the bar spacing.
[2024-03-15 20:04:45] |
Thank you for confirming John.
