Date/Time: Mon, 25 Nov 2024 09:45:13 +0000
No Values using Chart Values Tool
View Count: 202
[2024-03-15 15:50:01] |
User778120 - Posts: 4 |
Hi, I have installed the currect version of Sierra Chart and now when I'm using Chart Values Tool I see black rectangle instead of value of price and time. I probably need to change the value display color or background somewhere in the settings but I don't know where, please help. I don't understand why in the new version the default value and background are the same color, so I can't see the value. I consider this a defect and propose to change it in the next update. Best regards Mateusz Prost |
Chart Value Tool.PNG / V - Attached On 2024-03-15 15:44:56 UTC - Size: 39.63 KB - 46 views |
[2024-03-15 19:14:16] |
There is a new setting for the color of the text in the Price and Time boxes. It is set to black by default, so you will need to change the color. Refer to the following: Graphics Settings: Chart Values: Price and Time Boxes Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-16 20:15:10] |
It worked, thank you. But still, I don't know who came up with the idea that by default, the background color and font color should be the same... it wasn't like that in earlier versions. The person who came up with that idea should be fired.
[2024-03-16 20:39:10] |
Sierra_Chart Engineering - Posts: 17172 |
The default colors are correct and not as you say. The problem is you have changed one of them from the default. You can tell by installing Sierra Chart into a new folder. The request for the ability to set the text color came from a user, not us: The person who came up with that idea should be fired.
We could find out who. So we added the ability to set the text color of the price and time boxes rather than making them automatic. The default background color and foreground color, do contrast with each other. As we said you can verify this.: You can tell by installing Sierra Chart into a new folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-16 20:39:40
