Date/Time: Sat, 19 Apr 2025 09:48:47 +0000
Telegram Alerts
View Count: 1684
[2024-03-13 23:13:00] |
Jeff Li - Posts: 58 |
Hello, Can you confirm that telegram alerts are working as intended? I followed all the details and I can see the alerts showing in my group chat on my PC. Followed the telegram bot /detach and attached the newest ID, still i don't see any notifications that I see on my PC.. |
[2024-03-13 23:53:11] |
TraderJoe11 - Posts: 9 |
Same.
[2024-03-14 00:13:52] |
mattvk - Posts: 34 |
+1 on this for me
[2024-03-14 01:38:38] |
Sierra_Chart Engineering - Posts: 19276 |
Yes they are now working as expected. You need prerelease version 2614. You will need to edit the Chat Group, if you have already created one, ( Commands >> Edit Group Chat from the chat window menu) and make sure Relay to Telegram is set to Yes. Full instructions: Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts | Post: 375015 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-14 03:03:38] |
Great, thank you. Working as expected now
[2024-03-14 10:08:05] |
Yes, working great now. Thanks!
[2024-03-14 10:10:12] |
Is there any way to mask the account number in the alerts?
[2024-03-14 16:04:46] |
John - SC Support - Posts: 39362 |
Refer to the following: General Settings Window: Use User Defined Name Only in Alert Message (Global Settings >> General Settings >> Alerts >> User Defined Name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-14 17:50:29] |
Thank you, originally would see the message as: [Joe2TT in JoesTelegramTrades (96)]: Order Fill: Sell fill for MES-202406-CME-USD. Account: XXXXXX. Fill Price: 5206.00. Filled Quantity: 1. Internal Order ID: 2757. Close. With the user defined name only setting, I only see: [Joe2TT in JoesTelegramTrades (96)]: Order Fill: TelegramTrades | 2024-03-14 13:46:35 Is there a way to show the symbol, fill price, quantity, but not the account number? (I've xx'd out my account number above). |
[2024-03-14 19:21:03] |
The only option is the User Defined Name within the built-in tools. You could create a custom study to do what you want and have the text be whatever you want. Refer to the following: ACSIL Interface Members - Functions: sc.SetAlert() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-15 13:25:30] |
Thank you, I will check in to this. As an alternative, is there a way to filter the account number in the Telegram Sierra Chart bot? |
[2024-03-15 14:28:30] |
There is nothing that we have provided that will do this.
[2025-03-18 02:46:27] |
eddiep - Posts: 8 |
I was having the same problem, I just updated to the newest version and it's "working". But, the new issue is I can't see "Telegram Notifications" under Commands anymore.
[2025-03-18 14:56:17] |
We no longer support Telegram for remote alerts. Refer to the following: Notice: New Mobile Alert Notification Service Available Now! For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-18 16:24:13] |
eddiep - Posts: 8 |
Thank you, I followed the instructions and now it's saying "user is not authorized to read this topic"
[2025-03-18 17:28:01] |
You must not have entered the Username correctly. Double-check the information.
[2025-03-18 19:10:26] |
eddiep - Posts: 8 |
Thank you, it worked now.
