Date/Time: Wed, 27 Nov 2024 06:32:14 +0000
Region Data Line
View Count: 1365
[2014-08-09 20:19:24] |
User21113 - Posts: 62 |
Is it possible to display the Chart Region Data on multiple lines? The Region Data Line data is only completely visible when the chart is expanded to the entire screen. With multiple charts on the screen the line is cut off. Alternatively the data could be displayed down the left side of the chart as SYM 10M DV=123456 A=50.00 B-50.01 etc... |
[2014-08-09 21:29:25] |
No, but you can use Window >> Chart Values Window: https://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#ChartValuesWindow This window is the intended solution to this kind of issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
