Date/Time: Sun, 22 Dec 2024 11:05:38 +0000
The Message from the sc.SetAlert
View Count: 1264
[2014-08-10 16:46:46] |
Marek F - Posts: 244 |
Hi Sierra Chart Engineering, I have two issue: 1) Is possible to add only my specified text massage to be added to the Alerts Log by sc.SetAlert, without a standard message like below? Alert - Chart: GCZ4 [CV] 5 Min #1 | Study: Simple Moving Average | Formula: Moving average has crossed last price. | Last Price: 1318.7 | Bar Start Time: 2014-08-08 13:10:00 | Alert: Entry | 2014-08-10 18:22:16
2) Is there a feature which gets only the Title Bar Name which can be specify in the Chart Settings --> Advanced Settings 2 ? Best regards Marek Date Time Of Last Edit: 2015-02-07 17:26:22
[2014-08-12 03:01:06] |
1. We expect this will be configurable in a future release of Sierra Chart. 2. We will add this to ACSIL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-12 06:34:45] |
Thanks !
[2014-08-30 09:04:04] |
Sierra Chart, Have you already implemented these feature? Marek |
[2014-08-30 20:32:09] |
2. This has been done a while ago: sc.TitleBarName Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-02 18:42:14] |
Thanks. And, what about the issue 1? Marek |
[2014-09-02 18:48:53] |
1. We will not comment further on this.
[2015-02-07 17:25:30] |
Sierra Chart Engineering, Is there any chance of implement of the feature 1 from my post #1? The long standard text message in the Alerts Log led that my specific text from the sc.SetAlert is low-key. And my dominant text is key if I have only a few second for decision on entry after appeared the message. Best regards, Marek Date Time Of Last Edit: 2015-02-07 17:25:52
[2015-02-12 08:13:26] |
1. We will look into this.
