Date/Time: Mon, 25 Nov 2024 08:18:30 +0000
my sierra charts is totally out of sync after rolling over to june contract
View Count: 250
[2024-03-15 09:24:32] |
tom barlow - Posts: 3 |
Hi im after help. After rolling over to the june contract my composites and drawings are all out of sync and have tried so many steps to fix to no avail. Please help
Private File |
[2024-03-15 14:14:46] |
Refer to the following: Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-15 17:29:59] |
Hi there its not the drawings that have altered its the composites themselves. My previous composite levels on one particular composite was on ES was 5100.00 and now after rolling over the contract it is 5105.50. So its the composites that have altered not the drawings. Any ideas on how to fix this please? |
[2024-03-15 19:37:20] |
We do not know what you mean by "composite". If you are saying that the data is not back-adjusting properly, then update to the latest pre-release (v 2615) by following these instructions: Software Download: Fast Update And then follow the instructions at the following link: Continuous Futures Contract Charts: Basic Steps to Correct Invalid Back Adjust Amount for Most Recent Transition to New Contract Month For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-15 19:50:21] |
Sierra_Chart Engineering - Posts: 17172 |
Follow the instructions here to adjust Chart Drawings: Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
