Date/Time: Mon, 25 Nov 2024 08:49:05 +0000
Delayed Data Feed Issues.
View Count: 174
[2024-03-15 00:44:43]
Elio Botticelli - Posts: 1
Orders on the intraday chart are not coming in, instead charts appear frozen.
This is the message log that appears:
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:34:48.324
DTC Client socket (1) | Closed. | 2024-03-14 20:34:48.324
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-14 20:34:50.027
DTC Client socket (1) | Creating socket. | 2024-03-14 20:34:50.028
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:34:50.028 *
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-14 20:34:50.029
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:34:50.476
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:34:50.476
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:34:50.476
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:34:50.787
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:34:50.787
Delayed Data Feed | Received logon response. | 2024-03-14 20:34:51.093
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:34:51.093
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:34:51.093
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:34:51.093
Delayed Data Feed | Failed connections: 1066 | 2024-03-14 20:34:51.093
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:34:51.093
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:34:51.093
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:34:51.093
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:34:51.093
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:34:51.093
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:34:51.396
DTC Client socket (1) | Closed. | 2024-03-14 20:34:51.396
Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-14 20:34:53.094
DTC Client socket (1) | Creating socket. | 2024-03-14 20:34:53.095
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:34:53.096 *
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-14 20:34:53.096
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:34:53.548
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:34:53.548
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:34:53.548
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:34:53.859
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:34:53.859
Delayed Data Feed | Received logon response. | 2024-03-14 20:34:54.166
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:34:54.166
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:34:54.166
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:34:54.166
Delayed Data Feed | Failed connections: 1067 | 2024-03-14 20:34:54.166
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:34:54.166
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:34:54.166
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:34:54.166
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:34:54.166
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:34:54.166
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:34:54.468
DTC Client socket (1) | Closed. | 2024-03-14 20:34:54.468
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-14 20:34:56.166
DTC Client socket (1) | Creating socket. | 2024-03-14 20:34:56.168
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:34:56.168 *
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-14 20:34:56.168
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:34:56.620
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:34:56.620
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:34:56.620
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:34:56.928
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:34:56.928
Delayed Data Feed | Received logon response. | 2024-03-14 20:34:57.240
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:34:57.240
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:34:57.240
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:34:57.240
Delayed Data Feed | Failed connections: 1068 | 2024-03-14 20:34:57.240
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:34:57.240
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:34:57.240
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:34:57.240
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:34:57.240
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:34:57.240
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:34:57.367
DTC Client socket (1) | Closed. | 2024-03-14 20:34:57.367
Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-14 20:34:59.242
DTC Client socket (1) | Creating socket. | 2024-03-14 20:34:59.243
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:34:59.244 *
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-14 20:34:59.244
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:34:59.652
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:34:59.652
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:34:59.652
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:00.012
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:00.012
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:00.309
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:00.309
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:00.309
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:00.309
Delayed Data Feed | Failed connections: 1069 | 2024-03-14 20:35:00.309
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:00.309
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:00.309
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:00.309
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:00.309
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:00.309
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:00.448
DTC Client socket (1) | Closed. | 2024-03-14 20:35:00.448
Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-14 20:35:02.313
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:02.314
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:02.314 *
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-14 20:35:02.314
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:02.464
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:02.465
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:02.465
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:02.763
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:02.763
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:03.074
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:03.074
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:03.074
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:03.074
Delayed Data Feed | Failed connections: 1070 | 2024-03-14 20:35:03.074
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:03.074
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:03.074
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:03.074
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:03.074
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:03.074
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:03.212
DTC Client socket (1) | Closed. | 2024-03-14 20:35:03.212
Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-14 20:35:05.078
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:05.079
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:05.079 *
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-14 20:35:05.079
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:05.223
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:05.223
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:05.223
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:05.536
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:05.536
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:05.685
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:05.685
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:05.685
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:05.685
Delayed Data Feed | Failed connections: 1071 | 2024-03-14 20:35:05.685
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:05.685
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:05.686
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:05.686
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:05.686
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:05.686
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:05.835
DTC Client socket (1) | Closed. | 2024-03-14 20:35:05.836
Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-14 20:35:07.688
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:07.689
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:07.689 *
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-14 20:35:07.689
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:07.990
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:07.990
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:07.990
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:08.297
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:08.297
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:08.601
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:08.601
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:08.601
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:08.601
Delayed Data Feed | Failed connections: 1072 | 2024-03-14 20:35:08.601
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:08.601
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:08.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:08.602
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:08.602
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:08.602
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:08.803
DTC Client socket (1) | Closed. | 2024-03-14 20:35:08.803
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-14 20:35:10.605
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:10.606
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:10.607 *
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-14 20:35:10.607
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:10.826
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:10.826
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:10.827
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:11.062
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:11.062
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:11.368
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:11.368
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:11.368
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:11.368
Delayed Data Feed | Failed connections: 1073 | 2024-03-14 20:35:11.368
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:11.368
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:11.368
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:11.368
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:11.368
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:11.368
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:11.672
DTC Client socket (1) | Closed. | 2024-03-14 20:35:11.672
Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:13.373
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:13.373
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:13.374 *
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-14 20:35:13.374
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:13.826
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:13.826
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:13.826
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:14.136
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:14.136
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:14.443
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:14.443
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:14.443
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:14.443
Delayed Data Feed | Failed connections: 1074 | 2024-03-14 20:35:14.443
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:14.443
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:14.443
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:14.443
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:14.443
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:14.443
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:14.744
DTC Client socket (1) | Closed. | 2024-03-14 20:35:14.744
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:16.444
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:16.445
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:16.446 *
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-14 20:35:16.446
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:16.740
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:16.740
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:16.740
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:16.910
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:16.910
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:17.205
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:17.205
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:17.205
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:17.205
Delayed Data Feed | Failed connections: 1075 | 2024-03-14 20:35:17.205
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:17.205
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:17.205
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:17.205
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:17.205
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:17.205
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:17.508
DTC Client socket (1) | Closed. | 2024-03-14 20:35:17.508
Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-14 20:35:19.206
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:19.207
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:19.208 *
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-14 20:35:19.208
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:19.665
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:19.665
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:19.665
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:19.927
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:19.927
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:20.139
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:20.139
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:20.139
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:20.139
Delayed Data Feed | Failed connections: 1076 | 2024-03-14 20:35:20.139
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:20.139
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:20.139
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:20.139
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:20.139
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:20.139
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:20.252
DTC Client socket (1) | Closed. | 2024-03-14 20:35:20.252
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-14 20:35:22.140
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:22.142
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:22.142 *
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-14 20:35:22.142
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:22.427
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:22.427
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:22.427
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:22.739
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:22.739
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:23.017
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:23.017
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:23.017
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:23.017
Delayed Data Feed | Failed connections: 1077 | 2024-03-14 20:35:23.017
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:23.017
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:23.018
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:23.018
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:23.018
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:23.018
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:23.148
DTC Client socket (1) | Closed. | 2024-03-14 20:35:23.149
Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-14 20:35:25.022
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:25.023
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:25.023 *
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-14 20:35:25.023
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:25.166
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:25.166
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:25.166
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:25.502
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:25.502
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:25.804
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:25.804
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:25.804
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:25.804
Delayed Data Feed | Failed connections: 1078 | 2024-03-14 20:35:25.804
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:25.804
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:25.804
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:25.804
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:25.804
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:25.804
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:26.110
DTC Client socket (1) | Closed. | 2024-03-14 20:35:26.110
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:27.807
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:27.808
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:27.808 *
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-14 20:35:27.808
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:28.265
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:28.265
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:28.265
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:28.574
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:28.574
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:28.881
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:28.881
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:28.881
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:28.881
Delayed Data Feed | Failed connections: 1079 | 2024-03-14 20:35:28.881
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:28.881
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:28.881
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:28.881
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:28.881
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:28.881
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:29.017
DTC Client socket (1) | Closed. | 2024-03-14 20:35:29.018
Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:30.884
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:30.886
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:30.886 *
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-14 20:35:30.886
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:31.335
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:31.335
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:31.335
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:31.588
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:31.588
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:31.950
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:31.950
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:31.950
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:31.950
Delayed Data Feed | Failed connections: 1080 | 2024-03-14 20:35:31.950
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:31.950
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:31.950
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:31.950
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:31.950
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:31.950
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:32.255
DTC Client socket (1) | Closed. | 2024-03-14 20:35:32.255
Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-14 20:35:33.951
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:33.952
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:33.952 *
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-14 20:35:33.952
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:34.406
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:34.406
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:34.407
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:34.718
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:34.718
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:35.023
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:35.023
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:35.023
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:35.023
Delayed Data Feed | Failed connections: 1081 | 2024-03-14 20:35:35.023
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:35.024
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:35.024
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:35.024
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:35.024
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:35.024
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:35.326
DTC Client socket (1) | Closed. | 2024-03-14 20:35:35.326
Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-14 20:35:37.025
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:37.026
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:37.026 *
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-14 20:35:37.027
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:37.484
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:37.484
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:37.484
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:37.790
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:37.790
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:38.042
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:38.042
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:38.042
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:38.042
Delayed Data Feed | Failed connections: 1082 | 2024-03-14 20:35:38.042
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:38.042
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:38.042
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:38.042
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:38.042
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:38.042
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:38.178
DTC Client socket (1) | Closed. | 2024-03-14 20:35:38.178
Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2024-03-14 20:35:40.043
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:40.044
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:40.045 *
DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2024-03-14 20:35:40.045
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:40.551
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:40.551
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:40.551
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:40.865
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:40.865
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:41.172
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:41.172
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:41.172
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:41.172
Delayed Data Feed | Failed connections: 1083 | 2024-03-14 20:35:41.172
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:41.172
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:41.172
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:41.172
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:41.172
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:41.172
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:41.472
DTC Client socket (1) | Closed. | 2024-03-14 20:35:41.473
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-14 20:35:43.173
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:43.174
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:43.175 *
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-14 20:35:43.175
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:43.622
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:43.622
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:43.622
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:43.931
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:43.931
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:44.240
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:44.240
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:44.240
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:44.240
Delayed Data Feed | Failed connections: 1084 | 2024-03-14 20:35:44.240
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:44.240
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:44.240
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:44.240
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:44.240
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:44.240
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:44.376
DTC Client socket (1) | Closed. | 2024-03-14 20:35:44.376
Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:46.242
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:46.243
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:46.243 *
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-03-14 20:35:46.243
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:46.697
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:46.697
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:46.697
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:47.009
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:47.009
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:47.307
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:47.307
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:47.307
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:47.308
Delayed Data Feed | Failed connections: 1085 | 2024-03-14 20:35:47.308
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:47.308
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:47.308
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:47.308
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:47.308
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:47.308
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:47.571
DTC Client socket (1) | Closed. | 2024-03-14 20:35:47.571
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-14 20:35:49.311
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:49.312
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:49.312 *
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-14 20:35:49.312
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:49.771
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:49.771
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:49.771
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:50.079
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:50.079
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:50.385
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:50.385
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:50.385
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:50.385
Delayed Data Feed | Failed connections: 1086 | 2024-03-14 20:35:50.385
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:50.385
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:50.386
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:50.386
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:50.386
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:50.386
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:50.529
DTC Client socket (1) | Closed. | 2024-03-14 20:35:50.529
Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-03-14 20:35:52.386
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:52.388
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:52.388 *
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-03-14 20:35:52.388
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:52.839
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:52.839
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:52.839
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:53.146
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:53.146
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:53.456
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:53.456
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:53.456
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:53.456
Delayed Data Feed | Failed connections: 1087 | 2024-03-14 20:35:53.456
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:53.456
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:53.456
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:53.456
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:53.456
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:53.456
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:53.759
DTC Client socket (1) | Closed. | 2024-03-14 20:35:53.759
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-03-14 20:35:55.457
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:55.458
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:55.458 *
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-03-14 20:35:55.458
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:55.850
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:55.850
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:55.850
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:56.059
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:56.059
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:56.219
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:56.219
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:56.219
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:35:56.219
Delayed Data Feed | Failed connections: 1088 | 2024-03-14 20:35:56.219
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:56.219
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:56.219
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:56.219
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:56.219
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:56.219
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:56.524
DTC Client socket (1) | Closed. | 2024-03-14 20:35:56.524
Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 | 2024-03-14 20:35:58.223
DTC Client socket (1) | Creating socket. | 2024-03-14 20:35:58.224
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:35:58.225 *
DTC Client socket (1) | Connecting to IP: 38.120.62.83. | 2024-03-14 20:35:58.225
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:35:58.367
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:35:58.367
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:35:58.367
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:35:58.681
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:35:58.681
Delayed Data Feed | Received logon response. | 2024-03-14 20:35:58.987
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:35:58.987
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:35:58.987
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:35:58.987
Delayed Data Feed | Failed connections: 1089 | 2024-03-14 20:35:58.987
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:35:58.987
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:35:58.988
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:35:58.988
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:35:58.988
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:35:58.988
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:35:59.152
DTC Client socket (1) | Closed. | 2024-03-14 20:35:59.152
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-03-14 20:36:00.989
DTC Client socket (1) | Creating socket. | 2024-03-14 20:36:00.990
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:36:00.990 *
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-03-14 20:36:00.990
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:36:01.440
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:36:01.440
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:36:01.441
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:36:01.751
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:36:01.751
Delayed Data Feed | Received logon response. | 2024-03-14 20:36:02.059
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:36:02.059
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:36:02.059
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:36:02.059
Delayed Data Feed | Failed connections: 1090 | 2024-03-14 20:36:02.059
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:36:02.059
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:36:02.059
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:36:02.060
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:36:02.060
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:36:02.060
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:36:02.362
DTC Client socket (1) | Closed. | 2024-03-14 20:36:02.362
Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-03-14 20:36:04.064
DTC Client socket (1) | Creating socket. | 2024-03-14 20:36:04.065
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:36:04.065 *
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-03-14 20:36:04.066
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:36:04.514
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:36:04.514
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:36:04.515
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:36:04.821
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:36:04.821
Delayed Data Feed | Received logon response. | 2024-03-14 20:36:05.137
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:36:05.137
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:36:05.137
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:36:05.137
Delayed Data Feed | Failed connections: 1091 | 2024-03-14 20:36:05.137
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:36:05.137
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:36:05.137
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:36:05.137
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:36:05.137
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:36:05.137
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:36:05.432
DTC Client socket (1) | Closed. | 2024-03-14 20:36:05.432
Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2024-03-14 20:36:07.138
DTC Client socket (1) | Creating socket. | 2024-03-14 20:36:07.139
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:36:07.139 *
DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2024-03-14 20:36:07.140
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:36:07.588
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:36:07.588
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:36:07.589
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:36:07.891
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:36:07.891
Delayed Data Feed | Received logon response. | 2024-03-14 20:36:08.203
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:36:08.203
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:36:08.203
Delayed Data Feed | Logon error received from server: Invalid login data. | 2024-03-14 20:36:08.203
Delayed Data Feed | Failed connections: 1092 | 2024-03-14 20:36:08.203
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:36:08.203
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:36:08.204
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:36:08.204
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:36:08.204
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:36:08.204
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:36:08.504
DTC Client socket (1) | Closed. | 2024-03-14 20:36:08.505
Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-03-14 20:36:10.206
DTC Client socket (1) | Creating socket. | 2024-03-14 20:36:10.207
DTC Client socket (1) | Error setting receive buffer size to 0. Windows error code 10022: Invalid argument. | 2024-03-14 20:36:10.208 *
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-03-14 20:36:10.208
Delayed Data Feed | Network connection to server complete. | 2024-03-14 20:36:10.657
Delayed Data Feed | Starting socket receive thread. | 2024-03-14 20:36:10.657
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-03-14 20:36:10.658
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2024-03-14 20:36:10.963
Delayed Data Feed | Sending logon request message. | 2024-03-14 20:36:10.963
Delayed Data Feed | Received logon response. | 2024-03-14 20:36:11.270
Delayed Data Feed | Server Name: RealTimeServer. | 2024-03-14 20:36:11.270
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-03-14 20:36:11.270
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-03-14 20:36:11.270
Delayed Data Feed | Failed connections: 1093 | 2024-03-14 20:36:11.270
Delayed Data Feed | Waiting for socket receive thread to end | 2024-03-14 20:36:11.270
DTC Client socket (1) | CloseSocket call. | 2024-03-14 20:36:11.270
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-03-14 20:36:11.270
Delayed Data Feed | Disconnected from the server. | 2024-03-14 20:36:11.270
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-03-14 20:36:11.270
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-03-14 20:36:11.577
DTC Client socket (1) | Closed. | 2024-03-14 20:36:11.577
Date Time Of Last Edit: 2024-03-15 04:37:54
[2024-03-15 04:37:04]
Sierra_Chart Engineering - Posts: 17172
To resolve this update to version 2615:
