Date/Time: Wed, 27 Nov 2024 06:43:10 +0000
How to display high low (range) during a special period
View Count: 987
[2014-08-09 11:38:34] |
User99689 - Posts: 27 |
I 'd like to display the high and low from 15h to 16h00 every day, by drawing a cube or rectangle during this period on my chart. there is the time range highlight study but it doesn't display high low and only time start and time stop. |
[2014-08-09 11:47:34] |
PTG - Posts: 57 |
Add High/Low for Time Period study to your chart. Set Start Time to 15:00 and End Time to 15:59.
[2014-08-09 11:59:59] |
thanks PTG this is exactly what i want
[2014-08-11 05:28:27] |
Use the High/Low for Time Period study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s313 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
