Date/Time: Mon, 25 Nov 2024 08:52:48 +0000
Can help with this Rithmic error?
View Count: 249
[2024-03-14 20:03:02] |
sc05022024 - Posts: 1 |
Can you see this error? 2024-03-13 21:55:38.798 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (8) | Socket gracefully closed by remote side. 2024-03-13 21:55:38.798 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (8) | Closed. 2024-03-13 21:55:51.118 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (2) | CloseSocket call. 2024-03-13 21:55:51.118 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (2) | Shutdown started. Waiting for graceful close. 2024-03-13 21:55:51.119 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (7) | Creating socket. Using TLS 1.2. 2024-03-13 21:55:51.119 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (7) | New receive buffer size: 0 2024-03-13 21:55:51.119 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (7) | Connecting to IP: 38.79.0.89. 2024-03-13 21:56:47.625 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (4) | CloseSocket call. 2024-03-13 21:56:47.625 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (4) | Shutdown started. Waiting for graceful close. 2024-03-13 21:56:47.626 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (8) | Creating socket. Using TLS 1.2. 2024-03-13 21:56:47.626 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (8) | New receive buffer size: 0 2024-03-13 21:56:47.626 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (8) | Connecting to IP: 38.79.0.89. 2024-03-13 21:56:57.033 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (11) | CloseSocket call. 2024-03-13 21:56:57.033 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (11) | Shutdown started. Waiting for graceful close. 2024-03-13 21:56:57.035 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (12) | Creating socket. Using TLS 1.2. 2024-03-13 21:56:57.035 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (12) | New receive buffer size: 0 2024-03-13 21:56:57.035 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (12) | Connecting to IP: 38.79.0.89. 2024-03-13 21:57:23.634 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (10) | Close event error. Windows error code 10053: An established connection was aborted by the |
[2024-03-14 21:03:25] |
Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
