Date/Time: Mon, 25 Nov 2024 08:25:53 +0000
futuers realetime data
View Count: 152
[2024-03-14 12:11:52]
User468545 - Posts: 3
hai i want to get realtime data for es/spx500 and for NSE. which package should i need to subscribe. especialy for ES/spx500
[2024-03-14 16:53:01]
To start with, you need to be on one of the "Integrated" packages in order to be able to get real-time data. Refer to the following:
Description of Service Packages and Pricing: Integrated Packages
Then in order to be able to get the data for the ES from the CME Group, you need to have a live, funded, futures trading account. And you need to be able to connect your Sierra Chart to that account at least once a month for verification. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account that will qualify for the above, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have the above worked out, then you would follow the instructions at the following link to setup the data:
For the NSE, we have connectivity with Global Data Feeds India. Refer to the following:
Global Data Feeds (India) Data Service
If you are wanting to trade the CME Group directly from Sierra Chart, then you will need to install two copies of Sierra Chart, one for The CME Group and one for Global Data Feeds India. Refer to the following for how to do this:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
