Date/Time: Mon, 25 Nov 2024 07:54:34 +0000
Eurex Exchange Monthly Cost
View Count: 464
[2024-03-15 15:25:35]
User130696 - Posts: 88
What is the cost of real-time Eurex data such as FESX and FGBL symbols?
I just purchased this data from Trading View for 2$ per month. Why is it 50$ per month when using the Sierra Charts portal for the same?
[2024-03-15 15:32:47]
The cost of the EUREX exchange is $25.00. We can not comment on what you were paying to another vendor. The one thing that could be different is the availability of Market Depth data, which is included with our exchange option.
The reason you are paying $50.00 for the exchange is because you have the option for "2 systems" set, which means that you are paying the exchange fees twice in order to be able to get the data to two different systems at the same time.
[2024-03-17 04:41:05]
1. Can I pay Eurex just for one instead of two connections without impacting other exchanges?
2. Am I currently paying twice for other active exchange(s) as well ?
[2024-03-17 06:16:12]
Sierra_Chart Engineering - Posts: 17172
1. Not at this time. We plan to add this feature but it is not yet available.
2. Yes.
[2024-03-17 16:20:24]
If I use one system for two installations of Sierracharts as explained below, do I have to pay twice for any of the exchanges ?
Using Multiple Data and Trading Services at the Same Time
[2024-03-18 15:22:02]
If the installation is on the same computer, then you can have up to 3 separate installations all accessing the data at the same time without having to pay any additional exchange fees. Refer to the information at the following link:
Denali Exchange Data Feed: Connections
