Date/Time: Mon, 25 Nov 2024 08:42:51 +0000
Teton stop loss to stop limit mitigation
View Count: 248
[2024-03-15 07:33:01]
User488241 - Posts: 35
I've read the documentation for stop losses turning into stop limit orders on the CME when using Teton. I kind of hate the idea of a stop loss turning into a stop limit order and am looking for a way to mitigate this. It doesn't seem like disabling the use server side oco and bracket orders does anything. Is there a way to keep the stop order on the client side so it can execute as a market order? I am also considering using the global profit/loss management to market flatten all positions in the event of the server side stop limit getting blown past.
If there is a simpler way to make sure the stop loss is executing as a market order please let me know. Also, if I am misunderstanding the risk associated with a protective stop limit that's being used in place of a stop loss order please let me know.
Thank you!
[2024-03-15 14:03:07]
Keep in mind the change of a Stop to a Stop-Limit is being done by the CME Group. They simply do not allow for simple Stops.
The only thing you can do is what you have already mentioned - use a Client side order, which will be sent as a Market Order when it is hit.
[2024-03-15 17:02:42]
This really is not a problem because the limit price is significantly faraway from the Stop price. The best mitigation would be to consistently use Stop-Limit orders and set the offset even larger than the CME would use.
Refer to these two offset settings at the following link and the one below it:
Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset >> Primary Orders
