Date/Time: Mon, 25 Nov 2024 09:39:13 +0000
place a study on top of the chart
View Count: 274
[2024-03-15 17:03:47] |
User948434 - Posts: 7 |
Normally, the top of the start is the stock price, is there a way to place a study, such as Bill Williams's awesome oscillator on the top of the chart? River |
[2024-03-15 17:07:18] |
We are not sure what exactly you mean by "on the top of the chart". If you are referring to having it drawn above the candles, then make sure the option for "Draw Study Underneath Main Price Graph" does not have a checkmark next to it. Refer to the following: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) If you mean you want to display the study in the same region as the Main Price Graph, then you just need to set the Region to 1 and make sure the Scale is set to either "Independent" or "Same as Region". Refer to the following: Chart Studies: Settings and Inputs Tab >> Chart Region Chart Scale and Scale Adjusting: Displaying Multiple Graphs in Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-15 21:47:56] |
For example, in this chart, there are two parts. The upper part is the price and its change, the bottom part is the volume and its change. What I want to see is the volume on the upper part and the price on the bottom. Is there a way I can do it? Thank you. River |
Attachment Deleted. Chart2.pdf - Attached On 2024-03-15 21:44:15 UTC - Size: 180.3 KB - 100 views |
[2024-03-16 13:35:25] |
Set "Chart >> Chart Settings >> Regions >> Chart Region" to "2". This will move the Main Price Graph into the second region. Refer to the following: Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu) Then change the region for the Volume study to be Region 1. Refer to the following: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
